- CEL and Trac Off lights on.
- sc300 full suspension build finally installed
- full suspension sc300 build
- 92 sc400 temp gauge pegged at hot
- Smaller turbo installed now boosting higher
- 1JZ twin turbo replacement w/ twins.
- combination switch replacement
- Heads up tip : air conditioning leak
- please help with electrical issue on my sc
- new mufflers
- undercoating
- Wrecked!
- Rarest or most coveted sc300?
- Varrstoen ES6 - work meister reps
- Quick question on supra struts and mounts
- 1.5jz build parts needed
- 1jzgte vvti help.
- engine build opinions
- Should I sell my SC and get another one?
- Leaking calipers
- 95 SC300 street machine
- replace front turn signal bulb on 1995 SC300
- Best Gixxer Drew Spring Rates For Low AND Comfort?
- Should I buy this SC400?
- 1jz problems help !!!!
- DC 12V for Reverse Camera?
- SC400 A/C Compressor Revolution Sensor
- 1jz vvti water pump, where to buy?
- Deciding on 97 SC300 5spd purchase
- Soarer digital cluster help!!!
- Comfortable as Megan EZ Streets And Better For Under A Grand?
- brake lights not working
- Working on my 95 sc400 ignition
- transmission mounts help!
- parking bulbs
- Anyone know of any replicas for these wheels? HRE's C103
- driveshaft length?
- Soarer Badge Question
- SC3/4 full wrap kit?
- Finally landed myself a clean SC300!!
- NEED HELP fender rolling sc300
- Help!!! faulty MAF sensor not sure
- Bought the wrong water pump have a question
- Carbon wrapped center console pics
- 1993 SC400 Purchase Advice
- vvti vs non vvti parts.
- No overdrive / cruise control
- A Build Of Her Own!
- Quick favor from the 98-00 SC400 guys
- bad ecu?
- Can anyone recommend a good aftermarket 1JZ-R154 flywheel?
- GTE knock sensors while rebuilding the block
- can i bypass the immobilizer on the factory alarm
- 1999 sc300 comes with LSD stock?
- Head Replacement
- Auto TT trans
- Rims and a little tire!
- More Blinds
- vortech help
- Need some help figuring out what could be the issue with my SC
- Grinding fenders for larger tires
- SC300 Not Getting Spark; Aristo 2JZ-GTE
- Tabaka Build
- Just picked up my 3rd 5 speed SC300
- Charging Voltage Mod for $.50
- air cabin filters
- just joined and already a request
- New Stub antenna mod
- Getting tired of my fully erect antenna! lol
- clutch problem?
- 99 sc300 body plug diagram
- new member veteran mechanic
- 92-96 Airbag Into 97-2001?
- Anyone use window shades?
- High RPM lockout, southbend/soarer r154
- Blowing smoke under boost
- Is this the ABS sensor on my MKIII R154?
- u-joint
- Sc400 bogging at 4500 rpm after 2jzgte vvti swap, rev limit idk.
- SC400 won't start?
- supercharged 95 sc400 build ideas
- Is this good enough for fuel management?
- Help!!!hit a curb now clicking nosies
- Exhaust Manifold flange warped??
- Power steering OVER assisted, Too light, twitchy after overfill/drain extra
- Megan racing Street Coilovers whos riding on them?
- Low Fuel Pressure??
- Stripped nut on fan clutch need some ideas.
- fx35 wheels
- A manual SC400 is born: DD build thread
- Do you think the SC is a hard car to make a wheel look good on?
- ems choices and help
- 1JZ Sticky Idle symptoms?
- Need Help with my Loss of Power
- Window regulator killing me. See pic need HELP
- What was the story behind the Dave H orphan turbo kit?
- Will Supra or LS400 REAR calipers fit properly on Sc400 with Goodridge SS lines
- What mount and crossmember for R154 into SC300? (have searched)
- Control Arm confusion
- New Addition / Member
- well decided to keep my sc300 need some build info
- Need help w window regulator!!!
- Maybe a happy new sc300 owner
- Yet Another Incident... Slight Bumper ID.
- A/C smell
- W58 Clutch and Flywheel
- So my SC is overheating and I'm still deployed..Awesome.
- Rear Toe link???
- just bought my first lexus
- Window motor really starting to aggravate me.
- 1995 sc300 5 speed for sale ?
- 1jzgte swap into 93 sc300
- Another power antenna question
- OEM Fuel sender ohms range
- Neutral Safety Switch
- control arm bushings and ball joint
- Are these bad caps???
- Garrett t04e BB 60-1
- Can anyone help explain this: low AFR under boost and no Fuel Cut??
- Has anyone ever reinforced the rear trunk wall to support amps?
- Tire Stretch Guru's Please take a look(255/35 on a 13in)Having Trouble
- Cuirous re # on SC300 manual ECU
- Bought JDM wheels off an ebay what you guys think?
- What size spacers will put 18x9.5 +45 wheels in the "SWEET SPOT"
- Sparco seat identification?
- Need help, maybe ecu related
- AIRTEKK's Project SC
- ID my skirts!
- SC 300 Failed Emmisions Test, Replaced 02 Sensor...Still Not Passing
- lost.... im new to the lexus scene and need a lil help please :)
- 200k+ miles on your SC300?
- Need Pic: HID In OEM Projectors
- lost on what axles to run help needed.
- Ride diff from 17 to 18
- Help my wife install a grill on my sc400's front bumper
- 1UZ-FE Or VVTI 1UZ????? S13 swap
- sc400 cranks but wont fire up.
- Aftermarket clutch/gas/brake pedal assembly
- My new custom exhaust SC300
- SC car mats?
- Some help identifying a front bumper..
- 1jz vvti intake cam seal?
- Ride along Drift SC
- Trac light on...
- R154 manual swap needs clutch ??
- Gas mileage
- Where can I find parts for my sc
- some quick shots of scs at southern worthersee
- sheepskins
- '93 fuel filter and rear seat back
- Black on black, let me know what you guys think
- Please help! SC400 won't start!
- 5 speed pedal swap
- Installing new -6 AN braided fuel line/Aeromotive filter. Will these parts work?
- Club NA-T KIT
- 1uz Injector Rail Torque Specs??
- interior reupholster help!
- 1JZGTE Single Turbo Boosting SLOOWWWW HELP
- lower ball joint and control arm
- MAS performance sc300 runs a 9.8!!
- Please help me, don't wanna ruin new rims
- OBDI vs OBDII engine harness
- 2jzge obd1 code 14 please help
- is clutch pedal spring supposed to be super stiff?
- Walk through for installing BOV
- low idle and no ac, 1jz vvti
- GTR and SC at the track
- Shef's 1100whp '93SC400 Rebuild / Makeover
- Who Can HELP Me
- Seafoam!?!
- Need to verify exact length difference for factory R154 Soarer shift extension vs MK3
- Complete! 99 SC400 Salavge restore
- 93, poor low end power. solutions?
- 1999 SC300 bushings
- SC400 quantum-auto swap
- KA24DE Trans on SC400?
- startup hiccups sometimes
- Inexpensive Rear Lower Lip That matches 97+ Sides?
- Build help.
- Why want SC300 turnover?????
- Driveshaft deminsions
- Pulling out all my hair!!
- K&N Intake from a GS400 on my SC400, finally its been done with a pic!
- Ahead of its time
- Help a noob out.. A341E trans swap A LOT of Questions!
- ECU died!!!!
- Front Bumper question pre-97
- Need advice on what to price rims to sell for
- sc300 1jz swap help help
- Na-t vvti do I use a tt head gasket?
- Cluster compatibility vs rebuild
- Washing the SC [video]
- Book that reviews the Lexus SC400: Not many...
- Will a 99 3-spoke wheel and airbag work on a 97?
- O2 Oxygen Sensor LIES for the 1JZ... 4 wire to 3 wire conversion?
- NA auto shift kit?
- Titan Motorsports: Aeromotion Wing
- 1JZ VVTI FPR vacuum switch / solenoid?
- How much did you pay?
- 1993 lexus sc300 mpg ?! Awful help !
- Ebay Tails GONE! Stocks on, UNhacked Wiring, Left running lights OUT.
- New addition!
- Gs300 pumpkin swap into my sc300?
- R154 - Ridiculously high clutch engagement
- Rear Ended By SUV
- Pics of 92 SC300 5spd Im thinking of buying
- 97 1uzfe sc400 ground start run
- 1jz vvti second fuel pressure regulator under intake manifold?
- Seeking advice from NA-T expert ha!
- 1jz/2jz vvti aluminum accessory pulleys
- which driveshafts for your sc300
- Alarm problems please help!!
- DIY: 99 SC400 Valve Cover Gasket, T-Belt, Water Pump etc..
- 92 sc400 w58 no crank/no start. NSS wiring?
- The Future Of The Sc's
- Battery Draining?
- Got into a little accident
- hard oil feed line
- Helpp..interior lights stop working
- Is there a way to adjust the cluster brightness without turning lights on?
- Strange Occurrence!!!
- Need help with window regulator
- need to find injector orings
- Safc2 in 97 na-t, help
- Door lock "stuck"
- Battle Version Upper Control Arms
- What Kinda Wheels Are These
- new case for 97 remote
- SC400: Hesitation above 1500rpms
- temperature gauge issue on swap
- What is wrong with my SC!?
- My SC!
- Help...CEL 15 Ignition Signal...starts then dies...
- AC Codes 23 42 and 43
- My poor baby and my new one!
- MKIII R154 shift housing extension?
- Stuck... -.-
- Should i Upgrade to a '00
- anyone try this mod yet?
- 97 SC300 Cluster Repair
- 2JZ-GE ACIS Intake Vacuum Control Valve install questions
- How many manual SC300s do you think there are
- 1JZ W/ Sc300 shroud and fan??????
- Thinking of buying 93 SC300
- 1993 lexus sc300 2jzge questions about boost ? Please help
- White Soarer with black emblems..
- ?? for na-t guys, What is this for?
- Question on MAF's
- Cameron Moore's SC
- Supra prices "ticking" down? SC's prices "ticking" up?
