Strut Rod Bushings
Yea I know what you mean..I think
www.lexuspartsonline.com
has it, I forget though..
They're pricey..like 120 each..or some crap
My 3 bushings on the #3 in the diagram are bad. What is this part called? Can you purchase just the 3 bushings? Is this as easy to remove as it looks or is something going to fly out and go through the roof of my garage?? Thanks
Nel
Nel
# 3 is the Upper Control Arm. # 10 is the Strut Rod for pre 1995 ls400 95 -97 are different and u must buy whole unit $120(bushing can not be replaced). Sometimes very difficult to get old ones off . they get frozen in place . Will improve ride greatly along with ball joints and upper control arms.
At $55 each, I think the bushings alone would cost you close to that and you have to press the old ones out and the new ones in which is a PITA without a press. This way you got a new strut rod with OEM bushings ready to slap on.
I've heard a lot of complaints of a stiffer ride and squeeking from a lot of the poly bushings. Do a search and take it from there.
What lexus dealer are you guys seeing the strut rod bushing for $55. I searched hi and low and the cheapest was about $120 each.
I still havent changed mine and now they are worse, it is a safety concern now as the car sways around when I press my brakes.
thats the same problem that I am having. Like when its raining and wet the car tends to get spagetti like at the steering wheel. So is the bushing $55 or $120. And is it just the bushing or the whole rod and the bushing together guys. Need answers asap.
