- Stub antenna, poor reception
- Showroom new 1992 SC400
- Replace OEM struts...need alignment?
- need to know if a 89 supra lsd will go in to a 93 sc300
- need help i have supra seats and need help wiring the power seat
- Coolant line going to throttle body
- gas in your area?
- Power tilt gear...
- wtb sc parts
- How to re-align my steering rack?
- Interesting day at work
- Cam Replacement
- Busted 95 SC300
- Just scored these 18's for $150.00
- found a video with an sc300 in it
- Pics of a friends SC that came by today.
- Thinking about 1UZ Build. Questions
- soarer ac controls
- That damn crank pulley bolt
- Steering/Tramlining/possible brake issues
- Help! Cruise inop after 99/00 steering wheel swap w/pics
- Rough Running SC all of a sudden
- What is the weak link in sc 400 trans?
- New OZ Wheels
- Unable to Open the Door from Inside
- JDM 2JZ-GTE A/F at boost levels greater than 14psi
- Question about coil-overs
- Sc300 Wallpaper
- SC400 Transmission wont hold much fluid
- HELP !!need help airbag and steering wheel swap ?
- the sc's out of commission HELP
- Pounds of Pressure in Your Tires
- Interior issue help
- Steering vibration turning wheel left VIDEO
- Soarpra, Supra front end on a Soarer SC300 SC400?
- short video
- Tire width for wheel width?
- sc400 help
- Next car? Decisions..
- I finally found a mustang that i love.
- Tribute To The 2JZ-GTE
- Coil overs or normal setup
- finally working on my own car
- I Need Info - swapping 1jz from 91 rhd supra into a 92 lhd sc400
- Loosing oil (2jzge)
- Help with my turn signals
- 1JZ stalls randomly and now won't restart
- After almost 2 years....
- anyone using a controller from raddesign
- bearing
- help, r154 shifter housing confusion
- 2JZ-GTE Swapped Lexus SC300s @ Kaizen Motorsports
- Need help with trac light codes 95 sc400
- part numbers
- My 97 SC300, first pics..
- Radio Harness
- Wiring a 1jz Aristo to sc300 Wiring harness
- NA-T FFIM, 1jz iacv?
- Broke my rear! LOL.
- Getting vehicle speed reading to an aftermarket ECU info...
- SChema's Build Thread
- Think I found the wheels I want to buy
- Need Advice on removing rear lower control arm..
- aluminum radiator for 1.5jz
- ***BIG PROBLEM*** NEED HELP Rear Suspension
- JDM Supra Adjustable struts
- Supra rotors on SC300??
- Help! Need advise on short shifter!
- Tilt motor problems
- New Wheels - What do u guys think?
- Need sum fender opinions
- MAPECU(1) vs SAFC: Timing and fuel
- Help needed from the tire guru's.
- Tune Up - What am I missing?
- Need Help! White smoke from exhaust and check engine light!
- Passenger air bag, Black or SEM a tan one??
- looking for pt# in this kit
- Show off your Engine Bay Pics......
- New Cali smog rules for 2013?
- Supra vs. Aristo 2jzgte installation...
- NA-T Build Ground Up, on a budget--- Crapy Teaser Pic
- sc400 corner weight
- A question for those who have seen OEM Upper Control Arm Bushings
- carbon fiber hood
- power steering
- my ac is not broken but it doesnt work
- marlin crawler parts for late model soarer trans
- Road & Track - 1992 SC400
- need help w/ driftmotion aeromotive AFPR kit
- W58 Transmission noise!!
- Help sc400 1992
- not sure what do yall think?
- What should I lookout for when purchasing a sc300?
- pics of my work in procgress
- Opinion wanted: should I use these emblems?
- is this compression good on the 1jzgte?
- HID lights Help!!
- Car is worst after tune up???......
- my sc400 hydraulics fan went bad help??????
- HID's ...New battery?
- Where to hook up auto meter boost gauge?
- A Few Things I've Been Buying And Wanted To Share A Few Pics..Hope You Like!
- Custom tie rod spacers
- Should I buy?
- Corning/Fog light HID retro fit idea
- Evo Wheels on Sc300??
- Installed Front Lip Today
- Is my mechanic serious?
- Alignment results 1997 SC300
- radiator
- Common power sterering issues in the sc400??
- new guy
- Car died suddenly
- no power to radio
- New For 2011: XXR 526 surpise LOL
- Windshield fluid line
- Want to go lower... good spring compressor?
- Just got a sc300 last week.... and now I regret
- Numbers below VIN on 92 SC400
- rock chips up front
- RPM Help 98+ cluster w pics
- Ordered some new seats for the supra... may get the same for the SC
- Can I run an aristo ecu on my 1jz soarer swap?
- Power cutting out
- supra springs question
- taillights out, need help
- LexusFTW's Quest for More Horsepower
- parts interchange
- the beginning of another swap o god plz dont take long
- LS400 to SC300..
- Power gains without turbo?
- What are you doing with your tax return??? (if you were working)
- Which springs to remove fender gap on 275/35/19's?
- Anybody running the megan motor and trans mount set?
- 1jz swap question
- Bad Power Steering Pump?? **VIDEO**
- Some new pics of my SC.
- Help with 1JZ swap anyone?
- Battery Light. Altenator?
- How do you remove the wood trim under pass air bag on a 97
- some wheel help.
- Top 2 bellhousing bolt access?
- manual engine harness on an auto
- Remove back seats?
- manual engine harness in auto?
- A Gixxer-Drew suspension abridged writeup with pictures
- Problems lights keep flashing
- IMF performance Y pipe
- need help about harness
- 2jz rods newbie question
- 20" wheels on 97+
- Aem ems gte to ge
- 2jz egr system difference
- eye can see clearly now!!!
- Long cranks on cold startup, bad FPR?
- ebay turbo kits????
- What size amp for the stock sub??
- Pics from this weekend in Savannah
- What a Tease! Got me some fine looking tail this weekend!
- Drifting Pictures
- Not running on all 8
- Sc400 Stereo wire color codes
- Magnaflow 14829 vs 14828
- Driftmotion waste gates
- auto 1jzgte with soarer r154 into manual sc300
- sc400 flex coupler!!
- silicone radiator hose for 1UZ?
- 1jz Swap *Battery Keeps Dying
- 12 CD Disk Player
- SC Video...
- SC400 torque converter.......
- None of the speedo or dash lights working how to fix?
- How and why do i keep geting water in my cylinders! car wont start because of it.
- soarer r154 transmission input shaft cracked!?
- meganVs. Magnaflow
- Different Spring for Driver. Front?
- Anyone using the Apex Neo on stock SC400?
- Painted Wheels which looks better?
- Marimoto Projectors (H1/D2S)
- 1992 SC400 Rear Subframe.. Need some help.
- supra sway bar
- Wonder wth... Do i do!!!
- Need some help..
- Where is the factory chirp siren ?(Stock Alarm)
- Anybody ever rebuild there rack and pinion?
- My Baby wont start
- 2 Step on stock twins?
- Weird sqeaky noise Cant figure it out
- rear wheel problem
- cat delete or midpipe for sc300????
- 1.5jz-ge+t questions !!
- anybody with a passenger side door handle
- bogging badly at low rpm after tune up
- 97% complete 5spd swap
- will this strut bar fit a sc300
- Last night car died on highway at 70mph
- my cluster stopped lighting all up
- 98 SC400 Camber Kit
- 1JZ-GTE Non VVTI lately?
- 94 sc-300 got wrecked...
- Your opinions on my ball joints
- whats the diffrence in Misfiring,fuelcut.boostcut?
- 6.5 Speaker Adapter for Rear Fitment
- need some help with rims.........
- TT Fuel Pump
- SC300 idling high when cold
- HiRo Body Kit?
- t+t from the mkiv supra on my 92sc300 2jz?
- what is the best turbo to get for right now power?
- new exhuast concern.. is my new setup safe for my engine?
- What color should I paint my head lights ?
- How's this timing belt look to you?
- A little motivation for your slow going projects
- Instrument Cluster / Factory Alarm
- sc400 power steering issue?
- tail light strobes?
- Best source for Control Arms?
- Quick Brakes Question
- Question about rims
- Rear end Damage on SC. Debating what I should do.Pics included.
- 1jzgte or 2jzgte swap
- Camshaft regrings options
- Ok sc400 needs more power asap!!
- sc300 1jz single turbo need help
- A Lil "what rims are these" Thread.
- sc400 broken antenna
- Supra springs in front only?
- Code 25,26
- so after i sell the sc300.. what should i get?
- Installed 3M Di-Noc Carbon Fiber Vinyl on Interior
- soarer window trim vs sc300 trim...
- Ebrake have anything to do with seat harness?
- 350z wheel question
- Ebay Seller has Erebuni Style Rear Lip?
- Spring Setups
- my sc400 1jz swap finally
- who owns this SC?
- 2jz turbo downpipe
- Window Tint..
- Can't help but post these pictures!
- Quick ??? About cabin air filter.
- Seat belt light with after market seats. Q'
- Oil filter sandwich adapters/oil cooler adapters??
- Usdm and jdm ecu plugs for 2jzgte
- Future Plans For My SC400
- LeeSC300's OEM BUILD
- Need help first sc300 please!!!!!
