Alignment change after rotor/pad replacement
Old Jun 17, 2017 | 06:44 AM
Isentropic's Avatar
Isentropic
Default Alignment change after rotor/pad replacement
Hello All,
I recently changed the front rotors/pads on our '08 RX350. After 3 weeks of being driven by another family member, I finally got in the car last night, and noticed that the steering wheel alignment was off by ~15 degrees.
Could this have been caused by my brake job? Or someone went over a large pothole? I never lost alignment on this car in the past, despite road conditions.
Thanks much for your input.
Old Jun 17, 2017 | 07:00 AM
NVAKeith's Avatar
NVAKeith
Brake job won't affect steering wheel alignment unless one of the brakes is dragging so much you have to counter steer to overcome the pull.
I would inspect both front wheels and tires to look for signs of impact. To give your family member benefit of the doubt, maybe someone backed into a front wheel while it was parked and bent a tie rod. If it was winter I'd more likely think someone driving overcooked a slippery corner and bumped the curb with a front tire.
No no matter the cause, get it checked out to make sure nothing's come loose in the front end.
Old Jun 17, 2017 | 10:12 PM
Isentropic's Avatar
Isentropic
Thank you for the suggestion. I will book an appointment at Sears Auto Center to get the alignment checked and fixed, as suggested.
Thanks much again.
Old Jun 18, 2017 | 12:03 PM
RXGS's Avatar
RXGS
Only thing I can think of the caliper is dragging, I assume if you could change the brakes, you could check out the caliper. If not bring it in for an alignment
Old Jun 18, 2017 | 03:34 PM
frank12933's Avatar
frank12933
definitely the brake job can not affect the aligmrnt. Look for something else.
Danny200t
NX - 1st Gen (2015-2021)
Nov 9, 2018 05:33 PM
maximakid
Mar 11, 2013 04:48 PM
PlacidBoi
May 3, 2012 10:31 PM
RacerLex
Dec 13, 2006 04:33 PM
joshoowa
Apr 20, 2006 07:03 AM
