PDA
View Full Version : RX - 1st Gen (1999-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Differential Drain and Fill
  2. Optimal Tools to keep in the vehicle ?
  3. Looking for recommendations on oversize oil filter
  4. Antenna Grinding when Retracted
  5. Looking for MAF O-Ring : Where to buy ?
  6. Lexus Junkyards
  7. Buzzing noise from transmission when ignition turned on - Normal ?
  8. RX300 Aftermarket Wheels...
  9. Vehicle vibrates when pressing brakes
  10. How do you primarily service your RX300?
  11. A/F Sensor NUT size
  12. Trailer Hitch
  13. noise from engine compartment when brakes are used
  14. Shocks/Struts for 1999 RX300
  15. Bumper fitment...
  16. Where to install transmission in line filter?
  17. Obdii Code 0171
  18. FWD or AWD
  19. Need to change shocks
  20. Hard Wiring Tow Hitch for 99 RX
  21. RX300 fan noise (blend door motor)
  22. yayooooo
  23. sport/power transmission mode
  24. persistent shaking
  25. HID retrofit complete
  26. Transmission FAILED - But Lexus stepped up to the plate.
  27. strut bars, lower tie bars, and sway bars
  28. shocks and air intakes
  29. Check Engine Light On/Off
  30. Replacement Speakers
  31. storage unit between seats
  32. Mirror Control Not Working- Which Fuses??
  33. Can you remove the oil filter without draining the oil first?
  34. po171/1153/1154/0125 where to start
  35. Can I polish RX300 aluminum [not chrome] wheels?
  36. fuel filter change
  37. Cross referencing lexus/Toyota part #s
  38. Changed the oil in my new to me 300 for the first time
  39. 225/70-16 vs. 235/70-16 tires/Alternative to Cross Terrains (merged thread)
  40. Check engine light
  41. Long Time, No See.
  42. Need advice on buying RX300
  43. Ignition coil stand-in/Other goofy things
  44. oil change reset
  45. did 2001 RX300's factory alarm system have glass breakage sensor?
  46. RX300 Aftermarket Suspension
  47. 1999 rx300 cutting off
  48. Subwoofers
  49. Rotor remove / repair
  50. I am tired of resetting my clock!
  51. Another intake modification (oh joy)
  52. DIY Throttle Body Removal to get at rear spark plugs
  53. running boards
  54. Destroyed ABS sensor, need help
  55. P0174 and P0171 CEL code???
  56. accessories catalog
  57. Clean Engine Bays?! PICS Please
  58. Oil filter tightness
  59. how to lock the factory roof racks so people can't steal them? (along with cargo box)
  60. "Bad Gas"
  61. Cruise control not working???
  62. Mounting a front license plate
  63. 2002 RX300 - Center Console Display
  64. Seafoam?
  65. 1999 RX300 Synthetic Oil Leak Issue
  66. codes came up
  67. brake light
  68. my experience with Auto-RX
  69. 2003 Tow Wiring Assembly Power Problems
  70. Power window failed
  71. RX300 Firewall pass thru for remote radar
  72. replace timing belt at 90 thousand miles?
  73. 80k, now what?
  74. No more bullhorn on the black bull?
  75. Suggestion: New FAQ on Common Issues with RX300
  76. Knocking On RX300
  77. Light/Fuse problem
  78. 2000 RX300 Transmission Problem, Help!
  79. Rear main seal leak, what are my options?
  80. Rear hatch
  81. Congrats Lexmex!
  82. 2000 RX300 transmission story
  83. Transmission Flush - Good or Bad ?
  84. Check Engine AND VSC light
  85. Washable air filter from fram
  86. help Blinking engine light in boondocks
  87. engine treatment PolyDyn TX7
  88. Worried about tanny :S
  89. Tranny question
  90. Freaking P0125
  91. Door panel removal DIY
  92. 2002 RX300 - Information Center
  93. Rx300 02 Navigation Update DVD?
  94. Main seal leak question (tsb?)
  95. window switch
  96. Want to do something nice for my mom...
  97. headlight problem on 02 rx300
  98. P1130 and maybe Leak
  99. Tire Rack & Cross Terrains discrepancy
  100. Front differential seal leak
  101. P1346, P1351 and others on new engine
  102. passanger window
  103. Engine dies out after starting - very low rpm
  104. RX300 NAV Options
  105. Trading RX 300 for RX 350 - What to expect?
  106. Marbles in the dash???
  107. RX Driver's Age
  108. black rx300...gold rims?
  109. Fuel strainer (filter) replacement
  110. eyelids
  111. Check My Infi. Fx 35
  112. check my lex
  113. Which do you have AWD or FWD?
  114. Need help fast! IACV
  115. Front rotor stuck help
  116. weird question
  117. Bogus Rear-Main Oil Leak?
  118. Really Basic Oil Change Question
  119. 2000 rx300, stereo volume not working, bass, treble stuck at "0"
  120. Catalytic/mid-pipe where to purchase
  121. European Mirrors (Quater Sides Wide, not flat)
  122. Harrier in Ice
  123. Any one cleaned the rotation sender/sensor
  124. Cracked exhaust and o2 sensor replacement
  125. Brentwood, Long Island to Manchester, CT
  126. INViSiON DVDs
  127. hottest rx
  128. gold taillight???
  129. Window tint pic request
  130. Code Cel
  131. p0125
  132. RX300 Window Tint Help!!!
  133. lubricate steering knuckle and propeller shaft
  134. P0717 transmission speed sensor???
  135. need your opinion MRR wheels..
  136. Automatic Windows problem
  137. I saw an RX300 with a club lexus sticker
  138. club lexus decals
  139. Stereo Wiring Diagram
  140. Engine is gone at 149,970 miles
  141. Braking issues
  142. a/f sensors
  143. Air Intake Mod
  144. change power steering fluid
  145. "D" Light on Dash burned out? or warning sign?
  146. Timing belt question
  147. Wheel speed senor replacement help
  148. FYI: P0125 -- Has nothing to do with coolant
  149. Repair costs
  150. Auto door lock programming
  151. Which Battery for my RX300?
  152. Factory Alarm Problems
  153. help: 2000 Transmission problem
  154. flashy rx
  155. HVAC decals
  156. Check engine code P0125 and P1155
  157. help where can i purchase this
  158. where is vacuum line for 99 Rx300, i want to use seafoam
  159. Ebay or Lexus-Parts.com for a new master key
  160. dual amps?
  161. Air Mix Servo???
  162. Stock grille Mesh Mod
  163. drive + play 2 + JL cleansweep?
  164. please help, OBD CODE 0171 bank 1 too lean
  165. Water on passenger floor from a/c
  166. RX300 leather seat covers
  167. Sun/Moon Roof Sound
  168. ticking/shuffling noise behind right dash
  169. RX300 transmission advise - help!!
  170. vais iPod integration
  171. harman kardon drive + play 2
  172. What brand of engine oil do you use?
  173. Help!!
  174. Bye Bye RX300, hello?
  175. change LCD color
  176. interior lights (photoshopped)
  177. courtesy light wire connection point?
  178. Auto-Up Window Problem
  179. Cracked Key Shell
  180. OEM stereo info please!
  181. type x-speakers?
  182. custom console and iBus integration?
  183. leather
  184. Sold my RX300
  185. interior ideas
  186. painting the gray border
  187. steering tightness
  188. Wiring a Remote Start...URGENT!!!
  189. Trip computer
  190. help! don't know what to do. wheels or air suspension??
  191. dynamit door kits
  192. whats the max tire width and inches?
  193. rx300 engine options
  194. sub's under the seat?
  195. ignition bulb
  196. oil cooler mod
  197. what's too much? wheels and rims
  198. aftermarket power lift gate/panaromic roof
  199. how happy are you?
  200. 65k
  201. What causes these codes? P0440, P0441, P0446
  202. Engine knock during acceleration
  203. Transmission fluid change
  204. 06' RX330 console in a 02' RX300???
  205. Are Philips Ultions 6k Worth It?
  206. Speedometer needle over 160MPH!??!?!
  207. Front vents don't blow enough air
  208. What is this noise?
  209. my rx300 FROZE ON ALL FOURS
  210. speakers/sound, what to do?
  211. Install gasket when renstalling oil drain plug?
  212. headlight alignment
  213. Replace Backup Lights
  214. Couple of Questions!
  215. need help with '99 headlights
  216. 89467-48011 bank 1 sensor toyota
  217. Car Warranty
  218. Suspension thoughts.....
  219. DIY on motor mount??
  220. Cost of replacing a timing belt
  221. ATF Drain/Fill amounts
  222. RX300 screen
  223. Looking for sludge?
  224. How to remove stuck goo from exhaust pipe
  225. Rear wiper problem
  226. Bunch of questions
  227. 1999 RX300 AWD ABS Senor
  228. burning smell inside cabin
  229. pimp my new ride
  230. Intake Manifold Removal Q.
  231. How Many Miles are Knock Sensors Good for?
  232. Timing belt - Time vs mileage
  233. Traction control and Check Engine light on...
  234. P0171 fuel system for bank 1 too lean
  235. Brakemasters in Sacramento Area
  236. Whp, Top Speed
  237. Help with both Knock Sensors replacement
  238. cannot program remote key if door actuator bad?
  239. Noticed Harrier emblem on eBay
  240. Where's the door switch?
  241. Is this the future RX?
  242. locking "beep" volume increase
  243. rattling noise and check engine light
  244. rx300 rims wheels suspension
  245. oil change
  246. LED Taillight mod problem
  247. RX300 Dash Cover
  248. GM-9086ZT Amplifier Schematic ?!
  249. Opinion on engine flush
  250. RX300 dead radio
