PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. lucked out and got my LS 400...
  2. Help me locate the trans cooler line
  3. Road Trip In A Seville...Thanks Lexus!
  4. A/C issue
  5. 95LS check engine light
  6. anyone know how to disable auto steering wheele adj.
  7. disabling automatic steering wheel adjustment
  8. any of you guys use a monroe strut for your ls?
  9. Is the power source in the center console suppose to be switched power?
  10. is it possible to upgrade a Lexus key?
  11. LS400 stereo help - head unit backlight
  12. Thoughts/review on JIC VIP FLT-A2 coilovers...
  13. can we use 95SC400 transmission for 93LS400?
  14. Front & Rear Polyurethane Swaybar Bushing
  15. Power everything rear seats
  16. o2 sensor
  17. Fitting Optima Red Top In LS400
  18. Knock sensors ?
  19. pulls to the right
  20. please help a rookie
  21. 91 ls 400 vibrating after engine wash
  22. Spits water from AC duct under steering
  23. JIC Magic FLTA2 Coilovers
  24. How do you reset the trouble codes?
  25. Suspension
  26. Headlight Eyebrows?
  27. bursty feeling in acceleration
  28. Steering system
  29. wood dash kit
  30. Pwr streering leak
  31. introduction - LXU55
  32. Thinking about a 95 ls but what should i do .....
  33. '95 LS wandering
  34. Low idle (down to 200rpm) then it quits
  35. Polyurethane Rear Swaybar Bushings for under $20
  36. Water Repellent Windshield
  37. this afternoon I started up my engine and...
  38. Idle speed control valve
  39. Would you trade?
  40. LS400 compressor failures?
  41. Well it has been a while
  42. That's not fair
  43. Another strut bar question
  44. Fastest?
  45. Bra for LS400? Anyone have one?
  46. brakes pulling
  47. Time to do more mods
  48. Camber, A-arm kits UCF 10-31
  49. engine startup
  50. Alternator Weirdness - Expert Help Needed
  51. wheels?
  52. Lowered UCF 10-21 camber
  53. Pedals/ shift knobs
  54. 1993 LS400 factory alarm problem
  55. "cage house" light comes on
  56. 4 o2 sensors 1990-1994
  57. Fellas, educate me.
  58. Outside temp sensor location?
  59. Feeling some suspension vibrations through Steering wheel
  60. Green fluid
  61. Install Complete! for 93 LS400. But Keyless Entry Does No Work!
  62. on the good side, iam getting these tommorrow
  63. I tinted headlights/corner lights on 90 LS
  64. replacement tweeters????
  65. no seat belt tension
  66. Aftermarket Shiftknob for the UCF10/11
  67. key programming
  68. upper control arm?
  69. I keep popping fuses!!?? (97 LS)
  70. Help! driver window stuck open!
  71. Mad Respect from Toronto
  72. suspension problems.90LS
  73. Lemon Law?
  74. 1994 LS 400 brake squeal
  75. 93-94 LS Yellow Foglights?
  76. S Fla. LS's
  77. dome light problems
  78. Rotora Big brake Kit avaliable for 1st gen LS
  79. Would i be crazy to buy with 175,000 miles?
  80. exhaust......
  81. new LS owner at 173,000 miles!
  82. lighter socket problem
  83. Lowenhart LDR's
  84. Driver's seat problem
  85. Fastest you've gone?
  86. ouside temp readout in Celsuis?
  87. RSR Springs
  88. Interior Color Options for 95-96?
  89. Rear swaying?
  90. checking the air suspension?
  91. smoke at start
  92. Is there a separate ECU for Traction Control? Traction Control & ABS use same ECU???
  93. Timing belt?
  94. Is it possible to fit ?
  95. Blower Motor Question
  96. 1995 LS400, Creaking / Groaning
  97. what is the remote switch for that has the window on it
  98. need some help, headlight question for a 96 LS400
  99. Considering an LS430 - need some help
  100. Modify the Climate control
  101. 1st Gen. Shifter
  102. 150+mph?
  103. counsole disassembly w/telephone
  104. Whats the best way to remove my "Alternator".. I have a 91LS400?
  105. Starter ?
  106. Some info on future LS500
  107. Mechanic Says Replace ECU/ECM - HELP!
  108. trans problem ?
  109. Anybody has Pictures of 1st Gen LS with a Spoiler? Post Please
  110. Lowering my '92 LS
  111. Where to buy ?
  112. All Lexus brakes click, Part 3
  113. stull grilles?
  114. Any black LS owners have tinted windows?
  115. URGENT - Engine light when cold - please respond
  116. De-badged grille?
  117. WISE bumper for first gen LS
  118. swapping headlight assemblies
  119. Crystal Clear Headlights for 96 LS400
  120. engine ping
  121. I got my keyless entry working!
  122. Yet another costly repair. Bye bye Lexus?
  123. Finally - pics of my baby!
  124. What could this leak be?
  125. 1st gen clear headlights
  126. Has Anybody seen this in person (air runner suspension)
  127. Aftermarket head unit dash kit available 95-00
  128. erg pipe leaking
  129. Any "performance" mods for the LS?
  130. Center Wood Consel
  131. What makes the 92 SC400 1 second faster than the 92 LS400?? It has the same motor..
  132. My ABS & Trac Light won't go off?? What could be the problem?
  133. 91 LS400 headliner noise
  134. ouch!tires rubbing against rear fenders
  135. Tail lights for a 00 LS400
  136. Kids.........Celsior
  137. 92 ls400 throttle delay
  138. 1st Gen LS with real wood?
  139. trac control pipes ?
  140. 2002 LS430 bent rim
  141. 1992 LS400 TRAC light
  142. windshield wipers
  143. Recently purchased LS400 98
  144. All Lexus brakes click, part 2
  145. A/c - Help
  146. body kit
  147. replacing alternator
  148. which grill to get?
  149. New LS400
  150. 1st Gen LS Owners - Interesting email, help needed
  151. Finally! A pic and an avatar
  152. All Lexus brakes click
  153. Tein CS vs Eibach Springs
  154. Uh Oh!!! I Made A Boo On My Car!!!!
  155. advice on front suspension issue
  156. Quick wheel question
  157. I need help with tune up info
  158. Who make this lip spoiler?
  159. 90K mile service
  160. Should you take to dealer for alignment?
  161. History of the LS/Lexus
  162. Proud new owner of a 99 LS400!!!
  163. ignition problems
  164. Windshield Replacing
  165. Engine Shuts Off
  166. 90-92 stock ls wheels
  167. Scratched Rim
  168. Hi everyone, new owner of '93 LS (pics)
  169. 90-94 LS400 Fuel Injectors/Rail Interchangeable with the 95-97LS400?
  170. cheap performance?
  171. 1995 vs 1998 LS: Which would you choose?
  172. "Overdrive Light" blinking!!??
  173. Loud power steering pump
  174. 92 LS400 Clear tail instructions
  175. For the UCF20/21
  176. Heater Controls 94' LS
  177. abs pump failure signals ?
  178. forgot that i took this
  179. Transmission problem?
  180. Tailights redone
  181. Euro clear bumper lenses for 95-97 (Mother thread)
  182. Do LS400s and LS430s have any rattles/squeeks?
  183. 95-97 grilles
  184. A confession
  185. Newbie Questions
  186. A Thanks to all.
  187. help, does this price seem right ?
  188. Brake senor....
  189. Is it hard to connect Traction Control to a car without it?
  190. Beeping Lock Confirmation(1st gen)
  191. Red Clear tail lights
  192. The Fat look
  193. underbody panels
  194. wheel lightening
  195. For those who want performance + luxury
  196. Help! STUCK IN THE MIDDLE OF BUSHING INSTALLATION.
  197. Cool grille mods?
  198. Struts and springs installed
  199. Vent motor problem
  200. Interior Foot Lights
  201. 100k tune-up suggestions needed
  202. E-celsior.com
  203. folding mirrors if anyone cares
  204. will this work
  205. Selling 93 LS400 - This a Good Price?
  206. Kenwood DDX7015 in 93 LS400!
  207. 97 LS400 Master key and remote questions
  208. Rear valence mod for muffler tips
  209. Japanese front bumper??
  210. Will is300’s 17’’ fit my 90 LS400?
  211. Brake Questions
  212. power steering too loose
  213. Power steering dead!
  214. Bigger rims?
  215. Stiff Steering
  216. Jump Start the Tach and Speed Needle
  217. Purchased a 2000 LS400!! (a few pics inside)
  218. Break Wear Warning
  219. 96 LS Radio Display Bad
  220. Share my GOOD expenience
  221. Share my GOOD experience
  222. Hello all! looking to buy a 90-95 Lexus LS400
  223. Motor Mounts
  224. Taking of Exhaust Heat Sheilds ok?
  225. beefing up a 95 LS suspension
  226. A/F Exe photo shoot...........
  227. 93-94 LS400 vs. 94-95 Legend GS Sedan
  228. What do you think about the Bridgestone's Praxis suspension
  229. How to change 93 LS disc brakes?
  230. Auto change up points ?
  231. Car shakes real bad, Check Engine,Trac,ABS Lights On..Help Please.
  232. EGR malfunction
  233. cleaning MAF sensor
  234. Windscreen trim on Mk1
  235. 98 400 Mods.
  236. Interchangeable rear armrest
  237. Above the LS
  238. I crashed my baby! =[
  239. Gauge cluster flashes when brakes are pressed
  240. Airbag, horn and cruise control all don't work - do I need a new clock spring?
  241. Dashboard flickers, 93 LS
  242. my car is a gross polluter
  243. Noises from the brakes
  244. Door Lock
  245. Read this article - Consumer Reports - US vs European cars
  246. How well does the first gen LS AC work with R134a?
  247. Help!
  248. 92 LS400 Side Skirt
  249. I finally sat in an Infiniti Q45 to compare it with the Lexus LS
  250. New tune-up tutorial, take a look
