PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. 91 LS400 with suspension noises
  2. Will 20x9, 20x10 (245 & 275) rims and tires fit on a 96' LS400??
  3. 2LS caliper clearance issues on 1LS with various OEM wheels.
  4. Standard suspension – what one is what?
  5. double din bezel
  6. Timing Belt: 1992 LS400 250K KM
  7. New To This Forum...
  8. Got a slow seatbelt ? Get your 1 tip ready
  9. disable factory alarm??
  10. Search Help,,
  11. ECT and rear light issues?
  12. Strange steering issue with the LS today
  13. Opinion about Rotors..
  14. Gated Shifter
  15. 1995 Lexus LS 400 - Loud Squealing... Engine Area
  16. Just picked up a '92 LS400
  17. 1991 LS400 New Owner Help!
  18. best drop shock for a 98 ls
  19. '98-'00 Search ?'s
  20. Dolce UCF 10 -> UCF21 and UCF30/31 Conversion
  21. distributor cap problem
  22. Whirring noise while slowing down '93
  23. Removing and replacing drivers seat
  24. 97 ls400 hu help
  25. Whats the most money you put into a first generation LS400 with no avail
  26. I just had the front struts replaced on my 1990 LS400 because of rattling noice
  27. When I win the Lottery should I buy a Lexus lS460, or a BMW 750, or Mercedes S600
  28. Can I take the chrome Lexus emblems off an Es300 and put them on an Ls400
  29. A/C Problem Related
  30. Diagnosing need for bushing replacement
  31. Quick air intake box mod question, UCF21
  32. wiring diagrams
  33. Toronto LS400 prices - 1998 - 1999
  34. Auto shifter inhibitor module location on gen 1
  35. Did you upgrade from a Pinto or something worse to your new Lexus
  36. Why are the LS Models the Ultimate Lexus has to offer
  37. What can a bad radiator cap do to your vehicles cooling system
  38. Do you use lowbudget parts and service for your car
  39. What do you guys think it is
  40. Did I fix the Problem? Low engine coolant light, gen1
  41. Blew motor, how much labor in swapping?
  42. Yeah or Nay to this mod
  43. POLL : strut tower bar
  44. problem when changing spark plug wires
  45. The search never ends...
  46. My new Quad pipes !!
  47. Sirius satellite into 2000 LS400 w/nakamichi
  48. 1uz trans?
  49. Fog Light Bulb
  50. Why does the "LOW ENGINE COOLANT LEVEL WARNING LIGHT" keep going off
  51. Black grill for '91 LS400
  52. Exhaust question (L-Tuned parts)
  53. Celsior Up in Japan...
  54. starter problem ( MAJOR )
  55. engine feels sluggish
  56. need help stereo shows SEC in my ls400
  57. A host of car troubles... help !
  58. time to retire my '90?
  59. charcola canister and evap valve
  60. 1992 Ls 400 Eg001-98
  61. Platform
  62. Family member might be getting a LS400
  63. What fuel additives do you use, and how often?
  64. What RPM does your car shift at?
  65. 1998-2000 Ls400 Fog Lights, The easiest upgrade for added light ever.
  66. My New Exhaust System With An X Pipe, Removed everything but the rear Lsportline muff
  67. 1991 LS400....many minor problems
  68. a couple more pictures of my car and a friend's
  69. Downshifting....Do U do it.....????
  70. Clock and Seat Memory problems
  71. WTB? 95 LS400 rear tranny mount.
  72. Should I go with Monroe Sensa Tract or KYB shocks
  73. Did the Jamaican get Ripped OFF?
  74. Is anyone dumb enough to pay dealer prices for parts and service on their Lexus
  75. Idle is too high at startup
  76. Warning Light/Dome to the left of anti-lock brake light
  77. Remove Gold from Lexus Emblems
  78. O2 sensor replacement
  79. Infinti wheels on a Lexus
  80. How does the LS rear wheel handle in snow?
  81. Man I am lucky.
  82. Cd Changer Help Pleaseee.... '93
  83. Please Post your UCF20/21 pics
  84. How does your car perform with a full passenger load?
  85. 92 ls400 ... slow takeoff
  86. Rubber Cargo/Trunk Liner for UCF10...
  87. SoCal + Heat = Tint
  88. bought myself a birthday present...2nd generation LS400
  89. whining noise...
  90. 97 LS400 Automatic door lock/unlock
  91. What type of suspension do you have?
  92. idler pulley bearing
  93. Help Horn problem
  94. which shocks would be best with universalair?
  95. Catalytic Converter RED!
  96. Amplifier Location on '96 LS
  97. No A/C in 99 LS400, missing low-side A/C cap?
  98. any good shops in dallas
  99. Radiator Cooling Fan and shroud '91
  100. How to connect JDM Headlight wiring harness to USDM Headlight wiring harness?
  101. Chrome Wheel Center Cap / Emblem
  102. DIY A/C recharge?
  103. 2000 LS400 Passenger Wing Mirror Glass Replacement
  104. Where to find idle control valve for 1991 Ls400?
  105. How Often Do U Do maintenance wk on ur LS???
  106. Where did you observe the ugliest looking Ls400, describe it and do you have any
  107. What is L-Tuned Steering ECU and could it be installed on a 90 ls400
  108. Helpful web site for maint. and my new car
  109. [pics]She's BACKK!!
  110. White LS w/ tinted Tail/headlights
  111. MP3 & Satellite Radio Install?????
  112. Wood Trim Kits Yes or No
  113. '91 400 audio problem
  114. Will 19X8.5 +28 and 19x10+35 fit a 1995 LS400? thanks
  115. LS430 Cupholder Work in LS400?
  116. Hids for fogs, low and high beams
  117. Best modifications for 1990-94 LS400?
  118. AC whine HELP.
  119. Parking lights?
  120. spark plug blues
  121. The Great Flood
  122. Check Engine: Code 25
  123. Why do you think your Lexus is one of the best cars made?
  124. Navigation system in early gens?
  125. SC400 and LS400 wheels
  126. P/S Fluid leak - not easy to steer.
  127. New to the Forum
  128. My soon to be EXE(vip) Ls400
  129. Help!! need parts '94
  130. Super ghetto 45-minute EGR "fix"
  131. Common Problems Fixed
  132. Right tire for 45 minute commutes size 225/40/18
  133. Boring!!!
  134. My 98 LS with 05 18" wheels
  135. LS400 Rebuild
  136. 92 with 263000 gone 95 with 78000 well 79000
  137. Name Of head lights, anyone help?
  138. OBDC supported by 90 LS400
  139. Washer Fluid light comes on even though fluid is full?
  140. LS400 Wipers not working
  141. Need to replace struts....what else should I consider
  142. Right tire for 1990 ls400 with 18" 2006 Sc430 rims
  143. Were to buy Koni sport struts for gen1 LS400
  144. 1998 Electrical Problem - Alternator?
  145. New LS400 soon, any ideas and suggestions??
  146. EFI fuse keeps blowing.??
  147. I love my LS400
  148. rattle
  149. Got Cold Air>?????????????????
  150. Do the lexls.com tutorials apply to the 96 LS?
  151. Curbed 16 inch LS400 chrome - rechrome, or new rim??
  152. Is this a Good Deal???
  153. devils body kit...
  154. Stuck Tach!
  155. 98 LS400 navigation
  156. 98 ls400 flashing defroster light
  157. brake light sensor location
  158. How to tell if water pump is bad??
  159. Can someone help me out and check their tachometer...
  160. Finally got my car painted !
  161. 06-07 GS350 17" Original wheels on 91 LS400
  162. Lowering a LS400
  163. rattle
  164. seat cover replacements?
  165. Quick look at non OEM and OEM drive shaft bushing
  166. What Tyres Should I Put !!!
  167. '94 stalls
  168. Got some new wheels..
  169. Car won't start!!!
  170. problem getting into the trunk w valet key!!!
  171. Wiring for sub amps
  172. NOW some good pictures of my 90 on low and super low!
  173. Possible Alternator Problem?
  174. R1 Cross drilled/slotted rotors...your opinions?
  175. alarm / starter problems
  176. What year LS is best to get? selling my SC400
  177. Tick tick tick coming from engine compartment..
  178. Tein Coils for LS
  179. no park lights
  180. NOOB in need of radiator help!!
  181. 93ls CD player dead
  182. New in Town
  183. Trade my 1991 LS400 for a 1990 LS400
  184. 1995 Ls400, 105400 Service
  185. switching the engines
  186. 96 starting to pink - any tune up to do?
  187. 95 Fog light and low beam question
  188. 95 ls400 fusebox
  189. '92 LS400 from Seattle to HI, Big Island.
  190. K&N filter vs OEM paper filter & maintenance recommendations
  191. One after another..
  192. Strut replacement
  193. Egr delete..How do I install the resistor?
  194. 95 LS400 temperature control problem
  195. my 90 with air ride controller + work euroline s2's
  196. Malfunction indicators not operative + tranny acts funny
  197. Aftermarket Radio Dash kits?
  198. '93 "missing" after replace fan pulley bracket
  199. Good place to buy drawer from under drivers seat? 99 LS400
  200. How to know if your car needs "EVO" Rack and Pinion
  201. Dealer wants $1400 to replace Rack and Pinion
  202. 3 Months Later...
  203. white smoke!!!
  204. need help finding 1994 ls400 rims
  205. Uneven trunk lines?
  206. Hard to start in the morning? 1991 ls400
  207. Help!!!!
  208. What to do about the busted driver's seat..
  209. LS430 Wheels on a 1998 LS400 (pics)
  210. Manual odometer stopped working, but digital still works. WTF?
  211. Want your opinion?
  212. Picking up a car
  213. what is EVO?
  214. Looking for dac
  215. new member, two time lexus owner questions...
  216. Asian or Nippendenso Fuel Pump in 1991 ls400??
  217. What's a good price for Wald Duchatlet rims?
  218. Just picked up another Lexus
  219. What to do with grill...
  220. crank seal help
  221. Supra wheels on 90' Ls400?
  222. Propane(lpg) Instialtion Help
  223. Driving in Snow on the East Coast
  224. upper control arms for 91 ls400??
  225. New ignition key $376.74 + programming fee
  226. Anyone buy the ebay aftermarket seatbelts?
  227. Strut Rod Bushings
  228. Anybody ever replace the ALT on their 1st gen?
  229. Suspension
  230. Rotary Republic
  231. ucf10 and ucf20 suspension?
  232. program your remote?
  233. Tire Pressure Reading on an LS 400
  234. Rear sub-frame/diff cradle questions
  235. Salvaged parts search engine
  236. Painting my car montone?? How much$$
  237. Newbie...just acquired a 93 LS...needs work
  238. datasystems air ride controller question. URGENT!!
  239. after crash--Transmission won't shift out
  240. Telescopic Steering Failure
  241. Fog light question for 94 LS
  242. Starter gone out?
  243. 91 ls400 fuel gauge or fuel sending unit?
  244. Seat belt broken?!?
  245. Brake bad replacement
  246. Need water pump install writeup. I've searched...
  247. Checking engine code question...pic inside
  248. My 500 Mile Road trip
  249. electrical problem w/ headlights,& stereo
  250. Thump sound when going over bumps
