PDA
View Full Version : RX - 2nd Gen (2004-2009)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. RX 330 2005 fuse box
  2. Does the RX400h come with an engine undertray ?
  3. Intake removal
  4. 2007 RX350 cold startup rattle
  5. I need stereo radio CD player diagram
  6. What interior mods can be done with our RX's?
  7. Burned mp3 on a CD-R not playing playing "random"
  8. How to select right replacement key model?
  9. Any option beyond taking the door apart?
  10. 2009 RX350 Amp
  11. 2004 RX330 Antenna Snapped Off
  12. Rear power door
  13. Intro
  14. Stereo speakers
  15. considering purchasing a 05 Lexus Rx
  16. Check Engine/TRAC light on, VSC light blinks and P0128 code
  17. Engine air filter
  18. 120k Miles
  19. Best way to remove engine, please
  20. DRL issue not addressed in other threads
  21. 2006 rx330 with on and off belt noises, what to do ?
  22. Sliding the center console in 2009 RX350
  23. Check, VSC and Trac Off lights
  24. Radiator coolant pressure test
  25. Aftermarket key will not program
  26. Power seat not working
  27. Key Igntion/Locked Steering Wheel Issues
  28. 2007 RX350 alternator bad?
  29. 125k service
  30. Mark Levinson Audio
  31. Why the acronyms?
  32. 2005 RX 330 aftermarket wheel question.. Urgent
  33. Some issues with new to me 2004 RX330
  34. Paint Job Quote for my 04RX330
  35. Does your RX 330 engine turn over like this too?
  36. Sun Roof doesn't lock tight
  37. New Owner for 2004 RX330 - needing tire recommendations
  38. 2007 lexus rx 140k miles passenger wiper dead
  39. Audio upgrade... how much did yours cost?
  40. Need to cut dash speakers ASAP
  41. Crankshaft pulley recall/power steering pump
  42. Strange electrical problem rx330 2004
  43. Synthetic Oil?
  44. Any way to get a CD out w/o power?
  45. Insurance valuation -- options?
  46. Lexus RX Front Rotors (Japan vs USA built cars)
  47. Check Engine Light - OBD Code P2189 - Help!
  48. Pins Connecting Engine to Transmission
  49. Bad gas cap?
  50. Going to battle with Insurance
  51. 06 rx400h blinking nav and dash lights
  52. Mouse prevention
  53. Convert RX330 power steering to electric
  54. Is there an anti theft code for RX330 radio?
  55. New RX owner in the PNW
  56. Timing Belt Kit
  57. What is the part # on this rear latch seal + rear latch trim?
  58. Aftermarket Headlamp Unit Replacement 2005 RX-330
  59. Running speaker wires through door grommet?
  60. Drive side rear seat stuck in the down position
  61. Random Vibrating and broken shield
  62. AUX Options
  63. Push Button Start
  64. I'm on my fifth brake light switch in 12 years
  65. Does your dealer wash your vehicle after service?
  66. 2004 RX330; Fog Lights Only
  67. No Heat/Selective vents
  68. Is this bank1 sensor1
  69. RX400H - Faulty Park Assist ECU
  70. Rear end clunk need some help
  71. RX330 Lost ALL Windows control after replacing front doors speakers
  72. 2009 RX350 to 2015 RX350
  73. RX 400h life expectancy
  74. Is there a difference in quality between Japan and Canada RX production?
  75. Airbag Manufacturer?
  76. What water pump & other parts on 2009 RX 350
  77. 05' RX330 coolant leak long upper coolant plate?
  78. RX330 2004 Interesting problem with the windows
  79. Tiltgate issue
  80. Heads Up
  81. 2004 RX 330 Strut Replacement
  82. Alarm, noise, Navi problem
  83. AFS Level Sensor on Lexus RX400h
  84. Air conditioner HVAC help condenser grill
  85. Dilema: Lexus RX350, 2008, 195k km, Navi - 12,500 CAD$ - is it a deal?
  86. Buy or no buy? 2007 RX 400h
  87. Can toyota harrier 2005 4 speed transmission use WS toyota ATF
  88. What is leaking?
  89. Engine Vibration/ Noise @ low RPM
  90. RX330 valve stem seals replacement DIY
  91. New 2004 RX330 Owner with a few questions
  92. RX Reliability
  93. Rear driver-side door lock stuck
  94. Mirror Power Connection for radar detector
  95. CEL and VSC lit up
  96. after-market stereo over ML system
  97. How to turn on the DVD in my glove compartment?
  98. Extended Warranty Recomendation Needed
  99. Update: My RX350 Mods
  100. Good shop in Buffalo, NY for a 2008 RX350
  101. Front and Rear Caliper Bolt Torque Specs
  102. Heating system & engine
  103. 2007 Rx350 Steering Issues
  104. I can't find SAT XM id #?
  105. RX won't go into gear upon starting
  106. Tail gate lift problems
  107. Drove Over a Falling Object
  108. Weather tech bug spoiler
  109. Auto Tilt Away Feature Not working
  110. RX 350 (2nd Gen 2009) New Owner Questions
  111. 04 RX 330 : Car thinks Key is still in the ignition! Plz help
  112. RX330 Starting Problems
  113. saw something weird the other day
  114. 05 RX330 Center Console Compartment Replacement Part
  115. Rx400h High beam headlight change
  116. Quarter Lip / Mudguards
  117. Navigation/AC dead, please help!
  118. No defrost heat?
  119. New RX350 owner
  120. OEM cargo mat and net
  121. Rear Power Door Struts
  122. Calling all 2nd Gen RX owners with Panoramic sunroof option
  123. Steering noise
  124. Not that anyone cares, but snagged a RX400H about a year ago....
  125. 2007 RX Going Up a Slippery Hill
  126. DRL stopped working
  127. Aftermarket Rims vs OEM specs--HELP!!
  128. Totaled...Anyone care to guess?
  129. Rx nearly in the ditch
  130. Welcome Thread?
  131. remove rear upholstery. Tips?
  132. 2009 RX350, 30,000 miles,...known issues?
  133. Nerf Bars
  134. Can I use sedan wheels on the RX
  135. Back pain
  136. Two aftermarket rim setups 04 RX330
  137. 2004 RX330 - Code P0420
  138. Passing smog with aftermarket exhaust
  139. P1457 Free Easy Fix - Oil Control Valve
  140. Tire Pressure Monitor System Problem Need Input
  141. Ignition cylinder removal - Key wont turn
  142. $10-12,000 rx330 question
  143. Old problem, first time owner
  144. RX400h rear fog light does not work
  145. Does anyone know if you can replace 04-06 cd player with 07-09?
  146. Rear seat stuck forward in RX400h
  147. Hot and cold heater
  148. Annoying rattle from the tailgate? try this
  149. OEM navigation install, not aftermarket
  150. 2004 RX 330 AWD Driveshaft problem
  151. RX400h reversing bulb
  152. RX350 stereo problem
  153. Underbody shield screw sheared
  154. DIY integrated alarm
  155. 2004 RX330 - steel winter rims fit?
  156. yellow light indicator is on after replacing combustion engine
  157. ABS, VSC, Brakes, AFS lights on... but not engine light
  158. Daytime running lights
  159. Need Advice re: Right Manifold Heat Shield (Above the Catalytic Converter) Please
  160. 04 RX 330 A/C & Heat Problem with car running hot
  161. flapping noise from the back on high speeds
  162. the elusive Mark Levinson AMP
  163. A Different Navigation Screen Problem
  164. Hidden trick? How to turn off DRL
  165. RX330 Check Engine / VSC / Trac Off Lights
  166. Activate menus in Rx400h
  167. Lexus RX2007, paint peeling off.
  168. Best Bike Rack - 2007 RX350
  169. Sudden drop in gas milage RX350. Ideas?
  170. Oil cooler line clarification
  171. RX 350 HID bulb replacement
  172. Tire chains for Tahoe
  173. Cheap Workshop manual for RX330?
  174. Strut coil spring bad?
  175. Gaskets?
  176. help! 2004 rx330 check air conditioner connection
  177. ECT SNOW Switch
  178. PLS Help!! Power Door Locks problem
  179. Wheel/rim issue
  180. Security system
  181. Lower control arms (A arm)
  182. Akebono Brake Pad part Numbers
  183. Temporarially remove Headrest on RX 330
  184. Aftermarket radio on ML/Nav and Rear Seat Entertainment?
  185. Slide/Adjust Center Console
  186. Coilover options for 06 RX400h AWD
  187. TPMS seems 'out', light 'on'
  188. removing rx330 dash speakers
  189. My first Lexus...maybe - advice requested
  190. Another RX300 with P0420 and P0430
  191. iPod AUX?
  192. Anyone know what this green tube is?
  193. removed transmission vent by mistake
  194. P0355 - How To Replace Ignition Coil. '08 Rx350
  195. 2004 RX 330 Multiple, changing instrument panel warning lights
  196. Xenon headlight does not light up everytime
  197. RX330 3mz-fe timing belt coming off
  198. Video player
  199. 2004 rx300 height control compressor location
  200. Car goes off when lock steering to one side
  201. Did Lexus release the 2015 Nav Update?
  202. Need Help with fog light condensation
  203. Potential purchase advice
  204. Rack and pinion/ power steering pump leak
  205. RX350 Camshaft Position Actuator
  206. Tight front suspension still clunky!
  207. Help adjusting headlamps on rx 330 non hid 2004
  208. Timing belt replacement, one tooth off !
  209. Whining on acceleration?
  210. 04' RX330 alarm goes off itself for no reason
  211. front bumper question
  212. check/trac off/vsc lights on
  213. Interior lighting
  214. What am I missing on this TB kit
  215. Chirping noise from passenger side
  216. 07 rx350 coolant change
  217. For sale OEM hitch for 2nd gen rx330
  218. tire size
  219. Car dosnt recognize key
  220. Front air shocker
  221. New RX Owner!
  222. Eagle eye headlight replacement RX330 w pics
  223. What is this? Sway bar adjustment?
  224. 2007 RX350 upper cargo net hooks
  225. strut rod? what is this part called??
  226. 1MZ-FE compatibility question
  227. Lexus RX 350 tire light
  228. RX330 (2005) Larger Tires
  229. Navigation Unable to read data
  230. Rear View Camera Intermittent!
  231. front bumper cover removal...'06 RX330
  232. Looking for HID headlight assembly replacement
  233. 2004 RX330: Help! Someone stole my...
  234. Would you buy...
  235. New RX350-what to have inspected?
  236. Minor rear end collision - TPMS stopped working
  237. 07 RX 350 Center console lid not closing
  238. Cruise control switch broken
  239. Replacing side Mirrors
  240. Ignition wire help
  241. Rear carrier bushings replacement
  242. Windsheild wiper arm acorn nut cover?
  243. Picked up an 07 RX
  244. RX330 Tailgate issues 2004
  245. Navigation Issues
  246. 2005 RX330 Trans Filter
  247. 2005 RX330 Rear Replacement Struts Don't Fit
  248. Tire size advice
  249. 11 yrs later w 49 K on the Timing belt
  250. Front differential fluid
