- Buying a 1994 Ls400
- no radio when its cold?
- pwr steering noise
- Problem with Alarm on LS 400
- Where to find window switch cover plate?
- Anyone know what kit this is?
- Rough down shift
- Brakes - Front Brake Groan Noise
- enginer won't go over 4000 rpm
- Air Suspension Lowers itself when parked
- TCC problems?
- Instrument cluster
- Is it possible to install an aftermarkert HeadUnit in a 98-2000 LS400 with Nav
- How much for 1st Gen LS400 ??????
- 94 LS 400 Problem w/ Flickering Trac Instrument Light
- 97LS400 to 00LS400
- Need Rear Brake Rotors
- Check Engine Light Code 25
- Park Place Lexus
- Second Mortgage??
- Need info on 93LS to a 98-00 front end conversion
- Is it required to change Brake Pads when installing New Rotors??
- Suspension 'Clunk'
- Loose front seat bolts LS400
- Loose Front seat bolts
- Hi all! Im new and need stuff for ls 400
- Buying advice for a '93 LS 400
- where can I find a roof spoiler for my 95-00 LS 400
- P/S pump replacement story/ problem ?
- What's the best battery to use?
- Just a few 98-00 LS400 Q's
- 94 LS or 99 Xj8
- Pictures of my New 99' LS
- nAKAMICHI AMP
- LS400 in the snow?
- LS400 Radio Nak problem help
- Lights from a 95-97 on a 98-00?
- Wheel help for 98 LS400
- Chips....
- Sheepskin Update
- Lowering my 2000 LS400
- Door Lock Actuator Noise
- Windshield wipers banging away :(
- Whats the difference of driving with Tracs OFF and Tracs ON?
- 2nd GEN LS400 BUSHINGS
- Rear window crack
- Dash lights
- Orange Circle Light on Speedometer Cluster of 95 LS400?
- scan tool for 95 ls400
- Would a 2002 Wood Steering Wheel fit my 95 LS400?
- Power antenna replacement
- How much HP should I expect from a Cold Air Intake - On 1st Gen LS
- Common problems.
- Congrats to Cutecboy:::::COTM Jan2005
- Can you install Sirius Satellite without major mods? to 2000 LS 400
- Recommend Upgrades
- TPS location and removal
- Help with 96 LS400
- what do u think of my headlights part 2
- ABS Light - Brake Pad Wear?
- How many hours?
- Is anyone runinng a Cold Air Intake?
- Carbon Fiber Trunk Lip Spoiler 1st gen.
- What is on your list of mods?
- Would LS400 '91 rim fit '94 LS400?
- Help?? Motor and trans mounts for 2000 LS
- fixed most of the problem....
- power steering/ alternator
- Lexus technician in Tucson, Arizona
- How many miles until the Instrument Cluster Circuit Board starting malfunctioning?
- ABS warning light problem
- FYI: Power steering problems & Solenoid
- 1995 LS400 Immobiliser?
- New oilpan gasket?
- Scale Models of the LS400
- LS400 wheel & tire weight
- LS400 Caliper
- '98 LS 400 / '04 LS 430 price comparison
- Power Steering problems
- serp belt is too loose
- LS400 Seat Interchange Info (95-97 fit a 90-94??)
- 91 and 94 LS400 body parts
- 1990 lexus ls400
- Engine Tapping??
- Snowboard rack on a LS?
- 93 Supra Aftermarket Radiator in a 93 LS400
- 95 LS400 to 98 Conversion
- Power Steering Fix and Great Info
- Robot-filled Tahara sets standard for Toyota, world
- Hey, retrodrive! (Celsior 2Jz swap in Japan)
- 1st Gen. - How to replace the shifter. info
- 93LS poor gas mileage
- New Shocks and ride quality is rough
- Modifying a 99' LS400
- moving knock sensors' for more power
- swapping the torque converter
- "99" LS400 Radio Problem-HELP!
- Door lock actuators
- LS susension and engine sections?
- Merry Christmas
- ECU Part Numbers
- PLEAEE HELP...Check Engine Light Code 52 "KNOCK SENSOR?"
- 'trac' light staying on
- Need New Engine ECU
- Stock amplifier locations?
- Tokico Illumina for gen 1 LS????
- Rewiring your fogs in 95 LS400
- bushing replacements
- will 225\55\17 fit on a 95 LS400
- My first post.. anyone ever done 98 engine and trans on 97 down?
- AirSuspension...
- suspension
- Chrome Wheels
- Part # for 00 LS400 caliper rebuild kit?
- Wheel Vibration
- Changing a LS400 Headlight Lense
- Never ceases to amaze me...
- selling my 93LS
- How quick is your 1st gen LS?
- headlights,foglights,side marker lights
- Picking up a 98 LS400 Friday
- Reparing your car Warning...
- heat vents not working properly
- Big Loud Vibration when accelerating
- Just comparing...
- 93 LS400 dead after wrong polarity boost
- sunroof leaks
- racepipes (aka testpipes) direct fit
- horn working intermittently
- Climate Temperature LED Display: Smear can not read
- loss of power - no check engine lights on
- check engine light/ Egr valve.
- please help!! Suspension bottomed out
- 92 to 93 parts swap ?
- Transmission Screw up after little front bumper accident
- Belt tensioner?
- Loose Steering...
- 98-00 Factory mud flaps available?
- intermittent start problem
- I cant find how to remove the rear suspension
- conical air filter performance
- Gen 1 shifter knob
- does any1 play MP3 in there factory Levinson system
- Winter TIres for LS?
- ** So I'm thinking an Autocouture GB for Christmas...........
- Changin your OWN oil?
- random problems with my ls400 93
- Anyone changed their trac accumulator hose?
- Calling all winter driving LS owners
- GS or LS?
- Navigation
- new LS400 owner
- FREE Limited Edition" Amistad" License Plate
- Coolant Sensor?
- LS picture thread
- Silver 98-00 LS with chrome rims Virginia Tags
- 1998 LS for sale @ Auction in Baltimore Tomorrow 12/04
- What is the different between xx-94 and 95 and up rotors???
- Tires
- High Mount Stop Light for 98 LS
- GS or LS
- Rack is leaking...
- Hestitation on Flooring
- Noticeable vibration at a stop
- Where to sell My Lexus LS 400
- Steering computer?? What does it actually control?
- Daizen bushings....
- Anyone have a JDM magazine?
- Pic of new goody installed
- Looking to buy 2000LS and need some pointers
- What suspension is in yours?
- Stalling when flooring
- 2002 Lexus LS430 on E-Bay
- help me understand admiration kit or something like that
- headlight problem,
- 95/96 Ls400 low Idle, engine dies and jerking thread!
- Possible horsepower from a 98 LS400 ?
- any one know?
- Lexus Tech in Las Vegas
- How many mounts?
- Metric display
- Need to hear your advice
- Transmission over fill!
- Body Kits
- 1990 Ls400 Radio And Lights Dim And Turn Off
- remote programme
- gen 1 LS A/C Compressor Removal
- cd changer cable
- New taillights installed
- Interest for sway bars for UCF20/21?
- LS400 steering, wandering left and right?
- Replace A/C Filter
- Power Steering Pump
- Pictures of my ride
- Windshield Repair
- Does 91 Lexus LS400 have a Starter Kill in factory alarm? Help Please Car won't Start
- 91 LS400 remote key
- Windscreen wiper blades
- Has anyone replaced their Winsheild on a 98 LS
- Thump at start up?
- LTB 93 LS400 opinions needed.
- what's this black box?
- Engine surging at light acceleration??
- coolant leak...
- 95 LS400 trunk won't stay up
- Emergency Help & opinions needed!!
- Rebuilt steering rack
- new ls comming out in 2007/8
- Large chrome window trim - removable?
- Knock coming from right front
- MAF question
- Are the 2nd Gen LS400 (95-97) as reliable as the 1st Gen LS400s (90-94)?
- A LS400 saved my life
- Random things under the hood
- Got the LS back...
- 1994 LS 400 w/ 155,000??
- Crazy dash lights in cold weather???
- Door won't open from both sides
- Took some new pics today, LOOK.
- LS400 Aero Kit
- Just took the Lex into the Stealer!!
- Location on Speed sensor 1 and 2 on tranny?
- Am I getting a good deal?
- Replacement Pads
- Location of Total Diagnostic Communication Link TDCL?
- Tranny won't shift out of first gear, 92 LS400
- seat belts
- LS400 tranny won't shift out of first gear?
- alignment specs LS400
- removing 1st gen door panel
- Looking for rain shields 1st gen
- looking for pics of 1st gen w/ fender flares
- Mirror Turn Signals II LS - GS - ES
- 96 LS Cluster removal
- Club Linea Barletta on a "Black" 1999 LS400
- Door handle springs shot - now what?
- Junction Produce LS400 pics from SEMA
- Where is it coming from?
- Do i have a problem? New LS400 owner.
- i need A/C help
- cigarette lighters
- downshift jerky
- Blower Motor Not Working In Low Or Med Speed
- Buying a 91 LS 400
- Gen 1 AC compressor
- Another Celsior = LS JDM Catalog
- Engine is shutting off
- 95-2000 guys, I have a break pedal problem
- Any Brake upgrade for 98-00 LS
