Rear brake issue
Old Jun 28, 2017 | 02:12 PM
shikbas's Avatar
shikbas
Default Rear brake issue
hi all
RX 330
I took off a rear rotor to check a freezing shoes afte cLeaning and lubrication I can not put back the rotor as it hits on the shoes
I tried to adjust the mechanism no good
any help will be appreciated as the car sits on the stand
Old Jun 28, 2017 | 03:03 PM
05RX330AWD's Avatar
05RX330AWD
I assume you mean you cannot put back the Drum since the Shoes are new.
Normally you should get a Brake Spring Kit, that should also be changed, including the adjuster.
Another thing is the Drum can be machined to be cleaned & smooth all around, if slightly warped.
yonswizzle
Aug 9, 2019 12:29 PM
shikbas
Jul 3, 2017 08:37 AM
ajgregory
Jul 25, 2011 10:08 AM
Tchan1
Suspension and Brakes
Jul 28, 2010 02:08 PM
