Warning code
Warning code
Trac off/ engine light & VSC lights appeared on My Lexus RX 350, So at the recommendation of this forum, I took my car to auto zone & had it read .
My error code was P0456
evap emission leak ( very small leak)
suggested parts: EGR Vacuum Solenoid
Can anyone explain what this is; Is it emergent & the possible cost.
I'm not a savvy woman when it comes to cars & any advice is greatly appreciated!
P0456 TOYOTA - EVAP Control System Leak Detected Very Small Leak
Possible causes:
Missing or loose fuel cap
Incorrect fuel filler cap used
Fuel filler cap remains open or fails to close
Foreign matter caught in fuel filler cap
Evaporative Emission (EVAP) canister or fuel tank leaks
Evaporative Emission (EVAP) system hose leaking
Fuel tank leaking
I agree with the other CL Members...Possible causes:
Fuel tank leaking
That's a tough code to deal with, a tiny pin hole in a hose will set the code...
like looking for a needle in a haystack.
If the gas cap replacement doesn't solve the issue, a smoke test should.
NVAKeith (07-12-17)
Not emergent but emission related.
Clean gas cap first and put a thin layer of silicon-based grease or vaseline on gas cap rubber seal. if this trick doesn't work then you may need further diagnosis.
DONT SLEEP
03-12-19 05:46 AM
kRonX
CL of Southern California
10-31-08 11:47 PM
