Passenger side window is not coming up. I can hear a clicking sound, but no action
I have the same issue. Eventually it will come back up. Happens more when it is hot outside. I used a dry lubricant 'Blaster - The Dry Lube' It did help a lot by reducing friction,, but has started acting up again.
I would take off the door panel so you can check out the entire apparatus and see if the window regulator is broken, or if the window track is binding the window from moving.
Check out this thread for discussion of window problems: https://www.clublexus.com/forums/rx-...s-stay-up.html
This thread has photos of removing the door panel; https://www.clublexus.com/forums/rx-...-write-up.html
