- Brake pulse no ABS light
- RX300 Door Problems...
- Carpet
- 2000 RX300 has no shifting on gear shift on automatic shift lever
- Possible Transmission failure - advice
- High RPMs - 1999 RX300
- VVT Solenoid (OCV) Replacement DIY
- P1354 and momentary engine lag...
- 2001 AWD RX300 transmission cable
- Driver seat cushion adjustment repairs
- Sourcing small parts
- Foglights?
- Maf
- Do I throw in my RX300 towel ??
- Air Mix servo questions - not found in search
- advice on using "search" function
- Where to get 2 A/F sensors for under $180
- O2 Sensor Upstream / Downstream
- 2003 RX-300 sporadically hesitates/strange noise when accelerating after braking
- 19.5 mpg hwy @80 mph good?
- Isimple FYI
- RX300 Heat Shield help!
- Interior fan noise when on upper level setting
- 1999 rx300 without issues
- Regular gas and Knock sensors
- Replacing tail light bulb in 2000 RX300
- RX300 Air Mode Servo removal made easy
- Cutting out & rough idle
- Clicking noise from the AC/alternator belt area
- Rear Seat Protector (Large Dog)
- 2000 Rx300 cooling fans
- RX300 won't start, no light on dash board
- Low Speed Rear End Knock
- Need wiring diagram for 1999 RX300 ECU
- P0171 gas tank
- Acoustic Control Induction System Question
- Need help - 2000 RX300 lower timing belt cover
- Security System Issue 2001 RX300
- Need your help 2003 RX300 or 2004 RX330
- Driver door won't unlock from remote
- OK I have P0301 P1305 and P0300
- slight bump when overtaking
- First time buyer
- aftermarket radio help
- rear passenger window wont go down at all (checked owners manual and threads)
- Where is the best place to put the jack stands and jack
- Please help me diagnose
- PS Fluid
- Transmission shifting first thing in the morning
- Automatic Transmission Screen vs. Filter
- Can Rod Bearings After Oil Leak?
- Are these correct strut assemblies?
- Latest Cabin Air Filter Photo
- Weird issue with locks.
- Just cleaned my hazy headlights with toothpaste
- Radio Screen went blank, Air still works
- 1999 Rx300 catalytic converter question
- I got my Air Mix Servo fixed!!!
- Center Cup Holder
- Car wont start..how to tell if you need a new starter
- Climate Control Testing
- Front brake pads
- Recurring P0171 Code - bigger problem
- $113 for flex pipe r&r
- 01 RX with oil leak.. Main seal vs Valve cover
- My RX made the craziest sound today
- Antenna issues on my RX300
- Runs bad, need help asap, see codes.
- RX300 did not start
- Heat Servo won't move
- Rattle noise at rear shock
- i need help :)
- AC/Heat blower fan intermittent
- Apologies in advance for my third servo post
- RX 300 Issues
- 2001 rx300 shifts hard from 2nd to 3rd
- 1999 RX 300 Limp mode
- Checking Valve Clearance
- Pass side 3M headlight restoration
- would 6 months of generic coolant cause any harm?
- Downstream O2 bracket broke off
- Remove Passenger Quarter Panel 2002 RX300
- Emblem Shaving!
- Preventative Transmission Maintenance
- 2001 RX 300 Cabin Air Filter
- Drivers Seat Cover Replacement RX300
- Wanting to buy a 2003 RX 300
- Brake Assist Problem
- Squealing when it starts ?
- OCV Part Numbers
- AC runs during brakes, stops during acceleration
- Ignition Coils & Spark Plugs
- Is this important? (Exhaust Clamp?)
- Front side markers!
- Strange idle speed and power loss
- Headlight bulb options
- Dumbest thing so far!
- Reminder - periodically remove license plates
- Let's nit-pick our RX
- Low Idle
- Fail State Inspection :(
- RX300 Front Passenger Window - switch or motor?
- 2001 RX 300 codes p1155 and p1150
- 2001 RX 300 Window Woes
- Transmission Gasket Adhesive? Yes or No!
- R rear quarter panel glass installation
- Speakers Replacement as Maintenance Items?
- Daytime Running Lamp troubleshooting
- Transmission Fluid gray. Need advice.
- can the rx300 handle a turbo?
- 2000 RX300 won't start, it isn't the starter
- Couple of repair questions, abs and rear trunk
- Timing Belt DIY?
- Vacuum Switching Valve leaking
- Rear struts and mounts questions
- Replaced Speakers!
- 1999 Rx300 Bumper Cover removal
- check engine light
- In case anyone needs new tie rods
- is there a trick to this
- Fuel Trims?
- Rear wheel camber
- Engine Sound from 2001 RX 300
- Advice needed - can I ignore this issue?
- Rx300 16" to 18" rims
- Timing Belt Service - ?s re: parts
- RX300 Issues
- rx300 gas mileage
- Lexus RX330 2004 18 inch Chrome Wheels set of 4
- 1999 Rx300 blower fan barely blowing on high
- Replacing AF Sensor with code 1155
- Driver side low beam problem
- Odd knocking noise coming from underneath
- Buying a 2001 RX300 awd tomorrow...need thoughts.
- Please read this (vehicle won't start)
- Sensor/intermediate pipe repair
- FS and WTB posts go in the classified forums only
- Intermittent Loss of Power, Misfire, Exhaust Leak Noise
- Spark Plugs
- Solution for smoke from engine sludge
- Excessive oil usage on the highway
- help me check engine and vsc light on (P0300)
- New 99 RX300
- Radio Stats
- Worn Leather Steering Wheel
- A fix for Mode Servo that has me a little worried
- changing the color of the radio button lights?
- anyone know what size halo's we need for headlights?(RETROFITTERS RESPOND PLEASE)
- Maintenance for rx300 99 AWD with 150k miles?
- No first gear, starting in what feels like 3rd
- handle lubrication question
- New Guy Here- 99 rx black, grey leather
- problems with windows/locks from driver's door
- Blinking dash lights
- Bad Master Cylinder on 2001 AWD RX300
- Leatherique applied (pics)
- Water seal plate replacement?
- Transmission Cooler Lines Rusted
- Oil sludging
- Somebody help.....ugh!
- 99 rx300 passenger seat question
- Bushing repair kit for RX300 Trunk Lid Support Strut Arm?
- What is it?
- rx300 cel code P0768
- Correct tire pressure?
- Engine Oil Grade
- Alternator out?
- RX 300 lexus harrier 2001 cd player touch screen
- Honey, It's just a scratch!
- auto rx advice please
- Rear main seal leak- auto rx?
- 98 RX 300 Gearbox
- What the heck is this?
- Antenna Mast Replacement Help
- 02 awd tire reccomendation?
- Sell or fix?
- Considering used RX300...advice pls
- Oil change tips
- Transaxle Additives?
- Transaxle Drain Bolt Torque
- Timing idler was supposed to be all
- Mityvac 7201 Fluid Evacuator Trans & Oil Change
- Black smoke,no o/d shift , horrible gas mileage
- Dealer claims I need a new power steering pump, but...
- HID balast gets really hot? help??
- 2002 rx 300 rear end noise on acceleration
- RX 300 LED Tail Light Pic's
- Fuel Door Problem - need help
- Another oil sludge thread
- A/C Compressor Seal Leak
- mpg display
- What type of LSD in a 99 RX300?
- engine error codes: 0125,0300,0171,1130,1150, And 0768
- Anyone tried Pentofrost A1 antifreeze?
- How to repair leather seat seam damage on 2000 RX300 ?
- oil change question
- catalytic converter ugh!
- Knock Sensor questions
- warranty:)
- Window Vent Shades
- Airbag light started flashing
- Strange misfire issue
- HID lights
- Got an RX300
- Sorry! Another Servos question?
- Can I Neutralize knock sensor on 99 Rx 300
- Knocking noise in/around tire?
- Trac off indicator and CEL on, P0125!
- Help with RX 300 Check Engine codes
- NEW LED Taillights installed :)
- a/c issues
- What exactly does "Coach" add to 2002 rx300?
- Lexus RX300 2002 85k - Losing 1 quart every 750 miles
- How much have you towed in your RX300?
- RX300 & GS430 steering wheel swap
- 2002 RX300 Ball Bearings
- '99 RX300(AWD) Struts & Mounts Replacement
- Garage Door Opener--active even when car is switched off
- Front Passenger Window Motor Install
- I think I found touch up paint for gray RX bumpers
- Mayday, mayday spark plug help
- Broken antenna motor gear???
- abs brake pedal noise and pulsation
- Mode Servo 17 for heat
- 2001 rx 300 failed emissions
- Need Double Din for 2001 Rx300
- im so CONFUSED!
- rear lights
- Shelf life of "Toyota Red" antifreeze?
- TB/WP Life
- Reverse Gear Sometimes Hesitate
- Noise from rear end around highway curves
- Timing belt ?
- need a lil help
- Transmission Woes
- "rear lights" indicator
- Advice on tighter suspension for RX300
- Grom iPod DIY or recommend installer near S.F./S.J., CA?
- Engine turning over but won't start
- Help!!!
- DIY: Add Surface Mount LED to Center Console
- Replacing/repairing door weatherstripping
- Shift issues after new transmission
- Changed my plugs, got 2 codes
- Buy Acura MDX or Lexus RX300, after so many years of testing
- Starts but doesn't stall
- Rear bumper protector
- Dashboard Transmission Shift indicator Light
- Timing belt, crankshaft and cam replace!
- Valve cover gasket
