- OEM headlight differences?
- Boostlogic manifold
- Sc400 Limp plenty of spark
- suspension done!
- SC400 HOOD Lift Supports
- Building a 1jz, need all the help i can get
- Please Help me with Wiring on my 1jz Soarer Harness!!
- I'm new here and want advice on buying an SC
- Restoring my headlights
- sc front lip?
- Gasoline leakage Don't know what to do.
- All FS & WTB go in classfieds section only
- Neighbor just hit my 92 SC300 Natural 5sp:(
- What types of airbags are there ?
- What wiring harness for stereo in sc300/400?
- 1992 sc400 curb hit axel broken
- 99 SC300 Found Bolt In Tranny Pan
- SC300 5speed parts
- Small Leak
- Just need some real answers.
- power steering solenoid?
- coolant tank
- Hydraulic fan pump
- Could be power steering pump or pulley bearing?
- I'M BACK -- for those with the P1121 CEL (accelerator pedal position sensor)
- sc400 light weight exhaust question
- SC400 turbo
- car will not stay on.
- 2JZ-GTE Intake Manifold Q (VVti vs Non-VVTi)
- Gotta tear open my door to get it open...
- Setting up subs in 95' SC300
- what is this?
- problems with 1jz....help
- Vertex wheel and NRG quick release questions
- help clarifying some 1.5jz questions
- sc300/400 Suspensions/Coilovers.. help
- 5 Speed SC300 Starter Removal
- OOOPPPSSS....... Got a boo boo. Need some advice!!
- Lexus SC300 brakes, need help please.
- Ever wanted to build your own harness?
- help with my scary ride.
- SC300 Power Steering Pump Screen
- Air vent
- LED Upgrades!
- Brakes Update & Resource
- leds at the fog light
- Lexus Sc300 Power Steering & Heater Failure! Please Help..
- Help with 1JZ Sc300 fuse box connectors
- battery light comes on and off. rectifier? part# needed 96 sc400
- 92 sc300 suspension question
- Need speedo and tach help
- Foreigner thread ,post your ride
- Where to buy Sub engine harness (sc400)
- Bolt size question
- 1jzgte rebuild question.
- Oem black interior question
- No Spark at Ignition Coil
- type of coolents to use or can use on a sc400
- coil options
- Fabricated Skid Plates for our cars?
- SC300 rear knuckle bushing out
- Dash light issue
- want to remove gated shifter from 98 SC3
- New to club Lexus
- SC 400 park lights in rear only doesn't work help!!?
- vvti in a 1992 sc400
- 1UZ problems.
- My SC400 -HEATER AND AC QUIT
- Could it be my Southbend clutch setup?
- Standalone with auto transmission
- 1uz expansion tank
- 2j-ge rebuild suggestions
- odb2/inspection
- 92 sc300 speedo issue
- SC 400 Alternator Issue
- 1UZ to VVTI?
- Is the Sc4 cluster harness or body plugs identical to the Sc3/Soarer?
- few cheap upgrades
- Changed Fuel Pump Car started but now Dead again
- Sc400 owners.engine oil and transmission oil
- 2000 sc300 on eBay
- sc400 95 diagnosis port
- 1UZ header bolts.
- Help with some dash wiring please?
- Little help?
- Calling T88 users
- Built Motor vs 1JZ-GTE swap
- 1992-1997 sc400 Basic performance parts list
- Ultra Racing Tower Bars (F/R)
- 1jzgte issues
- 1UZ Crank End Table
- New Custom FSB for my 98SC430
- NA-T gurus in here please
- CD Player delete
- Battery tie down
- LCA's 1997 SC400 replace with supra LCA's?
- tensioner mark
- 94 SC400 Electrical Nightmare
- Need some helps, thought it was EGR
- JZS161 Aristo Vacuum Diagram
- Need some opinions on a tough decision..
- Will this work? 1jz harness/1jz ecu with a aristo jdm 2jzgte
- Aftermarket steering wheel
- merry xmas !!!!new member gt500tony
- Over fenders...
- Building a fuel system for 800-900hp
- mono-ball stud for lca's?
- sc400 replaced engine, ecu, cranks but wont start
- Charcoal canister mounted in the trunk?!?
- custom oil filler cap?
- 1150 whp SC400
- Issue Starting Car
- Rebuild calipers
- 97+ bushings on supra lca?
- Pcv valve hose
- Project Snail's Pace
- Trans problem wont stay in first gear!!!!!!!!!!
- Torque Converter 3800 stall speed
- Quick Question about the Parking Brake
- SC400 - Trivial question
- My SC400 - Coolant Reservoir
- My SC400 - Door Hinge
- Seat brackets
- Driver door will not open INSIDE or OUTSIDE
- changing backlight bulbs with led bulbs
- speaker issue help
- Belt tensioner help
- Finally - I'm back to ClubLexus
- PROBLEMS AFTER STARTER REPLACEMENT - uncontrollable idle
- Drive/Serpentine Belt Tensioner
- ac compressor bypass
- Aftermarket alarm guys (Need Help)
- Bolts for automatic 1jz gte Flexplate?
- Had to say bye bye to SC400
- sc300 or sc400 front bumper?
- looking for origin parts supplier
- SC400 rear twitch?
- Oil leak help
- 95 sc300 ABS unit pinout
- Weird brake problem
- A Very Odd Alternator Problem
- Low RPM issue ?
- Me SexC300
- how many quarts of oil for automatic 1jz transmission?
- 2jzge Na-t No Start Problem
- Sc400 hesitates
- Interior windshield fogs up when defroster is turned on.
- 2-wire and 3-speed sensor/sender
- seized 2jzge... What to do?
- 96 Lexus sc300 fog light issue
- Door Wiring Issue
- Been researching swap wiring, thought you all might find this useful.
- how much would you pay
- Sc Fender Options
- Sc300 foglight issue
- sc exhaust question???
- sequence for 1jz coil packs?
- Sc300 stumbling issues
- SC Update
- New SC owner need to work out some bugs
- Rear subframe bushings - has anyone replaced? (pic)
- stripped some bolts on my 1jz, what can i use?
- Auto Trans Shift Kit...
- Driver seat issue
- r154 swap rhd pedals in lhd sc
- 92 5spd slow build
- what DIY write up do you want?
- W58; can hear the synchros, huh?
- Rear coolant leak. Heater valve?
- Rear Differential mounting bolts
- Front Bumper Cover
- SC300 will not start, no CEL!
- eibach sportline lowering springs
- Battle Version Problems?
- No turn signals!!!!!
- final part of removing the starter
- please name part #13
- Possible battery problem?
- Rsp updated
- Good source for factory manuals?
- Wiring cam & crank sensor
- How to make tacho meter work?
- Upper Rear window brake light?
- Ultimate Hyperblink Fix for 97+ Tail Retro
- Thinking of twin turbo!
- some 1jz swap questions...
- car window wont close!
- Will Supra front sway bar end links fit the SC?
- Greddy MX Axle Back not fitting on sc400
- Maybe have a failed water pump
- SC400 Headunit Interchangeability
- SC400 Projector Headlights ? ebay ?
- 92 sc400 engine replacement questions & advice, not found through searching!
- My first sc build
- help! shifter button broke
- what do you think about the Ebay "Euro" tail lights?
- Sc400 Camber Kit
- Gas Cap Question...
- 2002 SC 430 Sometimes Goes Dead
- Help!!! 1jz backfire issues!
- popularity of e85 in the states
- R154 Rebuild (Opinions Valued)
- 326 power coilover need review about them
- Was I the only SC at the Paul Walker memorial/crash site?
- Rear view mirror
- Will a mk4 Midpipe bolt into stock sc300 exhaust system?
- Trying to choose 1
- Which trans to choose?
- seat brackets (trd aftermarket)
- Car will not start.. Is it the starter?
- 92 sc400 starter DIY - suggestions, hints, extras
- gas smell in oil cap? 1jz
- does a soarer 1jz downpipe match with a stock sc300 midpipe?
- Looking for quality and clean pictures of a turbo SC
- sc400 sputters, please help
- VVTI turbo swap...dumb wiring question, I'm gonna ask it anyway
- SC300 Heater Air Flow Display Fogged
- SC300 Wireless Remote Key
- max to mill vvti head
- SC300 Heated Seats
- sc400 power steering resivor in sc with 1jz?
- Wheels
- 97 manual ecu problem
- its -10F outside, heater issues!
- Is a 2JZ VVTI considerably stronger than a 1JZ VVTI on the butt dyno?
- Why does factory ECU lean in high gears/speeds?
- W58 acting odd
- Problem with seat reclining
- Reading knock PCM?
- Cosmis Racing Wheels
- Sc300 or 400?
- My daughter got her SC painted
- Need help with wheels for my vertex wide body SC!
- Tanabe NF210's on SC400
- PCV Valve between valve cover and intake manifold
- Power steering valve(?) questions
- Rear deck
- Project: Bertha--The SC400 Winter Beater
- Crank, no start, code 12
- Good God... I need emissions help please!!!
- Rough idle - code 27
- what cluster do you have on you sc
- Active SC
- Starter click
- DDM Tuning order options
- Help with ls400 brake swap
- Replacing the windshield cleaning fluid hose on 1994 sc400
- DIY for SC Cluster & Needles
- palomo 1jz sc
- 98 SC300-Dayco Part 89055 Belt Tensioner
