- 98-00 LS400 Camber
- Key Is Stuck!!
- VAIS technology
- Need to delete and Add sub key for a 1997 LS 400
- leaning suspension!
- 98 Cam belt failure at 73000 miles
- if i get 1-2 opinions i'll be happy.
- 2nd gen front seat base
- Chrome side mirrors for 1st Gen LS 400...
- Nos
- New Rims
- New to the Forum
- Any power-bleeder users here?
- Good used parts junk yard in so cal? Need door
- 95-97 Red Clear Tails Installed
- Clear bra on LS400/430
- my ls4 (I finally have pics)
- Will SC430 stock wheels fit a 95 LS400?? Clear calipers??
- LS400 intake problem
- Lost remote
- Gas Mileage
- Future 94 LS400?
- 5% Tints???
- rim question?
- Hit a curb and the Axle came out
- Vid of LS400 Exhaust
- Body Kit
- Any other options for tailights?
- Key gets stuck in my ignition
- 05LS430 demo premium+ 5kmiles 55,500
- New Member
- Removing tranny pan - how does the filler tube come off?
- Daizen Suspension Parts Question
- Speakers size and replacement
- Driver's side door jammed
- turn signal mirrors
- Hit & Run
- From American to Canadian Spec.
- A few basic service questions...
- Wiper Blades
- What does the overdrive button on shifter do?
- Why no special editions?
- Car clunks on start
- Upgrade headlights from 2nd to 3rd gen?
- new clear corners & park lights
- LS400 Demon Eye Group Buy Proposal
- full tank of gas , meter reading only half
- brake pad shift?
- LS400 Part swap: front/rear stabilizer (OEM)
- l-sportsline suspension:pros & cons
- How hard is it to flush the brake system 96 LS400?
- Where's the balance point on a LS400?
- Hissing sound coming from '93 engine
- PS new air control valve?
- CD changer replacement
- Hot Rims???
- brake hose fitting fouled
- Power ECT
- Alternator plug ?
- my LS 400
- Seeking Clear Taillights
- Has anyone seen this engine?
- engine replacement?
- Serious Help Needed!
- Bad Ride...How do I tell if I need new Springs vs Struts (not aiir shock) on LS400
- ls400 stock parts # from lexus???
- Clear corners installation 98-00?
- An air suspension query!
- alot of suspension noise for first 30 minutes
- Suggestions Needed On Exhaust ! !
- Alarm on a 1990 LS 400
- Help with part needed
- does any one know?
- Sweet! Got new rims on. Pics
- gonna replace struts and spring , what else should i change ?
- R134 is filled, but its still not very cold during the day
- Good price for Compressor?
- Help!!!!! Injector plug problems
- gas needle question ?
- 1994 LS 400 Need Shocks Replaced ???
- 91 LS400 all air suspension go bad at one time??
- lowering my LS400
- Help identify Celsior Stereo
- How to Drain Evaporator \ AC hose?
- a/c and bright lights
- 92 ES300 phone in 92LS4??
- Ethanol in an LS??
- which aftermarket lowering spring to get for car that has airbag suspension ?
- GS exhaust on an LS??
- Car won't start after LS400 Alarm went off - ideas?
- Stock '05 LS430, does it have an active suspension?
- Older LS Handling
- crazy problem, i brake the R light comes on, bad bulb light comes on car downshifts
- Celsior Oil Filter Same as '00 Avalon
- Interference Or Not???????
- 1991 LS400 A/C Issues
- Trouble Programming Key for Keyless Entry 91 LS400
- 97 on a 98
- timing belt nightmare please HELP! ticking
- 90LS400 Window Motor or switch problem
- LS400/96/55K...Good deal?
- help ! i get really bad gas mileage. only 10 MPG !
- IS on an LS
- k40 un3000
- WANTED, has anybody seen this? (trunk spoiler)
- New wheels on the LS
- 2 Weeks Until Lexfest!!!! Come On Everyone!!
- thinking of getting 96-97 LS400
- Question about door locks, when using keys
- H&R vs. Eibach Pro Kit, which is softer?
- car being lower by itself
- new to the site
- Does my 95 LS w/52k miles need shocks/struts ?
- squeking rubbery noise whenever suspension moves
- D2autosport 2000 Celsior : Cl Member Stefwilli
- So it seems I fixed my fuel gauge problem
- tint
- 2005 LS 430 Air Conditioned Seats
- Car thieves tried the LS
- How easy is it to change a headlight?
- 19" or 20" rims...what size and offset!?
- Remember the cheap 20" Rims I was going to buy? Well here's a pic installed!
- Console Lid Removal
- Door Locked -- Help!
- Headlights should go on w/ wipers but...
- 95 LS400 ... what to expect?
- LS400 shift knob
- battle of the import ... last sat
- rims on LS400
- Where to get a fusa...
- Very Strange Problem
- Non-uniform cooling from vents
- Conjunction Junction, what’s your function
- Caution with eBAY Cluster Rebuilds
- 1990 ls400 PARK LIGHT
- Function stickers for woodgrain kits
- LS400 at buttonwillow!!!!
- These Big LSs will REally Hustle :o)
- What was your previous car??
- Ready to put on my rims.
- Radio display
- Lord Celsior's Grille
- LS400 brake issue.
- how fast have you gone?
- So I took out my wooden console the other day...
- Thinking about buying a 95 LS400
- Good/Bad buy? 94 Ls400 126,000 miles $4,250
- LS400 Instrument cluster
- Timing Belt time
- could i cut off the air suspension ?
- Cigarette lighters don't work...
- Does anyone know where I could get...?
- Help with new AC Compressor
- aftermarket lowering with air suspension ???
- 1st Gen. Grill Mods
- 1999 LS400 Wheel and Tires
- My TPS issues resolved, small guide
- Wheels!
- hours of work and nothing, seafoam = crap, new ngk plugs
- silverstar4000k pic
- Where to buy replacement carpet?
- universal oxygen o2 sensor wires ?
- changed diff fluid and more p/s fluid today pics of ghetto pump and race jack
- 1998 ls400 daytime running light conversion
- Admiration Style Eyelids/Eyebrows
- antenna on rear window ????????
- Hood Latch problem
- Model Year Feature Set Breakdown
- My new car a 1998 LS400
- Newbie Help
- Wald or Exclusive kit
- car wont start .. any advice please .
- DIY Leather seat covers intall
- warning to those who adjust their TPS
- What oil filters does Lexus provide since the (90915-20004) is discontinued??
- crack my corner light housing
- Another starter dilemma.
- Tranny fluid changed, cleaned and sanded terminals
- LS400 air suspension aftermarket
- Does your Lex get you CHicks? lol :o)
- question for those who have change their brake pads
- brake pad wear indicator light ????
- 1993 LS with 88K is $7500 too much?
- 98 - 00 red/white LS400 Tail lights?
- Passer-by makes offer on the LS
- fuel pump problem?
- cd changer
- oxygen sensor part number
- pic of TPS, but which one
- Seat Belts Hardly Lock! - Normal or...?
- new owners first time p/s fluid change NASTY
- DaveGS4
- Wheels for 2000 LS400
- navigation screen problems
- Rack and Pinion steering on its own!
- Electrical sytem went crazy
- gas needle problem
- power steering moan on '90 LS
- Giugaro designs for Lexus
- TPS screw sizing
- Brakes Mushy
- LS400 Navigation Override
- Traction Bleeding.
- [Pics] My '91 LS400 (WIP)
- O2 sensor... Denso, Bosch, ?
- how to check check engine light ?
- Headlight troubles after replacing bulb
- Buying a LS400 soon. What to look for? Problems etc?
- Looking for experience-based advice on LS430 options
- lithium grease work wonders
- yet another ecu issue, it constantly blinks when diag port is jumped
- Mass AirFlow - BE CAREFUL!
- 1995 LS400 Starting Problem
- error code 31 HELP !!!
- Pics of Lsportline kit and LS430 18's on my 98 LS400
- ecu issue, which can i swap
- Suspension Change
- exploding door lock switch
- LS 400 A/C issues
- Headlight Adjustment on LS400
- wings west kit ?
- Engine Stalls with Black Smokes
- Aftermarket Grills
- Code 21 and Blinking AC Light - please help
- Electrical Problems
- MY first full week of ownership
- Brake Lag... ?
- Tach. Does not work
- Air Conditioner OUT A/C NEED HELP
- Gen 1 Front seat removal
- engine sound
- Sluggish cranking
- Ride getting bumpy...
- Small gurgle or rattle at low speed when tank is near empty
- Small work, yields big results.
- Power difference In gen1 vs. gen3
- Power window works then doesn't
- A couple sound system Q's
- Changing fuel filter was a pain -- any suggestions?
- NEw Member
- finally pictures of my new LS
- 90 Lexus wheel lugs size question
- ECT Power/Normal Swtich on 95-97 LS
- Adding factory Navi
- 94 LS400 "cuting out"
- Rear Subwoofer!!
- What color is it?
- I think i have a problem
- Need help how to pull ECU codes
