PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Popping, clicking noise from front end when I drop clutch at high RPM
  2. Where can I find brake caliper mounts?!?!
  3. 97+ Instrument Cluster swap to a 92 SC
  4. need sc300 bumper/trunk
  5. Ran Into A Few Problems
  6. Throttle body relocation on 2JZ-GE
  7. 97 sc300 5 speed black interior RARE RARE 92k somewhere in CA
  8. plummeting mpg
  9. 95 SC400 stuck in park, no power windows, roof, or steering Please Help
  10. Oxygen sensor questions
  11. Ordering some 5 speed conversion parts, missing anything?
  12. sc300 wont start anymore!
  13. Suspension arm overhaul
  14. Park interlock problem
  15. Installed Kenwood HD571 and get static on 2003 SC430
  16. About to be another owner of a 93 SC 400. Any pointers??
  17. Back in business!!
  18. Project Scarlett -> Slow NA-T Build"
  19. Fuel pump differences?
  20. helpp (SWAP)
  21. I am so bummed. Tranny frustrations.
  22. Are OEM Strut Mounts the only option I really have?
  23. will this injector work?
  24. Gauge cluster lights
  25. Aftermarket amplifier powering stock 5 ohm sub
  26. Need help fast.
  27. squeaky center console
  28. Intro - New owner of a 1993 SC300 78k miles
  29. picked up a shell ... guess ill start a track car
  30. Ignition switch ques.
  31. HELP!!!! My car fins fine untill put in drive or reverse!!!!
  32. The Black Mamba Build!
  33. How to make figs toe links OEM length
  34. Preferred Turbo kit?
  35. VERTEX Edition sc300
  36. So just did my coilover install and air bag light on
  37. gte 6spd swap (speedometer not working)
  38. 1JZ SC300 swap finally done needs tweaking! Help?
  39. My attempt to install mk4 lip on my sc.
  40. Issues after 5spd swap
  41. 1UZ spark plug torque?
  42. Grounding problem SC300 '92
  43. SC400 new fuel pump, ECU bypass, stranded again
  44. Need help, Cant decide.
  45. Cracked manifold worth fixing?
  46. what would you call this clip?
  47. are all transmission mounts created equal?
  48. 1992 sc300 with 95 bumper and fogs
  49. Stumped on clutch/trans issue on 2jz/r154
  50. Rear drive shaft
  51. 92 nat bogging issues
  52. tachometer problems
  53. Quickest & Fastest SC400 on DragTimes.com 11.78 @ 129
  54. '06 SC-430 Headlights
  55. SC400 Transmission Dipstick - Do I have the Wrong One?
  56. 1jz harness missing alternator plug and wires??? help asap!
  57. Big Power on a Budget: Dan's NA-T SC
  58. leather seats
  59. Supra or Aristo trans in my SC300?
  60. Climate Control Celsius readout
  61. Girls love boost
  62. SC300 1JZ Starter Problem
  63. SC430 rear 2-Pots?
  64. Thermostat question
  65. Help with AC compressor and clutch.
  66. HID Lighting Problem
  67. Boost leak/ Turbo failure?
  68. Removing resonators on Sc300? Effective for sound as on 400?
  69. Removing resonators on Sc300? Effective for sound as on 400?
  70. Buying a door panel.
  71. If you were selling this SC, what would YOU ask for it?
  72. Is this a good deal?
  73. Some pics from Another Level 2014
  74. lighting issues. please help
  75. 99 sc300 aristo swap driveshaft help needed
  76. Soarer shielded wire question
  77. Which standalone is for me?
  78. New to the forum
  79. Best Cosmetic Door trim mods?
  80. SC400 Code 25 OBD I
  81. Civic AEM V2
  82. ECU questions
  83. 17mm Bolt Above Thermostat Inner Threads Stripped Help!!!
  84. 1994 sc400 intake tube
  85. 1jz
  86. Back to Stock OR Built Drivetrain for this 1997 SC300 Original 5 speed
  87. Good source for Window Regulators?
  88. help me identify this plug
  89. Anyone know of a standard bolt-in extension piece to run a Supra MKIV exhaust?
  90. rear lip ?
  91. sc300 with 350z straight pipes
  92. FS wtt wtb go in the classifieds, not here
  93. front lower control arm camber adjustment
  94. Need experts advice on fender pulling
  95. My 98 SC300 1JZ project
  96. Anything wrong with this R154?
  97. 95' Sc300 W' 68K Miles~Slow Morph to NA/T Thread
  98. Help with 2 things. Starting issue/timing belt & water pump questions
  99. Serpentine Belt Question
  100. A.C. parts replaced after compressor failed but still not fully cold
  101. Goregeous soarer drift!
  102. Code 14 fixes? i need help!
  103. Getting out of the game ?
  104. overheating issue
  105. New brakes for my SC400 question on calipers
  106. jzx100 (chaser) into 93 sc300
  107. SC400 Trouble
  108. Cluster problem
  109. Rear Lower Control Arm Differences
  110. A/C refrigerant level
  111. Best deal on carbon fiber trunk?
  112. where is the DIY for fuel pump relacement
  113. Shaky, loss of power up hill.
  114. IS300 Fans - How to wire them
  115. just picked up my 1997 original 5 speed sc300
  116. Mechanical trouble already???
  117. Frankenstein SC300
  118. Has anyone done a full interior swap? Did you experience squeaks and rattles after?
  119. 97 SC4 Engine Idle/Whining Issue Update
  120. Interested in An SC? Nor-Cal
  121. 2JZ Dimensions?
  122. Just dropped in a gte
  123. Question on GS400 3.26 rear diff in a gte swapped auto SC...
  124. Question :O
  125. Couple midnight shots at the Gamble House in Pasadena
  126. DIY leather seat covers?
  127. Just bought my 92 sc300 180k.
  128. SC400 no power, burning, rough idle
  129. Sc400 idle problem
  130. Is there ANYTHING other than bad regulators that will stop windows from working?
  131. Strut bushings
  132. 97' SC400 Whining/Whirring from under Hood
  133. 1997 SC300 new to me PICS
  134. Ac compressor question about 2jzgte/1uzfe compatibility.
  135. 1jzgte vvti (JZS171) ECU PINOUT
  136. Anyone switching to air ride? Megan street-lp springs needed
  137. Which body kit is this ?
  138. SC570 (LS1 SC300) cammed idle.
  139. Will other 2jz valve covers work?
  140. 1997 Sc400 Ecu Pinout
  141. Am I forgetting any maintenance items?
  142. Need 97 SC300 ABS ECU Pinout.
  143. sc300 head gasket
  144. Low mileage Sc sitting in garage for 4 years. What would you do to it?
  145. Another gem: 27k orig miles - 97 SC400
  146. Anyone used Driftmotion's 1JZ aftermarket timing parts?
  147. how to remove "center pad" (ignition switch cover)?
  148. sc400 emissions problem
  149. Still got it this is the latest update
  150. 1995 SC 400 with low mileage-to keep or not to keep...
  151. Bought a new project, so I guess this is goodbye.
  152. 24 hour sale - HID's
  153. New daily - 97' SC400
  154. Map ecu 3
  155. R154 Clutch slipping?
  156. Help with Power Steering Pump
  157. headlight fitment
  158. Use factory brakes? Or another brand for 99 SC400?
  159. Looking for good replacement rear shocks for 99 Sc400
  160. IS300 steering wheel in SC300
  161. 1jz harness has extra body plugs?
  162. 1999 sc300 tune up
  163. titan motorsports cams vs gsc cams?
  164. W58 Trans issues
  165. Supra tt motor mounts
  166. Cheap injector option for turbo guys 😁
  167. lexus "spray paint"
  168. coilovers that simulate stockish feel but go low?
  169. Question about Power Steering Air Valve
  170. What oil am I leaking?! Help!
  171. how do you get door moldings off
  172. Differential options
  173. The definitive MKIV Supra SC300/400 suspension crossover thread
  174. help me with 2 things lol
  175. 1jz with 2jz-ge auto tranny?
  176. GG. It's sold.
  177. HOW TO:dual fuel pump & aftermarket gauges install
  178. Question about Floor Mats
  179. How to: Fix your door opener actuator rod lower end
  180. '93 sc300 transmission fluid
  181. Removed rear differential, I think it is making noise, is this normal?
  182. SC400 rear calipers
  183. $50 front lip
  184. rear speaker grilles
  185. Two 2jzgte swapped SC's Have A Play Date
  186. 97 fogs on a 93 sc
  187. wacky tail light parking light
  188. Lowlife's Build
  189. 2JZGE NOS Direct Port Nitrous setup coming soon! Any input?
  190. SC400 Max Fuel Pressure (help please!)
  191. Leather Repair - Results Blew Me Away!
  192. MYSTERY PROBLEM ): well maybe not..
  193. SC300 Coolant Reservoir Cap
  194. Sputtering & stalling issue... won't stay running!!!
  195. Need SS Brake Lines Installed on 97 SC400
  196. Throttle and tranny cable question for na-t swap
  197. spliced ECU wires?
  198. Sc300 front adjustable upper/lower control arms
  199. Heater control valve
  200. where to buy 1jz torque converter?
  201. Bushings!!!
  202. Well, Its been a fun ride guys.
  203. SC400 Transmission Whine in 1st Gear (A340e)
  204. Differential Fluid Change and Trans Fluid Change at the Dealer
  205. Defeating/Bypassing the Coolant Level Sensor?
  206. Code 52 Knock Sensor on 92 SC400
  207. 2000 Headlight Part Numbers
  208. lexus sc300
  209. gauge cluster removal tips?
  210. HVAC control unit help
  211. Sc600 is finally home!!!!!
  212. 1JZ custom patch harness, or just splice/solder?
  213. Aftermarket seats
  214. need lsd diff installed
  215. Airstrut bags installed
  216. No power to (stock) stereo.
  217. Who sells a full 1JZ maintenance kit?
  218. Think I found the 1JZ I will use
  219. Drag Tire Recommendations
  220. Awesome Soarer meet in Japan.
  221. I just purchased the lowest mileage 95' 300 5 speed I have ever seen. 68K
  222. New Sc Halos
  223. Hi question about buying an SC 300 Manual 1997
  224. Hi question about buying an SC 300 1997
  225. 36K mile Sc300 on Craigslist in NY 10.5K
  226. Random holes in rear interior panels
  227. Best site for selling an SC400?
  228. Thinking of buying Sc sold W' 20's. What's the 20's thread title?
  229. Red-Bull Drift in Brazil (HD) - MUST WATCH!
  230. SC300 SC400 Dashboard Differences?
  231. What's my SC300 5-speed worth?
  232. Odd brake issue
  233. My 95 SC300
  234. Does a 96 SC400 Emblem have pin holes?
  235. AEM EMS v2 Timing Problem NA-t
  236. LS430 Diff?
  237. All FS threads go in the classifieds section D:
  238. In an Sc400-W58 swap, would a manual cluster fix the OD light flashing?
  239. Alarm reset not working
  240. SC400 P/S Buzz question
  241. power window wont come up switch only makes noise help please
  242. A/C Compressor, Interchange and Bearing Info
  243. heres my 97 SC300
  244. O2 sensor resistance (cold)
  245. Electric Radiator Fan Install simplified?
  246. Looking to buy 1JZ swapped SC300
  247. Door stuck shut, at a lose...
  248. Who has prothane (or R2) control arm bushings in their car?
  249. Tranny Swap
  250. Radio compatability 1998 SC300
