- 2JZ swap
- engine swap
- wire harness in fenderwell.uhh owww
- SUPRA upper CA with camber adjustment fit sc300?
- dakota digital tach adapter? anyone else have one?
- 1998 Sc400 exhausts nd intakes
- No heat
- Pulls Strong Under WOT Until 5K - Lexus Is Stumped - Need Ideas!!!
- got some new ice.
- Lex-Fiend's TEMPORARY goodbye to SC300.
- Heater core bypass??
- jdm engine importer feedback? (good, bad, ugly?)
- My Boosted SC !!!!
- compression ratio, help!!!
- 94 SC400 Heater Control Valve?
- GTE Swap Cluster for >99 SC300
- Early birthday present... =]
- pics of my aristo swap
- decisions desicions....
- caliper question
- 1992 SC300 reverse lights stay on
- Strange noise while driving
- fuel inj cleaner?
- Front calipers worn?
- REAR brake upgrade?
- Aftermarket source for lights and bumper
- 1JZ Bypass Valve Limiting Boost? Yep!
- Question about 2000 SC 400
- Step ur light game up! Amber Alert!
- Fixing a leaking cat?
- where can I get a air flow meter?
- sc 400 running on 4 cyl HELP!
- Mobil ATF+III
- Changing oil pan gasket.
- ScNoobie need EXPERT advice on SWAPS w/ pic
- What Fuel Pump to buy for replacement? (92-SC400)
- Steering Vacuum Lines
- SC300 dies when cold
- Front LCA Helpful tip/Pesky ball joint removal
- SC300 seafoam DIY page?
- What do you (and your SC) want for Christmas?
- Belly cover
- Finally some pics of my Lexi
- Has this ever happened to you?
- which sway bars?
- motor swap ?
- my high beams suddenly arent working/...
- Car runs rough and stalls at idle after spark plug,wires,cap, and rotor change
- How do you know if your torque converter is bad?
- Hide away front tags
- power steering pump
- Blinking O/D light???
- RSX-S Seats on A SC300?!?!?
- Squeaking
- Power Steering Reservoir relocation???
- the most elusive pinout in the world?!
- Picture of my friend's SC400 - dropped on Stance coilovers with 18" Algernon wheels!
- sc300 swap
- Window wont go up 100%
- my bro's sc400 suspension question=D
- what lip is this??
- Open Headers?
- New Soarer pics...
- i cant turning on my fog lights
- where can i get a oem style fiverglass hoods?
- Finally i have some pics
- 1J runs like crap at WOT
- Qucik question about fuses
- question about origin-lab kits
- some action shots!!
- snow tires cause tramlining??
- Wind noise
- Cruise control delete??
- Gap between hood and bumper cover. Please help
- trac-delete ques.
- exhaust sounds
- wanting to turbo my sc300
- Neighborhood kids strike again :(
- What is the wheel off set on the 1992 sc 400
- Key wont come out
- 1UZFE valve covers powder coated in wrinkle black.
- Whats this thing worth not sure????
- fixing lip
- Mr2 seats
- Is this the ignition or tumbler switch???
- License plate lights
- Removal of our EGR C#$p!!!!
- Allen head size?
- Changing from a body kit back to stock (1999 SC400)
- new to the forum
- Turn my sc400 into a pickup truck
- Soarer R154 guys check in! Need quick help!
- springs...?
- Spotted sc300/400 in a music video!
- New Guy w/ Question
- SC400 Badge on an SC300
- sluggish?
- Saw an sc300/400 in a xxx clip!!
- '98 Supra motor and tranny in a '92 SC300
- SC prob..again
- Target body kits
- injen intake
- Which shifter will solve my problem?
- WTB Coilovers for SC300!
- Need your Suspension Expertise....GS300 - SC300
- Where to get M3 style spolier?
- My 94 build up!! NA-T
- Estima Steering Wheel
- Error code 29 NEED HELP!!!
- What lip should i get?
- some new sneakers..
- Florida People1
- whats the difference
- body kit id
- Any Royal Jade sc300s???
- New record lexus tony performance 8.74@162
- Looking to Buy a 96 SC400 or 94 Acura Legend 2dr
- Rebuilding my A340
- put on some new wheels. hitting my fender
- how do you fix the bleeding on our climate controls?
- RPMS go up when I turn the steering wheel
- What fluids do you all use?
- been doing a lil shopping he he :)
- Teaser pics of my madness.
- Car Hesitating
- Fire... The Aftermath *Pics*
- PICS from 11/16/08 Fort Hunt meet --703--202--301--
- Part 2: Build Results and Upgrades
- Airbag Swap ???
- downpipe fitting
- rim question again
- Anyone have pics of silver sp1s on an sc?
- if my sc300 is a 97'?
- trouble identifying an underhood part
- My window is making a strange clunking
- cams
- BFI, CEL and WOT
- Lexus SC400: WORKing overtime ;o
- OEM Lexus takeoff wheels -pics requested-
- 1jz-gte swap completed *pictures!!!*
- i got a story to tell about a los angales trip came up with some teins!
- New black carpet installed & gated shifter pix
- Help with supra control arm install...
- anyone have experience with this intake?
- stock whp
- No Cat down pipe
- Ahhh Help!!!!! Tranny swap problem
- Something crazy happened to my driver door..
- SC 400 Engine swap
- Metallic substrate cats
- For those who know how to read Smog #'s.
- After much time working on my enginebay.....no to 56
- front shocks/ struts install
- Who caters to our SC's?
- GTE swap rebuild thread into SC300
- sc300 95
- sc300 sc400
- Front Bumper Variety
- Brake issue
- Power Steering
- maxxed out stock 550cc injectors
- Gated shifter upgrade
- Veilside CI rear wing - Anyone have this?
- Please help radio going crazy!!!!
- 2jzge sc300/mkiv headers help asap!
- Electrical Ghost: alternator, ground harness, or other?!?! HELP
- price need 2 know
- Using an IS300 LSD?
- Replace lowbeam bulbs
- Idle problem, plz help
- Sputtering!!! Help!!!
- Help my batt light is on and brake light too
- Flip out keys...
- eibach pro kit springs
- what a rainy day (almost killed my car)
- The street credibility of a '95-'96 year model SC...
- finally had time to take some pics with the new kicks
- what will win?
- sc400 power steering pump removal??
- bought new climate control...weird.
- Help New Lexus Owner No Heat and Need Mechanic
- Sunroof stop working but windows work fine....
- 1JZ-GTE Single Turbo Toyota Soarer (Lexus SC300)
- Buying a 97 SC400
- Need some WHEELS advice
- ***sc4 trannys***
- tranmission on NA-T for Auto?
- 95 foglights on a 92 bumper?
- Black interior question
- teaser
- Cheap intake solution!
- Master cylinder (abs deleted)
- soarer body plugs not there
- I need help!!!!
- Blinker problem
- putting supra turbo parts in non turbo sc300
- No Heat!
- My new project... NA-T here i come
- Problems with Flexalite electric fans
- Auto X Pic
- What Supra Parts fit the SC?
- Time do decide 1jz or na-t
- 2jzgte sc300 & 400
- EGR Question...
- bye & swiss hello gs350's
- any advise
- Is this a good deal on timing belt/wp kit?
- more power
- I Need A New Gauge Cluster ??????
- wow stupid question, 2jz/1jz turbo manifolds
- Wow just test drove a sc...
- Project: 97 6-speed, SC400 supercharged 4.7L V8
- 1jz help
- Quick Question...
- Felt like taking pics
- Origin-lab trunk spoiler
- 99' sc400 pix
- 1995 SC400 Neo install help please
- ***WANTED***Upper Pillow Tops / Camber Plates
- Failed Emissions?
- Air To Water Intercoolers
- Crankshaft Pulley
- Should I be afraid of a SuperFlow dyno?
- exhuast leak help a brotha out please
- Just wanted to post pictures
- how to shut off fuel pump? HELP!
- Going Single! ohh fun... Choices
- Ebay headlights
- Help please!
- Need advice (Engine Swap ???)
- A/C unit issues continue...pics inside
- SC in Tein Green?
- pix of my sc400
- Help Crisis!!!!!
- HD photoshoot with the wife and SC (teaser pic)
- Upgrade t04b turbo
- Driving with an old battery in the trunk is a bad idea
- Air intake tube for '93 SC400?
- aftermarket steering wheel hub/wheel problems
- Washed the car and took some new photos!!!
- TRD high-flow drop in filter
- Please help.
- Thinking of Nitrous
- 2JZGTTE Coil Over Plug question
- 1998 SC300 K&N Air Filter ????
- Little photo shoot today
- What are the differences in the 3 headlight versions?
- Funny story
- Help me locate air conditioning service port (suction)
