- Need help with a #%@$#% stripped Ichiba spacer nut
- sc300 and sc400 rear brakes the same?
- How does the SC / Soarer do on the track? (not 1/4 mile)
- SC Exhaust Thread
- 1.5jz project update turbo aquired
- About to do a tune, what else should I get?
- 1999 SC300 transmission code clarification
- Exhaust System?
- Skirts and rear lip finally fitted
- so my bumper and light project is done
- ehaust?
- Clean your IACV - Idle Air Control Valve
- Anyone ever try Fix It Pro by Simoniz? *As Seen On Tv*
- GS300 2JZ comared to SC300 2JZ
- Picked up some Axis Milanos... Tire Size Suggesions?
- bushings for rear suspesion?
- Bad missing, stalling, smoke Oh My!
- Intercooler install
- Time for a stupid question!
- Post some pics up! Where did you mount your ballast?
- headlights broken
- aftermarket front end bras
- hks exhaust
- v160 swap
- Failed NOx emissions 4 times!
- tranny question
- Fuel pump problem on '92 SC400
- Strut Bellows
- sc400/2jzgte wiring diagram
- Slaming an SC and Fender Liners
- 1995 SC400 motor mount part #
- If its not one thing its another
- Intercooler help.
- Soarer Shifter Extension question
- what's the best lock lugs recommend?
- Oil Level Question
- Introduction: Fire Tips
- Some upgrades in the works....
- Fuel Pressue Regulator
- So the gas filter is rusted on the line..what to do?
- SC300 restoration thread - pics
- were is the telescopic motor????
- Thank You Club Lexus for DIY Threads!
- show ur WIDE BODY n RIMS
- Thinkin of painting headlights and tails
- Time to say good bye.
- My 1st Lex...'99 SC400 (56k oh noes...)
- Lower control arm question
- Anyone want to trade cars for a day? LOL
- speedo needle dark or on the way out
- How do you pronounce soarer???
- son of a beech!
- what is the size of the lock nuts should be for SC3?
- 1JZ... 2JZ... Jay-Z ... huh?
- uneven after coilover install?
- Turn the key and the entire car goes dead.
- A/C Leak (Freaking Somewhere)
- Gated Shifter questions
- Stock headlight delining
- opinions?
- w58 vs r154?
- clutch pedal broke= no car for days
- How do I remove my rear seats? and subwoofer question
- supra tein HA's do not fit sc300
- How much does it cost to fix an oil leak?
- wat is the best exhaust for 1uze
- which color?
- Christmas came LAAAAATTEEEEE
- Rust in the Radiator?
- Drivers Seat Broken
- Thread with all LED replacement bulbs listed for SC 300?
- car over heats
- strange sounds from tranny:(
- Spotted a 1995-96 Turbo SC300 in CO
- Cleaned up the headlights on my kids 94 SC4
- Lexus 202 help
- side view mirror
- Please help A/C problems. URGENT.
- Bad Screws on Bumper!
- do gs brakes fit?
- Some pics before the Overhaul
- Will this size fit?
- Ooooooops!!!!
- My aristo/Sc300 base dyno
- I've been busy.. ok my wallet's been busy.
- Help me make this look better>>new rims
- LSD ?'s
- I finally fixed my hyperblink AND my check brake light
- Seating Bracket Woes
- Need to know what My SC's Worth!!!
- Hard Top SC
- ...and then there were 3 (Picked up a SC400)
- No Overdrive, No codes, No redline
- How to replace rubber door boot
- Not sure if I should replace the rear strut mounts?
- 98 Quicksilver SC400 replaced this 92 Imperial Jade Mica SC400
- 2jz no s#!? (NWS)
- 903 Sc300
- Diversity / Soarer Antenna Fix
- pics of the sc getting a bath with the new lip
- Setting the timing on a 1999 SC300??
- car smells lean...
- Aftermarket HU DIVERSITY ANTENNA fix?
- Performance Problem
- Key will not come out
- Pics of my uncles SC...he's selling it btw...
- 1jz blow off valve help needed
- Just got new rims on the SC <<<<
- What could this problem be?
- Few Pics of the only SC3GTE in Idaho..
- audiophiles!!! question about component speakers
- Sold My Sc300!
- mounted on my new wheels and washed! 56k nono
- Help... Master Key Question
- Air Bag light on!
- telescopic motor ????
- Rebuilding AC Climate Control Unit for 1992 SC300
- Washed her up today!!
- Black Chroming
- Pics of My recently acquired SC
- Took some pics of jaza!
- Soarer 1jz swap in sc300?
- Recharge...
- DIY- How to fix leather seat (Side Piece)
- help pls.... headlights bubbles!!!!
- SC300 2jzgte r154 Build
- Exhaust parts in...
- Actuated Exhaust cutouts
- Seatbelt question
- Auto trans not kicking down
- anyone with supra swaybars
- Pcitures of my father's car throughout 3 paint jobs.
- SAFC for a 1999 SC400 with no Cats have questions !
- worst steering and suspension ever
- Transmission Question
- RMM exhaust for GS400?
- HELP! Air Fow Meter Signal?
- A Teaser: new rims
- Stock Alarm Location?
- removing trac. comtrol & cruise
- a/c help:
- Got my snail today
- Lexus 1995 SC400
- soarer stock auto?
- SC300 Fuel Plumbing
- 92 sc400 obd code 27,29 after new cats. help
- QUICKSILVER paint job finally completed after 18.5 months!!!
- Tire Selection
- Another DIY (Carpet Removal)
- SO heres the deal with 5zigen megas
- problem with early tails on a late model SC
- anyone on the west coast have leads on a complete JDM RHD SC300 shell
- FINALLY GETTING IT DONE Going 1JZ single!
- Which BallJoint Tool to use?
- Caliper/Rotor painting basics
- Reliability
- Price range on a/c compressor replacement?
- Suspension Guru's :: Advice needed!
- Opinions needed.... Check in~!
- sc400 engine help
- Replacing turn Signal Light, help please
- Windows are not going up and down smoothly
- UGhhh No power Sputter..SC3
- where to find these L's ?
- S2K Exhaust Tips on a 97+ SC?
- Need Help--Replacing Drivers Seat Track Assy.
- Pics of my first MODS-eyeSoar
- anyone have experience with wheel repair services?
- Coolant/Radiator Problem
- Broken Trans or broken diff?
- sensor ground and chasis ground
- *PIC REQUEST* Step Lip rims on your SC
- Transmission Mount Fitment
- The Party Posse inspects the 2010 Winter Olympic site: Whistler
- Bump Stop Size?
- Looking to Repaint the Coupe need some advice !
- help with telescopic motor replacement
- Engine Issue??
- Anyone using HID's from XENONDepot?
- passenger seat issue - help
- 1995 sc400
- lower control arm ball joint
- just lost my job and now car finally acting up...WTF!
- Tire Wear Dilemma
- Rounded crank bolt, Any advice?
- need advice on sc300 auto swap
- Fuel system advice... 42r 1000cc a1000 etc.
- Did Sc300 ever get 5 spd. auto tranny?
- need help with new 20's
- New molded carpet
- My bodyshop didn't properly install my 97+ grill..
- i was very hurt last night...... (not physically)
- Engine swap for sc300, which engine?
- HI-beams restored! Wash n Wax! 56k..nah
- telescopic motor replacement???
- What's the best way to get the rear strut/springs off
- Brakes upgrade
- Raceinspired.com
- Konige's new lace wheels on black sc
- HKS T3G 1jz TT UPGRADE!!!!!!!!!
- tps and circuit
- Front brakes sticking :(
- ball joint grease and bushing grease
- Any1 know what size of spacer i need to fit supra front brake to stock 16" wheel?
- Some Vibration in steering and brake pedal
- A/C check ... do these numbers seem right?
- did mazda 3 halo gauges today
- oem tt supra springs
- got my spoiler light done!
- Head bolt torque 2jzge 1992
- Battery discharge warning lights up at low rmps
- Need a little bit of help.
- Are 98 to 2000 sc300 VVT engines improvements
- cleaned motor and now motor shaking and stalling {HELP**
- Some jumping going on and Vibration
- when you turn your blinker on does your dash light dim?
- Weird head lights turn on
- new brake rotors gets hot?
- 92sc + 97tails hyperblink problem.
- r154 question
- Picked up an sc300
- 350Z Brembo Brakes
- Need help with price on this car again.
- quick question about fogs/sidemarkers '99 SC4
- Need help 5 spd swap!!!!!
- Most Wanted Exhaust! Brand new!
- Supra to SC question
- BBK Suggestion Rotora Or Supra/LS400
- What colour to paint my calipers?
- Oh here comes the flames..
- Pictures of my last day of school..
- Climate Control
- Climate Control Issue Pllleeeeease Help
- If you cleaned your engine (1uz) and this happens....
- LS400 Caliper mounting question
- Power window problem, need help asap
- Help me ID this window part
- Where did you get that?
- someone hit my car :(
- Air Conditioning Problem
- got laid off, now my project will have to be on hold....
- Need help from camber Kings
- Engine part rattle
- cluster not workin
- Battery light on. Need help please!
- 550 cc injectors ??? please help
- what manifold are you using(2JZGTE)
- I learned a new pilot bearing trick!
- sc400 oil filter help
- New steering wheel- Do I just cut the airbag wires?
