PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. VSC Off
  2. How do i find out my LS Ultra Lux or not
  3. When it rains it pours....now I need an ABS pump
  4. ASE664 air suspension controller help
  5. Failed emmison.1990 ls with code 28
  6. 96' LS Issues = Need advice
  7. Transmission Sticks in 2-1 Downshift while Slowing Down - Any Experts? '95 LS400
  8. NGK R sparkplugs in 91 ls400? Resistor plugs or Platinum?
  9. 98-00 Tail lights
  10. can a 98+ lip spoiler fit on a 95-97?
  11. need help
  12. Anyone seen Euroline Work wheels on LS400s? pix inside
  13. PS parts, help me get all I need...
  14. UCF20/21 name designation
  15. UCF20/21 1995 - 2000 LS400 FaQ(Frequently asked Questions)
  16. Car won't go into drive easily
  17. 91 ls400 front end vibration and clanking over bumps??
  18. $700 for water pump and timing belt!!
  19. Hydraulic Fan stuck at 100% operations
  20. Where to buy upper control arms???
  21. 2000 LS400 Brakes...
  22. camber kits for 93 LS400
  23. Watch DVDs on 99LS?
  24. Another minor problem for those smarter than I...
  25. LS400-Can Fuel Injectors be Rebuilt?
  26. HELP! newbeeie seeking wisdom!
  27. Fuel injector reapair
  28. Proud New Owner of persian451's LS
  29. Power Steering???
  30. 91 ls400 ported vacuum switch next to Iac valve??
  31. code 71? 91 ls400 malfunctioning egr system?
  32. Exclusive Euro Kit...
  33. Keyless Entry on UCF10?
  34. 90K Service Pricing...
  35. Doh! Check Engine Light Came On.. Went to the Dealer And got 2 codes
  36. Allow me to introduce myself....
  37. Front end noise - 98LS 80K miles
  38. Broken down Lexus Blues
  39. How much Money have you put in for Maint
  40. Seat Swap?
  41. 91 w/ issues
  42. antifreeze leak: rear of intake
  43. XM Radio / Tape Adapter Issue
  44. Diagnose Help! Strange clicking/ ratting noise coming near my timing belt in 94 LS400
  45. Amistad Kit for 1997 LS400
  46. 91 ls400 IAC valve(idle control valve) working?
  47. Brake Light on...Stop Lamp out? 92 LS400...
  48. Just bought LS400 and have questions
  49. need help with aftermarket HU install
  50. My short introduction
  51. Need Help!! Stuck On The Side Of The Road!!
  52. First time in snow! alomst died,
  53. First gen LS speedometer fix in Orlando area?
  54. need help, question about keys.
  55. Power Steering Fluid Question -- 92 LS
  56. Goodbye and Farewell (merged)
  57. New lexus member...just bought 99 LS400 blk/blk
  58. 95 Double Din install.
  59. 95 LS400 seat warmers?
  60. Grinding noise on deceleration
  61. LS400 failed inspection - check engine light on
  62. What is the correct idle for 1991 ls400 at warm engine temperature?
  63. 1994 LS Key won't open trunk?
  64. A.C. blower question
  65. Can't open my trunk '91
  66. HID question
  67. Who's LS is this?????
  68. front bushing question??
  69. HID in first gen fogs
  70. New 96 LS400 owner - 224K miles - questions...
  71. White/Black or Silver?
  72. egr problem on 91 ls400 causing jerking at 45mph?
  73. 1999 LS 400 Reno
  74. I took some pics today after washing it.
  75. Dash warning lights came on!
  76. 1991 ls400 master window switch cant figure out how??
  77. New LEX owner
  78. 100 Amp replacement Alt or go 145 amp?
  79. Bought a '95 LS 400
  80. Reduce engine noises & shocks: 2000 LS
  81. 90-94 LS400 owners, aftermarket headunit questions...
  82. The First Gen Power Steering Bible
  83. air suspension problem '90
  84. HELP Four Warning Dash Lights on !! '90
  85. vague steering
  86. Alarm Advice
  87. Any LA members bored and want to check out this car?
  88. Anyone ever hear of this weird tranny problem ?? '91
  89. Grease in Diagnosis connector
  90. 98-00 LS400 chrome bumper trim
  91. 1st Gen or 2nd Gen for the same price
  92. Potential 1995-1998 Purchase
  93. Camry Power antenna???
  94. Alternator Problem?
  95. Tried searching found nuttin' please help. Air sus.?
  96. UCF10 Air Suspension
  97. Potential Purchase: 1993 LS 400
  98. LS400 owners post your wheel setup
  99. Stock amplifier?
  100. body parts
  101. Would you Buy this LS 400?
  102. The Revival of the LS
  103. guess i will be frquenting the ls forum now :)
  104. How much Quarts required? '91
  105. LS400 fog light bulb application??
  106. 1990 LS Coolant Leak
  107. LS400 rims
  108. 1st Time Driving a Lexus...WOW!
  109. Lexus LS400 Acceleration Issue
  110. LS400 189,000 miles '92
  111. Power Steering Issue
  112. No more trac light
  113. Any of you know of of Godfather rims from japan?
  114. Silverstar Comparo with pics!
  115. Staggered wheel/tire fitment help!
  116. no point me being here
  117. 95 LS400 Jerks, Misfire Code 300, 302, 307 - Check Engine Light
  118. JIC FLT-A2's
  119. Bilstein HD struts for 2nd Gen
  120. ECT power switch backlighting
  121. So I found myself having an extra remote transmitter key...
  122. instrument cluster transplant
  123. a sad but much anticipated day
  124. Here's a good read about the LS series
  125. Window TINT?
  126. Fog light Mod for UCF10???
  127. Front Window Defrost
  128. How does traction control work on the LS400??
  129. Star Trek fans might enjoy...
  130. Engine Temp guage not returning to cold?
  131. 1991 LS 400 strut options???
  132. Cylinder Sleeves
  133. taillight problem - UCF20
  134. 1990 LS400 sluggish start off problem
  135. interior Bulbs HELP!
  136. '93 LS400 Air Suspension Help
  137. 90 LS loss of power
  138. Just Installed SS Brake Lines
  139. Types of Coolant, couple of related questions...
  140. Online manuals
  141. LS 400 - Tranny jerk '91
  142. One Crazy Lexi....Need help.... '92
  143. newbie here
  144. machining the wheel hub question
  145. transmission problem (help with diagnostic) '91
  146. new member
  147. 92 ls400 air strut
  148. '90 LS Alternator going bad?
  149. check engine light, check vsc warning '99
  150. 1992 LS400 Exhaust Replacement
  151. got new wheels!!!!pic inside
  152. newbie
  153. After 3 years finaly got my 19" '92 LS400
  154. Gaskets for the head
  155. look what i got!
  156. Difference between UCF/10 & UCF 20 Headlight Lens
  157. 1992 LS400 front windshield... what TINT would it be?
  158. 1990 LS400 Constant Battery Drain
  159. Nakamichi in oem pioneer ls400
  160. Ok to use DOT4 in 91 LS400?
  161. low windsheild wiper fluid
  162. Quick question regarding Upper Radiator hose
  163. Lots of White Smoke, First Gen
  164. 98-99 LS400 in the snow
  165. Wheel noise
  166. Heater issues...
  167. temperature sender location?
  168. 1st gen Air Suspension
  169. 1st gen LS swaping badges (us>jdm)
  170. Hard to find 1992 LS Suspension Kit?
  171. 1999 worth it?
  172. water from the sunroof
  173. Pull to right LS 400
  174. Help: Need a Buyers Guide
  175. running amp 12v wire through firewall
  176. 1998 LS400 Acceleration Problem
  177. Access to license plate bulbs in 1gen LS400?
  178. Gas peddle slowing down is not smooth. '95
  179. Help, car wont start!
  180. Repairing my 92 LS400, master cylinder help plz
  181. Puzzled With P0420 and P0430 Codes '97 (solved)
  182. LS400 93' crankshaft pulley problem. need help!!
  183. Where to buy coilovers for ucf10?
  184. 95 LS 400 Control Arm bushing question
  185. Age and Profession ?
  186. 1990 LS aftermarket coilovers going bad?
  187. Has any1 installed oem navigation on non factory equipped ls400?
  188. UCF10 air suspension
  189. '90 LS400 engine light goes in and out with code 52
  190. A/C and Heating Issues '91
  191. Wheel Fitment on a 95 Ls400.. HELP!
  192. Anyone done a shift kit for their LS?
  193. evap... how hard to change? '90
  194. Bumper foglights are just better (pics!)
  195. 99 LS400 front suspension rattle
  196. white/grey smoke on startup?
  197. will a 90 LS400 cluster fit 93 LS?
  198. will LS400 floor mats fit 90-94 LS? pics!
  199. Gauge needles!
  200. 1994 Ls400
  201. Looking to buy '00 LS400.
  202. You think you got problems
  203. Headgasket going on 1994 LS400???
  204. my car shuts itself off after stopping from a long drive '95
  205. 1997 LS400 Starter Trouble
  206. Rear bulb indicator light comes on randomly (1994)
  207. Front right speaker crackling only using CD changer
  208. pioneer or nakamichi '95
  209. Alarm Beep Whenever Starting Up '98LS
  210. Oil light??? '91LS
  211. Help!! 90 LS400 needs alternator R & R
  212. What is this?
  213. Rear 18x10 Fitment Issues?
  214. No power and stumbling 92 LS400...
  215. Lugwrench
  216. so our exhaust tips are faced downward....
  217. New to the forum
  218. catalytic converter
  219. 94 ls400 running prob. in australia
  220. newly bough 94 LS400 and 1st problem...water in the trunk
  221. Guys, my Lexus stinks! (a la Seinfeld)
  222. 98 Ls Makeover Need Suggestions
  223. Fluids / Filters brand loyalty???? How much?
  224. LS 95-97 Shift Knob Questions
  225. centercap fell off...
  226. 1998 LS400 Tail Light
  227. LuxLink Remote Start : 1997 LS 400
  228. Cheap wheels for snow tires
  229. when i get money and if my LS400 is ready and willing ......
  230. Thinking of upgrading ecu
  231. Where 2 buy Floormats OEM for good price??
  232. What happens when rotors go bad?
  233. 95 LS400 Drivers Door Will Not Unlock
  234. Replacing water pump on '93 LS400
  235. Power Steering quiz
  236. Help, my suspension is lop-sided
  237. 1997 Ls400 : Recall Dating Back To 1998?? Will They Honor???
  238. Small leak help
  239. Parts Finder site. Good for any car
  240. Strut Rod Bushing help!!!
  241. One piece head light installation on 93 LS400
  242. Car sat for two months, now low oil? *fixed*
  243. how to change driver side ignition coil for 1990 ls400
  244. How to Change Timing belt on LS400 1999
  245. **It Was a Long Road, Now Complete***
  246. instaling a sub in a 1994 LS 400 with factory radio
  247. 1994 LS 400 Power steering riddle
  248. Pics Of My Show Off And My Money Maker
  249. PLZ Help 92 LS 400 Won't start
  250. Seeking good leather seat restorer/ re-dye in NC
