- Minkara Carview Site Japan with lots of Harriers/RX300s
- rubber boot on the rear shock absorber is cracked.... how do I replace it?
- what is the CCA rating of the original battery that came with the 2001 RX300?
- CEL/VSC Sensor problems..!
- opinions on ATF change
- RX300 rear winder spray
- how many ATF drain/refills does it take to really clean out the auto transmission?
- need advice on replacing the two trunk stay supports...
- Catalytic Converter 00 RX300
- RX300 stereo questions
- RX300 Bad MPG
- Post a pic of the dimmer switch
- Passenger Side Headlight Problem
- Noise in my 2002 Lexus RX300
- does power steering fluid inside the reservoir circulate?
- Transmission failure mode
- Headlight molding
- Ac problem
- Help! Low groaning sound. What could it be?
- Remanufactured Transmission "Harmonic" Vibration
- Verify Power Door Lock Actuator Fix Please
- CEL Help
- Engine computer
- Headlight Failure
- Yet another tranny failure
- Original window sticker?
- Exhaust (?) noise
- steering wheel make rubber sueaking noise in cold weather.... how to cure it?
- Locks, windows, fuel and temp gauges not working.
- RX 300 not shifting into OD...
- Small town savings or Not?
- Problem with CEL
- Help!!
- Timing Belt?
- battery issues
- is this a good buy?
- ECT Snow?
- How many keys can I have?
- Hellooooo
- P0330
- Is hand-tightening adequate for oil filter????
- Drivers side window control replacement
- Heet in the gastank?
- Mobil 1 0W-30 advanced fuel economy
- 99-03 more sturdy?
- How do you get the left side crank to line up?
- p0136 code...air/fuel ratio sensor DIY help...'99 rx; 177k miles
- CEL On, Random Misfires, P0300/p0303/p0304, P1130, P0172, Running out of ideas???
- Possible solution...turn-off overdrive?
- Where is the DVD Player?
- Maximize the Amsoil
- Water in blower cavity froze - Stopping blower
- Steering makes slight squeeking noise when (only) turn steering left...
- Gear Shift indicator bulb replacement
- Coolant leak
- Glove box blowing out cold air on passenger floorboard
- Bad braking but pedal pushes back
- Freaking out!!! Cel codes $985.00 repair!
- RX300 valve cover gasket change
- Could my spark plugs be flooded or faulted?
- Side Mirrors
- Erratic a/c fan speed problem RX300
- Motor or Pump?
- Crankshaft pulley bolt removal...
- Transmisson for awd 2000 and 2002 same?
- From Bob`s site again
- Timing Belt Jumping/Stretching??
- actuators
- Noisy Interior (Cabin) Fan
- Wheel Alignment
- Check engine light on 2000 rx300
- Car Audio Help
- Front end "whirring" noise after 40mph - How to DIY repair?
- what do you guys think about these rotors?
- is it possible? IACV question...
- warning codes
- Tein coilovers worth it?
- Refueling The Rx300, problem
- How can you tell if you jumped timing?
- Low Quality motor oil
- Help need some option!!!
- Car died while driving...won't start
- I want to buy a RX 300...any red flags i should know about?
- Interchangeable seats?
- Recommended maintenance
- Need New Tires
- Low beams aren't working 2002 Rx300
- VSC on 2001 RX300
- Yet another Transmission issue
- Happy New Year
- Rear strut squeak
- Transmission slow to upshift when Cold <30 degrees F
- scuffed rim, where to get paint
- Changing transmission fluid again thinking about amsoil?? Or stick with OEM fluid?
- transmission problems or failures????????????
- Oxygen sensors and thermostat issues
- i.a.c valve
- 1999 rx300 motorweek road test
- I think my RX300 would give this car a better run for its money
- $%#@#&* Oil Filter
- Quote on leak
- Another Transmission Fail?
- quick question about battery output
- 2wd or awd
- Need help
- fog lights always on?
- Happy Holidays!!
- 2001 RX300 rear bumper removal
- timing belt brands
- cigarette lighter elect system
- ABS HElp Please
- rx300 trans fluid capacity?
- city or highway harder on transmission
- Sticking throttle
- 2000 RX300 2WD Stalled & Shut down
- on board display problem
- '99 rx 300 sun visors
- Is there a light out reset
- Lost Keys
- RX300 Stereo integration
- Who's roll'n on 20's...
- 02 rx300
- 90k sigh
- Toyota Harrier 1999
- replacement battery
- Where to buy factory RX300 carpeted cargo mat?
- 2000 RX300 - Trailer Towing Package Wiring
- RX300 Won't start At Times
- Water leaking into cabin behind driver's seat
- VVT-i engine codes?
- Where to buy Transmission Rebuild Kit??
- if I stick a tube down the radiator coolant cap openning, how far down will it go?
- 2000 rx300 interior light problem
- Cranking noise driving from a stopped position.
- RX300 - Instrument Panel Fuse keep blowing
- 99' Rx 300 Rack and Pinion Assy play
- Trans flush
- Dexron VI
- original struts
- mobil 1 0W-30 advanced fuel economy
- Rear Brake Pads
- 1999 RX300 Lug Nuts
- Sludge 2003 1mzfe engine
- Remote Control Help!
- Tail gate gas charged lifts
- 04 Rx300 - window quirk?
- RX uses 1/2 quart in 3000k on GC
- rx newbie and need some assistance please,,,
- Driver Door Won't Lock or Unlock using key transmitter???????
- New wheels on the RX! (pics)
- Pics
- 96,000 miles need to service
- Rear Defrost Not Working
- Fuel Filter
- Battery warning light
- shift lever stuck in park- causes?
- Will RX330 stock wheels fit my RX300?
- Shock abosorbers part #
- Help! rpm needle revs when at a complete stop
- Ping and clatter
- 1mz-fe
- Smelly Car
- Click in Steering Wheel
- Best car scratch remover?
- throttle position sensor
- rx300 tuneup
- Car wont stay on
- Coolant leaking on 2002 RX300
- cel
- WTK: RX300 Compatible Transmissions?
- Auto-RX
- 5W/40 Oil ok to use?
- Happy thanksgiving!!!!!!!
- RX Awards
- my moms 2001 lexus rx300 needs a new transmission
- The Gear shift lamp Out where we change gears
- WOW!! 1st time coming in here
- Were the glass AWD trannies fixed in 2002 models
- Anti lock Brake Issue
- Pass side mirror assembly replacement
- custom rims & tires
- A/F O2 P1130 P1150 Check engine vsc etc
- sludge! ticking time bomb?
- Unknown beeping noise from rear
- Starting problem (have to step on the gas)
- buy power antenna: broken
- back hatch wont stay open when its ridiculously cold
- First Time on Board -- Transmission?
- dead transmission! Highlander trans different
- 22" Rims
- Best replacement speaker
- Lexus rx300 2001 wont start.. Please Help!
- Where do I install the rod on my lock actuator
- Transmission - timing belt problems...
- where to find clear side markers
- Unknown oil Leak from bottom of Engine
- Code P1133 and P0171 for Lexus RX 300
- How to lockcentral diff
- Front Arm Rest Removal-How?
- Exhaust Leak front of motor?
- new battery causing alarm to go off
- Timing belt should I or shouldn't I
- High RPM Ping
- Which motors can I use??
- no power to cigarette lighter and side mirror adjuster?
- Cruise Control ECU Replacement
- P0440, P0441, P0446 and P1150
- Cracked Exhaust, Manifold, brown tranny fluid and more
- tilted steering after tire rotation
- When should you replace RX300 springs
- Great.. Knock sensor
- Rear runner light fire
- False "Rear Bulb Failure" Warning
- Headlight "lense" Removal?
- Wants to change engine main seal & bushings for transfer case
- VSC/Engine light & codes P1135 & P1150
- 99 RX Side Air Bag did not deploy
- p0022 on neighbors Highlander 2003
- RX300 Speaker Installation
- Rear Spoiler Installation / DIY???
- replaced my washer fluid pump
- Lower Control Arms - help
- Transmission pan gasket
- Radio Reception
- RX300 Storage In Arizona..Help!!
- Anyone know where to buy 3rd High Mount LED Brake Light?
- sneak peek / teaser pics.
- Please HELP! Just purchased 99 RX300, ECT/SNOW Light Dead
- Toyota coolant
- RX 300 Engine Codes
- When 7440 bulbs are not my rear blinkers!
- RX 300 Trans. Filter
- Headlights
- Rear Hatch Gate Issues
- Marvel mystery oil
- Tranny question
- Tail light exchange
- my lexus rx300 starts choking when I push the gas pedal
- engine codes: P0171, P0300, P0136 and P1153
- need maintenance schedule
- ** Did your signature image stop working? Here's how to fix it! **
- Does this look like sludge?
- odd noise coming from the glove box
- '99 RX300 Squeaky Driver's Seat
- Is Rims On Rx
- air intake clip broke...
- 6,000 rpm yesterday!
- The viscous coupling
- Looking for a "Rod Millen" front bull bar for RX300
- is there a better AC cabin air filter than the original Toyota filter?
