PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Finding Nemo
  2. Headlight Switch Question 94 SC400
  3. Steering wheel shakes when I hit a bump
  4. OEM gasket on Na-t manifold
  5. Clutch kit hardware
  6. DIY: How to Make the Stock Grill Fit Over an Aftermarket Sub in your SC400
  7. Tein Coilovers, Brembo Rotors & Wilwood Calipers HELP!
  8. Wheel Opinion
  9. Should I Pull The Engine?
  10. Na-t is go...
  11. Engine Dress Up ?
  12. Front o2 sensor for aristo swap?
  13. Front LCA info - What years are interchangeable
  14. Anyone here running Megan tie rod ends w/bump steer adjustment?
  15. obd2 96+ vin question becuase i live in ca and smog check sucks
  16. Correct cabin filter for 1992 SC 400?
  17. Sc400 maf adapter questions
  18. What should I know before buying this SC400
  19. Turbo Application + DD Reliability
  20. 96-97 (obd2 non-vvti ge) sc300, obd1 non-vvti gte head, ecu?
  21. Blacking headlight housings... again
  22. New MAF?
  23. What would it take to get a spindle grille on the sc400?
  24. Passenger windown slow at night?
  25. Where can i get a female ecu connector for a 2jz
  26. 1JZ won't warm up
  27. should i buy this 95 sc300 2jzge boosted?
  28. The CD Changer...
  29. 92 sc400 lower control arm rear bolt stuck
  30. My drivers side window wont roll down!
  31. Rear Tire wear (with pictures)
  32. Slowly but surely
  33. This is why you torque...
  34. Caribbean Cruise....Soarer Camera Car
  35. Who has sc in chassis shop at wyotech?
  36. TEMS or TEIN?
  37. SC400 Gross Speedo Error
  38. Paint Job Costs DIY and PRO (moved from plasti-dipping thread)
  39. General Motor Swap Related Questions
  40. Engine Running Slightly Hot Following T-Belt Replacement
  41. 2jzgte what do I need to go single turbo
  42. modified ecu
  43. Increased valve body pressure
  44. Csm059
  45. passanger seat help!!!
  46. 1998 SC400 long tube headers fitment ?
  47. Fuel Leak
  48. Help with supercharging my SC400
  49. Best products for Full headlight restoration (sanding, clear coat etc.).
  50. RSX Seats made easy *pics*
  51. Anybody ever seen this kit before??
  52. Sc400 M2 performance mufflers
  53. fuel filter question on SC400
  54. My 1997 SC400
  55. Gated Shifter Question
  56. window switch auto button
  57. Soarer R154 questions
  58. 1JZ Intake Manifold Question!
  59. interior help!!!!!
  60. Fuel System Emergency. Please Help
  61. Interior fuse box compatibility
  62. Single Exhaust bumper cap
  63. Anyway of repairing cracked inside window seals?
  64. Ralco rz underdrive pulleys
  65. Passenger door lock problem and clock
  66. A/T dip stick
  67. DWP 92 Sc300 Na-T
  68. 10.5 wheel in the front?
  69. question on mbc and hks style wastegate
  70. Heated Supra seat idea?
  71. Finally decided to get an SC300
  72. Wheel color - Help me decide?
  73. SC300/400 Body Exterior Detail Improvement
  74. TT iacv flange size
  75. Spark plug blow out
  76. what are these wires (92 SC 400)
  77. Fuel leak?!
  78. Tt ecu on obd2 car
  79. Any new ideas for a DIY for the center vent area??
  80. My SC300 has a couple issues i want to fix
  81. 1994 sc300 code 12 RPM signal no. 1
  82. resto-driver pics
  83. Fuel pump; car wont turn over
  84. 1JZ Single Turbo - Throttle Hiccups & Hard Starts
  85. (In Dash) Digital Battery/Alt Volt meter that looks good.
  86. Florida need mech
  87. Chopped SC?
  88. IS300 seatbelt buckle same as for the SC300/400?
  89. Holset Hx52 Questions
  90. Window goes down not up
  91. Leaking Distributor Repair
  92. Fuel Pump / Sending Unit
  93. .............................
  94. SC300 driveshaft question
  95. Trying to mount on 92-96 wing
  96. Sc400 won't crank after tranny replacement!
  97. 1jz NO BOOST???
  98. Stock Radio Intermittent??
  99. Going na-t
  100. 1j swap 3rd gen runner
  101. Want more camber?
  102. 1uz into sc300 questions
  103. What are my best economical exhaust options if smog/inspection is of no concern?
  104. Coilovers
  105. Coilovers
  106. Add new shift knob to the collection.
  107. 1jz wastegate fitting line
  108. Weird power steering leak during tranny replacement
  109. Oil Pressure Sensor
  110. My first sc
  111. Tabs on top of headlights cracked. Will they still mount/adjust fine? (studs are cool
  112. Your other projects
  113. Anyway to make door easier to close?
  114. 2003 GS300 rear Brakes
  115. 5-Speed Flex Coupling
  116. who here tracks their SC? brakes?
  117. Repeated Power Steering Failure
  118. 2JZ SC300 Rebuild
  119. Down pipe fabrication question.
  120. who slammed on megan ez?
  121. starters
  122. Whose white SC is this?
  123. Broken Tripod... R154
  124. My first car!
  125. What size fitting do I need for a feed on a gte block?
  126. emblems
  127. Are Tails with broken outer lenses garbage? Can I get just the cover somehow?
  128. Great White Beluga
  129. Plasti Dipping
  130. Help with windshield removal !
  131. po 430 pls help tell witch o2 it is.
  132. new here need help swap manual trans. sc400
  133. Buy cloudy headlights and send to shop for wet sanding? or wait for clear?
  134. Garrett gt35 vs precision 6265
  135. Replace Wheel Bearing or the Entire Hub?
  136. ^|^|^|^| **ladies and gentlemen** |^|^|^|^
  137. SEM paint color match
  138. help
  139. Coolant Leask streaming from right side engine, near PS pump
  140. Bad gas mileage (another gas thread.......)
  141. 1992 5 Factory 5 Speed SC 1jzgte conversion HELP PLEASE!!!
  142. 1994 sc300 alternator problem?
  143. Got an idea for the Sc? Share it here!
  144. sc400 1JZ or 1JZ-GTE
  145. 1jz-gte
  146. Lexus SC400 (1994) Shakes/Misfires/Backfires: Continued
  147. looking into getting a '93 SC400
  148. Wired my battery backwards (SOLVED)
  149. 1997 sc300 DRL bulb suggestions
  150. New Wheels! (F)255/35 ZR18 & (R)285/35 ZR18~Fit on Stock Suspension and Body??
  151. Smog legal 1UZ mods?
  152. overdrive issue
  153. Help Removing Sunroof Shade
  154. which cams
  155. Polyurethane LCA Bushings for 98-00
  156. GE/GTE Harness Wiring!!!
  157. What happened to my power steering?
  158. Instrument Cluster Lights (need something cheaper than $2)
  159. Sc400 Performance choice for the time being
  160. Heater Control Valve Repair
  161. JDM Engine swap and Cali emissions?
  162. Hiccup after sc3 spark plug change
  163. Help with hiccup at random RPM's Sc300
  164. Which is easier?
  165. Weird issue...do i have a different diff?
  166. Sc300/Is300 shots
  167. sc300 burning clutch?
  168. Washed and Waxed
  169. Specific questions before DIY transmission R&R
  170. Tial 50mm blow-off valve or HKS SSQV (old model)
  171. which brakes
  172. LFA style wheels on ebay
  173. SC400 Cat Delete pipes
  174. New SC400
  175. 1JZ single turboo swap - hose questions
  176. HELP! ECU problem?
  177. Rear rotor bolt size
  178. Rotors and Brake Advice
  179. wiring issues? How to check?
  180. Driver side window issue!
  181. What are you doing with your Tax Refund? If you are getting one...
  182. door lock actuator repair
  183. CA: Extreme Dimensions needs a SC
  184. 2000 Toyota Soarer
  185. CHECK ENG AND TRAC OFF Question? Please and thanx
  186. Help me identify where this noise is coming from
  187. Back into an SC300
  188. Clear tail lights
  189. Auto roll down windows
  190. Getting an sc300
  191. A little video I made
  192. performance upgrades
  193. Replacing PS Pump in a 97 SC300
  194. cluster
  195. Quick question
  196. A little help will be appreciated. Serpentine belt, etc...
  197. Just Dropped Off My Lexi At A Shop :/
  198. How "hot" do the heated seats get? Can't tell if they work.
  199. The SC Driver Gender Ratio ...
  200. Wild Front End...
  201. Need engine builders advice
  202. Can Anyone ID This Wing?
  203. What to do with this, please help
  204. To Buy or Not To Buy? Quick Reply PLZ
  205. Supra Clones Build
  206. oil pressure switch
  207. sc300 help
  208. Supra cam ?
  209. supra seats into sc300 help
  210. 100+ MPH in Sc-Video
  211. Rear Traction Link
  212. 1jz resistor pack/afc problem. Please help!
  213. Screw Headlight Restorer Kits
  214. Quick crank pulley question
  215. Two quick questions
  216. So what happens when your needles go out and you're a boss like me? Let me show you!
  217. Headlight interals interchangeable?
  218. Under-valued & Under-appreciated: The Official Mark-Up Thread
  219. New to CL. Got a project on my hands
  220. TPS adapter HELP??
  221. advice how to prepair my car before i take it to the track?
  222. 4" downpipe or 3" downpipe on a BW s366
  223. Don't hate on my car;P
  224. The Manual SC400 Swap, SMOG
  225. 1jzgte where can I get these coolant sensors new?
  226. What is the ohm range of our sending units?//Where do I get oil pressure on the block
  227. Fan Clutch Replacement
  228. 19x9.5 +42 / 19.8.5 +38 without rolling?
  229. Question about window trim?
  230. How do larger wheels affect ride and handling?
  231. Window Roll Up/ Down Stubborness
  232. Oh happy day....... I have FIXED the SPEEDO and TACH
  233. 1JZ Valve Cover material
  234. What cars have stock 18" wheel fitment that is perfect (aggressive)on an SC?
  235. Main Relay
  236. Power Antenna Problem
  237. Jay's 93 SC300 2JZGTE, Interior Redone by your's truly, 1JZPWRD !!
  238. SC400 wood trim colors?
  239. What do you guys think of a finger print scanner in the Sc?
  240. Instrument Cluster..removal easy...But the wires ????
  241. How do I replace this?
  242. Another Drift SC
  243. Fog Light Relay Location
  244. jack wont fit under the car need help
  245. my old car before my sc
  246. Rims or coilovers first?
  247. 92 SC300 Need info on doing the timing
  248. How do you get old brake system like new again...
  249. 1999 V8 Suprise!
  250. Broke oil feed line need quck fix
