Got codes P0441 and P0455
Replaced the gas cap, but check engine light still comes on. Today when filling the gas tank, gasoline appeared on the ground, coming out from under the car. 2009 RX350
Leaks are tricky & need to be followed carefully...
it could be the filler neck or anything else.
Gasoline leaks also can be extremely dangerous if in contact with parts which generate extreme heat!!!
hairyfish (07-05-17)
Antphilli
08-20-08 10:42 PM
