PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. advise which coil overs
  2. 1998 SC300 AC help needed
  3. 1 of 120 With 49K Available in NY on CL for 6.8
  4. !jzgte vs 1jzgte vvti 93 sc300 questions
  5. Fitnent question!!
  6. Replacing Stock Fan to Electric Fan
  7. Sc400 Newbie Needs help
  8. Does the SC300's A/C compressor temporarily shut off at higher RPM?
  9. Black sc on bronze wheels
  10. Car is slower than normal
  11. Sc400 cool intake into Sc300
  12. SC300 how many main ECU Capacitors?
  13. Quick Power Upgrades for 97 SC300
  14. Slight miss during idle
  15. Getting ready for my build
  16. New member... love my sc300... sudden overheat problem.
  17. Lamin-x Headlight Covers Project for Fathers Day Present
  18. SC300 Steering wheel hub adapter and aftermarket Steering wheels
  19. Supra TT strut mounts
  20. Driver side window
  21. SC's and pets
  22. 1994 SC400 Disconnected Vacuum Hose
  23. New pair of shoes (supra tt wheels)
  24. Dye Interior Tan To Black
  25. SC400 midpipe - cat?
  26. NEED HELP! NEW MEMBER! sc400 owner
  27. fort Myers fl sc400
  28. 92 SC400 Engine Swap Question
  29. sc300 : exterior help->
  30. First time at the drag strip
  31. Steering issues
  32. Transmission Not Shifting Into Overdrive
  33. Power Steering
  34. headrest removal
  35. Farewell Club Lexus
  36. How to read Transmission Codes
  37. 97+ SC300 Radiator
  38. sensor wiring harness
  39. More 1jz help
  40. KS-Auto supercharged Toyota Supras
  41. *old* Vortech supercharged SC300
  42. Sc400 supercharged
  43. A/c hell!!!
  44. EGR P0401 Driving me crazy!
  45. What are these worth? Blitz Technospeed z2
  46. To swap or not to swap?
  47. Newbie trying to decide SC400 or GS300
  48. Clunk when turning (video)
  49. 2jzge:denso/ngk wireset? Copper/platinum/iridium?
  50. 1997 SC400 AC Compressor Lock Sensor
  51. Smog help!
  52. Fuel door replacement
  53. Adjustable Control Arms?
  54. 97+ Sideskirts on 92
  55. Off-Center Steering Wheel
  56. Sc300 widebody cabrio
  57. Lexus Key Broke Help!
  58. Black drivers door
  59. 95 SC300 Looking for info
  60. mechanic advice please
  61. 95 SC300 Starts Sometimes But not all the time.
  62. Found this today.....
  63. Decent Coilovers...?
  64. Sc300: need HELP
  65. Replacing the trunk gas shock
  66. 96 sc400 engine wiring
  67. What's it worth? 99 SC400 - 78k miles - "Like New" condition
  68. 1JZ runs rich when decelerating in gear?
  69. Sc300 stalls immediatly AEM v1 NA-t
  70. 95 sc400 problems
  71. Help 1995 SC300 Code 25, running rough or limp mode
  72. The most aggressive SC300 body to date IMHO. SH Pic inside!
  73. A/C Light randomly starts blinking after turning off AC
  74. HELP! Overheating when in boost!
  75. custom door cards?
  76. Replacing Gauge Needles
  77. Need help driver seat will not return upright
  78. Lextech Stole My Dash Cluster
  79. Sc300 2jz-ge build
  80. 4th alternator
  81. 97 SC300 ECU pinout?
  82. Headlight Polishing Kit Actually Works before / after pics
  83. Removing Wood Trim Center Console
  84. Brake issue-need advice
  85. will a is300 5 speed ecu work on a 98 sc300?
  86. Converting OBD1 to OBD2
  87. Quiet exhaust for GTE/single turbo SC?
  88. OEM shocks/struts w Tanabe NF10
  89. Window regulator parts needed
  90. Just picked up 95-96 sc300 tail lights
  91. Need all the help i can plz!!!!!!
  92. Coilover options
  93. Finally back 1997 dwp sc300 factory 5 speed. Factory bbs vs aftermarket
  94. Car seat in sc400
  95. 2JZGE Radiator hose suggestions
  96. Sewell's parts diagrams...
  97. Car won't start, CEL 24 and 31..
  98. Aftermarket LCA's
  99. obd1 scanner?
  100. Ghostly trunk; opens involuntarily
  101. On 92 SC300 which control arm ball joint (UppervorvLower) supports Spring.
  102. motor swapped SCs - heater valve
  103. motor upgrades
  104. APEXi Neo question
  105. 98' SC300 55k "Keepin it classy" build
  106. A/C leak?
  107. Fog Lights for Inspection Bumpers
  108. A/C blowing cold out of pass vents, warm out of driver's vents.
  109. What type of tranny is this huh?????
  110. Help turbo matching for goals
  111. what psi do you inflate your tires to?
  112. starters???
  113. What tail lights are these?
  114. Radiator is garbage
  115. Sc300 1jzgte vvti cutting out, help!!!
  116. Ghost in the machine
  117. Sc400 temp gauge creeping up
  118. are my seats always heating?
  119. sc300 bucking when leaving hard or drifting
  120. turbosmart manual boost controller!!??
  121. Anyone help?
  122. Sc 300/400 meet
  123. MKIV Bilstein on oem springs the way to go?
  124. That discontinued air bag sub harness help
  125. 2006-2008 corolla steering wheel.
  126. How to adjust serpentine belt tension?
  127. Wheel well liner -- exposed wires?
  128. drag wheels (slicks and skinnies )
  129. Does anyone know if the Takata airbag recall affects 93-2000 SC's?
  130. 93 sc300 Repair manual needed!!
  131. SC300 owners: Do you change your oil filter from top or bottom of engine? (Poll)
  132. Map Ecu3 purchase inputs
  133. Alternators interchangeable
  134. changing HEAD GASKET
  135. Sc400 wiring harness woes, any ideas?
  136. replaced drvr window regulator but now rolls up slow
  137. Brakes Broke?
  138. Will this wheel clear my Ls400 bbk's?
  139. Bench test aem 30-1100
  140. wood trim problem
  141. Cleaned IACV now car won't stay started
  142. IS300 5spd flywheel question
  143. Vanity Plate
  144. Picture Request: Vacuum lines
  145. 80s kid fun, getting old school
  146. worn camshaft sc300 2jz-ge
  147. Drove my SC to a Ghost Town (pics)
  148. I need coilovers sc300
  149. LCA torment. mod or replace
  150. ross machine racing
  151. SC Newb looking for different stock wheels
  152. Need Help diagnosing !!!
  153. New coils?
  154. $3,000 USD to swap a motor!?!? In TX??
  155. 97-00 sc side skirt question on 92 sc300
  156. Small wiring issue
  157. 92 SC300 ECU Location
  158. tons of electrical gremlins out of nowhere
  159. what do you think of this 1998 sc400
  160. Rear hub squeeks
  161. will a 97+ spoiler boilt up tp a pre 97 trunk lid?
  162. Doing Ls400 BBk on sc400 don't have any mounting bolts???
  163. Mounting Flush mount spoiler?
  164. Need help/opinions with TAC signals
  165. 1993 lexus sc300
  166. Help. i want to install resistors for airbags in my sc400
  167. 1JZ-GTE stock turbo ventilation inlet block-off
  168. Need photos of CA spec sub ox location
  169. wanting advice before buying
  170. Help: Rust Removal
  171. 98 VVTI ECU Issue
  172. Coolant problem
  173. SC400 Radio Replacement
  174. 1uzfe to KA24de trans
  175. Vibration Above 60 MPH in SC300
  176. 350Z manual trans with GTE swap
  177. simple solution to tired trunk struts
  178. Golden95sc's Platinum 97 NA-T SC300 Build
  179. Mixing coolants
  180. Custom Headlights: Need your input before I tear mine to pieces
  181. I've a little idea (shortcut to boost)
  182. Should I paint my car? or get a Supra
  183. Steering issue
  184. repair manuals
  185. Pulling my hair out
  186. 97+ High beam city lights
  187. 2jzge obd1 oem v8 kvm afm
  188. +97 Radiator Grill Garnish
  189. Q:Strut Mount Supra Soarer
  190. Spoiler help!
  191. Can anyone tell me what these plugs in the seat belts do?
  192. What Is This and How Do I Replace It?
  193. Starting issues
  194. Ramos' 97 sc300 5speed slow build
  195. Air condition problem '94 SC400
  196. '97 inspection cover?
  197. ordering new door weatherstripping, need to confirm part #s
  198. Wondering about the years to do LS400 BBK on Sc400???
  199. small click in the rear on right turns
  200. Just found a W55 in my garage
  201. Q? Catalyst Clogged?
  202. Power happy at 4500
  203. Purchasing a SC300...need advice
  204. Anyone over 400hp using a W58?
  205. bilstean measurement request
  206. Buying a GTE swapped SC300 remotely? Chicago shop rec?
  207. Soarer 2.5 twin turbo bushes
  208. 2jzge manual tranny to jdm 2jzgte motor please help.
  209. JDM 2jz-GTE VVTI build
  210. my new build pic city hahahah
  211. Help removing differential bushings
  212. Do I still have a bad ecu???
  213. whats my sc worth gte/th350/restore
  214. Digital Or Standard HID Kit?
  215. Gated Shifter for 94LS
  216. E Brake Handle
  217. radio not working
  218. Need help!
  219. Aftermarker
  220. My SC300 did this....and I need help
  221. HELP ASAP tt fuel pump on na sc300 problem!!
  222. 93Sc300 Slow build
  223. 95 sc300 ecu
  224. 1JZ engine tear down (very pic heavy)
  225. where does this fuel line go
  226. Key Remote to Seat Memory Function
  227. And the black interior swap starts
  228. Please help- advice needed on '98 SC400
  229. Sc400 Swap, Tx
  230. Q?Interior: Seat safety realistically speaking
  231. Thoughts on a rear spoiler reverse light?
  232. 430 SC Ignition odd sound when turning key
  233. Q?Widest rear Tire on 18x9.5 +45
  234. Q?Perf:310CC Injectors from RSX
  235. Q:Brakes:JZA80 Rotor Lines and Pads
  236. Mini Photo Shoot and New Updates!
  237. Battery Discharging
  238. Fuse Box Help!
  239. Wtf!!! what's thread is on a is300 union bolt!
  240. What would be your conclusion???
  241. 1jz igniter
  242. My '94 gets some love...
  243. 97 tail light modification question
  244. temp gauge not functioning in 98 sc400
  245. replaced ecu
  246. Re-wrapping 94' SC400 wiring harness: minor questions
  247. 92 sc300 tranny swap help
  248. 1995 Sc300
  249. Swap Guide
  250. Opinions on coilovers
