05 RX 330 brake petal goes down still
One day at a traffic light I noticed my brake petal slowly sinking to floorboard. I replaced it with new master cylinder. One week later started doing same thing. They replaced it and I installed another new master cylinder. Now the same thing. I bench bleed the cylinders and bled all four wheels when installing. Took off all wheels inspected wheel cylinders and found no leaks. I have no brake warning lights showing in the dash. I'm not losing brake fluid anywhere I can tell.
Also I did not see any fluid leaking into the brake booster when I pulled the master cylinder.
I don't know the problem but I am getting good changing them out.
I got air in my lines once, didn't realize the reservoir hose was on the side, not the bottom. The only thing that got the air out of the lines (and a lot of brake fluid) was:
power bleeder. I don't actually put BF in the container, I just stop and refill the res. 8-10 psi is all you need pump the brake pedal 3-4 times gently, each time to get the air bubbles out, and then crack the bleeder screw just of a few seconds. close and repeat. You can re use the new BF if your catch container is clean.
Since I first bought the power bleeder, I've used it several times on friend's cars and motorcycles for normal bleeds and to get air bubbles out of the lines.
good luck.
good luck.
