- I need help finding an 1999 RX300 passenger airbag
- 99 RX 300 rear hatch
- "Rear Light Failure Warning Light" stays on.
- Codes P0125 P1155 P1153 P1155
- P0120 Code - 99 RX
- Possible sludge issue
- Cost to fix
- RPM rise when "shifting"....
- Locking malfuction
- Looking to Buy 2001 RX300 Silversport
- Transmission upshift delay when cold
- '02 RX300 noise from right front wheel
- when car is cold, and turning the steering wheel all the way, it makes a little nudge
- carb/throttle body cleaner on headlights
- Best replacement bulbs...
- **FIRST POST** :) Front Brake Problem
- Rear latch sticks
- RX Accident..Door got bent backward...help to find hinges or fix?
- VSC, CEL & TRAC OFF lights???
- Fort Worth,TX Service
- What type of new brake pads to get?
- Driver side-view mirror wobbly
- vibration in steering wheel above 70mph
- Hello all.
- P1150?
- Cylinder Layout
- Dark tranny fluid after transaxle service at Lexus???
- 2001 Rx 300 muffler
- Door Lock Actuator - A Different Solution
- Slip indicator on right turns, 2002 RX300
- Center wheel caps rx300
- 2003 RX 300 water leak.
- At idle, battery light comes on and radio cuts off.
- Timing belt noise stops when I press on cover
- Rear Axle removal
- P0442 code
- Engine misfires, p0305, cylinder 5 misfire
- DLC1 data link connector
- rough idle check engine light
- Customized 1st Gen RX Pictures...
- First Code ever on the '02: P1135
- Outside Mirror Shake
- 1999 RX300 Compass Upgrade
- Failure to start
- Rear bushings - any help
- Lights are out on middle console
- just replaced my a/c unit on my rx300...help
- High Rev on 2000 Rx300
- RX300 front passenger side window lift broke
- Driver's Side Door Lock won't operate from key remote
- Radio Antenna Problem?
- Easy way to find part numbers?
- after rebuilded the tranny.. ?
- Rear Rotors Help
- Seat interchange between years
- Self-Diagnosis on RX300?
- Help finding the Right Fuse
- RX300 Silversport suspension?
- premium gas? when to do spark plugs ?
- Trouble Code 1349/VVTi solution
- Transmission Fluid Question
- Front motor mount replacement
- A/C problem?
- High Idle on 1999 RX300
- MAF Cleaning
- Need help finding a replacement washer reservoir
- A/F Sensor Replacement
- Timing Belt. Years or Mileage?
- Timming Belt Change question
- check engine light/cruise control
- Dry or oiled engine air filter? What brand/type are you using?
- Couple ?'s to see what is wrong with mine
- Squeaking noise
- knock sensor
- Adding GPS in rx300
- ABS Vibration
- Leaking in the passenger side
- Roof Rack question
- Replacing rear center seat belt?
- Brakes Smoking after Pad & Rotor Change...Please Help!
- Help! Check engine light/VSC light on
- Metal strainer, where?
- roof rack cross bars
- AC blower motor
- Engine Compatibility
- Transmission "stutter"
- code po1155 solution
- 2001 RX300 Parrot MKi9000 install?
- Rough Idle on Cold Start
- need to get in wire inside...how
- Auto-rx results
- Front Rotors!
- connecting rod bearings
- Po420 error code
- Front end clunk?--> Diagnose sway bar links
- Ultra racing
- Transmission Filter Replacement
- Driver Side seatbelt making noise!!
- Fuel trims--Diagnosing P0171, P0174, P0172, P0175
- RX300 Navi?
- 2001 RX300 41,000 miles
- OEM Rotor's for Rx 300 yr 2000
- 4WD versus 2WD rotors
- headlight leveling malfunct. light
- Power Steering Fluid?
- auto level headlight indicator
- Motor Oil Filter Question
- rear wiper groan
- 2000 RX300 AWD Third Brake Light Out
- 1999 RX300 awd rear bearing and hub replacement----Please help...
- RPM's nearly doubled after IACV cleaning! HELP!
- Car Jack for 2001 RX300
- New member and new to Lexus, some questions
- 2001 RX300 Fog light replacement
- PCV valve upgrade
- need help
- Short Starts
- Left Pulling Suspension Issue
- recommendation for D2R bulb?
- brakes pulsating and grinding noise
- PCV oil into intake
- Transmission Issue?
- Trans control unit shifter
- New engine oil
- Code P0174
- Noise when starting
- coolant change
- Antenna stuck/ motor working
- CEL P0171-my experience fixing
- RX 300 Oil Consumption
- steering wheel shaking
- Error Code help
- Harness repair manual
- Help with engine repair
- XM radio install tip
- problem starting the car :(
- 99-02 RX300 FWD transmission interchangeable with other Lexus models?
- Headlamp Assembly Removal
- Looking for the Fuse Block Diagram
- What is this warning light?
- Breather plug on rear diff.
- Passenger Window Trouble
- stumbling, running rough
- metal noise under my car when bump
- Upper engine mount
- New Used Engine suggested for RX300
- How much preventative maintenance do you do?
- The sound of Muffler in the front?
- Car Problems and Issues (Front Right Tire)
- Whats the sedan equiv of our RX300's?
- New to Lexus. Thanks to all.
- Sonar Tail Light Installation
- Doors swing open
- 2000 RX300 Multiple Electrical faults
- How Do I Grease My Squeaky Cabin Fan
- looking to upgrade wheels from 16's to 17's
- 105,000 service visit and VSC/engine light on now
- any have a Front License Plate holder for 2002 RX300 or DIY pics?
- does anyone have a factory remote start?
- Whining from car only when cold
- 2000 rx 300 p1130 & now P1150
- corner light bulb
- Back this up?
- 200 RX 300 Leaking rear windshield fluid hose
- headlamp assembly
- 02 RX300 Cannot get out of Park-VSC+ABS on
- Keep the '99 RX300 or get another car?
- 2001 RX 300 0171 and 0174 codes showing
- rx300 rear hatch stuck
- Please help! headlight question...
- Looking for Rear Tail Light Cover
- SC400 brake disc conversion.
- AT Oil Temp light came on
- Towing Tow Wiring Easy And Cheap
- Anti Lock Pulses During Normal Braking
- rear end clunking
- Master Key Programming for 99 RX
- Replacing reflective glass
- How to change console language
- Is there a jumper trick to check CEL codes myself?
- A slight different transmission failure question - please help!
- rx 300 2002 france help
- Trans Fluid Change Question - 99RX
- Mold Pitting on Window Trim
- The bussing or winning noice from the transmission
- help - replacing A/F bank 1 sensor 1
- iPod & Sirius Connections for 2002 RX300
- Any DIY headlight removal?
- CD Player not working
- RX stereo just died...help =/
- High RPM's before shifting
- HID light bulb
- 99 RX300 with only 21,000 miles getting code P0500
- what to look for in 2002 rx
- I see transmission issues but...
- 2002 rx muffler
- How Lexus is screwing me on my Transmision
- Anyone looking to do a Highlander trans in an rx300
- Engine Oil Pan Leak at what mileage?
- Going to give a different oil a try
- Help - understanding code P1130 readout
- 2002 rx300 muffler awd
- Diagnosis scanner port
- 2000 Rx 300, With 85007 Miles -- Error Code P0115 --Help Help
- 2000RX: Clock resets on cold night
- I need help.. need to master key
- Front and Back windshield washer dead?
- HID Conversion Kits...
- Rear Window Washer Nozzle
- P1130 codes
- FREE GromAudio USB Ipod MP3 Adapter for RX300
- Informative website
- Finish (paint?) peeling on RX roof rack tracks...
- Tune up gone haywire?
- slotted rotors??
- Excessive Oil Under Engine
- Cel P0171 & Rear Light Failure Warning Light
- Retail/Wholesale Value of 2001 RX 300?
- Transmission Services, etc.
- i need new caliper for my 01 RX300- PLEASE
- Transmission cooler
- I need a New Engine. Advice needed
- 2001 rx300 front bumper cover
- Almost new battery time again
- Malfunction + VSC error lights staying on while driving...
- Front seat back panel falling off
- new rx300 owner
- Need to replace sensors.
- Anti sway bar
- engine sludge
- Buying a 99 RX..Help
- Might buy a 2002 RX300??
- Wheel with audio controls for rx300
- 2001 Rx300 Rotors and shocks
- RX300 knock sensor replacement DIY
- Insane Supercharged RXs from Russia
- Window Switch Problems Pass side
- Need help gathering information on transmission failures
- auto trans fluid flow diagram?
- New Master Remote Key
- Selling my 2000 RX
- passenger seatbelt
- Need advice - 2000 RX300 steering wheel
- Pennzoil Ultra
- Door open sensor and dome light
- how do you guys remove these bolt?
- How much ATF fluid is replaced with rear main job
- List what you've done to prevent transmission failure
- Timing Belt Kit On Ebay.....
