- antenna will not go down
- okay to use 215/70R16 on rx300?
- 1999 RX300 Specs and Production Info
- Oh no code P0770 !! one sick SUV :(
- Farewell
- **** i hate the midas service guy...
- Rx300 leaking headlights
- Lock button on the Key does not work!!!
- Timing Belt Question
- What should I do with my ride? lol
- Remote programming question
- New (frustrated) owner
- 2000 rx300 blower problem??
- '99 RX300 Cruise control not working - how to fix?
- 01 RX300 Check Engine, VSC, fumes, engine hesitation
- rattling coming from rear door?
- 2001 RX300 Spoiler question
- Yr 2003 steering wheel on Yr 2000 RX300
- Lowered RX300
- 2001 RX300 Headlight Help Needed...
- is the trans dead?
- Faint rattle while accelerating
- Intermittent AC Blower
- 2000 RX300 Bad A/C Blower Motor
- A 20+ year mishandling with wheel nuts
- Instrument Cluster
- HID Kits for 99 rx?
- my daughter and RX300 the same age
- highlander?????
- Trickle Charge w/o Disconnecting Battery?
- Got my shiny new '01 RX300 back today!
- Should or shouldn't I take this deal?
- Looking for mechanic in Fairfax VA
- Transmission or ECM? That is the question.
- A/C or Heater water leak?
- Glove Box will not stay latched
- How do you replace the Blower Control Module?
- sensor codes on RX300
- P0420
- Engine Block Heater
- 2002 RX 120k miles-Leaking Coolant not from Radiator Please Help!
- Roof Racks
- Problem to start engine.
- How many RX 300s were produced in Northern America
- new owner rx300 city mpg issue or normal?
- New to Forum.. 1999 rx300 owner
- Gold trim and accessories
- Several things: nothing specific
- Check engine light
- $1800 to fix airbag light on?
- VSC and Check Engine Lights
- New wheels are in...
- RX 300 Lost ignition key
- 2000 rx300 ac light blinking?
- UOA on Bob Is the Oil Guy
- Scratched paint
- Avg. Mileage display incorrect after recharged battery
- battery or alternator?
- RX 300 Cabin Air Filter change
- Looking for some info on a '00 RX300 - needs an engine
- fuel level gauge failure
- Door & rear hatch gaskets
- Air flow stuck in front position
- Brakes Breaking my Budget
- Impact wrench - need advice
- Seized Piston Ring RX300
- Exhaust pipe replacement - dry or wet fit?
- Instrument panel testing
- P1130 & p1346
- 2003 headlight adjustment
- Rear knocking sound and wheel play
- I am new and could use some advice
- How a "tired" Air/Fuel Sensor looks
- Crack in the Dash
- CC Malfunction.
- Where is the GPS Reciever Located in RX300?
- Does RX300 has an Adaptive Frontlighting Systems (AFS) Headlights?
- Help me resurrect this rx300
- RX Brakes are super good
- Stock Headlight Bulb (non-HID) Question? thanks.
- Maintenance Intervals
- Replaced my plugs
- Intermittent Heat -- 2001 RX300 AWD
- New oem alternator belt - noise
- New gas cap to solve my VSC/TRAC OFF
- Brake Light Sensor with warning sound.
- Knock sensor and Timing belt tensioner
- RX300 air shocks or H.D. springs
- Would you sell your RX300?
- 02 rx300 cel
- Brakes or VSC seem to kick in when accelerating from zero
- Heater not working
- Water Pump Studs
- help...multiple engine codes...
- So what is it?????????????????
- Sound system failure - need help
- Reset Security System
- Rear Seats!
- rear rotors ?
- Cost for a New Key
- OEM Quality?
- Cylinder 1 misfire - big job?
- LED interior?
- Humming Sound while driving
- Lexus Rx300 Rear End Clunking Noise Please Help!!
- Valve Seals/Guides
- 2001 RX 95,000 miles
- Code P0171
- Grom AUDIO usb/ipod adapter issues!!!
- Funny Noise???
- Navigation Info Help
- Newbie @ Lexus - HELP
- Door lock actuator fix? help!
- what is this warning light for??
- Head gasket
- Some transmitter key blanks do not work.
- water level sensor access
- Knock sensor problem
- Fitment question
- Installing fan on transmission cooler
- Speed Bleeders?
- What do you guys think about lpg conversion
- My 1999 RX 300 - Suspension problems and more
- Strange noise.... like a garbage disposal.
- Transmission stuck between P and R; car won't start
- Should I change back to synthetic oil
- What size bolts to pull the brake rotors?
- 2003 RX300 Moonroof won't Close
- Damage front caliper piston boots needs to be replaced
- brake pedal chatter
- Transmission
- Need help program the extra key!
- Tire size question (new rims)
- Driver's Side Windows Seal
- manifold sensors
- 2003 RX300: My first check engine light appeared (VSC & TRAC OFF)
- 2001 Transmission Failed at 131,000
- Outside Temprature Display
- P1137?!?
- Update 2002 RX300 navigation
- check engine light
- XM radio and ebay headrest dvd player
- is this related to the rear diff?
- need to confirm widest tire on RX330 18" wheel
- interior lights
- A/C Switch Possible Malfunction
- 1999 rx300 Major problem poss lemon
- What do you guys think???.........
- Hello
- security system problem
- Transmission Help
- New tires...any recomendations?
- Reading ABS codes
- How to set Compass
- How to access dealer maintenance/service records?
- PO171 and P0174 = Mass Air Flow Meter?
- Sensor Location P1135 and P1155
- New (to me) 2002 RX300 some questions???
- Front Manifold Cracked, PCV valve clogged, intake dirty
- husky or weathertech liners?
- Tranny temp hack?
- Downsize rim - brake clearance?
- window motor/regulator issues, any ideas?
- crazy lock problem
- Problems After Removing Battery
- Transmission Question
- Newbie - Harrier/RX300 grille emblem replacement
- Engine Sludge?
- UPSET, got PO330 code on newly bought RX300
- Are FWD and AWD suspension the same?
- Painted Front Bumper
- Any good Independants and/or Toyota Dealers in Phoenix?
- Paint for RX300
- Any tips/advice:RX300 front exhaust manifold removal
- Help a newbie buy a lexus
- Side Marker Light Buldb Replacement
- My new battery
- Oxygen Sensor (O2) Bank 1, Sensor 2 DIY
- How to look for exhaust leak
- Looking for RX for my college-age daughter
- RCA converter need help
- Door Latch Assembly
- Deactivate keys?
- Counter gear speed sensor
- cracked spindle knuckle - need to replace
- Cleaning under the hood
- Need bracket for Rear View Mirror
- Lexus RX300 remote
- genijet
- OEM running boards
- 02 sensor, mass airflow sensor and now knock sensor..
- New to this forum.
- Issues with my power windows
- CEL P1730 gear speed sensor
- Check engine and VSC light
- Brake light indicator on instrument panel?
- AC only blows cold air
- side mirror glass stolen
- I need your help/ideas
- Rididcolous airflow
- not downshifting at low speeds?
- Check Engine Light
- Steering Wheel Replacement
- CEL p0125, p1130, p1135
- Cel flashing and wont go over 40 mph
- My '99 is Moving to the Desert
- Rear End Clunking Golf Ball Syndrome Help! Please!
- 03 RX300: Front driver side door lock not working
- Fault code P1155
- Oil light on and engine has oil
- Gold Kit
- Rubber Protector over Rear Bumper
- AC went out!
- 99 RX300 fan at MAX speed then not work
- Upgrade Tires + Braking on RX
- Please help me identify this part
- )2 sensor parameters for a P0420 code
- bearing problem? right front axle...
- ipod
- good scanner code ?
- RX300 2001 light on D position?
- RX300 2001 strange sound in glove box
- rx300 2001 completely dead
- RX300 Drifts to left
- Power Locks and Keyless don't work
- ABS/Speed Sensor Problem...
- 99 rx driver window squeak
- do I need to remove window regulator in order to take out door lock actuator?
- '99 RX 300 Leakage
- anyone using Optima battery in RX300, if so, how does it fit?
- how often do you change engine oil and ATF fluid if RX300 only driven 5 miles daily?
- RX300 error code P0306 . How can I fix??? thank you
- 2001 RX300 low pressure A/C recharge port location?
- Is my car battery OK?
- 2003 RX300 w/82k- should I start using synthetic oil?
- Transfer Case Removal 1999 RX300
- SA said average miles to death of an rx300 is 220k miles.
- kicking. early trany failure?
- 01 RX300 Key replacement
- pre owned sales question
- A/C Control Knob
- Wheel fitment question
- My RX300 is smoking from the exhaust
- Clicking coming from interior fuse box
- Tranny oil change
- O2 sensor
- Rear caliper problem
- Accessory belt replacement recommendations
- 2000 RX300 getting code PO141
- Newer RX300 stereo into 2001 RX300
