- Knock sensor help
- passenger floor flooded with water whenever it rains
- Won't start ..
- flat emergency key stuck in ignition Gotta be a simple answer?
- Sign of future transmission failure?
- Hole in oil pan of 1999 Lexus
- 2003 Lexus Plastic CD trays ?
- Front metal clanking noise going over bumps.
- Rx300 are there parts desirable to Camrys etc?
- Yet another transmission issue
- Passenger side power mirror not working
- RX300 01 Transmission gears slipping help please
- o2 sensor heater RX300
- 2003 rx300 Relay and Wiring Info/Diagram Needed
- 1999 RX300 Trailer wiring harness?
- Glove Box Hard to Close
- 2000 RX300, transmission removal
- Transmission 1999 RX300
- Double unlock
- '99 RX300, missing rear wheel bearing dust seal on knuckle
- Performance Difference between Transmission U14E and U140F
- Rx300 2003 fuse box location
- 1999 RX300 Engine Swap
- warning tone and radio issue
- Warning: Do not buy parts from EBay seller
- 2000 RX300 - Overfill Check Valve? p0440?
- HELP! Code P1350 quit while driving, will not start!
- HELP! Door Locks
- Cam Timing Marks & Crant mark - off by 3 teeth
- Failure of power windows, door locks, radio, and climate control
- Electrics Not Functioning
- 2003 rx300 door locks actuators wiring diagram
- RX 300 Sub replacement
- Keys lesson for the uninformed...
- High-Pitched Squeak when Turning Left
- Looking to get a Ski Car 2000 Lexus RX 300 4WD worth it?
- 2003 RX300 Steering Rack Bushings
- how to remove the driverside door panel
- tail lights not working (SOLVED) OEM trailer light controller burned up
- Tyres for rx 300 2002
- Throttle Surge and Cruise Control
- Lexus is 220d kr56ydm
- Accidently bought very tall jack stands
- P1135 and P1130
- P0171
- were can I find a front bumper cover 2000 rx 300
- Does this sound like bad oil pump?
- Dome light wont go off - Green ring around key stays on
- High Idle After Battery Died
- Floor jack point for front end of 2001 RX300
- Slip indicator light flashes and front wheels can't move
- Replaced actuator motor, now remote doesn't work?
- Starting Problems 1999 RX300
- Door Lock issue
- 2001 Tranny failed
- Manually lower radio antenna for car wash?
- Interesting RX300 AC issue huge rain
- Alternator belt tensioner
- No heat on left , no a/c on right
- powersteering makes a lot of noise
- Car makes metal clanking noise on bumpy road & some freeway driving.
- brakes pulsating
- Engine Ticking Noise
- Blue Smoke at Startup
- Upper Oil Pan Removal
- Lexus nailed by tree during Irma
- Huge problems with RX300
- Lexus RX300 return?
- Front Brush Guard
- Non-extending antenna
- Are these fluids normal color?
- 2003 Lexus RX300 front Right window switch
- Confirm Rod Knock?
- P0420 code + horrible sound from engine
- Would capping off the PCV valve throw a code P0171
- Rear Passenger Door Stuck/Locked Closed
- real or fake flea bay Denso MAF
- Intermittent starting issue
- 2000 RX300 Oxygen/Fuel Sensor Issue
- where is the acc cable and cruise control throttle cable
- New buyer looking at a 1st gen around 130k.
- RX rear stabilizer bar - how much difference does it make?
- where to buy cheap Amsoil Transmission oil
- AWD RX300 forgot to drain front differential
- Replacing Flasher relay
- 2003 rx 300 not blowing air through certain vents
- Need RX 300 master key
- Full list of interior light bulb types for RX300?
- Buying a 2000 rx300
- 2000 Lexus RX300 Fuel Shut off Switch
- ground effects
- door lock actuator, Now Unlocks and locks opposite the original 3
- Door stuck on lock, won't open
- car value
- Advice on buying a '99 RX 300 that used to be in limp mode?
- Questions abot Transmission - Please Help
- 1999 RX300 - Fuel Gauge
- RX300 2000 Shift Solenoid E
- 2001 rx300
- Air vent noise
- Low compression
- Cannot disable the alarm system
- Alarm system
- 2000 lexus rx300 power door lock i
- Help: Considering 2000 RX300 170k mi
- Can I get these on my 2002 Rx300 without any special mods?
- Old School VS New School
- Unplugged power antenna now no sound from radio
- BFG AT T/As on 02 Rx300?
- 1C0 (Millenium Silver) Paint Matching issues
- is it dead?
- Better to buy a late 1st Gen or an early 2nd Gen ?
- 5 High Mile First Gen RX300 of Forum Members
- about cars
- Is friend ripping me off on knock sensor replacement?
- P0300 and P0301 & P0303
- Brake caliper bracket woes-warning about part
- Fan blower seems to not be blowing
- remove the green window tint
- 3rd brake light - in the rear hatch - problem with blowing bulbs
- Noise under the car when on reverse mode and steering turned
- Mystery part dropped from under my RX300
- Rx300 remote not working
- Old Timing Belt Not aligned!
- Loudsy noise after starting up, difficult to accellerate in 4,5 minutes.
- Gear switching
- dash board all light go off when driving
- Cylinder 2 misfire photo
- Fix a small dent by the wheel
- 1999 Lexus RX300
- o2 Sensor locations
- shift problems after JDM tranny replacement
- Lexus RX300 won't start (ticking sound)
- Not liking my clearcoat headlight job
- Washed my pants with the car key in the pocket. What to do?
- clunking rattling in glove compartment. Not fan.
- why does my RX300 vibrate at speed above 120KM/h?
- Ambient temperature sensor electrical connector
- Pin connector diagram for power seats
- 2000 RX 300 jerking @ 40 mph
- rx300 won't shift into 3rd, 4th or 5th gear all of a suddden
- RX300 Front Passenger Window Issues
- got a replacement stock grill for my 2001 RX300
- cross referance lexus and toyota parts
- Rattle caused by loose engine cover
- VSC, TRAC OFF, CEL - New gas cap does not seal. Any ideas?
- Terrible bog lag jerkiness in acceleration
- can't get power steering belt back on
- Check engine
- Got new keys...the dealer wanted insane amount to replace a key
- Anyone paint the bezels around the display?
- Replaced Driver Lock Actuator...Odd Behavior Now
- HELP! - Can't open rear passenger door
- How hard to do driver's side mirror on 2000 RX300
- can a bad oxygen sensor cause a misfire?
- 2000 RX 300 Reached 200,000 miles
- RX300 Belt squeals if started with AC on
- 2002 parts car
- How to remove spoiler?
- How to replace black window trim and where to buy a new one?
- Which air/fuel sensor?
- Runs Normal when cold, sputters once up to temp.
- 2003 RX300 Code P0155
- RX300 transmission repair in SF Bay area
- 2015 Lexus RX350 Navigation System
- Airbag warning light - No codes
- Radio and A/C won't turn on; Navi turns on only for 5 seconds and then shuts off.
- Is it dangerous to be driving Lexus Jeep 300 with engine warning light onthedashboard
- Can I permanently remove/disconnect the mode server
- Power steering line part number?
- T-REX single 12" sub install trunk mounted
- Uneven rear brake wear
- Key wont insert all the way to unlock or lock driver door
- Where is the flasher relay on the RX300?
- How to remove map light housing?
- RX300 blowing "Gauge" 7.5 fuse after using key to open windows
- Left rear brake binding
- Engine light on light on?
- Noise from behind center console
- Timing Belt AND Tensioner?
- hi it's been awhile..
- 2000 RX300 struggles to run after filling up with gas
- 2001 Rx300 Fix, or sell/junk/donate?
- Headlight Assembly Help!
- cabin noise on bumps, AWD to FWD conversion
- Need help asap brake failure
- RX300 Keyless entry not working with new actuator
- Valve cover gaskets
- Crazy Alternator Issue - Or is it
- Remote keys no longer work
- Does any body own a kx200t
- Key Code Lexus will not provide
- Grom Audio stereo adapter?
- Looking for advice (Stripped/Rounded bolt during Coolant DIY)
- 2000 RX300 makes fluttering noise above 4k rpms
- 2000 RX300 Shift Solenoid D Malfunction
- P0218 code - How much coolant do I need to replace the thermostat
- Strut/shock replacement
- Alternator Voltage Question
- hs250h year 2010
- transmissions problems
- A/c blowing hot air and a/c light blinking
- Recharge A/C
- Car jerking after dead battery
- transmission swap in 2002 rx300 fwd ,What will fit ?
- Lexus RX300 issue
- Unable to control A/C temperature
- Rx300- heard a loud pop from under car while driving ....
- P0005 fault RX300 2002
- Rear Toe Adjustment?
- installing stereo in 03 RX300 harness
- Help Needed - Rapid-Fire Noise from Gear Shift Box
- I'm new here and need some help!
- Replace wheel bearing or whole knuckle?
- DIY replace V6 ignition coil P0301
- How to install heated seats?
- water in fuel tank
- Help Identifying Bolts ASAP! (Part #)
- Rear clunking noise on 2011 RX 350
- New owner, I have a few questions.
- Steering rumble/grind
- Best product to remove engine sludge
- Coolant Drain & Refill
- Weird issue after replacing driver door actuator
- 1999 RX300 misses, stumbles many fault codes?
- Control blower motor - heat resister rx300
- Toyota Harrier 2000 (aka Lexus RX300) - Auto Locking
- lexus rx300 bogs misfires stumbles
- Rx 1st gen. vibration over 70 mph. tires, suspension, alignment?
- 2000 Lexus RX300 Console will not open
- Passenger side window is not coming up. I can hear a clicking sound, but no action
- What exactly is this part called?
- 2001 rx 300 low beams not working.
- pcv threads no threads
- Is there a CHMSL LED Bulb?
- RX300 Servos
- How do I remove rear seat power outlet?
- part compatibility for oxygen sensor Bank 1 sensor 2
- 2000 RX300 FWD transmission
- Broken Sunroof
- remove front small triangle and rear quarter panel fixed glass
- Zero Point Calibration clarification for 2002
- 99 rx300 after new transmission install
- RX 300 AC Problem
- First Things First
- Dim headlight question
- Noise on my rear tyres
- Actuator Replacements need reprogramming?
- State inspection headache!
- Replacing Bank 2 Sensor 1 2001 RX300
