- Newb Question
- Really need help. Hopefully last issue!!!!
- Hello newbie
- All dash warning lights on
- JDM Supra VVTi Engine / v161 / Differential Dropout Complete
- staggered or unstaggered?
- Krazematik Sold his SC400
- Help!!!:How much would you pay for this SC400.
- Any body knows a way to adapt hids or bright yellow lights on the 92 turning lights
- SEM tan paint??
- Drag DR-19's and Lug Nuts
- Installing a turbo timer on a 99+ SC300
- HID Lights and Bulbs
- Suspension qustions
- Car alarm thread
- Alternator issue SC400.
- Will this downpipe fit
- Another SC300 with 315/35R17 Tires Picture Thread
- Color Matched Vinyl?
- jdm 2jzgte swap question regarding wiring
- Can a 97 SC300 auto trans work on a 98 SC300?
- Need help Heater control valve leaking coolant
- Tail Light Issue
- Poly bushings distributor info
- 1uzfe Turbo Manifolds
- *Fitment*Ebay 1jz Y pipe
- All aluminum radiator
- Car misses
- How too quiet my fuel pumps...
- Specials build thread
- Need help with 1JZ body plugs
- 1jz vs 2jz
- RIMS questoin 18X10 +25 all around?
- Quick Photos--Supra TT springs/ Saleen Wheels
- 1992 Sc300 With Smoke Problem
- JDM suspension
- 2jzgte swap question regarding time
- Not sure what's up...
- can anyone recommend a good transmission shop in las vegas nv?
- Need some advice
- High beam replacement
- i need to be lower!
- parts needed for auto -> r154 manual conversion
- Is this a good body kit to get
- For those of you with Megan Coilovers
- CD Player
- drivetrain ??? driveshafts and pedals
- 92 SC300 Hypersilver XXR 521 18 x 10 +25 all the way around
- SC400-supra TT diff ?
- Stock sub enclosure
- Carfreak's Last Build Thread (hopefully...)
- can we use this?
- I have a doner 89 supra tubo car for my sc300 drift car. need to know what i can use.
- 3 Way Components Speakers?
- About to start my 1jzgte swap into sc300
- Its been awhile CL
- Compression numbers. 1uzfe gurus please step in.
- Coolant overflow tank leak? anyone sealed them?
- looking a foglight mod
- My MKIV 93.5 NA-T Build
- 1.5j build?
- ISF pedals on SC300???
- Ignition or something else?
- looking for a sticker.
- Will 92-95 taillights fit a 97?
- First steps towards sc400 R154 conversion
- Where are all the knock off vertex ridge kits gone?
- What every SC owner should do!
- Aftermarket gauges
- MAF Question
- antenna issue
- exhasut mod - follow up question
- Changed my Dash LED's....opinions
- bulbs
- OEM Power Steering Hose for $660 or Braided Stainless Steel for $65
- bellhousing question
- What should I buy????? Strut suggestions
- The definitive guide to fixing SC400 hesitation issues
- dropping tranny
- Donate a dead Fuel Pump ECU / what were your symptoms?
- I bypassed my fuel pump ECU. What now
- TEIN coilovers?
- What hose is this?
- SC300 1995 Emblems
- "Premium" Sound system?
- 2jz GE vs GTE
- wth??? aem ems only for m/t?????
- part number?
- Off Throttle Jerk, On Throttle Jerk
- Potentially Stupid Question
- Bee-R Rev Limiter
- MAF Plug
- federal tires?
- SC400 Fuel Pump ECU Check
- sc400 manual swap with mk3 trany help plz!
- my car is ready for turbo and i want opinions.
- why are my mirrors auto dimming
- *new* trunk lifts a little bit to long to snapon!!
- opinion on 1j fuel rail
- Radio help!
- Small Mods
- Guys looking to go NA-T
- Blown head gasket? 2jz-ge vvti
- turbo manifold NA-T
- Stereo Wiring - 0gauge wire?
- SC400 Twin Screw Supercharger Project In Development
- Sad morning for the SC400....
- Lowering springs and stock shocks ?
- Importing SC
- Must act fast: someone will know y/n answer
- 1j delay in power
- coolant temp sensor, please help!!
- 1jz alternator wire?
- Burnt connector...
- can i see some green sc's on aftermarket wheels.
- Some Rare FRP and Carbon Fiber Hoods for the SC300 / SC400 / Soarer
- How much are these wheels?
- One new picture of my 97 SC300
- Gold on gold?
- sc300 Ac woes
- Checking O2 sensors on 93 SC400
- AC problem/overheating
- A/C fan/thermostat not working
- The latest of my insanity, home made hood!
- red fluid leaking
- income tax time
- the many faces of my car.. now time to sell..
- DTC code 25 and 41 on 1992 SC4
- 99 SC300 for $6900, good buy?
- 03 gs radiator fit in sc
- 1jz vvti ecu pinout / sc300 body pinout
- How to turn on stock amp in 95 sc300
- Snow storm Chicago!!! Some pics.
- rear coilover problems
- Clutch what type?
- 97+ rear bumper extensions
- Electrical Issue? Can't diagnose.
- nor cal meet! if you sc guys havent seen it sign up asap! 40+ cars..
- K&N air filter ?
- trunk pop lock alarm possible?
- Whats the correct way to install a FRONT MAIN SEAL?
- HURRY!!! please help with photoshop!
- fuse blowout??
- passenger side door outer B pillar
- HELP! 03' IS300 manual ecu swap into a 00' sc300?
- Is this 92 sc400 worth $3900? help a brother out thanks.
- Needing a link or website
- 1jz swap time ALL INPUT NEEDED
- rear bumper or wheels?
- Metal Radiator VS. Aluminum
- will these fit??
- 92 SC300 Build
- which color wheels
- Suggestions for best aftermarket shortshifter
- a/c control unit.
- HID Advice DDM Tuning
- am i missing a lot of stuff for my steering wheel?
- which rear speakers??
- Bulb # for Climate LCD Screen
- 1jz swap idle/turnin off problem
- Automatic Lights
- The SEM experience
- Just Picked Up A Sc300, And Good Ole Minnesota Weather Challenged Me With A Guard Rai
- My Car Got A BooBoo!
- 4runner dizzy on sc300
- identifying bad LCA
- 1999 SC400 vvti Dyno
- gt35
- Some Pics from the Philadelphia Auto Show.
- Question about SAFC
- Correct antifreeze/coolant for 1997 SC300?
- Interior: Teaser.
- 1JZ swap-trans plug question
- Help deciding on Shock and Springs
- On the topic of 315s
- rare 1jz
- Opinions on this turbo kit?
- JDM Soarer Questions
- Is anyone on B7G Springs?
- 1j/2j turbo single w/ Catalytic Converter? in CA
- Common driveshaft length?
- 1992 SC400 Idles rough then dies
- Anyone on B&G lowering springs?
- Red, Black, and White Unite!!! SC-Shoot (pic HEAVY)...
- Selling Black housing headlights.
- where can i buy stock 1jz twin turbos at??
- Need Help, 95 SC400
- who wants to help me with my 1jz swap FL!
- doing a 1jz swap on my sc300 question
- Just got Eibachi Springs... I need struts...
- DIY SC400/300 High Beam Refinishing
- DIY red out taillights how
- Ignition Coil Pack
- Need help with my sc400 tranny!!
- which wheel??? i cant decide!!!
- lots of grinding in the rear.
- LED tailight bulbs
- what kind of wheels are these on my sc?
- High beam refinish
- fed & canada vs. ca
- Battery light flash low beams shut off ABS light comes on? WTF?
- Rolling shot! fap fap fap
- Interchangeable rear toe arms?
- need some knowledge
- will the sc400 run without a fuel pump ecu? fuel pump harness is bypassed.
- Fender Rolling Tool, Anybody Ever Heard Of Or Tried This Kind?
- what are your guises top speed?
- NEED HELP!! No power coming to the stereo.
- Time for new cat's does anyone know any that are aftermarket CA legal?
- What kind of shocks should I get
- strange battery problem
- Soarer or Supra harness?
- Gas leak Problem
- Supra Tanabe Shocks+Springs
- quick question.. installing coilovers as we speak
- The Soarer Story-Documentry
- Need wire diagram and pinout schematic for Soarer harness
- gas variety.
- differant answers
- crank pully diameter
- Still missfiring and running rich after ECU swap
- help with pulley alignment
- What model lexus wheel hubs are compatible to the sc3/400?
- Are coilovers the same for 94-97 GS300 vs. 92 SC300... Help!
- $550 turbo kit for sc300
- new member, first lexus
- Hello Sc owners, need some opinions about keyless ignition start system
- Local Tampa SC400 guru needed for hire
- 18 245 45..or..18 225 35
- I use tac cloth to wipe my car
- 1JZGTE, NA-T 1/4 and 0-60
- Went on a mini shoot today
- Two of a kind
- Cutting my springs.
- Srt 4 injectors
- curious pic request??
- TRAC problem.
- 1JZ wire harness body plugs questions
- Mini Build - What $2k and time can do
- 2000 Lexus SC400 offfers??
- I just put these wheels on my LEX
- rough idle after na-t install help
- what is causing this?
- smog test results-failed again PLEASE HELP
- odd power steering issue?
- Exhaust / Cat question on my 93 SC4
- First time buying rims; need CL's help.
- good deal????????????????????
- TT suspension
- color?
