PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 [98] 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. no cd player in my ls 400
  2. 98 LS with 92k miles w/ NO maint. What needs to be done??
  3. Help, which wheel to get
  4. My Celsior, New Member
  5. telling if you have air ride or not
  6. Aluminum Dash kit
  7. TINT suggestions for my color scheme, HELP!!??
  8. Wald Prices and Distributers
  9. Engine warning light
  10. Oh No, Demonic Noises! Ls400 1990
  11. difference between ucf10 and 20?
  12. holy SMOKE batman! (after a hard run....)
  13. 98 LS CD Player Problem
  14. Should I be using Mobil 1?
  15. So I changed my oil today and..
  16. Need seeling advice
  17. 93 ls with blinking od light on dash
  18. FAKE XENONS - Pimp or Wimp? lol
  19. Where can i buy brembo blanks?
  20. nakamichi cd changer 1995 ls400
  21. Lowering Ls400 questions.
  22. Which Tire to get for my 00 LS
  23. Dual Supra Fuel pump for LS400
  24. shifting manualy - bad for the car???
  25. Recommendations for 15 inch rims for 92 LS4
  26. Tire size questions
  27. 60K mile tuneup
  28. Just changed power steering fluid
  29. 98-00 Ls I found on VIPsylecars
  30. Gear Shifter Schematic for Gen 1 LS
  31. Filling my A/C - How??
  32. '90 ls problem "dies" please please help
  33. timing belf & water pump
  34. Wings West and Veilside Body kit combination
  35. 90LS air suspension prblm
  36. Is '98 LS400 "generation two"?
  37. Power Steering Issue
  38. Transmission replacement 92 in a 93
  39. Navigation on 98-00
  40. Question about fuses underneath driver side headlight?
  41. Trying to find low pressure port for A/C
  42. who needs lexus manuals?
  43. 1st gen LS400 temp gauge malfunction...
  44. Keyless Entry - Faulty Key??
  45. Not buying an LS400 anymore
  46. GS ride V's LS?
  47. Suspension question
  48. A/C, Heater problem, please help.
  49. Need to install springs on my UCF-20
  50. 95 LS400 Speed Sensor VSS and Kenwood Navigation Question
  51. I just bought a 1998 LS400
  52. TRAC OFF / Check engine light Fixed!
  53. Trenz Billet Grille just installed on my 1st Gen
  54. EGR tube replaced, no more exhaust leak!
  55. Pic of my '92 LS400
  56. LS Aniversary edition
  57. Just gotta 98 Ls; Which bulbs to get for xenons
  58. Removing the CD Changer in 90-94 LS400
  59. Car shudders/hesitates when shifting into park.
  60. 92 LS400 A/C Water Leak - Help !
  61. Replacing Antenna Mast on LS400
  62. torsion bar is bad,,,,,, anybody else have this problem
  63. Radar Detectors
  64. How often should I change the oil?
  65. Father and son
  66. New owner: A/C blower seems a little weak
  67. Deciphering Vehicle Identification Numbers (VIN)
  68. excessive steering wheel shaking after small bumps
  69. Is this too much mileage?
  70. Revving High Idle Problem Solved
  71. caliper loose, squeaking brakes ?
  72. Intake Manifold
  73. What!!?!?! LS 400 at the Nurburgring !!
  74. Tell me this aint sexy (monotone LS)
  75. LS400 with Amistad Type F
  76. Aftermarket headunit.
  77. Congrats to ATSOU: June's COTM
  78. Will RX330 Shift Knob Fit?
  79. when to replace air struts?
  80. Hard shifting into gears
  81. 18" 06 GS wheels on a 00 LS400 ??
  82. buying a 90-92 ls400 within a week or so
  83. Replacing the Navigator DVD on an '04 LS430
  84. LS400 + Army Truck *Pics*
  85. What Headlight Bulbs do YOU have?
  86. alternator prob.
  87. Amistad LS400 Body Kit - NEW!!!
  88. Need some help here about my ls 400 power steering pump
  89. 1990 JDM Celsior Pics
  90. 93 ls400 electrical
  91. Strut bar, is this a good one? 1990 LS400
  92. license plate screws needed
  93. Front End Shimmy LS 400 2000
  94. Transmission Cooler
  95. Having problem with my LS400, need some help
  96. LS Bike Riders--need your help!
  97. 92 LS 400 running rough
  98. Air suspension
  99. Help!!! How to change the rear brake light?
  100. LS question
  101. 2nd gen namakmichi ?
  102. 2000 LS400 wheel size ?
  103. instrument cluster lighting replacement 1990 ls400
  104. VIP Car DVD
  105. Just Installed custom JDM red/clear tails on 99 LS
  106. need some advice on a 1993 LS400
  107. 1st and 2nd Gen must check this page. Lot of info
  108. Ebay Hood/Trunk shocks?
  109. ebay Key question?
  110. 91' Ls 400
  111. Time for the LS to get a custom Trunk
  112. Is this a good deal??
  113. Driving on Dirt Roads
  114. ***Upcoming changes to forum lineup***
  115. Gen1 Alarm Question
  116. 18" OEM wheels on a 2000 LS
  117. Steering Wheel Deterioration
  118. 96LS with 2000 Identity
  119. Mirror Signal mod?
  120. Foglight mod for 98-00 LS COMPLETE!!
  121. sneek peek on Stefwilli/D2autosport LS
  122. New Toy - T04R
  123. L-Sportline Dual Exhaust?
  124. How rare is my Lexus...
  125. 1st Gen. Clear tailights leaking!!
  126. 1st Gen. Gear Shift Cover
  127. Is this 1995 LS400 a Good Buy?
  128. any time I depress the brakes my car shuts off
  129. info
  130. Lowered frontend uneven....here's cure
  131. My WALD KIT is installed *pictures!
  132. Dual Exhaust Question
  133. What's your opinion on Axis Wheels?
  134. pneumatic electronic suspension - replacement alternatives
  135. Integrated cell phone option
  136. LS400 19 in rims question
  137. ATF for my A341 automatic?
  138. Replacing AIr susp with regular susp? 90 ls400
  139. Getting really sick of the LS
  140. Xxx Lex Ebay
  141. Brake Pad Installation-Reasonable Cost?
  142. My Wald Body Kit
  143. dashboard cover
  144. Clear Headlights
  145. Major brake caliper problem.....(HELP)
  146. Crown Athlete UCF10 conversion?
  147. I found Cheap 20" Chrome Rims for a LS400 Should I?
  148. rotor installation..
  149. BRAKE & WHEEL QUESTION???
  150. 20 inch rims
  151. Switch behind tool compartment ?
  152. Stinky AC Vents
  153. ??SST tools for timingbelt/waterpump/oils seals??
  154. Noise when backing
  155. Factory Phone on '92 LS
  156. Where is the AMP?
  157. stock stereo question?????
  158. Suspension/driveline
  159. Looking at 1990 LS, Your input needed!
  160. interior differences....
  161. "lot of nuts" chrome wheel-anyone want one
  162. HELP - noisy AC compressor - again!
  163. need lexus mechanic in connecticut
  164. New 1998 LS Owner and VIN Location Question
  165. Is there a LEXUS equivalent?
  166. LS400 Comparisons
  167. Fuel Door -Dash Switch broken
  168. L-Sportline shocks: default height setting?
  169. $125 for a spark plug change?
  170. 1995 LS400 Paint Colors and Interior Colors
  171. 1995 Headlight Differences
  172. Looking for member named Khang
  173. Comparison Legend vs LS400
  174. High Idle on cold
  175. LS430 in Star Shield Armor booth at LA Auto Show
  176. test drive appointment
  177. PSI on bigger wheels
  178. LS Aero parts fitment FAQ
  179. Oh No!
  180. 150,000 Maintenance
  181. Anybody experience California Custom springs?
  182. Why do they call it this???
  183. Airbag wiring Gen 1
  184. Airbag schematic for Gen 1
  185. Pics (finally)
  186. LS done, finally (pics)
  187. Lower gas mileage after K&N and exhaust upgrade
  188. 7 seats white LS400
  189. Climate Control question
  190. 99 LS400 Dash Light malfunction
  191. WOT Switch under Throttle?
  192. Battery Draining
  193. Thanks To OVERSTEER!
  194. CEL Light Situation - WEIRD!!
  195. Spy shots of New LS430 (update Toyota Crown pics)
  196. DIY Celsior/LS website
  197. Should I get other stuff replaced when lowering?
  198. About my engine coolant...
  199. How much can I get? 93 LS400
  200. 90 LS400 Idle speed problems
  201. A very curious question about my LS...
  202. Two different ball joints made for the LS400?! (Need Advice)
  203. LS first gen '92 wheel/tire recommendation
  204. Stock LS400 owners..at how many miles did you replace shocks?
  205. Too much feeling in the steering wheel? Help?
  206. Door drain holes
  207. 96 LS front brakes
  208. Help Boot leg cds wont play in my 95 LS400
  209. Nice weekend for DIY
  210. 2007 (4th-generation) Lexus LS model plans
  211. Cool Interior mod
  212. Struts Koni or Bilstein?
  213. Speedo inaccurate need help
  214. Climate control help!!!
  215. Please when you make a Thread put the year of your car and make!
  216. LED Globes for LS
  217. My car died
  218. center dash light
  219. 1990 LS400 proud owner
  220. 98- 00 Ls400 L-sportline bodykit
  221. How can I remove the indash cd changer Help!!
  222. Help....LS430 Wheels on LS400??
  223. Q's from a new owner (94)
  224. Replace Speakers
  225. Tailight facelift for Gen 1 LS
  226. ls400 power steering noise
  227. 100 Octane
  228. Factory vs. Non-Factory Chrome
  229. 98 LS400 with 04-05 18" Wheels?? Anyone?
  230. JDM strut mounts
  231. Loose seatback....?
  232. Lowering Springs
  233. Low tweeter volume both sides 94 LS400
  234. Starter Question
  235. should I lease or should I buy?
  236. How to fix angled seatback?
  237. Fuel Pump replacement on Gen 1
  238. New JDM Type C-F Celsior
  239. Brake Issue revisited
  240. MAF Screw
  241. Thinking of buying a '96 LS400
  242. Small (economical) lip spoiler for 98-00 LS?
  243. Tie Rod Ends?
  244. No 6x9's!?:eek2:
  245. Celsior/LS 400 Stock Radio
  246. So my car wouldn't start today...
  247. Which LS are you in?
  248. Painting bottom cladding black and black grill.
  249. IS300 wheels on the LS400...and other misc pics...
  250. OH NO! p/s problems with my 1990 LS400
