- Should I sell or should I keep a 92 SC 300 5 Speed
- Custom gauge pod ideas
- Stupid question
- ALL FS ISO WTB go in Classfieds Section Only
- Driver seat switch question/issue?
- Just picked up a Renaissance Red 97 SC400
- Driftmotion 1jzgte single manifold owners chime in - oil return discussion
- My 1998 White SC400
- 4th Times A Charm
- Is this battery wiring setup correct?
- Awesome LED Tail Lights
- 1995 SC 400 AC Not working
- 1998 Sc400 collison...
- Lighting Services
- OEM Shift k*** question
- 1UZFE components identification help (93 SC400)
- 1UZFE intake manifold gaskets, change or reuse?
- I give up on the clunking
- Front belt buckle damage
- How to remove the PRD12L from shift bezel.
- HELLA Optilux Extreme Yellow XY Foglights Mini Review (WITH PICTURES)
- Do any of you have that ebay center armrest leather cover? How is the quality?
- 245/50r16 vs 225/55r16
- So I went to the Lexus dealership today for a 5 speed SC300..
- Buying 1J Swapped 300, Opinions?
- Spin turn knob? where to find?
- Loud squeal rear driver side with video
- Buying 1992 SC400 with 115K mile
- Just bought 1995 SC400
- Importing A Soarer
- Is my alternator shot?
- Who here has black/tan 2 tone interior?
- Wreked my car, curious on what u guys think it may be worth
- Best replacement speakers for rear deck?
- 99 sc300 headlights not turning on
- Bought me another sc400 98
- New SC300 owner!
- Finally Got an IS300 Steering Wheel Installed
- aluminum engine under shield
- Which one of you is this? :D
- 3trd brake light sc400 failure plz advise
- CD changer problem please help!!!!
- HVAC/Monitor Swap
- My black plastic radiator fan shroud cracked and finally broke apart. Need Part #
- 1jz-gte fuel pressure regulator
- Looking for transmission dipstick
- Not a clone
- SC300 Start up issue, PLEASE HELP!!!
- Which wheels - Black or Silver
- Mystery coolant hose buried under the throttle body / manifold
- Your opinion wanted; to buy or not to buy
- Help! Gas leak
- door rattle finally solved
- Condensation in DS head light
- Swapped from Pioneer to Nakamichi.
- 1992 Sc300 1jz Build
- Any Stock SC400 Running E85?
- What's a clean SC3/SC400 worth?
- Radiant Barrier vs Reflectix for hot cabins?
- First Maintance Job EVER done to my 1993 sc300
- sc p/s rack
- 97 sc300 traction control?
- Led turn signal blinks fast
- pics of your sexy sc300/sc400
- Blown ECU caps
- 1jz ECU
- Picture is Picture
- Body Kit Question
- Talk me out of selling my SC300
- Air conditioning mode stuck in hot
- sc300 lower control arm torque specs
- What could be wrong with my lexus?
- SC300 Muffler exhaust outlet diameter
- First Visit To Drag Strip
- SC400, weight deforming front tires too much?
- Pumpkin compatibility
- How do you get these bulbs out?
- Which one looks better?
- Swapping out engine harness
- Electrical issue help!!!
- Need help finding intake torque specs 1uz
- Windshield washer fluid running constantly when you pull up emergency brake
- Parking and side marker lights won't turn off when car is running
- Lighter won't work (checked everything!)
- Lost shift linkage screws/nuts - need diagram
- So who's gonna be the first to do this retrofit?
- Dark Knight aka Darth Vader Photoshoot
- Major Gauge Cluster Problem
- SC400 New cluster gauges
- Any tips on replacing the Steering shaft/yoke?
- Headlight wiring color picture request
- Sc400 problem help!!!
- No cluster lights after needle swap :(
- battery drain
- Lightbulb size?
- Where is the fog light button?
- Non VVTi 2JZ in VVTi SC300?
- Kbb
- Will replacing my cluster fix my existing cluster issues?
- power seats...
- 5spd owners - don't wait too long to replace the clutch
- Wiring Help Needed For My Mirrors
- Anybody installed low beam LED bulbs in their car?
- Engine noises and tapping.
- Differential Bushings
- rear brake lights won't shut off.
- 92 transponder key for lexus 300sc
- Compatible driveshafts?
- How to replace 120A ALT fuse?
- My 98 SC300 on air suspension
- 94 sc400 giving low voltage need help!!!!
- occasional leak from sunroof control panel
- Analog dash conversion on Soarer
- Car Shakes vibrates in Park and In Drive
- Finally got my dream wheels
- Anyway to make 95-96 tail-lights look more modern?
- 1jzgte sc300 patch harness
- Tanin vs Lextech Personal Experience
- 1995 Sc400 back fire
- Very First 2 Door and its an 92' SC400!
- Custom Subwoofer Box
- Are oxygen sensors interchangeable?
- No CHECK ENGINE light ......... turns out the problem is...
- Grounding
- what hood is this
- A/C randomly gets cold when it wants to...bad sensors?
- Turn signal activates hazards
- Likelyhood of a RSP? Thinking of getting back into the SC game
- Help!!!!
- Small Fire Under the Dash, maybe salvage
- power window relay.....
- Which Wheels?????
- Nakamichi Amp and Telemute
- Need advice on rims 18"
- Nulll
- LED Lightbulbs
- 1uz manual swap, dash trac light solution?
- It's just not safe to drive!
- Help identify this round effects kit please
- DWP 5 spd SC300
- Is the SC reaching classic car status?
- What diffuser is this from?
- v8 swap write ups
- SC300 Control Arms aftermarket options
- Help 92 sc400 no power to fuel pump won't try to start without ignition held over
- New Factory Keyless Entry Keys and Receiver
- Aftermarket Amplifier Wiring
- Headlight wiring issues
- 92 SC400 doesn't recognize key circuit to start???
- How do I move this harness
- starter problem
- 1jz-gte warm up time
- Custom rear spats
- quick radio question
- SC400 manual swap help with flywheel please!
- Repairing door panels
- Trying to identify transmission
- Just bought an SC400
- 92 sc300 body plugs
- Recommend me some door speakers that work with the factory radio.
- Replacing my SC as a daily, What do you Drive?
- Soarer gauge cluster wiring diagram
- 1jzgte VVTI swap (I have the Soarer version) basic question...
- Audio Project
- My 99' SideChick 400
- Anyone had good luck with aftermarket 4" components?
- Upper Rear Control Arm Bushing Replacement?
- A little Friday inspiration - Full carbon fiber time attack soarer
- Beware of lens vinyl overlays
- paint and body guys advice needed
- WTD, SC400 1997-2000 5 speed auto driveshaft
- Mystery device inside!
- Lextech Lighting
- HIDs in my DRLs?
- New to the lexus world, but not new to the toyota world
- resivor over flow hose assembly
- sc300 resivor over flow problems
- to SC430 or not? any experience 1SC to 2SC?
- control panel a / c in my lexus ls 400 1992
- Won at import face off
- Starter issues..... I think
- New to forum
- SC300/400 fitted car cover?
- All WTB Threads Go In The Classifieds Section
- SC Dirty headlight easy fix
- Aero
- Advice needed:completely stripping an sc
- Trade??
- Tanin V3 repair cluster installed
- FS: OZ Racing Ltuned 18x9.5 DFW, TX
- Tire and wheel fitment on sc400
- setting cam timing
- '98-00 SC400 A650E Shifting
- 1 of 120 ! Found on craigslist NJ
- engine wiring harness
- 96 sc400 vvti or no
- We want Action...
- governor
- Operation: <500
- The rideskinz vip lip
- Tips on painting an SC
- Passenger seat off track
- Choice between two used cars - Please Help
- Regular Car Reviews
- 2jzgte vvti ??
- Lamp failure sensor keeps blowing
- Blacked out window trim and OEM JDM Toyota Visor Install
- Shine/Auto Couture Measurement...
- Got an engine.
- 98+ Gated Shifter Help
- Window won't roll down.
- Help. Front left door speaker connector doesn't match oem speakers
- Crank Shaft Pulley bolt removal tool bolts
- 1jz Crank Angle Sensor
- 96 sc400 engine wiring harness
- Rolling shots
- UP TO DATE aftermarket alarm recommendations
- bmf gap filler???
- Rant-Why I can't do replica wheels
- Hid transfer into sc400
- What would cause a rumble in my driveline?
- Harmonic Balancer
- What's a rolling OEM 5 Speed shell worth nowadays?
- 1997 cheap!!! Help guys
- Engine Harnesses
- 1992 & 1993 5 speed cars
- No dash light after 95/96 tail light swap!
- where can i find a nakamichi amp?
- P/S reservoir puking fluid
- Where can i get a good price on Control arm bushings?
- I'm NOT the best chef(baking headlights)
- Curious case of CEL
- 94 sc400: recommended Transmission filter brands
- Price check these days, how much does 1997 OEM aero go for?
- Power Seat Control Help
- Has anyone found ways to write some of building a car (turbo upgrade etc.) off on you
- Is There Anyone Within 1-2 Hours Of NYC That Can Do the TT ECU Mod Flawlessly?
- OBD1 1JZ in OBD2 97 SC300
- Dumb Question about OEM Rear Bumpers..
- is this how i post to the forums to ask a question?
- HELP: auto vs 5 speed tensioner
- Pics for 97-SC300
- Question to all car enthusiasts
- Swapped your interior? I need your advice
- Looking for new set of rims
- Switching a Passenger Seat to the Drivers Side
- location of temp sensor for the gauge
- Need a little advice
- Question regarding body for snowy Midwest SC drivers
- Just fixed my squeaky console.
