- 2000 Lexus RX300 Key Alarm FOB
- Audio Help!! 🔊🔊
- MPG computer screwy after exhaust welding.
- Tail ligts
- Tools/sizes that all first generation RX do it yourselfers should have.
- Possible Short
- Installing/wiring LED DRL's (and turn signal)
- 2001 rx 300 problems!
- Lost my DRL and front markers...'03 RX300
- Please HELP! Rx crank but won't start
- Door not locking (2000 RX 300)
- disabling headlight off option?
- 2000 RX300 ABS Problem
- Drivers side windshield defroster not working.......
- Windshield Wiper Thump Sound
- Multiple alert lights on the dashboard - Any thoughts please?
- Roof rail fitting
- Time to Replace stock Subwoofer - but where do I gather line inputs?
- Starting problem. any ideas requested..
- Alternator with tow packaged 130 amp
- Slip light and abs issue
- Popping noise
- 2000 RX300 - Does stereo have AUX port anywhere?
- Transmission Problem (Not Shifting)
- How easy is it to replace the Charcoal Canister?
- Engine hesitation only on drive and reverse + hard brakes
- RX300 Radio Back Lights Center Console Instrument Panel Lights out
- Should I buy?!?
- power steering pump leak
- Engine dies in cold morning start
- Need help on total power loss issue
- Stabilizer Bar Link & Sway Bar Bushing
- Flashing cel & p0302
- Catch Can
- "D" Light and Air Mode Servo Guide
- Heating Problems
- Low Groan on start up
- Dimmer not working
- What is your idling RPM in Drive mode
- No Power To The OBDii Connector
- heater problem
- Cruise control cutting out
- RX300 noise and "lag" at front wheels?
- Block heater
- kenwood ddx471hd for 2001 lexus rx300?
- 2001 RX300 Glove Box Removal (AIRBAG CABLE TETHER???)
- Considering an RX300
- Replacing Engine 1999 RX300 AWD - Input needed
- 2001 RX300 no cluster, no heat, nothing
- Convert Rear Cigarette Lighter to USB
- lamp failure Sensor Location 1999 RX300
- Timing Belt Make-do Tools
- incoming radio signal amplifier?
- program key after car battery change
- Transmission Problems
- RX300 Rear Wheel Bearing Replacement Seal
- RX300 low beams driving me crazy! :-(
- Windows Problem for RX300 (2002)
- Headlight out, no voltage at connector
- Help!!
- checking for bad ground
- External System Not Connected
- Timing Belt & Water Pump Service Question
- 1,200 mile round trip!!
- Misfire under load really need help!
- Squeaking/rattling noise from drive belt area
- O2 and multiple Misfire help.. please!
- P0125 code and diagnostic dispute
- VSC / Engine check lights after work on car
- I searched to the end of the internet......
- RX300 chirping/clicking sound
- Farewell to everyone
- RX Running rough but No CEL
- How To: RX300 Instrumental Cluster "D" light replacement
- Can an exhaust leak trigger a code 1133?
- A/c problem/repair
- My rx is smoking and hungry, help!
- stereo sound being muffled
- Wheel Alignment Trivia - Stop That Car Pulling
- RX300 Rear drive shaft front section
- Drivers seat memory
- RX300 (2003) Drivers Door Problem.
- RX 300 hard to starts
- Will Not Accelerate
- Shudder coming from rear passenger side at speed - ideas?
- cleaning transmission screen/filter
- What is this leaking and how do I fix it?
- "Rusty" Rotors
- RX300 1999 have P1133 - A/F sensor Bank1 reading
- High RPM's after 2nd/3rd shift
- brake rotors are 26.8 mm, should I replace them?
- replace antenna with "generic" stub?
- 2001 Rx300 aftermarket radio help!
- RX300 Trans Failure?
- Time to Replace the Radiator? Really?
- RX300 Key Issues
- Remote Starter Installed
- Hardwiring Radar Detector to RX300
- Inner CV Boot repalcement DIY (FWD)
- Transmission Flush - the Volvo Technique
- Shaking/Vibes in Drive
- Install subwoofer in 2001 RX300
- Question from a new owner
- Road rash / paint touch up kits
- CD changer magazine won't load
- Color me Gone....
- Choosing Between Two Kumho Tires
- Knock sensor
- Pcv valve poll
- Want to +1 Upgrade Wheels with questions
- Timing belt replacement WAY overdue
- oil issue?
- Thinking about buying RX300
- windows going nuts!
- Spare Wheel on 'Tailgate?'
- Removing rear brake rotor problem
- That dam tow harness issue
- HELP with my rx300 2002
- Wheel Bearing Replacement, Dealer or Local Shop?
- **Rx300 Suggestion's On Shock's?**
- Need Help, Looking at Buying a 09 RX 350 on 8/30
- Stolen sun visors
- Difference in pcv valves
- Newbie 2001 front end noise
- APX Auto - Sensen Shocks
- Vibration/road noise on the highway
- iPod or iPhone AUX Connection
- RX300 Front Driver side door stuck closed
- Knock sensor Nightmares. Advice appreciated
- Anyone Running Tiger Paw Touring Tires on AWD
- New RX 300 Engine Using Oil
- A/C Compressor Install 99 rx300
- Do 2nd gen Struts fit our 1st gen?
- 2000 RX300 Instrument Cluster
- 2001 RX300--AC stopped working
- Left Rear Door Lock Chatters and does not lock: RX330 2005
- Left Rear Door Lock Chatter RX330 2005
- Is the Lexus RX300 a good first car?
- Rear liftgate support replacement--an inexpensive alternative
- Rear window defroster
- Replacement Coil Springs?
- Door lock and auto up window issues.
- Remote locks while running
- How to Get the engine manufacturing date with only the engine serial number
- 1999 RX300 p1354 on/off
- It's growing on me!!!
- Interior color code?
- CEL, Excessive Ripple & headlight leveler warning light
- 2001 RX300 Driver side low beam not working
- where can I get new replacement headlight housing('01 w/ HID) at a reasonable price?
- Fuel Gauge issues
- something fell off while driving
- RPM bounce all arround
- Lexus RX300 (advice on whether to buy)
- Help Identifying Hose from Airbox
- Transmission / Cooler Question
- Please Help URGENT----P0330 Error Code Come while driving on the Highway
- Need New Muffler--Size?
- Changing Computer from miles to km
- 89072-48380 vs. the part number 89072-48380-RK?
- Nav Screen gone blank
- Neeed iacv
- wife lost remote master key chip
- Make you own RX300 side window sun screen
- A/C tube clog - Article from RX300How2 a memorable website
- Master key won't start car
- P0171 & P0174 - poor mpg - stuttering
- Crowdsourcing New Purchase Decision
- New owner, a couple of questions
- P0128 Error Code
- DCTMS RX300 steering wheel rewrap with F-stitching
- Tired of burning your butt on hot leather seats? A fix for the RX300
- is the original '01 Bridgestone spare tire still usable? (never used)
- HELP!! A/c cooling problem
- AC identify help
- Trunk problem
- AC repair
- Oops, I seem to be missing a trim piece
- Daytime Driving Lights not working
- copied cd's
- check engine, vsc, shutters around 50 mph
- Reverse problems
- are Rhino ramps tall enough to let me change AF ratio sensor from underneath RX300?
- Front bumper and side marker replacement (DIY)
- Rx 300 Gas Gauge stuck on empty
- CEL - VSC - TRAC off Lights Answers
- OBDII Connector Location
- Radio issues, or lack there of....
- Sticky Transmission Shifter
- Opinion on these parts for brake pads/rotors
- Armrests reversible?
- A new tire option for the RX300
- Oil additive question
- Service intervals Transfer Case & Differentials
- front wheel / drive shaft noise
- 99 RX300: Messed up door lock actuator repair, doors won't open now
- Foggy headlight covers
- Happy 4th!!
- Hid kit, $24.99
- Wiring diagram for LED bumper help?
- passenger rear child locks
- custom grills
- DIY : Flex Pipe Replacement
- Venza Rim & ATE Rotor - Hits the caliper
- Rear Tire 245-50R20 and Front Tire 235-70R16
- Changing the transmission fluid...
- Oil filter question...
- Replaced front door actuator, strange behavior?
- Radio no sound but lights up
- Hey all--Wont stay running
- Anyone experienced Elmscan 5 Scantool software with virus/trojan?
- Help - Jus Bought, Now Totalled?
- Trac Flashing with ABS solid On
- Moving two doors down
- new member in need of help (codes)
- 2001 RX Air Con
- Air Mix servo motor part number-best place to order
- Side marker light connector in US RX300's?
- 2000 RX300 - Rough Idling and Bucking Acceleration
- Diagnosing bad MAF (P0171)
- Rough Idle, Hesitation, and Codes
- Master Cylinder Replacement
- Opinions on Techron Fuel Cleaner?
- Hesitation and Rough Idle
- My wife wants new HID headlight housings
- 2002 clunk
- Oil consumption is back 02 RX300
- Which fuse is ETCS fuse?
- I need instant feedback on broken transmission
- Clunking after brake job
- Leather Armrest *Restoration* - DIY
- 1999 RX300 AC problem
- Intermittent, heavy vibration - How do I check suspension??
- DRL: can't believe there are no solutions for this
- Running on 3 cylinders!
- Radio antenna trim
- A couple of interior questions
- Have to say goodbye...
- Whew...What a week!
- A/C not working and A/C light is blinking
- Seat Swap
- Rear strut rods and control arms
- Rear differential lubricant leak
- Navigation - External system not connected
- Hide-a-ways and Resonator Delete
- 2000 RX 300 fan noise/baffle after ignition is off
- How much does your oil change cost?
- Replaced starter contacts - $500?
- Front tires replacement for a 2000 RX 300 AWD
