PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. "92 SC400 Passenger seat
  2. Which wire is + and -
  3. Car comments
  4. Help installing a hks fcd in a 1jz with a safc2
  5. 1jz auto transmission won't go in to OD
  6. Parasite Battery Drain
  7. gone for a while... this what i came back with
  8. 1JZGTE SC300 Dr.Tweek wiring into SC400
  9. Aftermarket amp with original wiring ?
  10. What did you do to buy your sc parts for your build
  11. help.how to install a aftermarket amp and sub into sc300
  12. Sc300/SC400 owners in Orlando!!!
  13. Need Advice on How to Buy Used SC400!
  14. quantum auto spacer on w58, measurement for shims?
  15. SC400 Automatic transmission change?
  16. One problem after another it seems like.. Bogging after a couple min from start...
  17. auto transmission noise bearing?
  18. Selling SC: return to stock?
  19. Roll my fenders or pull my fenders???
  20. Boost leak, or....
  21. wing on wingless car
  22. Tranny question
  23. A/C Questions...Plz Help!
  24. SC400 - quick crank pulley question
  25. how would these look on an sc?
  26. Auto TT lsd rebuild?
  27. Might have found my ac issue
  28. updated pics of levie's soarer
  29. Need your help:)
  30. Center Support Bearing Specs
  31. SC300 stereo system and interior rebuild
  32. Evap Canister routing?
  33. Transmission problem??
  34. Transmission problem??
  35. Mystery Fog fuse
  36. Wiring harness removal questions?
  37. a/c for sc300 92
  38. Hood wont fully close
  39. solid diff/subframe bushing measurements
  40. My first Lexus, 1992 SC 400 : Seized Alternator
  41. where can i get chrome pillars for the doors
  42. 1uz vs. 1jz
  43. 94 SC 400 drivers door wind noise
  44. New England Car meet?
  45. NA-T Oil & Intercooler Piping Suggestions
  46. Picture Request. Spacers for SC400
  47. new cams dont require new springs?
  48. Rubbing Question..
  49. 96+ OBDII CEL Fixes after Trans Swap
  50. Please Help/ AC Clutch removal
  51. Another O. L. T. DIY - In depth with the heater core control valve
  52. Color help! *where your opinion counts!*
  53. got the windows tinted..
  54. Any SC3 SC4 Hard Top here in CL?
  55. Driftmotion AEM, anyone try?
  56. timging belt and water pump replacement price for sc400
  57. gartmaiers on a sc300
  58. which ARP head studs?
  59. Removing a tight nut on a battery terminal?
  60. price of spare key?
  61. traction control on my 92 sc300?
  62. Diff/HalfShaft/Can someone tell me what it's called please?
  63. Anybody here done their own wire harness for an aristo swap?
  64. How to Change Fog Lights?
  65. What colors go well with DWP
  66. Cannot figure out up/down idling loop
  67. 1994 SC 400 premier stereo wire diagram
  68. Awsome random pic of my SC
  69. Megan axle backs
  70. Supra LSD preparation for sc400
  71. Seat upgrade idea?
  72. trany fluid.
  73. FINALLY! A few Professional Pictures of my baby:)
  74. A/C Quick question recharge fitting and location SC400 97
  75. Tail light fuse blows
  76. Right Rear Quarter Panel Skin
  77. 92 sc400 wont start and stuck in park
  78. shop nightmare
  79. my 1st SC pics after bodywork done
  80. Ugh, Blinkers not working....
  81. My soon-to-be '93 SC300
  82. Can you swap a Cluster from a Auto in a 5speed?
  83. starter slow to disengage when cold
  84. Question on Supra Suspension Set Up
  85. Driftmotion AEM harness
  86. Need help.. regards to rack & pinion other work
  87. My SC300 [EDITED]
  88. Trying out new wheels
  89. finally some better pictures.
  90. soarer FSM!!!
  91. decision, need some guidance
  92. Telescopic Steering column 1995 SC400
  93. Tuneup #%@up!
  94. VVTI Soarer build
  95. Starter single click when "cold"... contacts?
  96. aristo tranny into sc300
  97. Has Anyone Ever Heard of These Springs?
  98. Serpentine Belt Replacement vs. Idler Pulley Replacement
  99. My 93 Sc400 w/1jz! How it started!
  100. Theres a hole in my engine
  101. My car was Spotlighted on Night-Import
  102. ZachTriggs's SC300 from Texas
  103. emblem shaving question
  104. JIC Magic Tie Rods?
  105. OK since I get ask about 15 times a day about the shifter.......
  106. Look what I found on craigslist
  107. in theory i can use these motormounts..right?
  108. lol my car just got rear ended
  109. Updated Pics of the SC400
  110. New Tires Recommendations
  111. Timing belt tensioner bracket :(
  112. Pics of my New Custom F-Sport wheels.
  113. Buzzer?
  114. SC400 A.C. delete
  115. Don't you hate teasers?
  116. help with overheating question!
  117. Power for Gauges
  118. I'm not really sure what the problem is, let's just say tranny problem.
  119. TUNE my 1jzgte!!!
  120. car overheating...heater core???
  121. Newbie to CL: Finally took pic of my SC:
  122. Steering Wheel upgrade to RX300
  123. What's this wire for?
  124. Are these the right shocks?
  125. Power Steering Hose replacement.....$64.99 from Autozone!!!
  126. 1jz auto ecu manual harness
  127. Any idea where I can a single megan lp coilover for the rear?
  128. swap compatability questions(iam not a noob)
  129. Lexus dealer service
  130. Headlights and fog lights HIDs need help
  131. Passenger Side Headlight and Fog Light Not working
  132. need help...
  133. driftmotion.com power steering hose
  134. Stripped head bolt.. help?
  135. Engine is finally starting give up?
  136. Soarer 1JZGTE 5SPD??
  137. stock stiff suspension?
  138. Throttle Body ideas and flipping upside down
  139. Check engine light on but?!?!? Cant pull codes
  140. Hydro fan leaking SC400
  141. diff problem please help
  142. Finally making some progress with my 2nd SC
  143. omg brand new molded carpet any color rhd or lhd!
  144. trd short shifter for remote mount trans
  145. wow look at this body kit..
  146. saving seat components
  147. WTB: sc300 harness and ECU
  148. ffim suggestions, where can u get one?
  149. Can't get my SC400 to run right? Help!
  150. Hydrogen injection?
  151. heated seats wiring
  152. Finally,pic of my sc300
  153. Need to know Firing Order
  154. Need help making a laundry list
  155. Importing a soarer from canada?
  156. 10-12 mpg on 92 sc300?????
  157. Mounted up some Corbeaus in the old beast
  158. mpg is terribly low still, need help !
  159. newer random pics of my SC3. low/flush/polished ;)
  160. springs
  161. Quick ?, alternator plug...
  162. Anybody done a sunroof delete ?
  163. did i just do something really dumb?
  164. sc300/4/trade/4 /240sx/s14
  165. Fuel pump fuse?
  166. Seat help?
  167. ECU question
  168. Wheel Decision time
  169. MAF dead? how do i know?
  170. My SC400
  171. Knock gauge (knocklite) installation
  172. Clutch master cylinder & hard line
  173. Bought some new SHOES for my SC400
  174. DIY manual pedal swap thread/s?
  175. 92 Climate control help
  176. pics of the sc
  177. lets talk LCA bushings
  178. Had my SSR SP1s refinished
  179. Starter Woe
  180. Duralast/Rack & Pinion
  181. disdtributer help
  182. Any Short Shifter for Soarer R154?!?!
  183. Need Clear Side Markers Turn Signals for my sc400
  184. noobie question: oil filter and fuel filter different things?
  185. What's your opinion on this aluminum coolant tank?
  186. lets talk cost n results
  187. Where did they hide the condenser ?
  188. Exhaust Opinion's
  189. 95 SC400 Timing Belt Change No Power
  190. I need some guidance guys
  191. new alum. radiator and slim fans for sc400? anyone done it?
  192. Engine compartment color? Parts?
  193. OEM Radio Unit with aftermarket speakers?
  194. getting 10 mpg and some problems with my car
  195. Where to buy 97+ control arm bushings?
  196. 92 Sc400 Cranks Ok, No Start
  197. Mirror Ecu Installation Help Needed
  198. sc400 meed help!!!!!!!!!!
  199. white cap seat fix!! it works!!
  200. hey, does anyone know how to put an aux port on an original stereo
  201. Wood trim
  202. Exhaust leak
  203. Can't pass state inspection.
  204. Bulb Light sensor
  205. new exhaust, and it seems to be getting quieter?
  206. Just changed starter still wont start
  207. SC400 exhaust idea.
  208. transmission problem
  209. 95 sc400 passenger window issue
  210. My 1995 SC400's photoshoot!!!!!(HD pics inside)
  211. Passenger Airbag Dashboard Q
  212. how to start 2jz with engine harness only??
  213. R154 & 1jz DriveShaft
  214. Anyone have any experience with Spoilersmart.com?
  215. 92 SC400 stalling issue
  216. 1jz vvti into 92 sc300 (i searched)
  217. Speedo died
  218. New and Improved Photos
  219. SC400 1UZ 113k MILES ENGINE FOR SALE IN TORRANCE, CA
  220. Help please!!
  221. I need help please!!!
  222. ATTN: How much would you pay for this SC300?
  223. sub size in the trunk?
  224. new exhuast whudgathink?
  225. What exhaust should I buy next? (Nur Specs got stolen)
  226. Opinions Needed On New Paint For My SC
  227. SC 300/400 curb weight thread ?
  228. The Unofficial NA-T Roll Call Thread - 2JZ's & 1UZ's Are Welcomed!
  229. Coilover Help
  230. nakamichi screen and button bulbs
  231. rebuilt stock motor now turbo
  232. Interior Trim on a SC430
  233. what are some of the body styles do you guys like? (pics appreciated)
  234. Best place to buy Extended wheels Studs?
  235. help with 1st gear on auto tranny issue
  236. Hey everyone! what's the best panel filter to use
  237. aristo swap in 98 sc400 (shifter question)
  238. 95' SC300. Paint Job.
  239. Well freaking fruitty doo...It's doing it again...
  240. Ac question
  241. Need help installing a HKS FCD
  242. what are you running for intercoole (sc3 1jz)
  243. Auto to 5speed clutch sensor
  244. 12 CD Changer 1993 SC300 problem
  245. Interest/Group buy for Big Win front lip....
  246. 92 SC400 front lip removal.....need help...
  247. LS400 Calipers
  248. Parting out my lexus sc400 in torrance ca
  249. Best performace without turbo?
  250. Body/Frame Shop Guide
