- 04 RX 330 make bubling sound at front dash? also heater does not works...
- AFS Light Tired of watching it blink
- is this true?
- Tires
- RX400H Hybrid Emblem
- Just pulled the trigger on an 08 400h!
- Any experience with the Parada Spec-X Tires?
- navi problem!
- Installing basslink
- 2005 RX330 cargo Tarp & Net & Shifter Knob?
- Side Mirrors when in Reverse
- decision help!
- Moonroof wind diverter rattle
- Service Bulletin
- rx330 performance package
- Cargo nets
- aftermarket audio in 400h?
- My debut, at Hot Import Nights: Austin 4.11
- Reliability?
- Update: Alenzas @ 15,000
- Chrome Wheels For RX330??
- Cigarette Lighter Rx330 Stopped Working
- Engine "knocking" on 2009 RX When Cold
- Silver '06 RX330 --clear coat OR NOT?
- Motive brake power bleeder
- Anyone knows this
- 12v Battery dead on the hybrid...
- Correct Tire Pressure for RX400h
- Actual Gas Mileage vs Computer Read Out
- Accessory code help
- RX330 tail light bulb replacement
- Is there anybody check and adjust valve clearance?
- Consider an 04 RX330 with 93k Miles....how reliable?
- Rx 330 or 350?
- Hybrid Badge
- engine temperature gauge
- Looking for a complete ATF change DIY photo instruction
- RX330 prt# Toyota equivalent Air filter?
- 07-08 LEXUS RX LED DOME LIGHTS - Vehicle Specific!
- DIY Power Steering Flush
- Side Signal Marker for the RX
- PCV Valve Replace help
- wheels for RX 330
- My 2004 RX330 Hood Strut is not supportive any more
- Extended Warranty Cost
- Didnt even put my new plates on and someone broke in and
- Rx 330 06 repair manual
- been searching high and low for these...
- driver side mirror hit and run
- Do you know someone who can read Japanese
- Internal Light Bulbs 06 RX330
- Color Code?
- mp3 dvd in '04
- Power Windows stuck!
- lost a tool in the engine compartment
- RX 330 trailer hitch info needed
- Side Mirror Cann't Be Adjusted. Help!
- Comments on the new RX design?
- How to identify AWD RX400h
- DTE distance to empty
- Just found a hidden service menu in my 09 Pebble Beach Edition
- 1/2" Drive Torque bar 80 ft-lbs where?
- My PB edition 2009 RX350.. AWD or FWD?
- Service at a Toyota Dealer?
- RX350 Oil Change Help
- Oem Front Bumper Vs non-Oem
- Help a lady out with service needs
- Deciding color combinations - anyone have chrome?
- better wheels and tires for better handling?
- 2008 RX400h... Already rusting?
- Removing the cross bars, simple DIY
- Seeking 2008 RX 350 AWD with NAV
- may purchase RX330/350
- 25+ mpg
- Bloodbath for someone at end of my lease...
- RX330 - Planning To buy
- RX330 Fuse Box
- Strange alarm, no indicator
- Transmission Fluid
- Anyone experiences this?
- Vais SLI I Agree Bypass & Phone bypass wire cut
- My findings Vais vs dice in NON nav RX
- All weather OEM floor mat
- 2004 RX330 - Options for playing iPOD
- New tires that WON'T Squeel!
- What Ipod integration unit to use for my 06 with no nav?
- Transmission Release "thunk"
- Proud new owner of an '05 RX 330 with a question
- pics of my fully upgraded rx330 stereo; now with more nav
- Any One Seafoam Your Rx330?
- 2008 RX350 not driven in 4 months
- Kuda mount
- I regret buying this rx350
- Lexus RX330/350/400h LED Turn Signal Mirror
- 06 Trans 02 Trans Difference
- Novice has question?
- drivers window works; other 3 do not
- HID Retrofit
- Bluetooth A2DP wtih RX350
- New motor, gears, etc for sunroof.
- which year hybrid got blue emblem grille in the front?
- Nav overide
- RX330 TRansmission Cooler Lines
- DIY: Remove condensation from headlamp (temporary)
- Parking Brake Switch for 2005 RX
- 2008 RX350 Air Filter/Cabin Filter
- Stupid phone book entry
- Door came open
- 08 RX400h -- bluetooth interference / buzzing
- Repair Manual for 08 RX350
- OBD II Code 2195
- Multiple warning lights
- Transmission pan: How to get it off to get filter out?
- Radio Head? After Market in dash nav?
- FM Transmitter and FM Radio? or MP3 ?
- Vsc trac off-engine check light came on
- A fly stuck in the taillight
- Rattles
- Length of Cargo area with seats folded down?
- Can this be done?
- 2004 RX 330 0-20 oil?
- 2004 RX 330 Idles too fast cold
- 2005 RX330 Transmission Question
- Who engineered this car?
- 2007 RX350 SAT radio in a 2006
- Explain
- RX330 Vanity Mirror Replacement Bulb
- RX350 Uneven tire wear at 11,000 miles? rattles in dash?
- BIG Problem
- Problem with Navigation system as well as Bluetooth
- Keeping it in the family: 09 Pebble Beach
- used oil disposal
- opinion:New tires
- iPod Adaptor - Does anyone know how to use it??
- Engine start button kit
- Easy aftermarket radio replacement option!
- Programming duplicate keys
- Power Steering Fluid Leak with my 04 RX 330
- Lexus logo scuff plate removal
- RX330 powerless
- Lower seat back cover
- what kind of transmission service I should do?
- Front end noise caused by tires?
- New Owner Nav Question
- headrest doesn't adjust forward
- Wheel alignment?
- the rims are on the rx!
- has anyone else had this problem.
- Is the maintenance expensive???
- RX headlight condensation / moisture fix - DIY
- 2009 RX Sound System - Cheap Sounding :(?
- Struts questions
- Do I have XM radio?
- 09 Pebble Beach Edition Gifts
- Listing of compatible cell phones
- Toyota Venza and the RX 350
- 2 new rides for wife and I
- ambient air temp sensor
- Looking for a better brand of wiper blades
- Pebble Beach Badges
- Venza rims on 2nd gen RX
- 2009 RX 350 - 6 hours old - wife opened the rear hatchback manually HELP
- Key Fobs????
- Side Markers on our RX!
- Have you put MODs on your 3.3 V6?
- how do i remove the navi dvd
- Looking for 10mm hub-centric spacers for my rx330
- Toyota Harrier better than RX?
- ABS, BRAKE, VCS,TRAC OFF, Tire inflation pressure lights ON
- Rear wiper blade (yep. Once again)
- Second Roll Seat in Reality (with kids)
- RX350 automatic height suspension option
- Opinions/Reassurance? 04 RX330
- RX 330 suspension lube points
- what gen is my rx
- I need some help...
- Key Fob Programming
- SF Bay Area Dealer (Service) Recommendation
- Did I get a good deal on my 05 rx330
- lexus diagnostic
- AUX input mod for 09 rx350?
- Power Steering Reservoir
- RX survived bomb blast
- garagejack lift point RX330
- xm volume, rear view dimmer, clear bra, ipod video
- Need HELP for buying a RX330
- A Few Questions With My New 09 Pebble Beach
- Looking source for the plastic guard that runs under the doors
- helping the economy..IS 250 for '09 RX350 on East Coast
- Is this dealer prepaid maintenance package worth it?
- 04 rx330 steering squeal
- buying a rx-330 with high mileage
- Warranty Question
- Installing new navigation disk
- SL2Vi Video Ipod for an 06 330 w/Nav?
- New 2009 RX350 purchase question
- Trailer Hitch for $1 if u live at Mass.
- Lexus Trailer Hitch
- Bridgestone Dueler H/L Alenza tire $100 (coupon attached)
- Air Flow Direction Changes by itself/Transmission Problem?
- Help Me Choose A Color For My New 2009 RX350
- Help needed in making my purchase
- 8.1 Map update
- RX330 headlight removal
- Engine Ticking?
- sunroof shattered!
- 09' Radio in 06 RX330?
- Lexus Personal Settings
- Concensus on Tire and tranny fluid??
- What parts do I need for a brake job?
- 2008 RX Transmission Problems-Please help!
- Nav System - Detail Displayed on Maps
- 2009 (current-gen) RX 350 - Feminine?
- 5,000 mile oil change
- help
- VCS, ABS, Brake light
- Newbie Questions
- Sunroof Rattles - STILL??!!??!!
- AC issue
- New RX350 2009 Is this something wrong?
- 2008 RX350. Won't start and won't accept boost. Urgent!
- Urgent! Help
- Rx350 available in Japan
- 2004 RX330 Passenger door will not lock with remote key
- 60,000 service. what the heck?
- 2009 Lexus RX 350 Base 4dr FWD MSRP 38,525 CarsDirect Price: $30,430
- Another rear wiper blade question
- 06 RX 330 Nav screen to DVD?
- Wash and wax
- Truck/lawn mower like sound from engine
- 2007 RX350 AWD maintenance question on transmission
- Factory GPS antenna location ?
- 2009 Rx350
- DIY Coolant flush?
- XM for RX400h
- Would like to update navigation system for 05 RX330
- Block Heater
- Roaring At Acceleration From Rx330
- Bought my first Lexus... never again.
- Yokohama Parada Spec-x Tires Vs Michelin Mxv4, Comfort vs performance
- Changing license plate bulbs
- can snowboards be mounted on factory cross bars without snowboard rack?
- 05 RX 330 Light Assembly/Brake Light Replacement
- RPM is abnormal at initial startup
- Anyone with Nav ever use a ferry?
- Is it really awd?
- Turning the Steering Wheel Far Left or Right Makes Noise
- RX330/RX350 Brake Lines - Are they the same?
- IPOD Adpater USASPEC PA20-TOY
