PDA
View Full Version : RX - 1st Gen (1999-2003)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Corner light of Lexus rx300 not working
  2. New Guy 2003 RX300 FWD
  3. Driver side door lock actuator replacement
  4. RX350 wheels on '02 RX coach - problem!
  5. 99 rx300 Transmission shifting from 2nd to 3rd trouble
  6. If you want to add a posi to the rear diff ...
  7. ignition coils 2002 lexus rx300
  8. 99 Rx300 P0446
  9. Please recommend place to buy air fuel oxygen sensor
  10. 2003 AWD System ...
  11. RX300 slams into reverse
  12. 2001 Rx300 Tran/Engine Compatibility
  13. Question about brake symptoms.
  14. Electrical Issues affecting LCD display
  15. No power to the fuel pump
  16. Odd brake light issue.
  17. Seeking advice on upper door trim DIY repaint
  18. 2002 RX300 104k miles Consumption/misfire/Smoke
  19. Liftgate won't lock by remote or central door lock button
  20. Drivers side window issue
  21. 1999 RX 300 seat/arm rest covers
  22. Starter never stops cranking
  23. Rx300 Charcoal Fuel Vapor Purge Canister Ports ??
  24. rx 300 motor removal
  25. How To Install and Sync New Air Mode Servo Motor
  26. Power antenna motor not working! Alternatives? Replacement? Wireless antenna?
  27. Front Struts
  28. Won't start, fuel pump not engaging
  29. Rear Control Arm
  30. Remote / Push Button Start
  31. Front Bumper
  32. Changing rear differential NOT fluid, whole thing
  33. Disconnecting MAF causes car to limit acceleration?
  34. please recommend rotors and pads
  35. Make ECU reset when starting up car
  36. Brake issues
  37. Can't open door using int or ext handles
  38. O2 Sensors
  39. 2002 RX300 #2 Cylinder no compression, burned exhaust valve
  40. 99 rx300 rear bumper material
  41. Hood Lock Assembly
  42. Recent timing belt done/ can’t start...pls help
  43. Body Cladding/Bumper Covers
  44. Rx300 rear vents
  45. i'm at my wits end with this thing
  46. Tail light indicator stays on
  47. New Wheels
  48. Front driver floor is very wet after rains
  49. Alarm System
  50. Lights
  51. Whew...made it to work. 😊
  52. 03 rx300 bearing size
  53. Rear light failure warning light staying ON...??
  54. 99 RX300 engine swap no start
  55. New Battery HeadsUp
  56. Seat cushion heater not working
  57. Our 1999 RX 300
  58. 2001 RX300 vs 2006 RX330
  59. 2000 RX300 runs poor when hot multiple engine codes
  60. Rattle in Right Rear Luggage Window Area
  61. Brake light not working initially- tried to fix it and now I have no rear lights, no
  62. Jerking
  63. RX 300 Heater problem
  64. Loud Noise, Rattling and Now Leaking Oil
  65. Blue Smoke after Knock Sensor R/R
  66. Fuel Injector Leak after install issues
  67. RX300 drivetrain
  68. Exploded diagrams w/part numbers and part sources
  69. Hood latch malfunction
  70. 5W30 in a 222K mile engine?
  71. Weird Electrical Issue ....
  72. 10 codes and a lesson learned
  73. So i bought a 2000 RX 300 last summer
  74. When unlocking the drivers door with the key...
  75. Quirky to me headlight problem
  76. 1999 Lexus RX300 Radiator Hoses
  77. headlight bulb?
  78. TPS Sensor
  79. Key fob randomly stopped working
  80. 2001 RX300 CD Player
  81. Rx 300 Gas Tank Vent Plugged?
  82. The RX 300 is now going on 20 years old and
  83. Strange problem with heating
  84. 1999 Lexus RX will not go above 35 MPH
  85. loss of power
  86. Heat from right rear wheel
  87. 99 RX300 untimely death
  88. Car Cranks but won't start after it has been driving.
  89. Evap Canister Assy 48010 & 48940 Need Expert to Figure what is going on.
  90. 2002 Lexus RX300 Noisy Dashboard
  91. drivers seat belt latch
  92. 2002 RX300 Remote Key Programming
  93. Alternator or Battery? who knows?
  94. Revs hunting through full rev range
  95. Thread size for oxygen sensor?
  96. Transmission fail no warning lights 2001 rx300
  97. 2001 RX skid control activates when starting from stop
  98. Small Evap Leak Detected - P0442 - I've tried almost everything - 2002 Rx300
  99. torque values....
  100. 1 year — 10,000 miles
  101. body cladding material and paint/primer
  102. DE3175 isn't the right size for dome light
  103. Buying friends 99 RX and it won’t go over 55mph...
  104. Brake lights won't turn off check this first!
  105. torque spec oil pan bolts
  106. 2000 rx300
  107. RX300 Electronic malfuntions
  108. Front fog light no work; bulb good; why?
  109. are there replacement headlight housings available for RX300 that came with HID?
  110. Newbie Here
  111. is Mobil 1 synthetic ATF acceptable for use in power steering?
  112. What's that pre-wired unused blue connector for inside the rear liftgate of RX300?
  113. Jack stand points for rear
  114. Brake booster failed: buy recon or used?
  115. High oil consumption but dipstick shows proper levels???
  116. 1999 rx300 I want to pull motor
  117. RX 300 2005 CD Player
  118. rusty exhaust
  119. Evap System Smoke Test - Help
  120. Steering rattling/vibrating noise
  121. Aux In using interface harness
  122. Engine Knock
  123. What to look for when buying a 1st gen RX
  124. How many brake light bulbs?
  125. Ticking sound from EVAP canister
  126. Which 92-03 Lexus have transmission issues?
  127. Rear brake hardware orientation?
  128. P0128 p0440 p0441 p0446
  129. Dome light circuit schematic
  130. Newbie
  131. Hello to everyone
  132. Remote Alarm Reset
  133. P0171 leading to p0325 leading to p0330
  134. Smelling raw gas
  135. ‘99 RX300 No crank and no start - Help
  136. LCD backlight stays on?
  137. RX300 Fuel Pressure Test - Port????
  138. Rear Light Failure Warning Light & Low Fuel light
  139. 08/98 rx300 alternator question
  140. Timing belt life / Bumper Hitch
  141. rear door panel removal?
  142. Over drive question
  143. programing fob with bad actuators?
  144. Need some Help - PO171 code - Read all Threads -Still cannot find Issue
  145. Tie Rod Ends - need advice
  146. 1999 RX300 radiator cap
  147. Safety hatch
  148. 2000 Lexus RX300 Multiple Electronic Issues
  149. RX300 New Water Pump Install (Flush) Question
  150. Preliminary research question...
  151. Cigarette Lighter Replacement (Center Console)
  152. Rear door hatch is stuck closed
  153. 2002 RX300 AWD Splash Guard fasteners
  154. Flood damaged 2000 RX300 - help!
  155. Change Evaporator without tearing the dash apart
  156. Where is the AC sight glass in 1999 RX300?
  157. 2000 RX300 - rust corrosion in the wheel well at rear door edge
  158. Tire size 235 front 225 rear possible?
  159. Rear Caliper Sliding Pin - Caliper Rotates on Pin - Stuck coming off
  160. New RX owner with tweeter question
  161. Pump Noise at Start Up?? ‘02 RX300
  162. Headlights
  163. Hello Everyone - I had it, gave it away, and now its back
  164. P0171 / P0174 (lean codes) pops up but ONLY after refueling!
  165. ABS Problem
  166. Nakamichi vs Pioneer door speakers
  167. Rx300 not getting reverse
  168. Oil leak from valve covers near timing belts
  169. Key
  170. 2001 RX300 Battery Drain and door lock problems
  171. For Sale items go in the marketplace only
  172. P0505
  173. PSA: Go change your cabin air filter
  174. 2001 RX300 Post knock sensor and manifold replacement
  175. Determine model of rear valve cover?
  176. ABS activating
  177. Odd brake issue
  178. RX300 Rear ABS Bolt Size??
  179. What does this plug connect to?
  180. Rear diff fluid
  181. Engine or Transmission Mount
  182. Remote stopped working suddenly
  183. 2003 Lexus RX300 timing belt or chain
  184. Brake ? System problem
  185. rotor brands
  186. No reverse
  187. RX300 Codes and Stability Control
  188. RX300 no start no spark... SOO stumped
  189. What was it like when your AWD transmission started to go?
  190. $500 Lexus
  191. Cruise control disengaged when I set speed
  192. Power Window Switch
  193. 2000 RX300 Heat Problem
  194. Stalling after Starting - Need Help
  195. Misfire only @ 65 to 70mph
  196. Black plastic rod front seat RX 300 2005
  197. Grinding Noise From Timing Belt Area
  198. 0-60 test
  199. Noises coming from behind dash?
  200. P0330 knock sensor suggestions
  201. Multi CD changer problems
  202. Stalling
  203. Check Engine Light comes on after resetting ECU
  204. Rewire fog lights to work independent of low beam status
  205. Need A New Proper Fitting Key FOB Case
  206. RX won’t start
  207. Replacing heater core while doing evaporator - is it really necessary?
  208. Rear positive camber
  209. Looking for Some Advice
  210. Bulb combination for optimal color uniformity
  211. Clicking Noise
  212. 2002 rx ABS problem. Help needed.
  213. Antenna Motor or Mast Problem?
  214. Suspension question
  215. Brake engaging
  216. Griding noise when turning
  217. '99 RX timing belt replacement due to age?
  218. irontoad
  219. Lift 4”
  220. Power window issues
  221. Need Tire Suggestions
  222. Updating OEM Navigation
  223. 01 RX300 Transmission dead- rebuild or replace?
  224. CELs on 02 RX that I cannot go look at, historical problems, your best guess
  225. Please help me with my suspension
  226. headlight lens replacement?
  227. OEM vs Aftermarket Antenna Mast - differences?
  228. Quick question about MAF sensor and A/F sensor
  229. more trouble codes
  230. New RX300 owner - misfire problem diagnoses
  231. P1150 issues
  232. anyone run 235/70r16 size tires?
  233. FUEL pump
  234. ATF Valvoline MaxLife Synthetic instead of Toyota T-IV?
  235. Passenger CV Axle Replacement (AWD)
  236. AC fuse / clutch - how to disable?
  237. jacking up just the entire front or rear
  238. RX300 Ashtray Light Bulb Replacement Question
  239. Headlights not working unless hot wired in fuse box
  240. Exhaust work
  241. One Key not starting car, and other key needs replaced.
  242. Driver legroom
  243. Shudder/Hesitation from dead stop
  244. Seafoam cleaning
  245. Transmissions Issues
  246. should I add washers for a valve cover job?
  247. Key Programming 2001 RX300
  248. RX300 Transmission Cooler?
  249. Acceleration not strong?
  250. Radio Replacement
