- rx 330 rear hatch won't open
- Power Steering Leak
- mud guard for unpaved road?
- Center Console Doors not work
- 2008 RX350 power tailgate issue
- I am looking for help with my anti theft system..
- Tailgate opens then closes
- pinout ecu 1mzfe 204 hp
- Impossible to align the wheels?
- Sun Visor problem 2004 Rx330
- Anyone Put H9 bulbs in their halogen low beams?
- Am I being taken? What should brake and rotor replacement cost?
- Catalytic Convertor
- Front Liner partially destroyed
- Aftermarket forward collision warning (Mobileye)
- 05 rx330 afs light
- off idle system too lean. LTFT AT 29 OFF IDLE
- Raining Sensing Button on inside of Windshield ?
- Possible Overheating issue
- Blown fuse
- Battery Size?
- Need rear brake pads P/N
- How to remove the stereo from a 2009 RX350 sports luxury
- 2009 RX350 Brake light on dash randomly comes on
- RX350 steering wheel vibrates after steering work
- Timing belt question
- Struts? Lexus or Aftermarket?
- pulsation while braking, sometimes.
- Compass Mirror Acting Weird
- Snow tires for RX
- Part number for '06 RX400h 3-button remote key
- Melting dash or door panels on your RX?? No problem Lexus is replacing it!!
- No Power at all
- RX400h transmission/engine vibration
- RX330 Weird rear caliper issue
- Help please!! Lexus rx330 power steering hose!
- Tow package
- Power mirror question
- Airbag lights comes on intermittently
- I need a trickle charger for the car...
- Ever heard of lifetime oil filters
- Coin Holder (where to get one)
- Steering/Vehicle vibration @75mph
- Just Purchased '04 RX330 - Goals: Subtly Unique and Reliable!
- '04 RX white spots on steering wheel
- Need replacement luggage cover
- Best place to get toyota emblems for front and back?
- RX350 AWD 2007 Traction control engaging when not needed
- Phoenix area services prices!!!
- dipstick reading ??
- RX 330 Power Issue After Replacing Junction Block
- Rear End Clunk
- 08 RX350 coolant change?
- Car ad slamming the RX?
- Headlight leveling warning light
- differences between 04-06 &07-09 wheels
- Rear Liftgate opening at different speeds
- 2010 rims on a 2004
- RX330 Suspension Mystery
- Question after tire install - tire sensor.
- Power Windows Question
- Struts- Replace 2 or 4
- My 2008 RX 350 - Definitely having concerns
- RX330 power steering rack bushings. Help.
- `09 RX350 Suddenly lots of fishy work needed
- Oil Cooler Pipe Repair and Reimbursement from Lexus
- 2004 RX330 stereo upgrade
- Michelin tires - which one?
- Passenger Heated seat not working
- 2005 RX330 P0420 Catalytic Converter?
- Port Plug Installation Location?
- '06 RX330 rear wiper blade not gripping well
- 2006 RX330 traction control does nothing but beep
- Who has had a water pump or timing belt go bad?
- Lift gate shock/strut repair
- 2004 RX 330 Loud humming sound
- Help! My cigarette lighter outlet keeps pulling out every time I use it.
- DIY door sill LED upgrade (Lots of Pics)
- Brake Rotors
- Sunroof randomly opening
- RX350 Headlight Poor Output
- Which one do I trust?
- Any issues with 0W-20?
- tow hitch for RX400h
- Looking to buy a used rx
- 3.3L Broken timing belt teachable moment
- The same old tire questions 2008 RX
- Stereo System Problem - Radio Frequency Changes by itself
- 2008 RX 350 Extended Warranty Expiring
- Remote Start for 2007 RX350
- Moving on up...
- interior lights dont turn off
- 2007 RX 350 Misfiring and Wind Noise Coming from Engine
- RX350 Phone Contacts Setup
- Rx330 hwy ride quality
- Loud Rear Wheel
- Spare Tire Carrier Repair Corrosion
- How to remove front seat rear panel???
- Hanging from bottom of car (2004 RX 330)
- 90k service: would you change the water pump?
- Coolant leaking! Don't know where its coming from
- 2009RX-350 AWD,90K..radio antenna
- 2004 RX with 68K miles or 2009 RX with 93K miles?
- Nav Screen Dark
- 2007 RX350 Driver Side noise rattle over 50 mph
- Radio/CD sound not working
- Replacement headlight bulb for RX330 above DRLs?
- What's the fastest you ever gone in your RX?
- RX incompatible with Chamberlain Garage
- Another brake light switch dash lights question
- Rear Lip - Who makes this
- Cargo Door
- ?? DVD Navigation purchase & update DIY
- Vibration at freeway speed…..pull over to the shoulder, place car in park, then back
- My engine survived 15-20k mile oil change intervals w pics
- How Long Have Your Tire Pressure Sensors Lasted?
- Curb Check
- My RX 2006 model approached its 8th year
- 2005 RX330 height sensors problem
- Need help to resolve Cold Start Problem
- Input on GY Tripletred and Conti PureContact
- Disassemble 2004 RX330/Damage
- Intermittent Cruise Control
- RX330 Passive Alarm Issue Q?
- 15 L/100 km / 15.68 MPG
- Will 3rd Gen RX 2010+ Cargo Cover fit 2nd Gen 2004-09?
- somewhat urgent question about tires 2008 RX350
- How many belts are in a 2004 RX330?
- Noise when braking (Squishy too)
- Will 3rd Gen floor mat fit in 2nd Gen?
- Rx350 2007 navigation screen dead
- Help me decide
- Engine block heater
- 4G Bluetooth compatibility with 2006 RX 400H
- RX330 Aftermarket Radio TYTO-01
- Replace your rear knuckle bushings with NEW OEM Bushings/Spherical Bearings
- Keyless Entry Remote Buying Options?
- Will Lexus fix this or will I have to pay for one??
- My console lid is stuck half way!
- Question about rearview mirror and rain-sensing...
- transmission flush
- Best way to adjust HID low beams separately from high beams on RX
- Lexus Logo on Carpets Falling Off
- clean fuel injection system service
- Crack developing in dash
- Just got remote start installed. Quick issue
- Dud Key?
- Rx 350
- Vaistech SL2i-UP install help
- Buying Used Second Gen
- Fall 2014 Best tire update (please participate)
- 2008 RX400h water pump, timing belt, oil change, fog light, condensation in headlamp
- The winter is coming!
- transmission
- 2008 RX350 - Rear Bumper Reflector Replacement
- Homelink Console RX330
- Cracked dash
- dead car : battery / something else ?
- 2005 Rx 330 headlight extended warranty
- The RX has to go to the hospital!
- Pimp my 2004 RX330
- The dreaded: Sunroof stuck open
- Speed dial/speed tone
- Lexus RX330 (2nd Gen) How to paint Headlight housing
- Front swaybar endlinks mounting point broke!
- High mileage 2nd generation RX-350
- 2004 rx330 original key not working
- 09 RX Problems!
- AWD test on RX330 2005 - how to verify
- 2006 rx recall for headlights
- 2008 rx350 TMPS light on
- When will the new Navigation Update be issued?
- 05 RX330 Wheels
- alignment print-out - Cross Camber not important for AWD?
- Photo of brake light switch?
- I suggest EVERYONE do this...
- trans mission failure
- Will tire size mismatch front to back damage transmission?
- So long, and Thanks
- Will JDM Rear Taillights/Trunk lights fit on a USDM 2006 RX330?
- Right side speakers not working 2005 RX330
- Retracting steering wheel
- air shocks
- new to RX
- Gas Door Hinge
- Thinking about a 2008 RX400h
- Console differences? Which is which?
- Installed Vaistech SL3B yesterday and tested it vs CD
- Should i buy 2005 RX 330, 14000 miles for $10K
- Disable auto re-lock function, please...I'm panicked.
- anyone know how a diff breather valve look like?
- #3 cylinder code of P0303
- Body side molding replacement
- Error 4 revisited--request help from any and all experts!!
- Changing inner door panel driverside...
- Please help - What engine oil to replace recommended
- A mysterious suv showed up in our garage:)
- '09 RX Radio Security Code?
- navigation system
- windshield wiper replacements 2009 rx30
- Transfer Case Leak 2004 RX 330
- 07 RX 350 Lights
- Replacing rear bearing
- Automatic Window Up Mod
- Unlink headlight washers from windshield washer
- VICTORY!!!! Fianlly Solved an ABS problem.
- Sounds like a diesel when started
- Transmission slipping
- Shifter skips "D"...trans won't shift to 5th
- No way to open rear trunk manually?
- Can I Obtain A Build Sheet For Our Lexus?
- 2006 RX400h Aftermarket Wheels Offset
- New to Lexus and forums
- From Toyota Tacoma to a Lexus RX350
- Heat only coming from Driver's side, but Cold A/C works on both
- 08 RX350 AWD Transfer Case and Rear Differetial fluid change
- Cruise range of miles on computer
- A question for those that have painted headlights
- 2006 RX 330 Check Engine & VSC light on
- Dash pad
- Cracked dash
- AC occasionally doesn't work on 09
- 2009 RX 350 Rear Hub Replacement
- Are There Replaceable Batteries in the 2007 RX350 Tire Pressure Monitors?
- Timing belt plus
- Brake line flush/gasket repair
- Rear Hatch Beep Be Gone Please!
- TSB for RX330/RX350 rattle
- 18 watt backup bulbs
- Tail Light Picture Request
- Pulled The Trigger Today on an 09 Pebble Beach
- 2005 rx330
- 2004 - Fender "Inner-Liners"
- 2007 RX 400h lost power, even with new IPM
- Need Help Considering buying 09 tomorrow, 8/30
- Valve clearance
- Life expectancy?
- 2nd vs 3rd generation styling/design
- Water under carpet mystery
- Side mirror looks like it is peeling?
- Should I Buy?
- 09 Rx350 Power lock issue...
- Steering Gear Replacement and Spark Plugs/waterpump and transmission cooler
- RX330 Purchase and new sound system
- 2004 Rx 330 Suspension Rattle with Air
- Strange Noise - Only when AC is on
- Installed new struts, axles, brakes (***pics***)
- Auto Shop in L.A. 2005 RX330
- Sound System Problem! Please any help!!
