- Need to swap passenger front door. Where is the harness connector?
- read door problem
- Are there supposed to be slider bushings on rear pins for 2009 RX350?
- 235/55/R18 tires, psi for summer?
- Electrical problem car will not start
- 2007 Lexus RX350 oil change torque specifications?
- Keyfob not working
- Compressing front strut spring? Is there a trick?
- Can headlight moisture burn out an HID bulb?
- RX350 07' - knocking noise when a/c turned on
- Tonneau Rail Replacement
- 20x10.5 rims fitment question
- Small Radiator Leak
- TPMS non-OEM sensors
- Tar on Paint from Roadwork?
- Cracked dash on 2005 RX330
- 05 RX 330 brake petal goes down still
- Who says there's no Lexus love anymore?
- Front seat back flap issue
- Monitor goes blank when I flip on brights
- Warning code
- How do i update GPS on 2008 RX350
- Transmission delays and seems to Hunt
- Rx350 2008
- Ignition Boot Stuck on the Spark Plug
- controls for rx350 eng and trans
- rubber roof inserts
- Looking at buying a second gen RX for a family member. What are the common faults?
- Rear Gate Switch Cover
- 2004 RX330 not shifting in to 3rd or OD
- Engine Air Filter / Cabin Air Filter
- A/C Auto Mode Malfunction
- 2008 Lexus 400h Volume stuck at 0
- Electric wing mirror folds too far
- Excessive fuel consumption RX 330
- Changing front seats
- Constant A/C flow to windshield after evaporator replacement
- RX 330 AC squeal
- Radiator bleeder allen screw - 2005 RX330
- How to connect a 2nd Bluetooth iPhone5
- New type front bumper for me RX400h 2006
- Could you post your OEM HID beam pattern?
- Tail light and brake light bulb replacements!
- help with removing read door trim panel
- Got codes P0441 and P0455
- 04+ ES330 OEM nav in RX?
- Toyota Genuine Oil Filter 90915-YZZD1 vs 90915-YZZD3
- child safety lock wont turn off.
- Navigation system won't show my State
- 2006 Lexus 330 Brake light Indicator constantly on
- Rear brake issue
- Rear brake issue
- Rear suspension Bushings
- 5W-30 synthetic oil recommendation
- Radiator Coolant Filler Neck Leaks
- DRL with 2008 RX350
- Sam's Club Headlight Restoration Review
- Car dies after replacing rear ignition coil coil (video included)
- Lock/unlock using key buttons is a mystery to me.
- Locking & Closing Windows & Sunroof
- 2007 RX 350, what cleaning products for interior?
- Rx330 battery power drain question
- diy Coolant flush - question / suggestions needed
- A/C Pressure sensor for 2005 RX330?
- Techstream identifies car and VIN, but cannot customize settings
- 2007 RX350 Transmission Filter?
- Fuel requirements for 2007 RX 350
- Need to take apart cargo cover
- Ac cooling intermittanly
- 03 Rx 330- climate control buttons stuck
- timing belt replacement
- adding numbers to 2006 lexus phone book
- Just jumped from EX300 to RX400H
- Tall driver 6ft .2in
- heat shield rattle
- 04 Rx330 ac overcharged? How is your sight glass?
- RX 350 Cold Transmission hard shifting problem.
- Broadway Mirror
- Lower Driver Seat
- Alignment change after rotor/pad replacement
- P0340 and P0345 codes
- Changed the wrong wheel bearing now what?
- Advise for new RX350 owner
- Rear cam timing marks not the same as front cam timing marks
- What is the A/T light?
- Two antenna adapter
- abs module
- Where can I source a form fir hood deflector to fit lexus rx350?
- need help rx350 wngine swap between towing otion
- 2004 RX330 Slow/poor acceleration
- RX330 Steering Rack bushings availability!
- New RX350 owner with a couple of A/V queries
- charging ports not working
- RX330 passenger side window issue
- 2004 RX330 Mark Levinson Sound Settins
- 2007 RX350. New seats from 2008 RX400h. Are they compatible?
- Experiencing a *JOLT* when I shift into drive
- AC fan loud rattling noise
- RX 350 Rear DVD player
- Update nav system software (not maps)
- Telescopic Steering Wheel
- 05 RX330 Leaks
- P0136 P2195 Error Codes - Help Please!
- Mobil-1 5W-30 Oil & Mobil 1 M1-102 Oil Filter
- Rear diff axle oil leak
- Navigation Map Update
- Running new speaker wire from factory amp
- motor power upgrade
- Replacing factory installed navigation
- 2004 RX330 acceleration 15-25 mph problem
- Wiring Diagram for Rear View Mirror
- Volume control knob
- skid indication
- rx400h finnish manual
- Custom interior
- Rx330 Gorilla lugnut lock removal
- Accidentally shifting into P then R
- rack pinion
- RX400h rear brake problem
- Lexus RX330 rear lift gate motor removal
- Park Lights on side of Headlamp
- Lexus 2008 CEL & VSC oof & track light on all at the same time.
- Missing headlight vent caps
- coolant bypass hose - how to get to it?
- I changed ignition assembly
- Hanging from Rear Passenger Side
- Cllicking/rubbing noise front left wheel 400h
- Frustrated with Power Steering issue
- Backlights for radio, nav. and climate control
- Another Mode Servo
- tire pressure bulb steady light on 2008 RX350
- Coolant Plate repair?
- Code PO793 intermediate shaft speed sensor
- Play music through bluetooth on 2006 Rx 330?
- Vacuum Smoke Test RX330 2004
- RX330 - engine light / code: p0420
- 2009 RX350 intermittent starting problems
- 2009 BMW X5 vs 2009 Lexus rx 350
- How to replace tail light housings (2007 RX350)
- Anyone have a silent RX350 engine?
- Horrible beeping in Reverse 2006 RX 400h
- Lexus GX470 2005 Ck engine,VSC Trac,VSC Off,Anti traction lights
- 2007 Non ML audio information
- Still getting P0352/VSC Off After Replacing Ignition Coil
- Made in Japan or North America?
- Recommend Replacement Stereo Head 2006 RX400H
- 06 330, changed both DRLs with Sylvania 9005...now Does don't light up in auto mode
- 2005 Lexus rx 330 steering sticking when i turn
- Alternator or battery?
- AC Bad Odors Easy Fix
- Unlocking of Hatch of RX 330
- 2009 Lexus RX350 power rear door won't open with button
- Ignition coil replacement part number
- 2004 Lexus RX330 Shuts Off
- AC Odor Fix
- 2009 RX350 Stereo Not Working
- headlight lens-RX-350
- RX300 O2 Bank 1 sensor 2
- Water pump failure
- car keys 2004 rx 330
- Lexus dashboard replacement update?
- Remote key locking function
- Resetting cruise control
- 2008 Rx 350 Hatch lift support problem.
- Lexus RX 330 struts
- won't start
- Battery eating 2006 RX330 – finally solved!
- control arm replacement on RX300 or just alignment to correct outside tire wear?
- 3 Passenger Door Locks will not Unlock (FIX)
- Looking for an OEM XM Satelitte Fit Kit for OEM TOYOTA XM RADIO RECEIVER BASE.
- CEL + VSC Light Multiple Codes
- Timing belt replacement interval
- High mileage maintenance/repairs?
- RX400h rear door in auto lock mode
- Gruba
- 2008 Lexus RX400h engine crankcase condition
- F sport wheel tire size question
- 19" wheels on Rx350 2007?
- Rx330 2006 fender inner liner,washer reserve both same as rx400h 2006?
- Beware - Valvoline Maxlife ATF ???
- RX400H New Shock Needed
- Lost Engine Air Filter Bolt
- power window reset
- 2006 RX330 Liftgate Lock Actuator Repair
- Looking for replacement side mirror for 2009 RX350 - questions
- Small Rust Spots
- is my battery ok?
- Lots of questions - RX 300 or 350 - new forum member!
- Hoping to join the club officially this weekend
- Maintenance and mileage on RX
- Front oxygen sensor
- Engine Wire Harness/Neutral Position Switch
- Beware of Lexus battery warranty fine prints
- Dash replacement
- 2006 RX330 Condenser Replacement DIY
- Is nav update worth it?
- 2009 RX350 w/door lock problems
- Not possible to paint match liquid graphite rims?
- Any ECU updates/calibrations for 2008 RX350 AWD JAP?
- steering wheel vibration
- Coolant contamination in #2 cylinder
- 2007 rx350 [Baby seat sun shades]
- Check my fluids - ALL
- Broken Sunroof-RX330
- cruising range way off
- How to DIY program a spare key
- lexus 350rx 2007 beeps after taking key out, steering wheel moves up & down -keyfob
- 2004 RX 330 Help With Codes & Lights
- Problems after replacing Oxygen sensor
- Timing cover
- Forgets last phone user
- Power hatch won't close - usually.
- '04 RX330 AC compressor clutch will not engage.
- How to remove the bumper retainer clips?
- Twin Exhaust - found this post finally
- Removing Oxidation From Chrome Wheels
- Part differences between Candian and Japanese assembly?
- 2004 RX330 automatic headlight leveling system warning light
- Luggage/ Cargo Lights: No power?
- rear fold down seats
- 2015 RX 350 rear wiper blade
- batter cable contamination/premium gas
- Rust under door handles on exterior
- Knocking from under driver's seat
- 2007 RX350 Transmission Question
- Rx330 p0420 p0430 CEL VSC light
- Head light washers quit working
- oil cooler line tow package
- best Front brake pads, 2007
- Gx 470 paint
- 2007 RX350 Adding Bluetooth Audio Streaming
- 2007 RX350 Loose Hood Release Cable
- Trans fluid leak
- 2005 RX 330 w/126k miles. Do Sealers work?
- Loud Engine Fan Noise / A/C Problem
- Air filter box. Filter in the lid?
- 2004 rx330 transmission question
- 2007 Lexus RX350 TPMS Main/2nd selection
- Gas milage - better with lower grade
- Problems
- Replacing xenon light bulbs on a 2008 RX400h
- Lexux RX 330: High temperature gauge reading but engine is not over-heating
- Satnav dvd
- Does front diff fluid share with the transmission transfer case?
- 2008 RX350 aftermarket remote starter location - alternate?
- 2004 rx330 passenger side mirror stuck on dim
- Cold Start-up rattling sound help
