- after the catalytic converter, what size nut?
- Game Over
- Need advice on my 99 RX300
- Blinking Engine light?
- Seat Backs Popping Off
- is it safe to use 70w fog lights?
- Possible transmission problem with my 2003 RX300
- How do I replace the light inside the car?
- Comments on this transmission fact pattern?
- p1135-p1155 code
- Is the DRL the high beams (9005)?
- hid kit
- Hard to remove gas cap
- Blue license plate lights/cops
- The plastic thing that holds the trunk cover
- 2003 Struts- Reccomendations?
- RX 300 Windshield Molding Help
- 1999 RX300 Opportunity
- Rx300 awd -2000
- 2000 rx300 awd
- 2000 rx300 awd/lights issues
- my first rx300
- Urgent Help Needed PLEASE... 1999 rx300 AWD
- New RX owner question
- What are your stereo settings?
- Need advice 1999 RX300
- P0134- Oxygen Sensor Help!!
- Can I use different antenna in my RX
- P1130 & P1150 as car is warming up
- Rx300 awd -2000
- 200-300k Odometer Discrepancy
- Anybody got HIR headlights?
- ATF Protectant
- New to Lexus and forum!! Got a question....
- Getting 14.5 mpg a gallon ... what can I do to improve?
- Someone call P.I.T.A b/c I am about to whip a dead horse
- Annoying Starting Problem
- Special socket for Ball Joint R/R...?
- 99 RX audio upgrade log
- Air filter and Oil filter questions?
- Ongoing clicking noise with 10% overall power.
- rattling
- Just noticed the car was leaking fluid.
- Is she (wife) really running gas that low?
- DIY diagnostic software
- 2000 RX300 FWD Maintenance Questions
- how to remove my grille!!!!
- DIY Video: 1999 Lexus RX300 AWD Complete Rear Brake Job
- RX300 2001 rust spot on roof and on side of windshield
- Where can I buy a lugnut for a 1999 RX300?
- Odd Sound coming from heating/air system
- "D" Light inop in Speedo Cluster
- extended warranty
- Rear brake pads and brake fluid flush
- 5W-20 or 0W-20 Back-Spec
- LED Interior Lights
- paint fading off.. suggestions?
- How to Change the rear side marker light
- GROM unit ???
- Intermediate Steering Shaft
- cold weather shifting
- Leather Restoration
- RX300 2001 codes PO171, PO174
- weatherTech VS Husky Heavy-Duty Floormats
- 1999 lexus Rx300 AWD
- Lexus RX300 1999-2003 P0021, P0300, P0304
- Lexus RX300 2003 Check Engine and VSC lights came on at the same time
- Instrument cluster lights
- Question on antenna motor issue
- Outside temperature display is way off
- Strut Mounts...OEM?
- Floor mat recommendations?
- My truck won't start ?
- What is the cd changer worth?
- Messy oil change fix
- Which kit for bluetooth and iPhone in 2001 rx
- RX 300 rollover audio warning?
- A/C temperature knob doesn't react
- iPod/Aux-in for Nakamichi?
- lisle antenna nut socket - must have for antenna repair
- 01 RX 300 Air fuel sensor code p1135, p1155
- Photo DIY: Changing the fuel pump
- Upgrade the tranny fluid cooler?
- Oil Change
- Blinker's Bulb Replacement
- LED license plate lights DIY?
- Oil Leak 99 RX 300
- Preparing for 90K service- any advice?
- Transmission Fluid Level (with Visual)
- oil filter recommendation
- Fog Lights.... Yellow or White?
- Remote key receiver
- Looking for a mesh AT filter
- Strange 01 Rx 300 audio sound issue when closing glovebox?
- My backup camera install/DIY
- gold vs. silver
- DIY: Clean Remote Key Contacts
- Left rear quarter glass question
- 10 Min Atomatic Transmission Fluid Flush + Replacement (Most Cars)
- Comparing Headlight Globes
- Calculated Load
- Oil puddle in throttle body and hoses big or small problem?
- 2001 Rx 300 vsc engages for no reason
- Nexen SB702 tires
- 2000 rx300 CEL codes p0330,p1130 and pp1150
- 200k Club
- RX300 New Owner / Member
- Backup Camera...
- need help please
- P1354
- 1999 RX300 Headlight/Foglight Replacement
- Can cleaning Idle control valve cause idling rpms to rise above 2000 rpm?
- Keyless Entry
- How do I replace the wing mirror unit?
- selling the rx...but for how much??
- flickering or pulsating lights any ideas????
- Windshield wipers
- Which model you own
- Use toyota t-iv ATF for power steering?
- Changing Spark Plugs. Check for Bad Coils?
- mpg on the screen
- Heated seats and poor engineering
- Transmission Update
- Radio Replacement
- P0171 2000 rx 300
- P1130 and P1150 at the same time
- Cost of transmission service
- Replaced Struts - Not Front SB Links – Should I?
- Help identify this loose hose??
- 2003 RX300 - Transmission Worries
- ABS wire?
- 1999 RX300 What could cause a random misfire in Cylinder 3 and 5 only? P0303 P0305
- Help with 1999 RX300 189,000 miles intermittent miss cylinders 3 and 5
- Transmission service question
- Im thinking about get a remote starter? what do you think
- the major repair/new parts list
- RX300 LED taillights
- Sensor fell out of exhaust
- TSB questions
- Lean fuel ONLY 0171 error
- are these legit/reliable struts from ebay?
- 1999 satnav swap?
- Throttle Position Sensor
- lock button on the key issue
- PSI tire pressure and monitoring valve caps
- Where to find part number for DSL Shift Solenoid
- Have you noticed this?
- Replacement Engine for 2000 RX
- Cabin Filter location RX300 with CD changer
- Does anyone have any experience with ...
- Mechanic says my 2001 Lexus Rx 300 needs a computer?
- Wheel offsets with 20's
- How much should struts/shocks cost me around?
- What fluids are important to be changed?
- Buzzing sound on throttle advance
- 115K Service Advice Needed
- Antenna grinding, but different than usual
- V timing
- replacement parts
- How high can we raise the RX?
- rx 300 code p1130
- Steering wheel upgrade
- Lexus RX/Toyota Highlander
- rough low idle tried everything......
- installing a cargo net???
- Battery
- Exhaust question
- Anyone with a car starter?
- no dome light and no headlight reminder chime???
- is buying a used exhaust system a bad idea??
- Heated Seat Thermostat
- Detailed information Links regarding Transmission
- rear tire noise please help me
- tranny drain and fill issue
- Smoother idle and 2 mpg loss after cleaning IACV
- Right Passenger Door Won't Open From Inside
- To keep or not to keep
- Found sludge in airboot
- Another seat problem!
- Rear collar & bearing
- Need small interior trim piece.
- RX 300 Lock Actuator and headlight issue
- Suggestions on adding USB to my '01?
- Recommendations for spring compressor tool??
- Transmission changes- 2001+
- What are the 2000 and 2001 RX300 Top Maintenance Issues
- What's Your Draw Man
- 2000 to 2001 tail light upgrade question
- GROM TOYA3 Issues
- how to replace engine air filter
- 99 rx300 front license plate holder issues
- Happy Holidays
- dead 99 RX300 - transmission??
- Torque Android App + ELM 327
- Transmission Problem! Will a flush fix it?
- Changing Coil Packs
- Stop working on your RX and
- Towing and the RX
- What are your tire's inflated to?
- Overfilled Tranny Fluid...Problem???
- 99 RX300 2WD "Knocking"
- Light vibration/rumble at idle
- new exhaust suggestions anybody
- ikeyless.com for replacement transponder
- Heated driver seat issue, rear tire noise
- Part number of Toyota OEM Serpentine Belt?
- HID to Halogen conversion?
- 2001 RX300 -CEL's: C1201, P1130, B2796 & Trac Control
- 99 RX running bad P0302
- 2000 rx gps navigation upgrade project
- AWD oils
- License plate screws rusted
- When Do You Turn On The Heater?
- Stuck ignition
- Mechanic in S Puget Sound (WA State)
- ongoing p0305 problems?
- Timing belt tensioner
- PCV Valve R&R whoops...
- Blacked out wheels
- Steering wheel Vibration/Wobble during braking
- Help with wiring!
- Power Steering Pump??
- Steering wheel vibration when exceed 70mph
- Need to Reset The CE Light. Which Fuse Do I Pull?
- 02 navigation in 99 model?
- Anyone with upcoming repairs they are planning to do
- Help with transmission/shifting issues
- On the fence RX300
- Will changing PCV valve help with oil consumption?
- Front Hub Assemblies
- Need advice - front/rear window washer motors
- Post pictures of your RX300 on here!
- Starting problems
- DEI Cell Saver Battery Insulation Kit
- New magnetic drain plugs for transmission + transfer case + front differential
- Can somebody please answer my question???
- RX300 - clicking noise when releasing gas pedal
- car stopped responding to keyless fob, where is the "receiver" located?
- No way to drive In 2WD
- Rear Strut Replacement
- Aftermarket ABS Speed Sensors
- Rear seat belt replacement (child got stuck / twisted it so had to cut it)
- Discount price ($74.99) on DENSO AIR FUEL RATIO SENSOR
- and the list goes on HELP!
- Is it possible to retrofit OEM navigation?
- Rear brake light dashboard indicator light
- Problem with dome light not lighting
- Need to buy rebuilt heads.
- Next project for install rear view mirror/display and backup camera
- sunroof issues ANY IDEAS
