Can headlight moisture burn out an HID bulb?
Hi guys,
I recently bought an '08 RX350 from my boss and have been fixing things here and there.
I used it friday and both headlights were working, however we have had very heavy rains lately and my driver's side headlight has a lot of moisture inside (i'm aware that i need to seal them) and sunday night I noticed the HID low beam is not working. I have not done any troubleshooting yet like swapping bulbs from side to side, etc. but I was wondering if someone knew if the moisture can kill the HID bulb.
Those bulbs are about 9 years old, and they most likely need replacement anyway, but i'm hoping it is not the ballast so i don't have to take down the bumper, etc.
any insights??
any insights??
Hi guys,
any insights??
any insights??
You can try swapping sides for the HID bulbs to see if the problem follows the bulb or not. Also try letting the ballast and bulb connectors dry out a bit and firing up again. An alternative option to replacing a headlight assembly due to moisture is resealing it, you could buy new sealant such as Morimoto Retrorubber.
