PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Which diffs fit an sc300
  2. SC300 odometer flashes
  3. Check engine light
  4. Loss of power
  5. Looking for another silly part
  6. 97 SC300 2JZ-GTE R154 Swapped Worth?
  7. Looking 4 BLITZ NUR-SPEC R on SC300
  8. Need help with rims!
  9. Check Engine Light only on below 4k rpm, wont flash
  10. Manual transmission swap
  11. Repair Manual
  12. Engine Code 28 Coming on and off
  13. Jay Emm On Cars reviews an early series UZZ30 (V8) Soarer
  14. Loose wire going into ECM
  15. 8K for this SC300? video walkaround included.
  16. Why does everyone manual swap?
  17. 2jz ge into a 700hp beast ?
  18. NRG hub/quickrelease
  19. Soarer fan shroud on 93 sc300
  20. SC400, Lost Torque from Exhaust
  21. Soarer antenna?
  22. SC300/Supra MKIV muffler on Soarer?
  23. Weird sludge/grease build up at the bottom of the windshield washer reservoir?
  24. When I let off the gas above 20-30 mph it bucks
  25. Rear end jerks to the right ?
  26. Do I need an aftermarket ECU?
  27. Gauge cluster help
  28. 1992 turbo prep
  29. 95 SC400 Cranks. Won’t Start. Help Please.
  30. R12 to R134a (SC300/400)
  31. Washer/clip for rear upper arms
  32. 1997 sc a/c
  33. Coolant change help
  34. water, oil, electric, cluster gauge pods
  35. Best 12 disk CD changer cassette replacement option
  36. Quick struts
  37. Sc400 electric issue ABS light
  38. Lock Issues = Rekeying
  39. Awesome old time Hot Rod show
  40. 2jz ge head swap to 1jz gte
  41. 1992 SC Transmission Pan
  42. Sc400 not turning on at all
  43. SC300/Soarer Radiator Grill
  44. Overheating?
  45. Engine misfiring
  46. My 14yo son’s first car
  47. Any roof rack for a SC?
  48. Sc300 1992 help
  49. Should I reprogram ECU if I have straight exhaust now?
  50. New Stereo
  51. ecu problem?
  52. Soarer dash/cluster in SC
  53. SC400 : How Do You Remove the Power Steering Pressure Hose?
  54. What is the large slot on the dash, next to the head unit for?
  55. AMG Monoblock Lug Nuts
  56. 1991 era review of the Soarer 4.0GT Limited and 2.5GT on track (VERY 90's atmosphere)
  57. Parasitic draw
  58. Cool Flagship Soarer Video
  59. 1995 sc300
  60. sc300 ecu problem
  61. 95 I believe
  62. SC400 Coilover spring and dampening rates
  63. Starts strong, no idle (code 15)
  64. Engine dies immediately after starting after I changed the alternator
  65. 1UZ-FE 92' SC 400 NO SPARK and not turning on after changing (almost) EVERYTHING.
  66. Gauge cluster Non functional When hot
  67. SC400 Wheel fitment
  68. Center cat delete = back fire?
  69. TRYING to install IS300 fans
  70. R.I.P. coach Hassan, good man and great friend
  71. Ac Clutch engages and Disengages
  72. “Driver’s Seat” vintage 1992 review of the Lexus SC400 Canadian model
  73. My car is idling weird
  74. One single clunk...
  75. Hydraulic Motor Valve 16929-50050
  76. Another EPR Post
  77. Can a bad ecu cause knock sensors to “burn out”
  78. SC exhaust muffler pipe replacement
  79. Losing brake pressure but no leak
  80. Wire tucks and bay clean ups
  81. Knock sensors and coolant sensor wiring ripped out by mad tech
  82. Airbag Light Not Working
  83. Need part #
  84. 1995 Sc400 Power Steering Pump bearing
  85. Issues after replacing steering wheel in '95 SC300
  86. Am2
  87. Phone and First Aid Kit
  88. Does anyone know anything about this body kit?
  89. O2 sensor code coming back
  90. 98+ Radio Removal
  91. Thinking about purchasing an imported JDM Soarer...
  92. Looking for help: Keyless entry
  93. 98+ Valve Cover Gasket Replacement
  94. BC Coil Srping rates and it's length
  95. 97 black on black with the 5sp swap I bought the car from a friend of mine
  96. SC400 fuel pump issues… I think
  97. MAPECU3 question
  98. Center cat delete
  99. Headliner + Sunroof Replacement
  100. 1993 SC400 Heavy Body Wobble - Differential?
  101. 1993 SC400 Driveshaft U Joint
  102. Covid help with sc400
  103. 95 sc400 metallic clank on startup! Please help
  104. Rear Seat Belt Buckle Bezels
  105. Trouble finding brake Booster 1st gen
  106. ECU Testing, intermittent crank no start
  107. Just bought a 1994 Lexus sc400
  108. Who sells new headlights?
  109. Mystery screw found in my automatic transmission pan.
  110. Progress update on father son (SC)300
  111. Weird hesitation
  112. Need some Advice on SC Purchase
  113. sc 400 security system issue
  114. lexus or soarer?
  115. 1995 sc400
  116. How important is preloading w lca
  117. SC300/400 rear bumper differences?
  118. Steering Rack EVO replacement
  119. Super weird idle problem, please help
  120. Washer fluid level sensor grommet leaking.
  121. Timing questions
  122. Cannot find source of Misfire
  123. Kingskii's 95 SC400 Journey
  124. 2JZ-GE to 1JZ-GTE non-VVTI
  125. Magic's 1998 SC300 Grand Tourer Project!
  126. Which Shocks for 94 SC300?
  127. 1993 400 faster then 1995?
  128. Best Radiator replacement SC400
  129. Trying to 3D print the gas door
  130. Need help dont know why my sc400 misfires
  131. JDM 1995 Soarer WHITE_RIC3
  132. sc 300 header back exauhst
  133. KSR Racing SC3
  134. 1992 SC300, SC400 on "What To Buy" page of Car and Driver
  135. Hey guys I have a Lexus sc300 (FFIM, throttle body, fuel rail questions)
  136. Egr delete
  137. Vvti cams
  138. 97 fog light connector Variants?
  139. Question About Fitment and Tire Sizing
  140. OBD II Asleep?
  141. Quick question about top speed
  142. Power Steering Whine and Where to get parts
  143. 95' SC400 Trans mount bolts snapped
  144. 1jzge ecu pinout 1jzs171
  145. Misfire 97 sc300
  146. Rear window Removal , How?
  147. '92 SC400 Fuel Pump Won't Shut Off With Car
  148. 1uzfe
  149. AutoPower U-Weld in full cage? (SC300/400)
  150. Gate shifter wire diagram
  151. SC300/400 Compass Options? (OEM GS or IS Rearview mirror swap and aftermarket)
  152. No Brake Lights (94 Lexus SC400)
  153. 1993 SC400 purchase opp
  154. Cleaning an ABS sensor
  155. 1992-1994 SC300/400 Electrical Diagram TSRM
  156. Efi relay no signal power from pin 1
  157. Steering Wheel Clock spring
  158. Sc400 (1998 model flooding on startup issue)
  159. 1997 SC300 EGR valve removal
  160. Will entire center wood bezel from a 97+ bolt to a 95?
  161. Has anyone here used these AC vent gauge holders?
  162. Can I get these studs for the bumper separately?
  163. Couple of Pics from a car meet
  164. Parts????
  165. VVT-I O-Ring Replacement
  166. Rear View Mirror Post Windshield Replacement
  167. Work 3-piece wheel 2nd opinion
  168. Just got a 97 SC300 non vvti baby!
  169. Windshield washer reservoir grommets?
  170. Center stack electrical issue
  171. SC300 Question - Rubber Rocker Panel Underside Plug
  172. Aftermarket Headlight Options? 99 sc300.
  173. 95 SC300 Wipers wont turn off (harness looks ok)
  174. VVT Gear replacement
  175. 1UZ-FE safe build
  176. 1995 Sc300 new key fob registration not working
  177. New to SC. Curious about maintenance, vvti swapping, and speedo way off
  178. IAC Valve - cleaning Tip
  179. Sc400 no start situation
  180. 92' SC300 Code 24 and 31 car wont start HELP
  181. Velox Flight 18x8.5 40mm offset Fitment on Stock Brakes & SC suspension
  182. Broken ACV hose, need to pass smog
  183. Urgent
  184. Matt's White Hot 1998 SC400
  185. Someone finally uploaded the Motorweek '92 review of the 1992 Lexus SC300 5-speed M/T
  186. VSV supply line location
  187. Did SC 400 manual Swap & Speedo is not working
  188. 92 300 5spd Build
  189. Aftermarket Seat configuration for tall driver (already have supra seats)
  190. hero SC
  191. Help Finding Screw Specs for Dash Bracket/Shift Bezel
  192. Shifting delay at wot. Is this a normal thing for sc?
  193. Wot shift from fist to second delay
  194. w50 bellhousing options
  195. Mandatory 1992- 2000 SC400 Engine ECU Electrolytic Capacitor Replacement
  196. TIme attack sc400
  197. Lexus SC400t LC inspired bodykit
  198. Starting Issues
  199. Window Rail Part Name
  200. 1999 SC 400 Manual Swap
  201. For aerodynamics which year front end is best?
  202. 199 sc300 wire colors and what they do
  203. Ebay lists 87 Supras, zero sc300/400 .....HUH?
  204. Creegan’s Green Goblin - 800whp or bust
  205. Sc400 import exhaust
  206. 1992 sc400 Wiper Control Stalk
  207. Web site
  208. 1998 Lexus SC400 engine bay bolt sizes
  209. '96 SC400 - AC light flashing after battery change
  210. Emissions/Check Engine Light Help
  211. The legitimacy of Sideways Performance
  212. Why is the SC400 heavier than SC300?
  213. 1995 Sc300 bogs and pops trying to accelerate.
  214. What type/grade bolts/nuts/washer to use with these lower aftermarket arms
  215. 1jz ac and power steering delete
  216. Hello everyone!
  217. Sc400 Amp
  218. Need help with some body lines
  219. New owner 97 MT SC300
  220. 2000 sc300 power steering .
  221. DIY LED Tail Light Kit
  222. 2000 SC300 differential / axle question
  223. rear diff questions
  224. Transmission / Differential Fluid - Brass parts?
  225. Exhaust diagram and system
  226. Anyone use FDF Rear Multilink kit?
  227. 800HP+ E85 2jz lets do this together
  228. Loud THUNK noise from rear end
  229. Spark plugs
  230. Proper differential choice
  231. 92 SC400 5spd Viper Woes
  232. cooling issue need help
  233. 92 SC400 Stalling while Stopping
  234. What spoiler is this??
  235. 1992 SC300 TMC Plant?
  236. Frame repair and Engine overhaul
  237. Sound System messed up
  238. 98 SC400 Transmission Sluggish Initially.
  239. Should I get an SC300 or an IS300?
  240. 93 SC400 Electrical Issues!!! Dash flashes/ wipers go randomly!!
  241. sunroof loose & humming noise(1998 sc400)
  242. Supra Tein Coilovers
  243. 1992 Center Caps for 10 spoke wheel - Searched and couldnt find info
  244. 1998 SC400 Radiator upgrade
  245. 97-2000 Rear Bumper Extensions (right and left) sides
  246. 92 sc300 hub bore size
  247. For sale threads belong in marketplace
  248. Leatherseats.com. vs Ridies/Interior Innovations
  249. Front Lower Control Arm-'95 SC400
  250. Funky noise from the window switch
