- 2008 RX350 vs 2007 GS350
- New RX interior??
- wider tires for rx330?
- Next gerernation RX:Lexus LF-Xh
- RX350 or BMW X3?
- Differences between RX's
- Where to get Replacement Mirror
- replacement date
- Transmission Thump upon deceleration fix needed
- need help
- Toll Transponder and Rain Drop Sensor
- 2004 RX330 Performance Package--wood trim?
- 2008 RX 350 Navigation 7.1 and Lockpick 3 Ultimate
- experienced buyers wade in
- Mounting License Plate
- Flat Tire...Jack Collapse...TPMS
- 2009 Lexus RX
- IS air suspension incompatible with mark levinson?
- ID3 on Navigation screen?
- Lexus AWD compared with BMW's xDrive
- Are rear seats removable?
- Headlights
- 2004 RX 330 30K mile service maintenance ??
- My Lexus RX350 AWD at SoCal Fire
- Chrome wheels seen on 2008 RX 350
- Transmission problem?
- Air compressor
- Canadian (Ontario) October Sales Program
- Bluetooth - sound over speakers or phone - how to switch?
- Odd sound when accelerating or higher RPMs
- Updating navigation for 2004 RX 330??
- Hidden Navigation Dvd Player
- RX330 A/C temperature Unstable
- Lexus finally replaced Brake Rotors, Pads & Shims -Free
- RX330 Headlight Replaced due to moisture
- Toyota skids in reliability rankings
- door locks
- Automatic Dimming of Instrument Lights
- Are you unhappy with the Lexus NAV?
- How to remove back door panel?
- 2004 RX Purchase questions
- Thought Id Share this Predicament
- 2004 RX330 Purchase Question
- 04 head light question
- issues
- xm sat radio
- Thunk/Clunk in rear - not suspension related?
- Navigation - Using Buttons below Screen to select different displays more quickly
- VAIS Ipod interface to JDM Harrier installation success! (Crappy pics, sorry)
- Preferred Tire Pressure
- What type of Coolant to use?
- 15,000 service
- Possible Spotted - 2009 RX Test Mule ? - with pics
- Is this possibly the all-new-RX photos?
- Check engine and VSC light came on
- Is dealer maintenance required?
- Tire Inflation
- Stock Stereo help
- Upgrade 04 Nav system
- Driver seat
- 04 rear camera
- Who's Responsible for Service Bulletins?
- Blue tooth issue with hearing through speakers
- When to replace brake pads and rotors?
- SL2X bypass not available on 08 nav
- Question about Lexus Navigation/DVD
- Alternative to Lockpick 3?
- All Brandy Wine Mica RXs are built in Japan by the way
- Voice Input: Need Cheat Sheet!
- Windshield Fragile?
- 3M Filtrete filters $14.95
- Do all RXs come with towing package?
- Is there Hype in "handling"? Letdown for U
- Rx 350 Driver Window Noise
- How to tell if your RX has a factory towing package?
- Need photos of RXs with towing hitches
- Break pads
- Air Filter Replacement for 07 Rx350
- Locked out of my 330
- Questions about oil and oil filters
- 08 rx350 rattles (how bad a hit?)
- Trailer-towing service requirements
- 08 sunroof rattle
- What is this that locates close by the door?
- Iron Toad IS NOT the cheapest
- A/C problems '05 330
- RX radio kit
- Wiper replacement deal
- coupon code for Sewall Lexus..aka lexusparts.com
- Trunk help!
- Navigation accuracy and upgraded tire size
- Lexus RX 350 Servicing question.
- 2008 RX 350 from Oklahoma
- Gen3 Nav 7.1 for '04 RX330 Now Available
- Need owners manual!
- picking up the new lex.
- Where can I find the paint code?
- Extending the factory warranty?
- Fuel cleaner additive
- OEM parts online
- Which Fuel for my 08' RX350
- How much are people paying...
- accidently put my car in reverse while driving!!
- New RX 2008 FWD with NAV
- Running Boards for RH400H
- Black sandy build-up under oil cap
- windshield cracked 18" inches.. need help please..
- RX330/350 KenStyle Body Kit raffled off at EOS by Sewell Lexus
- weird sound coming from rear
- Position of Roof Rack Cross bars for least wind resistance?
- Extreme Diemsions Body Kit
- enough tranny issues...
- RX330 AWD Part Identification. See Pic!
- 2004 vs 2005 NAVI difference
- iPod integration - DICE
- 6.1 Nav Maps...How old are they?
- deciding on an SUV
- Timing Belt
- how to clean navigation screen
- How to install 7-way Trailer Wiring?
- Scratch on Black Panel Between Windows
- 2008 RX350 Transmission Slipping
- Kenstyle RX330
- An observation
- parrot 3200ls bluetooth kit in 04 RX
- Equivalent Toyota Part: Oil, Air, Cabin Filter.
- What Does Your Mileage Read?
- How to tell if RX is AWD or FWD???
- Difference between towing prep and towing package?
- What is normal Braking technique?
- RX330 Owners with Bridgestone Dueler H/L Alenza
- 2004 RX330 Factory DVD Rattles
- 08 RX350 used price?
- Has anyone carried a Kayak on RX?
- Where to get Factory Floor Mats at a good price?
- why buy an RX instead of the new Highlander?
- bought a lease return
- RX350 Turn Signal Mirrors
- Bluetooth on 05-08 models
- RX330 High Pitch Noise
- Air Condition Compressor Shut Off When Going Through A Puddle
- Trailer Wiring Harness
- LED at footwell area
- Does Nav 6.1 update add new features?
- Need help ASAP, what to look for in 2005?
- smoked tails
- The cost of certification process to a dealer?
- Accident today; wasnt even moving (pictures)
- Front Brake Vibration
- Toyota releases iPod Integration Kit
- After Market Rear Ceiling Lights?
- After Market Bluetooth Kit Installed
- Rock chipped windshield...How?
- Gas mileage for 2008 RX 350
- Back Hatch "Door Open" Chime
- Removing Front Centre Console (RX 400h)
- What Oil Viscosity Do You Use?
- possibility of 07 navi in an 04???
- Hint on design of next RX?
- Inside Edge Abnormal Tire Wear
- DIY: 30K Service
- Automatic Door Lock option
- Replacing rear emblem
- Navigation dvd
- 20's on RX 350.... What fits, pix? (merged threads)
- Tips from the Manual (04 Rx330)
- Lexus RX non-nav to nav
- A/C Question on 2004 RX330
- After Market Remote Start?
- Front License Plate Bracket
- multipanel moon roof confusion
- RX350 in Northern VA
- How to replace Cabin Air Filter
- Guess the plug
- After Zaino treatment - Thank you CL
- No TRAC OFF button at footwell
- 400h Taillights
- Maintenance Required Light
- Dude, where's my seat heat and car height knobs?
- Gold Lettering Package...aftermarket
- Love My RXus...but...some questionable design choices for an otherwise perfect car
- Difference between Lexus and Toyota Oil and Filter Change
- Strange noise coming from the area around the radio
- Navigation Voice Commands
- Need ignition switched wire for Radar Det.
- Bluetooth hookup/connecting
- Roof Rack for a 2004 RX - 330
- Turn Signal Flasher location
- Ray Catena Dealership(s)
- Are keys under warrenty?
- need some advice on new car
- I love it...(Long story)
- 08' Rx 350
- Say a command after the beep.
- Just bought a 2008 RX 350, but...
- 07 350, Deafening sound from the Rear
- Sirius or XM in 2004 RX330
- New RX Pickup
- RX350 rear door close button
- Needed a Jump Start from lexus roadside...no idea why
- Any success with Rt hand vent cupholder install?
- RX330 Oil Plug Plastic Shield
- Do you still love your RX
- TC Grille GB sale still On!
- Web article about octane, and another about nitrogen
- My MPG is LOW
- Input needed on 04/05 RX 330
- Brake Pads & Rotors???
- Passenger outside mirror
- 2005 RX330 brake pedal
- HID foglights
- 2005 RX330 Air Conditioning TSIB
- When the yellow light comes on, i have two more gallons right?
- Gas Octane
- Bluetooth connect--sometimes
- RX with air suspension in LOW mode (pics as requested)
- Vanity Mirror Bulb
- 04/08 compatibility?
- 07 RX350 retains their value THAT well?
- Headlight's stolen off 2007 RX350
- Updating the Nav?
- 2004 Rear Back up camera
- AWD Systems Differ 04-08
- Current Values on 04/05 RX330
- iPod Lexus Neo Prolink
- Key Programming for 2004 Toyota Harrier
- Seat cover problem w/ front seat mounted airbags.
- Rust Proofing
- ATF: lexus vs Toyota
- What are the 2 switches for?
- Phone Voice tags in Navi
- New car Undercoating
- Question about Switching to Synthetic Oil
- New Shoes
- Automatic Volume on Radio?
- 20's are on...O-Z & Yokohama
- How do you program a speed dial with speed tone?
- Dash scuff on RX330
- Funny video about Lexus auto park -- enjoy
- Using the Luggage Rack
- Atf Change
- Dealer is Replacing My Stereo
- 2009 RX Picture
- RX Door visors
- Sirius radio
- Backup camera trouble
- Unexpected Glass Shattering?
- First oil change before 5000 miles?
- LED tail lamp bulb
- Is there a mute button on the steering wheel?
