PDA
View Full Version : RX - 2nd Gen (2004-2009)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. RX330 body control module
  2. starter stuck to transmission
  3. Rear Differential Axle Seal & Lower Control Arms - A Few Questions
  4. Normal idle speed on rx350?
  5. code 0304 and various VSC ABS codes help!!
  6. rx330 tranny stopped at a light now wont go into any gear
  7. code 0304 and VSC
  8. Remote keys
  9. Power Steering Difference Between RX330 & 350?
  10. alternator swap
  11. Compare RX AWD v GX 470 AWD
  12. 2004 RX Electrical Component Issue
  13. What is this spring sticking out in the back of the trunk Rx330 2005
  14. Busted my mirror
  15. Break Job for 2009 RX350
  16. 2009 RX350 air filter 2
  17. 2004 RX 330 - code P0351 to P0356: Ignition coil A - Primary/Secondary Circuits
  18. 2005 rx330 evap. hose part number
  19. Adaptive xenon headlight conversion
  20. RX Downshifting Pros & Cons
  21. Upgrade to 99-03 RX300 Armrests
  22. Preferred brake pad/rotor combination?
  23. 04 Rx330 air suspension conversion
  24. Dashboard Whipping a dead horse
  25. Rear control arm bushings needed !
  26. water in headlights
  27. RX 350 Spark plugs
  28. 2007 Lexus RX350 Throwing A Ton Of Codes
  29. Leaking washer fluid reservoir
  30. Barking brakes, Bleed Brakes, Check VSC System
  31. P0014 code, Dipstick Dry, Boot exploded?
  32. Need Help with Diagnosis with the p0300 code. Shaking. Also needs head gasket, water
  33. Coilovers
  34. New to me RX questions
  35. Had dash replaced, now my 6 disc cd changer is acting up
  36. Aluminum Sway Bar End Links
  37. RX 400h Thermostat change
  38. Brake padel sinks
  39. Help in identifying trim component.
  40. 2GR lubrication system= Shocker
  41. I change the O2 sensors Check Light Still on! Need help RX 330 2005
  42. Brake booster removal on right hand drive
  43. Shout out to PowerBass and those FKers in Germany.
  44. 09 Headlight Upgrade
  45. 2nd Gen RX Upgrade/Modification List, DIY Help & More
  46. 2007 RX 350 keeps dying after changing fuel pump and ignition coil
  47. 09 RX350 Ignition Coil
  48. 2009 RX350 cranks but no start- HELP
  49. Help! 2009 RX350 Trouble code P0171&P0174
  50. Another speaker/stereo replacement thread
  51. rear differential swap
  52. Leaking Seams! Definitely check your RX!
  53. Trunk latch keeps popping open
  54. P0441 2007-2009 rx350
  55. Help!! All Cylinder misfire on 2007 rx 350
  56. screeching noise when turning - much louder after replacing tires
  57. Will 235/60/18 fit on 2009 RX350?
  58. 2008 RX 350 windshield washer not spraying
  59. Does '120k Service Performed' Really Mean That at Lexus?
  60. HID to LED headlight conversion
  61. 09 RX350 Hesitation when accelerating
  62. Swap to RX400h Taillights (2004-2009)
  63. What to look for when buying 2009 with over 200k?
  64. 2008 RX350 Does not blow enough cold air
  65. Refrigerant Pipe clamp at firewall
  66. Question about rear hatch button 2006 RX330
  67. 2009 RX with Nav - can you set the screen to open up on the function you prefer?
  68. Another Door lock issue - LOCK but no UNLOCK
  69. Glitch in steering column retraction
  70. Replacing Dashboard Junction Block
  71. 2004 Lexus Rx330 rear lift repar
  72. Is this leather peeling or it is some synthetic panel on the seat? Is it fake?
  73. drivers door light switch / Body Control Module
  74. RX300 dragged into the 21st Century, CarPlay & Android Auto
  75. Blend Door Hunting/Crunching
  76. Belt Molding Tool
  77. RX 330 & 400H Suspension Differences.?
  78. Ghost in the Machine
  79. 2007 rx350 alignment
  80. Maintenance Questions
  81. Wheels lugs and lock
  82. 2008 RX 350 Check AC on Nav then overheated
  83. 2008 RX350 Driver side AC is not cooling/ Passenger side is cooling OK
  84. Is this exposed wiring in front of the radiator normal?
  85. Rumbling noise when coming off gas
  86. 2009 RX350 cold start noise
  87. New Dashboard Wanted
  88. What does the unused blue 6-pin plug do in the factory NAV?
  89. Gauge cluster brightness dim during daytime
  90. 2009 rear tailgate struts que..
  91. Lexus RX400h - change stock radio to aftermarket Pioneer SOUND ISSUE
  92. AC completely stopped working in 400h. What do?
  93. Air intake button issue
  94. 2008 RX350 Key question
  95. anyone had calipers replaced?
  96. MOOG K100401 Greasable Rear Toe Adjustment Bolts (AWD models)
  97. Work on a'07 RX
  98. How the VVTi works and the noises it makes
  99. RX300 air Suspension (again)
  100. Cup holder insert
  101. Need help diagnosing inoperative intermittent wipers.
  102. rx330 motors
  103. U151 spec'd for T-IV and WS
  104. Auto headlights don't turn off
  105. RX350 2008 won't start new batter inserted
  106. RX330 AC question
  107. cabin sound level ????
  108. Check engine light
  109. 2007 RX350 Transmission additives?
  110. AliX cheap dash cover (carpeted)
  111. 2001-2003 Highlander Steering Rack Fits
  112. Dash cam install, 2008 RX 350, Hardwiring
  113. Coolant leak 2007 Lexus RX350 HELP PLEASE!
  114. New Shock or Struts???
  115. Display screen (the no nav version) is starting to discolor
  116. Rear sway bar 14mm to 16mm?
  117. 2001-2003 Highlander Steering Rack Experiment
  118. What front struts to go with the oem springs
  119. Sound Deadening wheel well?
  120. Key assembly -- NEED HELP!
  121. Reducing wind noise, Quiet cabin (cheap)
  122. No air from front hvac blends.
  123. 2004 Rx 330 Bad Vibration under center console when accelerating
  124. shaking steering wheel
  125. Radio + CD changer issues
  126. Remove Under Seat Vent to Remove Object
  127. Transmission filter change
  128. Got brakes
  129. Looking for a good USB data port for Alpine radio
  130. Steering shaft stuck(?) Up in actual steering column
  131. Power steering rack isn't tightly bolted in
  132. Hit the Like Button, Post More PLEEZE!!!
  133. Air-Fuel O2 Sensor (Bank1 Sensor1, Bank2 Sensor 1)
  134. Rear diff and transfer case - 1st fluid change
  135. FELPRO MS 96786 Intake Plenum Gaskets - BUYER BEWARE!
  136. Unidentified noise
  137. ignition switch problem.
  138. Best replacement shocks and struts for the money?
  139. Body Side Molding Replacement
  140. 2005 RX330 Calipers & Brakes
  141. Volume Control '05 RX330
  142. ABS light on after driving in snow,ice
  143. Clunking pop while steering
  144. low beam replacement without shock
  145. 2009 RX350 with nav and newer Samsung phone - sync contacts
  146. RX400H FWD Front Tow Dolly
  147. Check engine light, trac off, VRC warning lights 2 codes appeared then went off?
  148. rx400h low beam bulb change?
  149. Newbie here - RX330 front chunking noise
  150. Loud clanking on start up 2008 RX 350 help.
  151. Camera check unavailable in service menu
  152. Aftermarket Stereo
  153. 3d maxpider kagu floor liners
  154. Chevy 350 swapped 330
  155. Dim navscreen on startup & keyfob takes long to unlock doors
  156. 2007 RX350 whining and ticking noises
  157. 2009 RX350 outer tail light red dome over bulb detached
  158. Vibrations up to 20mph…. Then gone!!!
  159. rain gets into closed locked car
  160. roof rack part missing
  161. Current gas mileage? This normal?
  162. 2007 Lexus RX350 faint smell of gasoline
  163. Engine / Motor Mounts
  164. another new owner question and thanks = mirror tilt?
  165. are 2nd gen cars notorious for interior noise from tires and or wind?
  166. MAF no 12v at pin #1
  167. 2007 RX350 rear entertainment system, system locked message
  168. RX400h Blown right front tire severed wiring harness ABS VSC AWD
  169. Rear strut replacement - 2006 RX330
  170. 2009 RX350 head light assembly for HID headlights with dynamic leveling?
  171. new to me 2009 RX350, car nice but chatter noise from water pump area
  172. Lower control arms
  173. 2008 RX350 A/C Repair
  174. 2005 RX330 won t engage wont move forward or back
  175. 2007 RX350 - Ignition Coils
  176. Bolt plate for body mods attached to Lexus undercarriage holes
  177. OEM part number for the hood for 07 rx350
  178. Secondary air system not ready
  179. Please help, tranny swap
  180. Another "my car is leaking inside?!?!" thread - what next?
  181. New hid lights?
  182. P0420 even after changing oxygen sensors?
  183. afs off light flashing
  184. 2005 RX330 headlights not working but all others are?
  185. Thumping coming from rear drivers side at all times
  186. Wood Steering Wheel
  187. LCA replacement advice
  188. F-Sport Pedal Install
  189. Front Grill Replacement
  190. Error codes c1568 & c1241
  191. 2004 Lexus RX330 Driver Door Outside Center Moulding Fasteners Needed???
  192. Son wrecked the '05 MDX. '04 RX330 as possible replacement? Questions...
  193. 2009 rx350 awd no reverse HELP PLS!!!
  194. New Rotor Thickness
  195. Can no TPMS on spare tire cause errors ?
  196. 08 rx350 suspension suggestions
  197. kill switch (any Ideas)
  198. E-brake/parking brake clunk
  199. Tilt wheel squeak
  200. CUT Wire Under Windshield Wiper Cowl? (2008 RX350 Base)
  201. Highlander Strut Brace Won’t Fit RX
  202. 2008 RX350: Is it a solid travel vehicle if VVT-i / 9LH hose replacement was done?
  203. Switch to 235/50/R18 tires
  204. small windshield chips
  205. Free shipping at SE Toyota dealers
  206. 2008 RX400h. OEM Pads and ROTOR Suggestions
  207. spark plugs & coils replacement on 2007 rx 350, need suggestion
  208. Dash replacement
  209. reset fuel consumption without head unit display
  210. Roof Rack Cross Bars
  211. ALL of my power windows just quit working.
  212. Increase fuel consumption on 2007 rx 350 ?
  213. Great Key Fob Hack Discovered by Accidental Purchase
  214. More Check Engine and VSC issues. 07 RX350
  215. TPMS Receiver issue
  216. Engine temperature sensor RX 330 2008
  217. new alternator and battery, now rear windows don't work from driver's master switch
  218. 2008 RX350 starts and dies
  219. Lexus RX400h (2008) brake backing plate (shield)
  220. Crankshaft sensor was pulled out from connector now it won't start
  221. Subframe Bushings
  222. RX350 P0365 start and die
  223. 077500-5191 Ambient temp sensor loom routing
  224. RX400h lock actuator still not working
  225. RX350 No start
  226. Anyone running LED headlights in their RXs?
  227. How I added Bluetooth to my RX400h
  228. Loose side door mirror
  229. Looking at a 2007 RX400h
  230. NEw INterior Carpet 2005 RX330
  231. P0172 and P0175 Codes
  232. Painting grill guard?
  233. Aftermarket Mud Flaps
  234. Wood trim
  235. Removal Door Handle Protective Sticker Glue
  236. Struts, mounts, bearings, OEM vs aftermarket.... sigh
  237. Struts and strut mounts or just struts?
  238. Roof Rack Trim Piece
  239. I'm not kidding....
  240. Plug and Play headlights
  241. Timing Belt Kit: TKT-033 vs TKT-026
  242. Map update
  243. 05 lexus rx330 tranny issues
  244. Electric issues in my lexus rx 350
  245. Battery loss
  246. Failed Emissions: OBD Connection
  247. Head gasket
  248. RX 330 PowerSteering Noise
  249. RX350 - Cranks, Idles rough, Stalls
  250. v-belt quality - OEM vs. Bando
