- RX330 Windshield Washer Cold weather problem
- FS and WTB posts go in the classified forums only
- Power Steering noise
- Who has a paint matched roof spoiler??
- rx 350- 08- heated seats not working!!
- 08 Lexus Rx350 AWD
- need maintenance advice on 08 RX350 70k miles
- Clunk!
- Ignition Coil questions
- How to change the serpentine belts on a RX330?
- Toying with a trade idea
- 2007 RX350 front wheel bearing replacement!!
- Refueling Problem
- Who has the door mirror cover with puddle??
- Video of Auntie reversing the RX
- Problems Problems Problems! Venting... this post is essentially pointless
- How long before battery is dead?
- Nexen CP521 tires...
- Does anyone have the weathertech rain guards?
- Better half got a recall notice for her 2004
- Chrome Strips
- Anyone had to replace radio button lights?
- Rear Lights RX350
- HID bulbs for Rx 350 2008 awd
- Pcv valve problem pleaseeee help
- 2007 RX400H Newbie!
- Rx330 AWD Strong shake when braking wet
- Braking and engine-braking best practices
- 04 RX 330 Radio Not Working
- RX330 Rear Window Issues
- Need your suggestion ..
- 60k Mile Service
- RX330 humming noise
- Propriety System
- Said Goodbye to RX 350
- How to remove the luggage compartment light covers?
- Is it true that electronics drain battery?
- Another "yes I searched" oil change question
- FINALLY SOLVED! P0171 and P0174 Codes!!!!
- 2008 RX 350 Engine oil and transmission fuild/brake fluid
- Spark Plug Replacement
- Automatic Door locks do not unlock completely on 2004 RX330
- Buying 2004 RX330 AWD
- Firm steerying at startup and then goes away?
- 70k miles and all this gone wrong?
- Report: Pirelli Scorpion Verde
- Rear door
- 07 RX350 Windshield washer motor weird problem
- headlamp washer door?
- Completely Useless Information
- Staggered tire fitment rx400h
- Engine covers
- Mystery coolant leak 2004 RX330(58,000 miles)
- Battery drain on 400h
- Strange problem - after battery drain and jump start
- rx 350 vsc issue
- 2004 RX330 Battery too big for alternator?
- Isimple and RX 400h 2006
- GTA Kit
- New Owner of 2005 RX330 - just one question please
- Rear Hatch Only Opens With Remote or button in car.
- Extended Warranty Suggestion?
- New 2007 RX 350 Owner - Quick Question
- Rear Hatch Sticks
- 2004 RX330 External beep
- power steering leak help!
- 04 RX 330 65 K mi. Coolant level issue
- power steering fluid?
- 2007 Rx400h - 225,900 miles - anyone has higher mileage?
- New Google App for iPhone - directions via bluetooth.
- Anyone Replace your ignition coils with an aftermarket brand?
- Road trip from Vegas to snow in Brian Head/Duck Creek Utah
- 2008 rx400 hybrid gas
- 2RX Oil Line Failure - Catastrophic Consequences (pictures)
- Clogged Sunroof Drain repair breaks transmission?
- Share my experience with Engine light/VSC/trac light
- Transmission gear light mostly off on console, sometimes on - HELP?
- check the system
- Cup holder problem with my RX350
- Extended Warranty???
- Frequency of oil change with 2009 RX 350
- 05 seatbelt
- climate control air temperature problem when idle
- XM Radio ID?
- How to work out the equivalent LED bulb to replace stock?
- 86100-0W160 Surely there must be one somewhere...
- First timer
- headrest
- 2006 Lexus RX330 AWD Questions
- Lexus RX 350 2008 Chain Noise
- please help - how to refix rear fog light
- Parking brake stuck 2006 RX330
- 2006 rx 330 rear cover
- Do these H&R springs fit?
- rx330 recirculation leaks external air
- Rear window wiper not working
- Anyone know these aftermarket wheels?
- Where can I tap the Illumination wire on 2008 RX350 ?
- Rotor Discolored
- Rattle Noise upon initial exceleration...
- Codes P0171 and P0174 - found a good reference site regarding these...
- What entails "Air Induction System Service"
- 2004 RX330 How many Miles?
- Navigation Memory Issue
- horn relay location rx350
- Replace ignition cylinder
- RX 330 info
- Side mirror keeps adjusting when in reverse
- Power Steering Fluid Leak?
- Interior mods for RX400h
- More Roof Noise Woes
- Door Actuator Diagnosis - Unable to manually unlock
- Thinking of purchasing a CPO RX
- Speakers and fog Lights
- 2004 RX330 Rear Wiper Blade
- Chipmunk dining on engine wires.
- Confession to make
- Gas Quality
- 2007 RX350 Instrument Panel
- 2006 RX400h Rims on 2004 RX330
- Drilled, Slot or Not: Rotors
- Driver's Seat Creaking
- Ride Setup for Comfort
- Replacement HID Headlight - What is the best non-Lexus?
- Auto position for headlights
- is Base RX pre wired for AFS turn lights?
- Moved on to a Gen 3
- RX330 Headlight condensation and HID help?
- Toyota Harrier Rear window?
- Sticky windows
- Orange interior lighting
- GS450H Wheels on an RX? Anyone tried it?
- transfer case 2008 RX350
- can you remove the nav dvd altogether?
- Slight alternator whine through speakers after new deck
- Rear Brakes RX350 (2008)
- Navigation 12.1
- FWD/AWD Struts confusion.
- 2007 RX350 XM Radio
- RX 330: Rack in Pinion issues
- 2008 RX350 any known problems before 75k miles?
- How to reset AVG MPG computer?
- radiator recall? 2006 RX330
- CDs Won't Eject....HELP!!!!!!
- RX 330 Problem areas past 150,000 miles?
- 2009 RX350 Wintertire replacement.
- Wheel sensor replacement- help!
- V8 Engine
- Can you pair Bluetooth audio device in RX 350 2008?
- New 05 RX330 owner w questions
- What type of lowbeam socket is it
- Which generation?
- Rattle around top of backseat driver side?
- Strange Noise please help to find out
- Handsfree Mic question
- 2009 RX350 U-Haul trailer hitch
- Plug Sizes (Wiring Loom)
- Trailer Hitch questions
- 2004 with 90k miles $15k - good purchase?
- neew help,wipe trans and blade rplacement
- Rear hatch won't open with remote
- New Windshield - Lexus or Aftermarket?
- Nothing from interior air vents
- Winter is almost here with snow for some. Post pics of your RX in the snow
- I have a leak from the sunroof drivers side drain on floor board ?
- Help Identifying this front lip
- Water in headlight. Common problem?
- Lexus Dealer in Reading, Berkshire, UK
- Vibration, vibration sound in gear.. Belts?
- 16 inch wheels
- Manually shifting the transmission = feels quicker
- Will 235/60/18 tires affect my 08 RX350?
- Help!! Beeping sound
- Transfer Case Oil Change?
- 03 RX300 or 04 RX330 Need your help
- Fuel system needs cleaning?
- High pitched squeal on cold starts - 2007 RX 350
- My Wife's 2005 RX330 saved her life.
- Cruse control stopped working
- Vibration in Steering Wheel
- 2004 RX330 passenger air bag light stays on
- I need a Rx330 transmission AWD
- RX 330 Transmission Problem Please Help me
- 2009 RX350 Where is auto trans plug located?
- Scangauge and/or software tools
- Problems Using New 160GB iPod with 2008 RX350
- Battery for Second Generation RX 350
- Timing Belt Replacement
- 07 RX350. moon roof problem
- Navigation ID for 2004 RX300
- alignment for my '07 RX350
- Scratch Identification / Has This Happened To You
- odometer/speedometer accuracy
- Struts and rack and pinnion
- Climate control for the fan speed
- Power Liftgate beeping and poping?
- Toyota Extra Care warranty for Lexus?
- Fuse sheared off
- Inner and Outer Tie Rod DYI
- RSES retrofit?
- Anyone seen an RX330 with these rims?
- 07 RX350 Trans Service
- 06 RX330 engine ticking while off. normal?
- Drain and fill transmission fluid - made a difference
- Review of Pirelli Scorpion Verde
- Should I expect more issues with 2007 RX350 than I've already had?
- High Beam suddently quick working
- Sunglasses Holder - source for parts
- FYI: Lexus Battery warranty
- Wheel fitment query for 2009 RX 350 with ES350 rims
- Gas mileage on a 2012 Camry LE
- Evo 8 Rims on RX350
- Help - shocks and strut
- Passenger side rear seat won't fold down.
- Basic question on Automatic Climate Control
- Groan when opening rear hatch door
- New RX owner
- Does Platinum Extended Warranty cover Battery?
- Info on Club Lexus saves the day again *dealer replace battery for free*
- Just picked up my 2005 Rx330 yesterday!
- Battery drains
- Just got my 07 RX
- Rx 330 Struts Replacement
- Back passenger door lock problem
- Cruising Range is lower than fuel gauge
- TPS Warning light
- 2006 Rx400h dvd/nav hack
- How to open/close RX 330 moonroof?
- !! 2008 RX350 Help Please !!
- Rear Door Issues
- 2008 RX 350 - Starting Problem
- Brake Line Measurements
- '07 RX350 non-HID to HID?
- initialize the electrical stuff after disconnect battery
- First time lexus owner, introducing myself
- Jacking Points/Jack Stand Location? 2nd Gen RX
- Cost for 55,000 miles service
- Radio presets
- Is2 or GS3 steering wheel will it fit RX400
- Lexus Service Bulletin LSB-0059-12
- Auto Dimming and AFS
- quiet, smooth ride tires for 2009 RX 350
- New Tires
- RX330 Transmission Service Interval
- looking to buy a rx350
- Mold in Air Conditioning
- Headlight went out
- Help! Used 2004 Rx330 value??
- Winter Wheels
- 2005 RX New Owner
