- 49MPG Current Fuel Consumption Reading on a 99LS400
- 99 LS400 with Bad radio LCD
- door problems
- retrofit to 134a: need to drain old oil?
- 2nd Gen Crossdrilled Rotors
- Rotors and Pads
- L-Sportline Springs for 2000 LS400, what is the rated drop?
- Please Help Power St. Pump
- Need a gearshift knob FOR 1994 LS400
- Need opinions (Exterior)
- Do you have REAR aircon in 2-nd gen LS ?
- navigation system light dim
- Rough Start
- Clearing the amber out of the taillight??
- LS400 Rotors/Brakes
- Steering noise on LS430
- Brake light on
- Place to buy replacement antenna
- 95 ls400 with 99 eng $5500
- help with xenon kit
- 98-00 Steering wheel controls; what do they control if you havr NAV?
- Would you jump into this boat?
- vnt turbos
- questions on hilltop lights
- What do you like most about your LS 400/430 or any other lexus you have or had
- I know this is the GS forum But I need serious help my LS now!
- Quick ball joint question...
- Lexus UK track day!
- Which headlight is better?
- Headlight conversion
- 1998 LS 400 with 39K Kilometres...
- newbie here....need helping on purchasing an early model LS400
- preventative maintenance at high mileage
- HELP!!!!, Broken Serpentine Belt Tensioner
- U.S. Wald body kit distributor ??
- Anyone ever take their LS on a road course?
- Thanks!!!!!
- Celsior Pic Post! (56K beware- lots of pics)
- computer screen is stuck, how to reset?
- dropping off ls for service at local shop
- JDM Headlights
- are you kiding me? $1000 for repairs?
- what do u think of my headlights
- Wood Shift Knob?
- Have a Non Lexus Extended Warranty
- Suspension damage from custom wheels?
- Addco rear ant-roll bar
- now THIS is a wet bar
- Motor Mounts
- crankshaft breather
- Lexus Aftermarket (used) parts information
- Airbag warning Labels
- Mods On A LS 400
- Timing Belt Replacement
- Year differences in 98, 99 and 00?
- Power Steering Leak...Help Pricing Parts!
- Want to see a $70,000 1990 LS400
- Alignment Cost
- My Throttle control went out again !!!
- GS 430 stearing wheel?
- Does Your Lexus Have A Lot Of "Problems"?
- Great I-5 San Diego Trip and then...blasphemy?
- Group Buy from Leatherseats.com
- Wald Body Kit: 92 LS400
- International Shipping Question
- just a general question about a pic
- Maybe You Guys Can Help
- models line up
- lexus extended warranty
- LS Pass Window installation
- LS or GS?
- Lexus ls 400 '93 turned off one day and won't start back up. Help!
- tough decision
- ABS pump location
- Gas smell on startup
- Intro of new member
- Question for non biased lexus owners please
- those experiencing a mushy/soft pedal
- R-spec ASC 680 Air controller
- '97 LS 400 - squeaking front suspension questions
- Fender Flares
- Well my 03 LS430 is gone..
- 91 LS Ac Blows Cold on 1 side & Hot on the other?? What could be the problem?? Help
- anyone have a repair manual for first gen? starter prob
- 90K service/ cheaper in SoCal vs NoCal?
- Howdy. Blast from the past...
- ignition coils
- should I let the dealer do the work
- New to the forums... with questions...
- Finally for yall LS400 guys.. SPEAKERS!
- power mirror problem on '90 LS400
- 90LS400 Air suspension
- Video of my LS400.....
- hesitates after oil and transmission fluid change?
- Intermittant Tail Lights
- Transmission Cooler
- anyone need to stop the smoking on start up?
- new suspension
- Time to say goodbye Lexus.....for now
- Help wW LS400 :(
- Hey "Kidcapp" don't I know you?
- tilt/ telescopic steering wheel
- car height and tire size
- Can we get some pics plz?
- 04 Ls 430 Q: Blue Tooth?
- help - front lower control arms
- where can i buy cd cartridge for 92 ls400??
- looking for a little hlep on hood shock replacement
- Well new rims and a lazy afternoon...
- Front end swap LS430 to LS400
- New guy here...
- ano ther over heating issues again
- RPM's jump up after letting foot off gas @ Highway Speeds ..... Normal !?!?
- Outside temp display
- audio no sound help!!!!
- Window Seal Squeaks and Crackles
- Fast or Stylez?
- where to buy MAF sensor and TPS
- Blocking EGR in LS400 -91=>More power?
- Japanese Magazine Photo Shoot in socal
- Can the factory options be looked up from the VIN?
- Motor Trend mag tire testing article w/ cool LS pic
- Reverse light coming on when brakes are applied?? WTF
- Exhaust noises
- LS- my electric fans don't work
- 1992 Air flow meter
- What brakes to get for my 92 ls400?
- V8 stalls after startup unless gas pedal is massaged..
- 95 LS Parting Out.
- What happened?
- Polarized glasses
- Second Car To LS430
- great website for LS
- clime control display swap
- where can i get 95ls400 rotors?
- Loose Driver's Seat
- Exhaust Growly noise
- won't start
- car won't start
- Lexus Fluids
- Best place to get new antenna ?
- 94 ls 400 drivers exterior door handle
- new struts...
- Please help me! My Car jerks a little at highway speed. Change the ECU?
- Lexus Special Service Tools
- part question
- Can anybody answer this question for me?
- Hello from London!
- Help: Inner Tie Rod Removal Tool
- Vibrations at 1200 rpm
- Pic of Colgan Carbon fiber bra
- Squeaky Armrest
- Wanna see some slammed 400s.
- one or two idler pulleys?
- Got bored...some nite pics of my baby
- finally strabded with my 90ls
- brake pressure switch?
- Suspension is off balance, lowring module??
- Scary Not Throttle Control on my 98 LS!!
- Front Suspension Parts
- musty smell
- Grille styles for 95 Lexus LS 400 A.K.A. Celsior 20 in Japan
- Whats your biggest accident you been in?
- Transmission Stutters 95 LS400
- A/C ports
- dealer complaint.. where to call ?
- wat you think of this?!?!?
- Need help with suspension conversion
- my 95 LCD light in the radio is out
- Cold start stumble
- grill
- Power Steering Valve On 91
- 91 Lexus Ls400 Front-end Creaking, Creak, Creak, Creak
- Harsh Engagement Solved!!!
- My Dad's LS
- 91 Lexus on 20's...needs a lift
- End of an Era
- a/c not working in 1992 ls400
- Advise please family buying a car....
- Oil and Coolant Questions :)
- A/c
- Vibration gone
- About to paint my car
- 92 ls400 with a pulsing sound
- 11 Mpg
- Best Handling Wheel/Tire size combo??
- Easy fixes to do...
- Control Arm Bushings for 2nd Generation LS400
- Carbon fiber hood avail. for 1st gen. !!!
- Which is the better buy?
- Bad AC Compressor Breaks Serpentine Belt!!!
- '95-'00 Stereo button backlighting replacement
- AC Unit Guagepod ***Pics***
- colour not matching after accident repair
- speedo incorrect
- a/c????
- Ls400 Maf?
- R12 to R134a conversion problems
- Connecting the idle up valve hoses to each other
- self cutting brake pads for the rotors.90LS
- Timing belt question
- A/C and Clock Display
- Hesitation
- 2006 LS500GT over $100K
- Cigarette Lighter
- Starter / Charging Problem
- Well...$550 to fix the steering wheel!
- Who really wants the wood steering wheel?
- Torquemaster spark plugs
- NEEDN suggestions and help on my 91 ls
- need help for my 91 ls!!!
- Sand Rotors?
- A/C Compressor
- ABS on 93 LS400 question
- any experienced auction attendeers?
- suggestions for my 91 ls400!!!
- Off center steering wheel
- Brian V. did sell his LS
- Newbie
- Keyless Remotes-Which One? Both? LS400
- Wipers
- PS leak - from cylinder atop rack/pinion - now what?
- brake bleeding from service manual 93LS
- 90-91 Ls400
- Finally got my stuff....:)
- Help....96ls400....vibration(tranny?)
- proportioning valve / abs actuator
- twisted seat
- Exhaust Residue on Bumper/Trunk
- Oil Filter from Dealer - New Product?
- how to replace brake bulb?
- Toyota Celsior Emblems, where to get?
- 91' Ls400
- Door lock actuator problem -locking unlocking randomly
- No AC, rear defog, thermometer, clock
- 93 LS400 - Fair Price?
- 2nd car choice? another 400?
- Rpm @ 60 Mph?
- H3C to H3 conversion
- 1993 LS400 How to Change Cabin A/C Filter?
- strut /spring question
- winter driving
- Celsior (LS) side emblem
- First time pics in the gallery!!!!!!!
- Newbie Hello!
- Incompetent Grease Monkeys
- Where to get LS400 badge for trunk?
- Damn fool scratches my 400...
- Hard time starting my 98 LS400
