RX300 Front Passenger Window Issues
Old Jul 7, 2017 | 05:26 PM
JLH8432's Avatar
JLH8432
Default RX300 Front Passenger Window Issues
Front passenger window goes down and gets stuck when trying to put window up. How do I fix it myself?
Old Jul 7, 2017 | 05:51 PM
salimshah's Avatar
salimshah
25 Year Member
Have you tried holding the up button 'up'? There is pinch protection that prevent window glass from moving.
Other than the simple thing above, there may be a problem with a relay ... search and you will find lengthy discussion on it.
Salim
Old Jul 7, 2017 | 05:57 PM
JLH8432's Avatar
JLH8432
It works fine to put the window down, but when I try putting it up, the window goes down the whole way if it's not already down the whole way. Then I have to hold the window lever up until it decides to go up. It takes awhile for it to respond and go back up. Not sure what the problem is.
Old Jul 7, 2017 | 06:23 PM
salimshah's Avatar
salimshah
25 Year Member
cycle twice by holding the button till it reaches the top.
Did you disconnect the battery or did the battery run down. If so, the learning has to be done.
Salim
Old Jul 7, 2017 | 06:33 PM
JLH8432's Avatar
JLH8432
Nope, didn't do anything with the battery. I checked the fuse for the windows, and they are all good.
Weidnera
May 25, 2017 01:54 AM
Leines
May 8, 2012 01:22 AM
elvis1955
Feb 19, 2012 10:42 PM
mydann
Jun 26, 2007 11:00 AM
biotix
Mar 16, 2007 09:36 PM
