PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. extended rear wheel studs
  2. Power Steering Problem
  3. help!
  4. 93 sc400 ignition/fuel issue
  5. Sc400 Deleted Cats
  6. Your Worst Garage Mishaps (warning graphic pictures)
  7. 92 corner lights to 97 fog
  8. CD009 350Z 6spd On 1JZ SC400
  9. SC400 cranks but won't start- have narrowed the problem, see inside
  10. 92 sc400 Garnet Peril pt2
  11. Looking at '96 SC300 & Question About Value
  12. driftmotion AEM V2 1JZ-GTE - car won't start
  13. 95 Lexus SC300 Overdrive Issue
  14. Diary of an abused SC400
  15. 92 sc300 shut off at traffic light - 12v mod still relevant?
  16. Problem with spoiler led light strip
  17. Coilover noobie NEED ADVICE
  18. Cigarette lighter doesn't work
  19. Help, No climate control
  20. RIP Loka Lee, need your help..
  21. can someone please confirm which plugs to extend
  22. What did I get myself into🔧
  23. supra lca
  24. supra lca
  25. 92 sc400 shift lock
  26. Did the 1992 sc300 w58 have an aluminum sandwich plate?
  27. Question on third brake light and 97+ tails
  28. Tensioner and two failed water pumps?
  29. Hood doesn't latch and lock
  30. SC300 Engine Rebuild then Turbo Time.
  31. Hazards and lighter not working.
  32. What emissions is not needed?
  33. battery dying
  34. Get new sc300 trunk?
  35. R154 question
  36. Rims/offsets
  37. Changing rearview mirror to conventional one . .
  38. Searched, no dice. Where is best place to add an additional coolant sensor
  39. sc300 93 headlight bulbs
  40. My Drift/Fun Build
  41. Self dimming mirrors
  42. 96 sc300 5sp cali ecu vs. non-cali?
  43. could the SC be one of the sources of inspiration for the LC500?
  44. '92 SC400 Drift Build
  45. Glazed Pads?
  46. Help Engine Light Code: P0300 P0304 P0306 P0307
  47. Does Anyone Know What Happened To Lextech Lighting Systems
  48. 'Streetable' SC300 Makes 9-Second Run at Rocky Mountain Race Week
  49. Help finding high beam fuse!!!
  50. Will I lose low end torque/HP?
  51. R12 and R134 same climate control unit?
  52. BigEZ 96 SC300 1.5J
  53. SC400 piggyback options
  54. CD009 Swap With JZ - Calling All Members Who Have Done It!!
  55. 96 Sc300 Gte swap
  56. r155 transmission a new solution to r154
  57. Too Chicken To Test Fuel Pump Kill Switch
  58. Keep hydro fan or replace with clutch fan from LS400
  59. JDM 2JZGTE VVTi wont start
  60. Anyone have is350 wheels on there sc300 sc400
  61. Spark Plug Troubles
  62. OBD2 Monitor Question
  63. Where is the flasher relay
  64. 1995 sc300 50/50 taillights?
  65. 1jz Sc300 Cranks but won't start!!!
  66. Caliper to wheel spoke clearance. How close is too close?
  67. License plate light PROBLEM
  68. SC400 headlights
  69. Potential Purchase of 5 speed sc
  70. 1UZ-FE engine failure
  71. 97 tails on 96 body.. HELP
  72. Any of you electrical gurus, looking for a way to activate blower on high with one
  73. What shifter is this?
  74. My 98 is in the body shop
  75. '92 SC300 resurrection
  76. Sikky LS mount
  77. Sc power window fix
  78. Interior Window Surround Removal
  79. what are safe coolent temps (while cruising)
  80. Weird problem with sc300 electrical
  81. DIY: MY take on how I made 6.5" speakers fit my rear deck
  82. lack of power need some help
  83. Who has had their AC fixed / Freon leaks. (AC FIX THREAD)
  84. No tail lights, Brake lights work
  85. Another Window Regulator Thread?
  86. '98 SC400 Power Steering Pressure Hose Parts Help
  87. 93 2jz-ge intermittent misfire under load
  88. Smog check failing at idle, third time, need some advice
  89. Stepped lip Work VSKFs
  90. 98 Lexus sc300 with 244k miles?
  91. Transmission crossmember for w58 swap on sc400?
  92. Did factory 5spd manual SC300s ever come with traction control?
  93. LS400 Center Cap
  94. 1uz w58 bellhousing lengths?
  95. SC400 Motor Mount Options?
  96. SC300- 5 speed manual(and auto) guys, post your mpg
  97. Will this set up work for daily driver (no coilovers)
  98. Power drain issue
  99. Pics of Shine Front w/ 97+ Side and Rear
  100. 93 SC400 acceleration issue
  101. I need help
  102. what is this wire for?
  103. front end suspension wheels skipping?
  104. Looking into 98 SC300..
  105. Power steering pump from a 92 to a 97?
  106. 1jzgte swap from chaser into 93 sc300 any insight
  107. Sc 300. Building
  108. Help! Crashed 97 SC300 Repairable?
  109. SC300 Harness Damage Please Help!
  110. sc400 mufflers
  111. Power Steering Died, now ABS light on?
  112. Need assistance deciding on an exhaust...
  113. TPS/ transmission issue
  114. ECU rebuild vendor in the NYC tristate area?
  115. tax time is on its way!
  116. Unused plug in steering wheel?
  117. 1JZ intake turbo tube
  118. TPS install issue. Need advice ASAP
  119. Doing a w58 swap with a 240sx master cylinder, have some fitting size questions..
  120. Advice on removing r154 output shaft oil seal
  121. Need help troublshooting
  122. Oh ****** Handle Removal
  123. Oil Pan; need some assistance
  124. Keep Sc400 or sell it
  125. Tail light condensation
  126. Sc400 Big amp alternator?
  127. E-brake barely engages, where to begin?
  128. Need some help
  129. 1JZ Sc300 CEL Wiring.
  130. SC300 Clean OEM Wiper Blade Upgrade
  131. 1JZ grime!!! (camshafts/head)
  132. SC400 startup problem
  133. Any ideas Ls400 BBK???
  134. JZZ30 Daily Driver Build
  135. Can I supercharge a stock 98 1uz or is it a waste of time
  136. 1992 SC400 Won't Start
  137. My SC300 isn't holding idle rpm on its own
  138. 402hp stock everything. just about
  139. viper 5706v alarm install
  140. SC300 Clutch Replacement
  141. Show us your intercooler (pic thread)
  142. Mysterious relayed harness, pics inside *1UZFE*
  143. Easiest performance upgrade?
  144. SC300 1jz auto spark/no fuel
  145. Buying sc300 salvaged?
  146. Factory radio Tape deck inop
  147. My first SC, Needing Some Help
  148. Help! Starting a project SC400
  149. Rebuild my motor or another?
  150. Injector issues???????
  151. Power steering assist delete
  152. fuel line crush washers
  153. map ecu vs. competition?
  154. Replacing Water pump
  155. New brake fluid 1996 SC400 any tips?
  156. SUGGESTIONS mk4 TT shock/spring
  157. 1JZ Afr all over the place.
  158. Blown Head gasket!
  159. Bubbling water sound behind my dash board
  160. Need help pricing
  161. simplicity is the ultimate sophistication "Build"
  162. How do I get this off?
  163. Tire Size?
  164. XS Power Turbo Kit Review
  165. A Pillar Trim Removal
  166. ECU capacitors leaking 89661-24313
  167. Difference between front springs, MKIV vs SC
  168. Rap Cap/Radiator Gunk
  169. SC400 Recommendations
  170. Exhaust sc400
  171. newbie needs help
  172. Connecting rods sc400
  173. what you think?
  174. SC400 V8 LHS LCA bush damage, replacement suggestions?
  175. AutoBahn Soarer on Speedhunters
  176. Wacky startup idle w/ video
  177. Sc300 wiring
  178. New Wheels = Bottom out
  179. 98 SC400 Emblems template
  180. I'm back.... back again...again....and again
  181. Should I go back to the SC?
  182. input on my setup?
  183. The Deadpool SC
  184. Any common places to buy tires?
  185. What Alternator upgrade to chose? 250, 200, 150 amp?
  186. Which Intercooler? 800-900hp
  187. 95 Sc300 Na-t MAF AEM FIC MAP
  188. Oil Leak :(
  189. Does anybody have the paint code for the 1993 red SC's?
  190. What am I missing? Robbed ECU from one car to another won't start
  191. Resonator or muffler delete?
  192. 93 sc300 ge idling at 1100rpm?
  193. Parallel ECU's - 1JZ VVTi and 1UZ
  194. 495 Performance '93 Lexus SC400
  195. NA-T Guys - Brian Crower 2JZ-GE Non VVTi Camshafts
  196. Misfire help!!!???
  197. Wire Tuck, ABS Delete & Engine Bay Painting Questions!
  198. Climate LCD backlight fix generic bulb
  199. VVTI NA Throttle issue
  200. Rear brake rotors
  201. Lower Control Arms Question
  202. Question regarding how an SC300 engine temp gauge receives its signal
  203. Revive Boring SC Thread
  204. HVAC stopped working!!!
  205. E Brake Question
  206. sc300 ZealFunction coil overs rebuild
  207. Project SC4 spark issues
  208. Seibon hood window washer fluid sprayers
  209. Brakes for a 2000 SC300
  210. Need help on which part to order online
  211. 92 SC 400, Temp gauge "HOT", w/ check eng. light
  212. 2jzgte Having trouble boosting
  213. sc300 LED Needle diy
  214. 1998 sc400 to 350hp/400 tq
  215. stock ecu tune
  216. Lower control arm Bushings, where can I buy them
  217. Urgent help needed with TPS!!
  218. Pics Of Gold SC's w/ Rims
  219. Drive shaft parts question
  220. Aristo Ecu difference?
  221. Front Lip Splitter
  222. install Wideband in EGR pipe?
  223. Telescope wheel
  224. R154 VSS Marlin Crawler Sensor Issue
  225. Rear Suspension Strut Rod Measurement NEEDED
  226. trunk strut bolt/stay
  227. AEM V2 auto transmission burnout questions....
  228. Need help!!
  229. Top speed Pro 1 exhaust installed!
  230. Need help sc acting up
  231. Gte ecu swap transmission options?
  232. Need a new intake set up.
  233. How to remove wheel hop?
  234. blower fan speed increases with throttle position.
  235. Possibly trans solenoids?
  236. Cant open door, solved!
  237. Who repairs 12discs Changers? Found a great guy who rebuilds original speakers
  238. Got a new SC! (Well kinda)
  239. Project PMS (Poor Man's Supra)
  240. 94 sc400 restore need motor advice quality motor advice
  241. Supra sc300 na-t
  242. needle light issue discovered????
  243. After Some Info On My Headunit.
  244. LSD install: pinion gear removal necessary?
  245. 1992 Lexus LS400 Check Engine will not flash when pin the TLC
  246. How to "disable" antenna?
  247. Fitting wheels on ls400 brake calipers
  248. 95 not shifting into 4th!!
  249. Tein SS VS CXRacing Coilovers
  250. camshaft sensors
