PDA
View Full Version : SC- 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153
  1. Huge/Annoying problem
  2. Door Hinge replacement with pictures
  3. Who's The Top Dog SC? 1UZ vs 2JZ
  4. 94 SC300 engine start problem
  5. 1JZ SC300 having issues when giving gas/startup.
  6. need a 1jz like yesterday
  7. 2JZGTE swapped SC3 need help finding home for plug
  8. New Snapshot of My Shine Auto Project SC300
  9. Engine Light Issue
  10. some things i have been up to with my SC
  11. Timing Belt. To Do or Not to Do
  12. Power steering issues
  13. remove the intake manifold on a sc300
  14. car shaking!!
  15. Rear Quarter Panel Repair DIY
  16. so I went drag racing.
  17. info needed
  18. 18'' G35 Ray "Forged Look alike"
  19. Looking to Buy an SC300 TT
  20. Hot around the E-Brake and shifter...
  21. Show me your headlights
  22. Stupid hood question
  23. Finally pulling the trigger on Body Work!!
  24. 92 sc400
  25. a literal shout out lol
  26. Need opinions....
  27. Changed Fuel Pump still not wanting to crank PLEASE HELP
  28. Brake light during acceleration
  29. Bad gas milege 98 sc400 vvti/ How about replace some sensors??
  30. What color to paint my wheels?
  31. Drift wheel suggestions
  32. Right size to plug into 92 sc4 fog lights
  33. i dont understand whats going on
  34. HELPP! car lost power and is smokeing :S
  35. Tinted windows, mirrors won't dim.
  36. door panel reinforcement and repair.
  37. New to Club Lexus. Introducing my SC300
  38. Recline lever rendered useless *HELP*
  39. WIll the Treadstone is300 cast turbo manifold fit a pre late 97 head?
  40. Ash trey shorting out!!!!
  41. cant drift in my sc300
  42. Just bought "Dome Lights" from Superbrightled.com
  43. Looking for a 4.5" or even 5" gold "L" emblem
  44. Ruff Racing R280?
  45. automatic - manual?
  46. Would You
  47. My SexC300 in the fast pace zone
  48. My SexC300 in the fast pace zone
  49. flexible led strip for 3rd brakelight??
  50. Parts Car Sc300 - "92
  51. Need some help please!!!!
  52. new pics are up..see original thread 20mm to 25mm ichiba
  53. alternator wiring issues
  54. SC300/SC400, MKIV Parts list? OEM #'s?
  55. "Complete" 1992-1996 (picture)THREAD
  56. E Brake hot at times
  57. In search of the "Infamos" white seat cap
  58. engine fuse box diagram
  59. Random pics from oil/filter,trans flush + 20mm to 25mm ichiba's
  60. Question about LS400 brake upgrade
  61. ipad dock
  62. Crazy idea. Rear seats swapping?
  63. 18 or 19 Work Euroline DH 2 on a sc?
  64. key fob reprogram?
  65. What is my rolling shell worth?
  66. Prius steering wheel
  67. Aftermarket radio install in SF bay area for SC 300?
  68. Monitor in the glove box area?
  69. im thinking about halo headlights off ebay
  70. clock stays at 3:15
  71. cluster issues..once again, plz hlp!!
  72. Sc300, minnesota plates:)!
  73. Control Arm Bushing??????
  74. The Power of Google lol.
  75. Sunroof Problems! Help please!
  76. wtb a swap for SC300
  77. looking at buying a 93 sc400 question
  78. bov vacuum question?
  79. Info on this SC
  80. Throw out bearing install help
  81. Removing Driver's Mirror (glass only)
  82. Multi piece wheel guys post here!!!
  83. Updated pictures of my civic :D (no honda content)
  84. ALL WTB and FS posts go in the classifieds, not here.
  85. Aristo swap problem PLEASE HELP!!
  86. 1jz gte-toyota avalon??
  87. Stuck gear shift
  88. Replace climate control LCD lights
  89. Stock tt shocks springs
  90. now i can say "fully loaded" and mean it
  91. Found a near perfect SC today... Its Nice
  92. air fuel problem plz help
  93. Test Pipes/ Cat Delete Pipes? Do they make them for sc4?
  94. 245/45 or 245/50 Tire Size 18'' 350z Rims
  95. Who makes engine harnesses
  96. Door handle bolt access
  97. what pulley is the largest one
  98. Advice on Injectors
  99. Check this out!
  100. This is just the beginning!
  101. 18" RiMs Secret ID.?!? dUn DuN dunnn
  102. Which wiring harness for aftermarket radio do I need?
  103. New Lenox SC sighting
  104. Changed Master clutch cylinder, now no pressure?!?!?
  105. POST YOUR SC300/400 ROLLCAGE SET-UP's
  106. I don't know what to do
  107. Alfa Otto Reverse glow gauge cluster.
  108. Sequential Turn signals in!
  109. 1992 - SC400 - Fuel Pump Location
  110. 1993 sc300 cluster tach wire
  111. My front end feels like $%&^@!!!!!!!HELP
  112. '95 SC300 - 1JZ - Need fluid motor mounts, I Searched .. but :|
  113. A/C Questions
  114. Where do I wire in my turn signal loads?
  115. 1uz mass air question??
  116. tt shock tt eibach/ drop question
  117. SC400 Single Turbo (Rear Mount)
  118. 2JZGTTE flex plate differs from 2JZ NA in 92 SC300?
  119. Power limit of diff., axles, etc..
  120. Cluster needles rebuild?
  121. 19x10.5 +0 offset all around will this fit?
  122. my new door mod...
  123. Toytota Soarer to Sc400 Steering shaft
  124. Need help with wheels
  125. 1jzgte(whats different water pumps could i use with it)?help please
  126. Changing Fuel Pump Question
  127. ImportAlliance
  128. And the list goes on.....
  129. aem ems need
  130. Need Help with EGR Delete!!! I wanna rip my frickin hair out
  131. I know, I know, the search keys....
  132. SC300 faster certain years?
  133. maybe im lucky? weird problem
  134. Problem with AC PSI Reading LP Port
  135. Starter question(year change?)
  136. driver side window not working
  137. adjusting window height help!!!
  138. My fav. slap in my sc400 and spotted e-40 sc400 in video!
  139. SC 400 AC Question
  140. Video of 1JZ breakin up
  141. Wow, What do u think Guys?
  142. Cheap power steering reservoir alternative for 1jz swap?
  143. Turn Signal Issue?
  144. Tail Lights Went Out; High-Beams; Strange Sound Tranny
  145. Shark Fin Antenna on SC pics?
  146. Dad owns Z06 VS. my 97 sc300 1jzgte lol
  147. Pics of Unfinished Wheel Build Project
  148. sc400 ac condenor on sc300???
  149. side view mirror interchange??
  150. any suggestions on bottom end
  151. Considering an SC400
  152. Where can I get a Tan Driverside Seatbelt Replacement
  153. Coupes you think are comparable?
  154. Warm Start Problem
  155. Rack and Pinion acuactor valve plug?
  156. EGR valve
  157. spotted 4 sc's in houston
  158. Need help identifying bushing behind steering wheel on column
  159. cheapest way to ship bumper???
  160. key replacement help
  161. I searched, but... MOMO Steering wheel.
  162. STEERING Wheel removal (help please)
  163. 92 SC turn signal question, please help
  164. ARISTO 2jzgte extending harness
  165. FS and WTB posts go in classifieds only.
  166. Got new front bumper lol
  167. my 95 dwp sc300
  168. FS and WTB go in classifieds forums only please
  169. ***Engine Mods***
  170. replacement carpet? (all GBs MUST have approved CL vendor support... closed)
  171. Nicest factory black interior ( No SEM)
  172. Forza Motorsports 4
  173. 2jzgte JDM cams into 1jzgte....Anyone have more info on this?
  174. Photoshoot Time: Platinum SC Content!!!
  175. Proud new owner!!!
  176. Baltic Blue SC300's...Where they at?
  177. should i buy this cheap thing?
  178. Rear deck question.
  179. are these the right mounts? need help!!
  180. Fog Light Question
  181. Terrible SC Finds
  182. Is this nardi a good deal? need help asap
  183. 1jz tuning ?'s
  184. going to paint my sc300 a new color. Any ideas?
  185. Bought replacement cluster needles still not working
  186. Is this a master key??
  187. Driver S. Door actuator?
  188. Side Markers
  189. 72mm guys post pics please
  190. steering wheel options
  191. 1997 SC400 modification help
  192. Spray Paint on stock rims...
  193. R154 vsR155 transmison, with pictures! recommendation pls
  194. 1997 5spd. full exhaust video.
  195. too much information confused!
  196. stock 94 auto trans and GTE auto trans
  197. transmission options & gear options, recommendation please?
  198. bumper strip
  199. this is in my car SC400
  200. Taillight Lenses interchangable?
  201. Keep, Trade, Sell, or Part-out
  202. Finally Got My Transmission Done!!!!
  203. Butterfly Cupholder?
  204. Does anybody know what rim this is?
  205. My Final Thread
  206. where can I get my 2jzgte cams machined in FL?
  207. Brake Light Issue???
  208. Help with SC brake mod - is250 brakes
  209. New Rim on my SC...Well New to Me
  210. My SC, my headache. Please take time to read.
  211. Headliner Removal DIY?
  212. do these actually help?
  213. motor rattle when accelerating
  214. My HUGE SC300 project and VERTEX questions
  215. found a couple supras at junk yards
  216. Replacing Chathodes In 98-00 Clusters?
  217. Windshield help needed!!!
  218. Poor CD changer.
  219. Stocks Sub swap?
  220. Cluster size LEDS?
  221. Fuming on my Windsheild repalcement
  222. 1994 sc400, fully loaded,jade green,tan interior.16K miles.Will it be a collectable?
  223. What size tires should I go with?
  224. Front speaker size
  225. Best pics so far!
  226. before and after pics
  227. Help! My Headlights wont turn on ('97)
  228. I really hate these threads... What would you pay?
  229. new here, lend me your expertise
  230. ROM Chips
  231. Finally, got myself another SC300!
  232. Got a pen mark in inside of tan leather door
  233. passenger window and Seat problems
  234. Plastic peice over shifter nobb??
  235. SC300 Needle Gauges - Cluster?
  236. so the Sc Rear got a lil makeover pics pics
  237. sc300 with 1jzgte. I want to swap in 2jzgte ???
  238. Wheel questions with a couple of pics
  239. Toyota Soarer 2.5tt (Not an Auto) from south london uk. lots of pics!
  240. No Turrning Signals or Hazards
  241. cel code p773
  242. Difference between turbo and na wiring pigtails??
  243. Can I change the odometer lights?
  244. Starter Repair Kits or New Starter?
  245. Stance WI and mini Meet up!
  246. Got a sc baby!!!
  247. anybody in jersey
  248. auto shifter replaceable?
  249. Anyone have a viper 5902 alarm?
  250. Better intake system hopefully
