- Front tires replacement for a 2000 RX 300 AWD
- Are These Headlights Too Far Gone
- I keep getting P0778 code!
- Hello Americans...
- Center Console Pop Up Cup Holder 99RX300
- Foglight Day running lights
- Strange new noise
- Crazy Steering wheel shake
- New To Me Rx300 Dome Light /keyless Issues
- Confused about remote and key programming
- Where is engine coolant temperature sensor located?
- Valve Cover video and wire set rx300 1st Gen
- 1999 RX300 Radio giving me some attitutde
- Exhaust bolts
- Center cup holder HELP !!!!!
- Is this the CD changer cable?
- Acceleration issues, shifting issues, 99 Rx300
- Multiple ECU Failures/Electrical Problems...help!!
- Question re: oil control valve
- Door Ajar Will Not Turn Off HELP!!!!
- Rough idle / RPM drop when idling in drive
- Pioneer Amp Not Working...No Audio. Fix??
- Multiple Misfire Codes
- RX300 "no disk detected" issue HELP!!!
- Spring cleaning!
- Fans not blowing - Possible Blower Motor
- Shocks and struts options?
- Front Seat Removal
- Help diagnosing engine noise/problem
- 2001 RX300 HID Headlamp Assembly Info?
- Burning out coil packs
- RX300 - speakers
- Timing Belt Kits
- 2002 Rx300 Projector Retrofit
- Hitch recommendation?
- HELP!!! rx300 driver step side light
- RX300 Won't Reverse!
- whats your highway rpms and at what speed
- Replacement Key
- Colder A/C on 2002 Lexus Rx300
- Sell RX300 for an X5?
- Question on Brakes
- DIY: Front Lower Control Arms
- Drive it or tow it: P1346 after timing belt
- Prepping Your Used Engine For Install
- 2003 RX300 Engine Compatibility
- Dented and repaired oil pan OK?
- Window stuck down..
- 2000 RX300 Burning Oil
- Hella supertone horn installed
- 2002 head light removal
- 2000 RX300 Won't Go into Overdrive - P0125, P0330, P1150, P1130
- RX300: Terrible MPG average related to faulty transmission?
- 2000 RX 300 plastic ext driveside panel removal
- No power to fuse block
- Connector for center brake
- scanner
- Suspension Lift
- Devils advocate. Why shouldn't I buy?
- 99 rx300 won't turn on w/ loud noise
- 03 RX300 Noise under dash
- Which RX 300 to purchase?
- What mods does this rx300 have????
- code PO420
- Lexus 2003 rx300 driver side master switch problem
- sludge update
- Battery light, P1130, P1150, P0136
- Rear caliper replacement
- Help my wife's rx300
- Muffler is rusting through? Any Suggestions?
- New Member - Transmission issues
- gas mileage - depends full or empty ? is it true ?
- The Giant RX300 trans mystery problem
- Loose Steering Rack Bushings
- Lower control arm with ball joint question
- RX300 - change of radio unit
- Emergency Brake Cable - Stuck
- Code58
- can't start please help
- No spark after changing spark plugs and filters
- Clicking noise when turning on hills?
- rx300 Transmission
- Oily, black soot in intake/throttle body
- Bulb Out Warning Light
- Woe is me....
- Timing Belt Experience - Lifetime perhaps?
- New Member
- Rx300 error code po420 and car dies when idling
- RX 300 Side window sun shades
- heater core sweating on to carpet?
- Horrible steering issue......need help!
- CPU or alternator?
- Timing Belt Kit questions
- Replacing RX300 check engine light bulb
- Not sure what is wrong with my transmission
- Pinions rack oil leak replace please advice?
- Factory woofer replacement
- problems someone please help
- Rear tire rubbing on strut
- P0500 vs P1725, P1730
- Driver side door lock
- 1999 RX-reliabilty/issues
- 2002 Model with engine problems
- I Need Help with window TINT??
- Bank 1 valve cover hold down bolt access
- Pick your mechanic wisely or DIY
- RX300 rear washer does not work
- Weird thumping noise
- Air bag light on after impact without deployment
- timing belt parts
- Theres something seriously wrong with my 2000 RX 300
- What is this transmission related thing that is leaking?
- rx300 problem
- rx300 runs ruff with multiple codes help please
- alignment needed?
- Loud Humming Noise: Suggestions?
- short, alternator, or battery?
- RX300 Silver wheel paint
- Major Repair of RX300
- Caliper stuck Front passenger side
- Cladding paint code or color
- Wobble..thumping..burning smell after riding for ~20min
- Throttle cable stop bushing?
- RX300 Error code P0765
- High pitch squeak at idle that goes on and off
- need p/n for sway bar bushings
- 99 Lexus Rx300 won't start after having lean bank1
- Blue gray smoke coming from exhaust
- 2000 rx 300 with no heater controls or power windows
- 1999 rear seat slide inoperative
- Lettering on back hatch
- Silversports ?
- Help please With my cluster lights
- Oil Pressure sending unit on RX300
- Headlight Restoration - need advice
- Crank bolt stuck
- Sun visors
- Multiple Misfire (7 Codes)
- diagnosing fuel trim, bad a/f sensor? obd supplied
- Door position sensor
- Steering angle, anyone tried spacers
- 7 DTCs, and Battery light on - a little help?
- problem when changing starter on 99 RX300
- Master Window Switch or Motor?
- Stalling problem
- Code P1135
- HVAC/Heater Blower
- Puddle of water on my RX300 floor
- Window Switch Question
- sometimes I hear a thick whistling breathing
- Help needed - Front Differential fluid change
- Should I sell?
- help! what does flashing SRS warning light mean?
- 2000 RX300 fwd
- Filler neck refueling problem 2001 RX300
- Headlight Replacement
- Success thanks to ClubLexus help
- Sudden acceleration
- Help about my 2001 RX300
- New Member
- New and Questions
- filtering atf is it ok ?
- Help with heater blower
- hello RX guys! here is my new car project... 99 rx300-330 awd
- US RX300 in Europe
- best app (android/iphone)for lexus rx300 elm327r
- How to remove rear power outlet
- is the emergency hazard light switch supposed to light up in the dark?
- Considering an RX
- Remote entry, courtesy dome light, door locks randomly "lock/unlock" while driving
- Master Radio Code
- does the bulb failure warning light monitor rear turn signal and reverse bulbs?
- Is a BG Power Steering fluid flush Reasonable?
- Headlight help for rx300 please
- 18" Rims on my Rx300 help
- Coolant Leak
- P/N for the front seat belt button?
- Having some problems. Any suggestions?
- 2000 RX300 Door Lock problem
- ECM Master Key/Valet Key Mixed Success
- RX300 Misfire CEL codes
- Can the electromagnetic side mirror just stop working?
- My RX is totaled
- Audio Button
- Oil Drain Plug gaskets
- 2002 rx 300?
- CEL: code p0171 after replacing Bank2Sensor1
- AC Not turning on or Trip info not displaying
- rough idling and lack of power
- PCV vacuum routing?
- i erased the label (beside engine) any help?
- i found a parts like filter but it is not ?
- rubber engine support
- someone's opinion please spark plug
- My latest high mileage RX adventure.
- strut noise
- Test Driving Today/ What to look for?
- oxygen sensor part, are they same? help
- Fellow-up "help no oil flow"
- Rx 300 2.4L
- Talking about bad luck!!!
- A Hamster in my RX AC vent?
- A LOT of work on her yesterday.
- New to THIS forum & buying a 2002 RX300 AWD this week
- starter overhaul - question
- Loud POP while driving...now small noise when turning
- 1999 RX300 Alternator Pulley Size help
- Oil flow problem help!!!!!
- Lexus RX300 left speakers problem
- KYB rear strut mount VS OEM
- Calibration of the climate-control system.
- Tire Dressing ?
- Scored some parts today for the RX300
- Remote Door Opening
- radio button and switch lights
- hearing a chime after major undercarriage repairs
- How To Search This RX300 First Gen Forum
- Should I get one?
- my bumper got smashed!
- I bought Super White 9005 12V 100w Xenon Gas HID High Beam 5000K Light Bulbs to 99rx
- Autobox jerking and bucking after fluid change
- 225/70/16 Hankook Dynapro ATm
- Both Rear Doors cannot close
- all electronics dead
- My driver rear door does not lock
- OBDII scanner problems
- Dreaded VSC & Check engine light
- Rear Wiper Length Mystery
- '01 RX300 vs '01 GS430 - Utility, Reliability, Value?
- 99 RX won't shift into park - can't start --Help
- HOW TO: 2 Minute Fix for FAULTY Brake Light Failure Sensor Module.
- Poor turning radius on my 99 RX300
- Factory Radio Power/Volume control broken
- Happy New Year 2014
- ABS and VSC light pulse on when braking
- Obdii actron cp9125 scan no code (0)
- Need a Re manufactured Driveshaft - RX300
- Air servo problem
- Tacoma Antenna Conversion Power delete
- RX300 year 2000 airbag light steady on
- how can I determine which door needs to have the door check replaced?
- part number for this clip ..(pics)
- body Kit
- AC Noise
- Wish you all Happy Holidays
- Day Time Running Lights inoperative
- Misfire DTCs 0300, 0302, 0306 all at once.
- still leaking after rear main seal and gasket replaced
- Bought a RX 300 for 2K
- Question for GROM users
