- like son, like father... another LS400 (pictures)
- How to remove side panels on an LS?
- 93 ls key locked in ignition!!
- Two Questions, tires, gold emblems
- Almost Owned by not 1, but 2 Deer!!!
- What is this on 93 LS400
- some updated pics of my ls
- Running 245/50/16, how far off is my speedo from stock?
- Quick Tire Question
- Question? (chrome door handles for UCF10)
- 1992 LS400 running extremy rich and rough
- 1997 ls400
- 99 LS400 with 18"AME Shallen LX
- dead shocks
- how did you guys run the power wire from the front to the back of your ls
- 2nd gen power steering leak
- Just thought I would post....
- 1991 Lexus LS400 - need good door speakers....
- Back from the shop...
- need help at identifying a problem (pic)
- take a look!.... lol...
- Car dead
- air suspension strutmasters convertors
- Thanks CL! This is what $21k got me
- Front replacement speakers?......
- interference v. non-interference
- 95 LS400 A/C Unit
- Do the FX35 rims fit the 93-94 LS400?
- trac light on upon start up botton doesnt turn trac off when cold
- Another newbe question
- 93' LS -Replaced factory head unit, now no lights on radio or a/c
- 1991 LS400 question!
- JIC Magic Twin Spartan SUS Exhaust Opinions?
- 1999 LS400 Navigation Override / Unlock
- PIC REQUEST: 1998-99 LS400 with SC430 18" wheels
- Front end fixed!!! Update
- My NEW ride!
- First gen questions
- 91 ls400 all warning lights come on and go off
- Failed Emissions....Help?
- Wiring stock amp with new headunit
- Really strange problem (bug between plastic and LCD screen '99)
- Almost bought Silverstar 9003 bulbs for lowbeams...
- How well does an LS get around in the snow?
- Post any pics you have of modded LS400's!
- A Few Random Questions Regarding My 98
- Replacing serpentine tensioner
- Slight surging with light throttle.. suggestions?
- Anyone add oil to their fan clutch?
- dash lights 91 LS400
- 2000 LS400 Platinum
- Volk Te 37?
- sc400 versus ls400 trannys
- Gearshift Lightbulb ... how to get to it? 2000 LS400
- 91 Ls Car Won't Start. Help!
- Need to know if transmissions have a vin#
- Higher Stall Converter Questioin?
- 95 LS 400 Wiring Diagrams needed. Audio Most important at the moment.
- 1998 - Shaky When Revving
- Purchased 1995 LS400 blue w/tan (pictures)
- mpg diagnosis
- Having problems with my headlights...Please help me!
- Did something alittle crazy yesterday...
- 18x9" Wheels for a 95 LS400
- new member with questions
- P/s Oe Srvc. Vacuum Valve Ls400? Plz Help!
- Video of my 99 LS400 with Muffler Delete / Jbrady|Lexkost type Intake
- 1998 Lexus Phone Removal
- S/S Brake Lines for a 2000 LS?
- Front Suspension Problems. Need advice
- My 98 LSadded 15mm spacers with OEM 16's
- problem with cd changer
- 96 LS400 audio
- Cluster Needle Going Dark '90
- who makes adjustable pillowball mounts for 95+ ls400?
- Oil Pan Gasket '91
- Ticking noise on acceleration 91 LS
- Replacing Fuel Filter In LS400
- Daizen bushing problem?
- Need to identify what year my 1uz HELP!!!! Please
- EGR delete problem
- Check engine light for 30secs till warm up
- Do you have slop in your driveshaft? Look here.
- Radio Exchange?
- Help! I have a screw loose!
- Listen To This!
- Dropping My Ls 400
- LS400 Bad gas mileage and TRAC
- 1991 Ls 400 Original Paint
- headlight conversion
- Lexus EGR Vacuum Modulator
- MPG Has gone down the drain
- 92 ls 400 tranny problem
- 1LS Williams Edition?
- Another odd-ball question.....
- Help-Air Bag Suspension on my LS 400
- No Heat
- steering wheel
- Overheating
- Air Bags?
- Lexus maintenance website
- Celsior Badge? Black Pearl Emblem set?
- 93 Ls400, 160xxx, tranny solenoid?
- Two unrelated questions on a Gen II...
- tips for replacing upper control arms on 96 ls400
- Got my head unit
- intake helP
- 92 Ls400 Stock...rims??
- Door panel prb....
- Oil Leak Under My Ls
- Lexus LS 400 year 1997 to 1998 change
- Weird Knocking noise
- MPG from Vacation in 99 LS400
- Head Unit questions 98-00 LS
- Oil Filter (location) 98 Ls 400
- Rolling pictures of my LS400
- Which would you pick?
- Lights on and the car looses battery power
- Help Gettin Rims For My 92 Ls400
- Anyone able to install an SRT intake onto a 98LS?
- Watching The In Crowd.
- Steering wheel recovered
- Door Chime Removal
- Key
- What is your air filter setup?
- *JASBMO's '98 LS400*
- Possible fix for climate control LCD
- show-off your lex!
- which spark plugs should I Put?
- 98-00 LS400 Ashtray Assembly...
- Auto Leveling Hesitation...
- Is it just me that has this issue?
- With TC off, my LS still doesn't have the balls...
- what size wheels?
- Lexus Ls400 Xenon
- Problems Replacing Broken Antenna Mast
- 99 ls400 clunking noise
- 93 LS400 shuts off - Part 2 Updates
- speaker size
- MAF in 92 LS400
- Why is Lexus such a dependable car?
- Problem (slow acceleration)
- Code 25 and 26, anything related to code 71??
- Looking burgundy door for LS 400 - 1992
- 93LS engine stumbles intermittently at idle only
- Hesitation, related to EGR??
- Roofmount dvd monitor/player gen 1
- Towing another car.
- Offset question. (MY1996)
- 99 LS400...I Pod????
- Been driving a 1988 dodge ram P.O.S. to work everyday..
- Is the emblem for a lexus...
- Replacement K&N air filter.
- Nakamichi to replace pioneer head question
- How easy is it to steal a 1LS
- Stock Exhaust picture
- First Seattle rain.. car handles like a death trap!
- Trouble with reverse
- '98 LS 400 Navigation Boots up intermittently
- Purchasing a 97 LS. Questions about dash...
- Illumination around ignition cylinder will not turn off???
- Supra Turbo front end brake conversion...
- Rims for a 98 LS400
- Sway Bars
- new pics of my ls and radio install
- tilt steering not tilting
- Injen Intake Problems
- 2nd gen gurus..
- 98 LS400, Transmission Hard Shifting
- Here's a really nice one on BBS LM's!! [pics]
- will this fit a 92 ls400
- 93 LS400, bad radio reception?
- Oh I Miss My LS
- Just got a 1999 LS400
- Steering column issue
- 93 LS400 Overheating at stoplights.
- LS400 Dash warning light legend...
- Vibration - Old Subject But Slightly Different
- LS400 with case of the jimmy's at 60-65 mph
- Stereo questions 1999 LS 400
- YAAAAYYY ac compressor locked up last night... i think
- Are Head Units the same in 1996 and 1997 LS400?
- why are used cars so much cheaper in the UK?
- Photoshoot of my VIP-style (in progess) 91 LS400
- one last question. I promise....on catalytic converter for the 92LS400..
- 1999. Squeaky sound when going over bumps
- 1998 LS400 Instrument Panel Lights and Gauges are Dead
- For anyone needing a harness
- 98 LS 400 Timing Belt Question
- 93 Pioneer Stero Dead
- SC300/400 or LS400 (or something else) for a second car?
- Radio Install ????
- Water pump replacement - 94 LS400
- 96 LS400, "TRC OFF" Light flashing
- brake light fail warn light
- 92 LS400 Problem
- Newbie-seeking ways to update 1st Gen interior
- Bilstein, Tokico, or KYB
- NEED HELP!! CAR IS RUNNINg badly
- 1ls Bfi?
- Car has had synthetic oil its whole life, can I...
- keep it or lose it
- LS400 for old farts only?
- Number of cap and rotors
- Are double din kits available for the 1st Gen...
- Reached the end of the road with my vibration
- New shock time, what to buy?
- Another Lexus Key question. Frustrated.
- Should I replace Shocks and Springs at the same time?
- What kinda deck do you have?
- 94 LS 400 questions
- 98 Tems ?
- Help On 95 LS..
- need some help.
- Can a pro identify and tell me what this engine part is
- How much did you pay for your exhaust?
- I need bushings.......today.
- Does anyone has or know of a link that contains info on the 93 LS
- About to buy a 93 Ls with 99k what to look for?
- Radiator for LS400 '91
- car starts (w/ jump) but NOTHIN else works
- Where to drill 4 holes to install reverse sensors?
- My driver window not working
- In an effort to improve gas mileage...
- General Charging Problem - Alt? Regulator?
- what wiring harness do i have? HEEEELLLLLLLLLLLPPPPPPP!
- Needed some opinions!
- qustion about cd changer, driver seat
- 1990 LS400 question - Curb Hopped
- question on 92 ls400 keys
- question on my 92 ls400 keys
- Key does not open trunk lock
- Replacing ABS System Controller - Estimated Labor?
- Brake pad light is on, pads are good..
- Strange RPM dipping around 40-50
- Consumer Reports comes out with 10 best reliable cars...
- Polo Edition?
- Just did the muffler delete mod...
- 1995 LS400 Bulb Information
- Keeping a car (Lexus LS) can save you $31,000....
- Fault Code 43 TRAC light Flashing! AGH!
- Post a movie or TV show that an LS 400 has been in.
- I noticed something with the LS's front wheels.
- Best online lexus parts shop
- When does your gas light come on?
- New Wheel/Tire setup!!
- 93 LS400 w/179k Oil change resulted in a ticking engine.
- 1995 lexus ls 400.Low battery/charge light on
- hiding spots?
