- Replaceing Gear box bushing in 5 speed?
- Upholstery in SoCal
- Is 2jz crank forged or cast
- Fujitsubo Legalis R on eBay for $650 shipped
- Power steering question per the pressure side
- Planning on goin single..
- Question about driftmotion
- PICTURES!: rep your city!
- Who carries sc400 p/s rebuild kits?
- What do you guys think??
- Help Installing a new clutch on my sc300!
- Can't find ECU
- No revese or nuetral gears
- Car is driving me nuts HELP!!!!!
- Where you get SC 400 Caliper bolts in Toronto?
- Parking Light Diode?
- 1994 SC300 with random stalling; fuel pump ECU?
- have a question
- 1uz to 2jz?
- a/c compressor
- 671 blown methanol Soarer
- Just Hit 200k
- Trans test port thread diameter? (trans guage install)
- Need Help with Fan Issue
- Has any1 with a 5speed installed a automatic cluster?
- Electorcial
- Oil Feed line question
- Advise wanted for my n/a build
- question about 1jz vvti into pre vvti sc300
- sc400 Tuning question
- wheels ??
- CL meet Debora, 97 SC3 project.
- Will these water pumps work
- Electronic and Cable Trans
- These parts are expensive!!!
- Wheel Poll: Need your opinions!
- Coolant leak...what to do
- Distributor Question
- new rims/wheels...criticize
- new to the 2jz sc3 world.
- sc400 oil change info
- replacement needles
- What differences are there between 92 & 94 2jz
- Kaizen motorsports e85 742 rwhp 2jz-gte v160 sc300
- Everyone likes pics!
- Some quick eyelids i made
- Auto>5spd. guys.... how did you remove the "p,n,r,d" off your cluster?
- Just installed S2000 AP1 wheels on my SC4, where's Celine Dion?
- Which Rear Bumper Lip Flows Best With 97+ Skirts?
- 1uzf noise screaming
- Stand alone for sc300 2jz with 1jz head.
- I think i screwed up my distributor timing. help
- Power steering fluid or atf
- New pics of my Soarer.
- help! car wont start
- Sc300 pics and also randomness... Enjoy!
- Alternator light on at idle/over 3000 rpm??
- 95 sc400 swapping the steering wheel.. will this affect pass airbag?
- Center wood trim removal HELP!
- Intake hoses , part number COST??
- Date code 3/93 ecu
- Virginia 5 speed sc300 trying to pass CA smog!
- 2jzgte swap
- SC300 5speedl Cluster swap
- Can you swap your seat heater into a new seat?
- Exhaust questoin. (new to site)
- Daigo Saito 200+ kmh drift (soarer inside)
- Manual transmission temperature
- SC300 heavy doors?
- need some maintenance help
- Just installed new trans mount sc400
- Part number for tail lamp failure sensor.
- Hey I'm new and got questions and stuff. 92-00 SC400
- auto tt diff questions
- FS and WTB posts go in the classified forums only
- Head Gasket
- replacing rear rotors
- W58 Tripod Shifter Extension
- FINALLY!!! My new 1999 SC 400
- Noob gearing question
- What clutch for NA-T W58?
- Supporting mods for turbo upgrade
- DIY - Remaking your 92-94 Tail Lights
- clarification quest?
- confusion about my sc400
- performance parts sites
- How does it feel..
- 5 speed transmission swap in NJ/NY area
- Valve Cover Badge
- Which intercooler and piping for JDM 2jzgte swap?
- how much to refill ac ... r12
- Adjust eccentric bolts
- key code location
- 93 sc300(auto) issues
- any lexus tech care to help me with price quote?
- wtb oem amp
- Check Eng. and Trac Off Lights on... Help?
- Two tone pink SC I spotted
- Black Interior swap question
- Grrrrr I'm so mad - need advice
- Vent Removal Help
- factory amp
- power steering quick solution
- Engine stand bolts for a 2jz?
- I bought a SC400
- Wont advise people using lextech's service...
- New to the SC club
- first time under the dc, now got some questions
- Flip out keys?
- (UPDATE!!) put the new rear bumper on today and redid my tail lights.
- another dirty car photo shoot lol
- sc300 99 remote battery
- Problem with ignition i think... please
- Took my rims off, back to factory (pics)
- CEL, ...low idle, ...horrible mileage! HELP!
- Advice on new remote key for sc400 1992
- spacers and stock wheels
- JDM 2JZGTE guys... what downpipe are you using?
- headers for supra 2jz on sc300?
- Compressor installed Brrr
- Blinking A/C light - only at night
- A/C needs to be replaced, what should I do?
- dimming wire for gauge install
- Car wont start! Need help ASAP!!!
- SC300 midpipe question
- subwoofer amp
- Which should I go?? Na-t vs 2jzgte swap
- Header Bolts
- headlight bulb question... ??
- Temp gauge not working. Suggestions?
- single turbo questions.
- Water Leaking On Driver's Side.....HELP!
- started on the paint project today.....pic inside!
- Pic request SC with gold advan rg-d wheels
- NA-T guys? step inside. oil line related
- How plug and play would it be to swap a na-t in my sc400?
- A Little Driving fun
- sc owners in Southwest Louisiana
- exhaust system loudness
- CA Smog Assisntance CAP, VRRRM programs
- Finally going single turbo on my 1Jz!!!
- rare to see,what do You think Guys ?
- 1JZ A340E Wiring
- Definitive SC400 Header Question
- Nak drivers side door speaker
- My fix for cluster needles
- SC400 Suspension
- SC400 Suspension
- RPM doesnt work after 2jzgte swap
- Kennesaw State University Kappas Host Car Show
- Squealing noise from the engine bay when accelerating?
- Loud squeal AFTER serpentine belt change
- AC Compressor suction/discharge plate removal
- 1.5JZ Power loss-Bad Clutch or Bad Turbo?
- Question with EGR delete
- Shift Lock Override Cover
- Help with jdm 2jzge swap
- Sc stories
- Just got a 99 SC300
- So my AC..
- Rolling Shots of the SC600
- Pictures: what was the previous owner doing to my headlights?
- How do I fix this?
- Rebuilt r154 or buy another r154?
- Any 97-00 owners: picture/location of OEM fog lamp switch?
- Got two question for you guys
- Mounting bolts for 97-00 SC fog lamps?
- Daizen control arm bushings, anyone kno?
- Who's SC is this?
- 94 SC300 idle issues
- carbon fiber fun
- cont' 1996 LEXUS SC400 JM LEXUS INSPECTION REPORT!!! WOW
- Oil Leaking from Valve cover?
- SC400 45K miles for $6000 should i buy?
- Calling all lowered/slammed/Vertex Ridge riders
- No power steering:-(
- standard audio system
- Is300 rear caliper fitment, yes or no on Sc's?
- My AEM came in today
- so heres a few pictures of progress.
- Need Buying Advice
- confused as a gremlin at midnight in a grocery store built over a pool
- SC300/400 owners ... are you still buying premium gas for your car?
- HOw to become a vendor or be authorizes for group buys
- oil pan pain
- egr and maf questions
- New to me 92 SC400
- SC300 GTE or Supra
- Alternator Connector
- headliner removal?
- strange radio behavior
- cd player wiring
- Broken CD and Tape player
- Double Din setup?
- Continuous beeping
- What plugs/wires?
- gte swap
- Lowered on nf210's & seems high in front w/ pics
- 1996 lexus sc400
- Wheel spacers question(s) :)
- A/C Vent trouble and dash
- Date with Smog Check
- Both headlights, at the same time??
- Oh Snap...that looks Japanese!! Let me grab my camera for a quick Shoot...
- Is tranny fluid change necessary? If so which?
- Possible new SC, buy at 90-100k?
- Sc/Soarer Awd??
- mini photoshoot
- Stupid Texas Heat!!!!!
- problem with rim center cap
- Dead Instrument Cluster
- Transmission questions
- Ecu questions.
- SC Interior......
- Help me out
- Best(cheapest) Place to get the vertex front bumper?
- Which lowering springs for Supra Shocks
- 95 sc400 driverside headlight plug has no power
- SMH 1 W58 Distroyed!! That didnt take long...
- My 2jzgte swap
- i dont know it its the starter or.....?
- which single turbo is the best to swap with the stock twin turbos in a 1jz-gte?
- spacer for flush fitment? 18x8 (+49 offset) 18x9 (+49 offset)
- My SC400 Daily/Drift machine
- cooling sytem problem
- 3A seat bracket questions
- Coilover instalation problem (UCA)
- SC300 5speed Clutch questions..
- 92 sc300 electrical problem
- Outter tie rods
- New Battery?
- Need help with rims & tire size
- Es300 cluster needle on sc300
- Cant find hesitation source help!!!
- New Ground Points (little update)
- 1997 SC300 2JZ-GTE current swap step by step
- anyone else tweaked body after hitting pothole?
- Five Axis S5f...what's your opinion?
- gte swap and camry throttle cable ??
- Door actuator wire colors
- SC300 D2S MINI retrofit
- Sc300 fan blower stopped working!!
- CEL help needed
- Head Light Restore [Lots Of Pics]
- Radiator help??
- 1uzfeswapkit.com
- Igniter wire question, please help (Lexus sc 300)
- Sighting: Downtown Atlanta SC
- HELP with coolant leak
- a little sc gathering
