PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. pics of my '93 LS400
  2. replacing front rotors---stripped set screw!!!
  3. CA or Fed Equipped 98+
  4. Diagnostic Code?
  5. Is300 wheel LS400
  6. CA/Fed Equip differences 98+
  7. Any Lexus techs on board here?
  8. Longest you've gone on your oil?
  9. What does Lexus know that nobody else does?
  10. Strut Bolts too rusted?
  11. Towing Package?
  12. yeah, our LS400s are quite capable....
  13. Headlight Mod
  14. Lightweight disc combo's?
  15. '95 LS400 heat..sometimes
  16. K&N engine air filter
  17. What do you think about this spoiler?
  18. Check engine light on
  19. 97 LS400 Big brake setup on 93 LS400?
  20. pricing question
  21. HELP!!!- Broken driver's seat
  22. Strut Rod and ball joint replacement
  23. How to replace leather on shift knob?
  24. Floor mats
  25. i got this today..
  26. Widebody Celsior (Warning Big Picture)
  27. fuel gauge question
  28. What color is your LS?
  29. Big Question about taking my car 2,000 miles??? PLEASE HELP!
  30. Xenon lights on 92 ls400??
  31. trac light on
  32. Got stalked days ago! (Pictures Included)
  33. intermittent loud KNOCKING on startup
  34. fuel gauge and tach not working
  35. Speedometer
  36. Sunroof Leaks
  37. no sound...
  38. Lexus Drag Racer!
  39. clutch
  40. 92 LS vs. 93 LS wheel/tires
  41. Side skirts for 91
  42. Source for Lexus stock brake pads at good price
  43. LS 400 problems
  44. Body Kit for a 1990 LS400
  45. Stalling LS after highway drive & shifting hard
  46. Color identification 92 LS400
  47. Gen 2 Ls400 Steering Wheel On Gen1
  48. wat you think about my lex.. for being 17 years old?
  49. My power steering system is leaking and emmison
  50. Nitrous
  51. engine noise
  52. Why doesn't A/C Comp. cycle?
  53. Tilt / Telescopic Problem ?
  54. Lexus ES and LS - Differences
  55. Hard To Steer?
  56. My car shakes real bad? What could be wrong?? I gave it a full tune up..Help Please!!
  57. I need more interior light. Any ideas?
  58. Advice needed on selling LS400 (long)
  59. Accident Picture, Should keep or total loss?
  60. 94 LS400 problems
  61. resealing oilpan
  62. Pic
  63. slotted/drilled rotors
  64. more gremlins!Power steering fliuid leak
  65. Tokico Struts
  66. 1996 to 2000 tailights
  67. About to do tune-up...need to know what else i should replace while i'm at it
  68. Busted antenna
  69. car stalling...fuel system flush
  70. Installing 98 OEM radio on a 97
  71. Rumble sound @ times when rapidly shifting out of overdrive- what could it be?
  72. 92 LS400 Power Steering
  73. P/S pump replaced...still have problems..
  74. Tokico Struts/For Sale
  75. wing
  76. ah coilover question
  77. wide body LS400
  78. '91 LS400 - Catalytic Converter(s)
  79. Are the back struts hard to change?
  80. Need Help From Bodykit Experts!
  81. 90-94 stock suspension question
  82. Shake Rattle and Roll
  83. HELP! Engine is ticking (Lifters???)
  84. cheapest way to get a 1995 LS400 into the 13s
  85. Disable telescopic steering wheel tilt-away feature?
  86. Anybody have an "Carfax" Acount?? Help Plz!
  87. Generations: Difference is softness over bumps
  88. Cumbersome Glove Box
  89. seat help
  90. Problem finding a Platinum Series
  91. Odd Vibration- Possible Transmission Problem?
  92. I'm new and about to purchase a 1998 LS400
  93. give me ur suggestion please
  94. radiator fluid flush?!?! was he for real?
  95. is ls400 w/ es300 seat swap possible?
  96. What kit is this?
  97. Noise problem Solved!!!!
  98. Height Control / Auto-ride system
  99. need help ASAP !!!!
  100. bodykit
  101. weak horn
  102. How to make alarm beep?
  103. 90 LS400 vs 94 ES300
  104. '00 corner lights
  105. Trouble code confusion
  106. WALD Executive Line PRICES Lowered
  107. Climate Control
  108. stiff steering wheel
  109. Lexus-parts.com
  110. JIC have new VIP coilovers?
  111. ordering upper control arms from USA for shipping to UK
  112. battery for key in 1992 model
  113. Lease used lexus?
  114. engine knocking
  115. Frustrating: please advise if possible
  116. Is 10k for a 93 LS400 w/ 95k miles Reasonable?
  117. Cartrdige replace time
  118. O/D and ETC power
  119. Need help changing brake light
  120. My 3000 miles trip and 1 problem...
  121. Need to repair stock Nakamichi deck...help needed
  122. Engine Squeaking
  123. How Much To Purchase Decent (older) LS 400 ?
  124. Is the idler and the idle up valve the same?
  125. Check engine light.....code No. 25
  126. Input on when to Replace Struts
  127. Found cure for the common problem...
  128. Help! few things failed to work same time
  129. Smog Test with Injen intake
  130. Tire Suggestions
  131. vibration between 55 and 65 mph
  132. 2 weeks left for stage 1...pic
  133. Is LS400 alternator connected to starter instead of to battery?
  134. Drivers seat belt
  135. Anyone know what these things are? They're not in my manual.
  136. 1992 SC differential and 1990 LS
  137. Where can I get one of these orginal parts ? For LS400
  138. Help (missing 'l' from engine cover)
  139. Egr Pipe Replacment
  140. How to read error codes on 92 LS400
  141. Steering bushing/Damper
  142. I can't take it anymore...
  143. free mod? traction control removal
  144. ATTENTION all LS400 Owners !!
  145. pics
  146. New Member
  147. Cabin Filter
  148. How the Tire Pressure Monitor Works
  149. O/D button failed
  150. Air Suspension Conversion
  151. EMERGENCY!!! Need Help ASAP!!!
  152. ok guys help me out a lil bit.. need expert advice
  153. interior colors on 99-00 LS400 ??
  154. can one drive w/o instrument cluster in?
  155. Armrest Mod Help !
  156. warning lights keep coming back
  157. What do you guys think ? ?
  158. Removing door panels
  159. LS400 Floor Mats
  160. Sagging Sunvisor
  161. Smoke at startup
  162. leather shift knob
  163. LS stalled today
  164. Can I Get A Suggestion?
  165. electric water pump
  166. Windshield washer motor
  167. Iridium spark plugs
  168. Pearl White/Black Leather LSs????
  169. 1999 Brochure
  170. any pics of the strtut bar nushing
  171. thinking of buying a used ls400/430
  172. EGR Vacuum Modulator
  173. K-Break has a web page now.
  174. 1990 LS400 Tranny Problem
  175. ls400 worthless in snow!
  176. Original 1988 Lexus LS 400 Crazyness
  177. 1998 AutoLocking
  178. Happy New Years - New Pictures
  179. more problems with my LS
  180. Grounding kit
  181. Strut bar w/air suspension
  182. XM Radio for 1990 LS400
  183. Location of amplifier 94 LS400 + mystery sensor light
  184. Brakes are bled, but still feels like mush.
  185. Side View Mirrors w/Turn Signal Lights
  186. is my air suspension bad ?
  187. Timing belt change How?
  188. idling problem
  189. jim walker/dash repair
  190. Jan VIP Car mag UCF10/11
  191. Consequences of oxygen sensor and throttle position sensor malfunction?
  192. Headache!PCV valve change
  193. Traction Light
  194. How do you lubricate the bushings ?
  195. Strutmaster uses Tokico Blues!
  196. Keyless entry ECM chip
  197. Major rattle on front end of my LS - HELP !
  198. Check it out
  199. Anyone know what this is
  200. what are the consequences of having a bad coolant sensor?
  201. Folks, maybe you can help this dude
  202. Recommend your Lexus Mechanic in the L.A./Orange/San Bdo. counties
  203. noise during idle??
  204. Shift lock
  205. Car is Hesitating
  206. Location Of Interior Light Delay Module
  207. Does everyone have their LS serviced at Lexus?
  208. present for an LS400 owner.
  209. Any Pics of 1st Gen/2nd Gen LS400 with 20" Rims?? Post Pics Please
  210. For what reason does an LS owner drive his/her car?
  211. Does extremely-dark tint affect the GPS/Navigation system?
  212. Tail Lights
  213. help with keyless entry programming
  214. Rear end sags when "loaded"
  215. NEW ITEM........ UCF10 wood shift cover
  216. RPM vs. Speed
  217. Are these the original annversery rims?
  218. Importing a Celsior
  219. suspensin noise and anyone try Eibach springs?
  220. BG Products
  221. gold package passe??
  222. Stuck vent motors
  223. not enough power...
  224. oem wheels fit?
  225. RPM's and repairs
  226. pics
  227. How do you fix a mirror
  228. 94 ls400 headlight replacement
  229. i was wonderinG?
  230. 91 vs. 2000
  231. how much is TOO much tranny fluid?
  232. low idle...potential for damage?
  233. My aerodynamic LS
  234. Factory "Lexus" (Toyota) struts say "KYB". Thought KYB was different?
  235. How Do I Change My Starter In A 95-97ls400
  236. Where Can I Get A Repair Manual From
  237. Retractable Rear Window Shade
  238. My Engine Mounts Broke On The Freeway!
  239. new LS owner
  240. Where can i get a repair manual on CD (ASAP)
  241. Speedometer
  242. Trouble Starting
  243. parking brake light won't go off
  244. 90 LS 400 Warning Lights On
  245. best dealer for oem parts?
  246. Drivers side mirror does not work right
  247. Question on coolant & plugs for '95 LS400
  248. 1st gen OEM rims
  249. Nokian WRs...First Report GOOD!
  250. Chirping Sound From Speedo?
